Anyone Using AC Infinity to Cool their AVR? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #61 of 210 Old 02-27-2018, 11:14 AM
rocky1's Avatar
Quoted: 450 Post(s)
Liked: 124
Not sure if this is correct. I have the temp setting at 91. the probe temp reaches 90 but stays there. when the fans do come on its at the max of 3 when I notice it. maybe I'm noticing too late? never seen the fan at 1or 2.could I have my settings wrong so should I change the temp setting higher?.or does it matter
Sony XBR65A1E,(Pioneer 500m relocated), AppleTv 4K,Marantz sr7012, System Audio Loudspeakers( sa1750 mains), ML Grotto.
Eastern Electric Minimax cd, Oppo UDP-203, Toshiba HD, Pro Ject 1expression Carbon TT.
rocky1 is online now
post #62 of 210 Old 02-27-2018, 11:46 AM
Quoted: 487 Post(s)
Liked: 259
update RTFM!
Originally Posted by dmb12679 View Post
The T8 is dimmable, I would assume the S8 would be. I can dim my 8 and 10 all the way to black/off.
nope. I wish they would have mentioned that. I didn't feel the T-8 was necessary., for that feature alone, it would have been worth the extra $20.
Update, When all else fails RTFM!!!!. so, I went back and reread the manual and lo and behold: the s8 also has a way to dim the panel LED!
dmb12679 likes this.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #63 of 210 Old 02-28-2018, 05:50 AM
dmb12679's Avatar
Quoted: 596 Post(s)
Liked: 297
I think auto mode will spin them full speed, smart mode uses a progressive 1,2,3 fan as needed
Marantz SR6010 -- Marantz MM7025 -- Marantz UD5007
Klipsch RF-7ii's - RC-64ii - RB-51ii's - RS-42ii's - R-112sw(x2)
HK990 -- HD990 -- Klipsch RF-7ii's
dmb12679 is online now
post #64 of 210 Old 02-28-2018, 06:01 AM
rocky1's Avatar
Quoted: 450 Post(s)
Liked: 124
thanks.thats what I ended up doing putting it in smart mode.Wierd though that in auto temp would stay at 90 but smart mode temp would be 86-87. Never hear fan in smart mode either since fan doesn't even get to 3(max) as it does in auto.
post #65 of 210 Old 02-28-2018, 06:45 AM
Dave-T's Avatar
Quoted: 1156 Post(s)
Liked: 551
After reading through this thread I think I may the turn on feature set to low on all 3 T8's. I have a T8 on my marantz 8802a, Rotel RMB-1575 and Rotel RMB-1585. I have the turn on temp at 80F on all three units and set to auto. I try and keep the until at 81F, the RMB-1575 which is used for Atmos idles at 77F -78F and turns on for short stints and then turns off. The Rmb-1585 is always on at idle 79F but as soon as I turn my system on the temp goes up to 80F and then depending how loud i have the system it gets up to 82F. The RMB-1585 has the fan set to speed 4 on auto and the RMb 1575 has the fan speed set to 3 on auto. The Marantz 8802a ides at 77F and will go up to 81F depending on how loud i am listening to a movie or tv. My cabinet has no back and mesh black wire on the front doors so air is getting in and out. The shelf in the cabinet looks like swiss cheese because I drilled a bunch of holes in it so air could pass, i also drilled some holes in the bottom of the cabinet so air can get in from the botton as well. So her his my question, Do I have the fans set way to low to turn on? i read somewhere that you do nor want your components to get over 85F or it will shorten the life of the electronics. This info was not on a website that sold fans either, it was an article that Easy did on Audioholics.
Thanks for any help or insight
dave
Dave-T is online now
post #66 of 210 Old 02-28-2018, 07:45 AM
dmb12679's Avatar
Quoted: 596 Post(s)
Liked: 297
Cooler is better, it's up too you. Remember that 90% of people who own AVR's don't have active cooling systems like Tx and most are just fine. Someone posted above that it's fine until your unit can boil water
Honestly I think mine are set pretty low at 90. Next we'll have a coolant system that cools it below room temp I needed them as I needed to stack on top of my avr due to space issues
post #67 of 210 Old 02-28-2018, 09:34 AM
gpzbc's Avatar
Quoted: 43 Post(s)
Liked: 32
I like smart mode because it maintains an even temperature. The only thing I don't like about smart mode is that it constantly turns the fan off and back on to speed 1 for 1 second intervals.
Is there a setting that I have wrong?
Sent from my Pixel XL using Tapatalk
gpzbc is offline
post #68 of 210 Old 03-05-2018, 11:31 AM
noah katz's Avatar
Quoted: 1873 Post(s)
Liked: 660
I'm going to get the S10 or T10; is the latter in any way functionally superior for the extra $20?
Noah
noah katz is online now
post #69 of 210 Old 03-05-2018, 12:32 PM
EdQ
EdQ's Avatar
Quoted: 23 Post(s)
Liked: 68
They work the same. I would prefer the display.
Sent from my Note 8 using Tapatalk
Samsung 75" UHDTV | Marantz 7010 - Heights | Emotiva XPA-7 Gen3 | (2) AIRCOM T8 | HTPC with Blu-Ray
Front - Polk RTi12 | Center - Polk CSi5 | Surrounds - Polk RTi6 | Atmos - Polk S15 | Klipsch R-115SW | 7.2.4
EdQ is offline
post #70 of 210 Old 03-05-2018, 12:48 PM
noah katz's Avatar
Liked: 660
Oh right, it's nice to be able to keep tabs on the temps; I ordered the T10.
Thanks, Ed
EdQ likes this.
Noah
post #71 of 210 Old 03-05-2018, 12:54 PM
Quoted: 1019 Post(s)
Liked: 557
It also depends on where you live, I am thinking of ordering one of the AC Infinity units to replace a little cheap one I got on amazon. I live in Texas and I have no central heat or air. So before we get home the house can be an EASY 85°F+ on any given day, and it takes time for the window unit to cool the room down. So yeah during the summer time I am starting in a bad place to begin with lol even though I run it, my Denon AVR, in ECO mode
liffie420 is offline
post #72 of 210 Old 03-06-2018, 03:00 PM
silver-eye's Avatar
Quoted: 178 Post(s)
Liked: 118
Just bought the T9 for my Denon x2300.
Any idea what should be the temp set for the smart option?
thanks!
silver-eye is offline
post #73 of 210 Old 03-11-2018, 11:35 AM
RobScreene's Avatar
Quoted: 25 Post(s)
Liked: 25
Thinking of getting one of these units to put on top of my Marantz. I'm assuming the fans turn on automatically when needed when they sense a certain temp?
Yes.
I have a T8 on a Marantz SR7011. It matches it perfectly and works well.
RobScreene is online now
post #74 of 210 Old 03-11-2018, 12:35 PM
Quoted: 86 Post(s)
Liked: 38
I just use a laptop cooling pad, works really well.
rxp91 is offline
post #75 of 210 Old 03-11-2018, 07:38 PM
kcgr's Avatar
Quoted: 71 Post(s)
Liked: 76
Due to the shape of my rack (obstruction) above my Denon x4300, I couldn't go with the 17" wide units, as they were too deep. Anyhow, I went with an S7 ~12" wide and 6"+ deep unit. I set it to come on at the lowest fan speed when the temp trigger is hit. The Denon's top vented panel was noticeably toasty before the S7 and now it feels almost at room temp.
I wish I could fit the 17" wide unit, as it looked better, but the S7 does the job just fine. Highly Recommended.
kcgr is offline
post #76 of 210 Old 04-18-2018, 06:06 AM
Quoted: 417 Post(s)
Liked: 46
Looking at these to put on top of my receiver and future amp. My Denon and Marantz tend to get hot in the cabinet even though the cabinet don't have a front.
I cannot see a difference in these looking at their website. Can anyone educate me on these units?
https://www.acinfinity.com/compare/156/154/224
Which is better? rear or front exhaust?
Asgard1an is offline
post #77 of 210 Old 04-18-2018, 06:11 AM
gpzbc's Avatar
Quoted: 43 Post(s)
Liked: 32
It just depends on your setup.
Sent from my Pixel 2 XL using Tapatalk
gpzbc is offline
post #78 of 210 Old 04-18-2018, 06:19 AM
Quoted: 417 Post(s)
Liked: 46
Well the top is pretty tight so I figured if I do either rear or front, it could double as a heater in winter haha. My marantz throws some serious heat
post #79 of 210 Old 04-18-2018, 06:34 AM
gpzbc's Avatar
Quoted: 43 Post(s)
Liked: 32
I chose the rear exhaust because the back of my cabinet is open. Plus I read some reviews that say that the front exhaust sounds slightly noisier because the air is coming out toward you.
gpzbc is offline
post #80 of 210 Old 04-18-2018, 06:54 AM
Quoted: 417 Post(s)
Liked: 46
Good point. Rear exhaust it is. Thanks
post #81 of 210 Old 04-18-2018, 07:12 AM
jdsnov73's Avatar
Quoted: 141 Post(s)
Liked: 46
I needed a front output unit, and wanted the T10 but it had a July estimated instock date. So, I ordered the S10 from Amazon......which worked great, but then a week later the T10 had a few instock on Amazon so I ordered one and paid the $11 to return ship the S10. Probably didn't need to, but I wanted the added capability of the T10 and the digital screen. It is nice to see the actual temperature. Even on the lowest fan speed the T10 keeps my Denon X2400H right at an indicated 80F using the Smart setting.
jdsnov73 is online now
post #82 of 210 Old 04-18-2018, 07:20 AM
Quoted: 417 Post(s)
Liked: 46
Amazon has both the T8 and the T9 (front and rear exhaust) at $99. I will need 2 rear exhaust with digital display.
Do these go on sale sometimes?
post #83 of 210 Old 04-18-2018, 07:39 AM
jdsnov73's Avatar
Quoted: 141 Post(s)
Liked: 46
AC Infinity had a banner on the site here showing 20% off, using code AVS28 I think, but they charge shipping. It was basically the same price via Amazon and I have prime with 2 day shipping so I went through Amazon.
post #84 of 210 Old 04-18-2018, 07:49 AM
Quoted: 417 Post(s)
Liked: 46
Did you see a big difference in heat exchange when using these? ow about the fan noise?
post #85 of 210 Old 04-18-2018, 07:57 AM
jdsnov73's Avatar
Quoted: 141 Post(s)
Liked: 46
Yes, the upper surface of the receiver was hot before and now it is very cool. The entire case is cool now. I can have the T10 in the OFF mode, but the screen is still on and measuring temperature and you can watch the temperature climb, but running the fan set to 4 for it's max speed but it will maintain 80F with the fan at speed setting showing 1 using the SMART setting.
Fan speed 1-4 are probably the max I would want to use as far as noise goes. You can barely hear settings 1 and 2, and 3 and 4 are noticable but still fairly low for me. 5 and 6 are definitely loud, but I doubt you would need that speed unless you forgot to turn on the unit and were trying to cool down quickly.
post #86 of 210 Old 04-18-2018, 10:43 AM
mbroadus's Avatar
Quoted: 1090 Post(s)
Liked: 431
I ordered the T8 today from Amazon for my Anthem MRX-720, thanks for all the great info.! Does the T8 Stay on constantly or is there a way to use the 12V trigger on the back of the AVR?
It should work well with my BDI Ola cabinet.
Panasonic P60VT60 Calibrated by Chad B
Anthem MRX-720, Oppo UDP-205, Bluesound Node 2i, Focal Aria 936/CC900
MacBook Pro, AppleTV 3 & 4K, Sony PS4 Pro
mbroadus is offline
post #87 of 210 Old 04-18-2018, 12:33 PM
brazensol's Avatar
Quoted: 717 Post(s)
Liked: 533
Not directly but I am using their Cloudline T6 pulling air from a 12" x 12" exhaust grill located directly above my equipment shelves. This is also being used, along with another T6 setup on the other side of the room, as a means of pulling warm air out of the theater in general. I'm hoping this will be enough to avoid installing a mini-split system.
brazensol is online now
post #88 of 210 Old 04-18-2018, 12:38 PM
afrogt's Avatar
Quoted: 2098 Post(s)
Liked: 1397
thanks!
Did you find the T9 is too deep for your x2300? The Denon is only 11.5" deep whereas the T9 is 13.5" deep so you have 2 inches hanging over the back of the AVR. Found that out with the S9 and my x2400.
Afro GT
afrogt is offline
post #89 of 210 Old 04-18-2018, 01:04 PM
jdsnov73's Avatar
Quoted: 141 Post(s)
Liked: 46
My T10 feet are partially on the back edge of my Denon X2400H with the front flush. The fans are still effective, even though they aren’t centered on the unit.
post #90 of 210 Old 04-20-2018, 04:42 AM
Quoted: 111 Post(s)
Liked: 99
I have a slightly different perspective. I do not want the fans cycling on and off. I prefer for it to just run on low the whole time the system is running. I bought a cool little gizmo on Amazon that you can plug into any outlet and it turn that outlet into a remote controlled outlet.
It comes with the device you plug into the outlet and the remote. With that, you can plug in the AC Infinity (I have the T8). Any time I turn on the stereo, I use the outlet remote to turn on the fan also.
https://www.amazon.com/Etekcity-Wire...wireless&psc=1
Trell likes this.
ARC Ref 3, Parasound A21, Parasound T3, Marantz SA-15S2, SAE E102 eq, Joseph Audio Pulsar, Rythmik F12
gottajam is offline
aircom , cooling fan
