New receiver options - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By jdsmoothie
  • 1 Post By jdsmoothie
post #1 of 6 Old 09-17-2016, 11:32 AM - Thread Starter
Scott Stice's Avatar
Quoted: 127 Post(s)
Liked: 131
I am looking into getting a new receiver my current receiver is starting to go I believe. I currently have a Yamaha RX-A700 it is a 7.2 receiver and has been great. I don't have a 4k TV yet but will be getting one soon. Is there anything specific I should be looking for in a new receiver I believe I want it to be HDMI 2.2 compliant for 4K. Debating between Yamaha, Denon, Marantz. Any and all suggestions are appreciated!
Scott Stice is offline
post #2 of 6 Old 09-17-2016, 11:52 AM
jdsmoothie's Avatar
Quoted: 22173 Post(s)
Liked: 12041
Depending on your budget, you may want to consider the following:
Denon X2300W
Marantz SR5011
Yamaha A850
Madmax67 and Scott Stice like this.
jdsmoothie is offline
post #3 of 6 Old 09-17-2016, 01:14 PM - Thread Starter
Quoted: 127 Post(s)
Liked: 131
I'm looking to stay around the $800-$1000 range.
post #4 of 6 Old 09-17-2016, 01:17 PM - Thread Starter
Quoted: 127 Post(s)
Liked: 131
I see the Denon X4200W is going for $799 and the Denon X2300W is $799 as well any big differences between the two?
post #5 of 6 Old 09-17-2016, 02:45 PM
jdsmoothie's Avatar
Liked: 12041
The X4200W is a much higher level model (original MSRP - $1499) and would be the better choice if you don't want to be able to "tweak" the Audyssey EQ curve which will only be possible with the newer 2016 models.
Scott Stice likes this.
post #6 of 6 Old 09-17-2016, 04:06 PM - Thread Starter
Quoted: 127 Post(s)
Liked: 131
Ok good to know thanks jdsmoothie!
