Audio problem driving me crazy - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #31 of 33 Old 10-13-2018, 07:28 PM
douggie's Avatar
Thanks for your reply Brigitte. While this is extremely disappointing (my very first Arcam amp and also the very first amp that needed to be repaired twice in less than 20 months of ownership), it's good to hear they have finally found the correct root cause and fixed the problem.
I suspect by this time, it is a known issue for them (although the service representative denies it). It really seems like a batch or design issue since the issues are highly similar/repeatable across the many a29 amps posted here.
douggie is offline
post #32 of 33 Old 11-05-2018, 03:26 AM
Liked: 0
Hi everyone,
Does anybody knows where to find Firmware for A29? I need firmware to program new 64f3664FPV chip (picture attached)?
Thank you in advance
Vladimir Derenskyi is offline
post #33 of 33 Old 04-22-2019, 04:42 AM
dopefishzzz's Avatar
Any updates ?
Any updates on this issue ?
I'm having the same troubles with mine,
I'm good with electronics though so if i knew which component to replace i could do it myself.
dopefishzzz is offline
arcam a29 , htpc , problem , sound
