Anyone Using AC Infinity to Cool their AVR? - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #151 of 216 Old 02-13-2019, 10:31 AM
Vordak's Avatar
I assume the only benefit would be if I left the cabinet doors open, which I don't want to do. And I guess I didn't specify that, the receiver would be behind doors.
Vordak is offline
post #152 of 216 Old 02-13-2019, 10:39 AM
flyinion's Avatar
Quoted: 491 Post(s)
Liked: 333
Wow that sounds like really not a good way to go. No matter what model you get you're going to just be recirculating hot air in there with it being closed up like that.
Sent from my iPhone X using Tapatalk
Pansonic TC-P60VT60 | Denon AVR-X4500H | Sony UBP-X800 | Chane A2.4 L/C/R | Chane A1.4 SR | SVS Elevation Atmos/height | SVS PB-2000 | Logitech Harmony 950 | Arris MX011ANM (Xfinity X1) | Apple TV 4K
flyinion is offline
post #153 of 216 Old 02-13-2019, 11:41 AM
Vordak's Avatar
It's not completely closed as there are decent sized opening on the top. The question, maybe unclear, was more around would the hot air have a better chance escaping through those holes in the cabinet if it was pushed towards the back of the cabinet or the top of the cabinet. Both wouldn't push it directly through holes. And I guess maybe I'll need to add in exhaust fans on the holes them in addition to the AC Infinity, but at that point, I'd just keep the receiver on top of the cabinet.
Vordak is offline
post #154 of 216 Old 02-13-2019, 12:48 PM
flyinion's Avatar
Quoted: 491 Post(s)
Liked: 333
The problem is getting both cool air in and hot air out though. Sounds like doing both will be a problem without some modifications to the cabinet.
flyinion is offline
post #155 of 216 Old 02-14-2019, 06:02 AM
dmb12679's Avatar
Quoted: 596 Post(s)
Liked: 298
AC infinity makes many options like a fan that goes in the side of the cabinet itself for situations like yours. Browse around you will be able to find something made for your situation, or modify your situation to make one their solutions work
Marantz SR6010 -- Marantz MM7025 -- Marantz UD5007
Klipsch RF-7ii's - RC-64ii - RB-51ii's - RS-42ii's - R-112sw(x2)
HK990 -- HD990 -- Klipsch RF-7ii's
dmb12679 is offline
post #156 of 216 Old 02-14-2019, 06:11 AM
jdsmoothie's Avatar
Quoted: 22594 Post(s)
Liked: 12294
And yet, the best option to ensure longer life of the receiver, otherwise, as suggested look for a different external fan solution that better meets your requirements.
jdsmoothie is offline
post #157 of 216 Old 02-15-2019, 06:41 AM
Vordak's Avatar
Thanks all for replies. I have more to think about now. Much appreciated.
Vordak is offline
post #158 of 216 Old 02-28-2019, 12:13 PM
GoZags13's Avatar
Quoted: 174 Post(s)
Liked: 91
Just to add onto what has been mentioned, the airflow in for cold air is just as important as the outflow. I have all my A/V gear in a cabinet that's 36" wide by 12" tall, and let me tell you cooling is a huge challenge. I ended up doing an Airplate S7 and one S5 for inflow, and Airplate T3 and one S5 for outflow, and one S4 inside the cabinet to redirect the xbox exhaust towards a vent. It might sound like overkill, but when I run the xbox at reference volumes I need every bit of it.
I played around quite a bit to get to this configuration. Key takeaway is with gaps around cabinet doors, you want more airflow in than out. Put the outflow as close to the hot spot on the AVR as possible, and the inflow opposite so air flows across it. Ideally you'll also have the door opposite of the inflow as well so leakage is pulling air out versus your inflow simply going back out.
Denon X4300H; Sony XBR75 900E; Definitive Technology RLS-II/DI 5.5LCR/DI 5.5R; NHT SW12
GoZags13 is offline
post #159 of 216 Old 03-02-2019, 06:16 AM
TomGallopavo's Avatar
Quoted: 12 Post(s)
Aircom T8. If I use the smart mode, the fan cycles on and off every few seconds. Is this ok? Or should I leave it on auto that cycles on every 4 degrees but is louder (fan set on 3). Noise is not an issue as we like it fairly loud. Thank you for your opinions.
TomGallopavo is offline
post #160 of 216 Old 03-04-2019, 10:17 AM
dmb12679's Avatar
Quoted: 596 Post(s)
Liked: 298
It's your preference, try both and see which you like best. I personally use smart mode. Both will keep your equipment at your desired temp, just goes about in a different way.
dmb12679 is offline
post #161 of 216 Old 03-05-2019, 07:36 AM
Quoted: 12 Post(s)
I like the smart mode but was concerned the fan cycling on and off would wear it out faster. I also emailed the company and they said it is designed to turn on and off like that.
post #162 of 216 Old 03-05-2019, 07:45 AM
Jonas2's Avatar
Quoted: 2835 Post(s)
Liked: 1806
Yeah, I totally wouldn't worry about it. If there is any additional wear due to on/off cycling, it'd be minimal. Heck the things are less than $100.00 and it'll go for years regardless of what mode you've got it in. Use it the way you want to use it!
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #163 of 216 Old 03-05-2019, 08:02 AM
gpzbc's Avatar
Quoted: 43 Post(s)
Liked: 32
You could also play with the set temperature in smart mode to keep it from cycling on and off so much. I use Smart Mode and eventually found that sweet spot.
Sent from my Pixel 2 XL using Tapatalk
gpzbc is offline
post #164 of 216 Old 03-05-2019, 09:07 AM
Quoted: 12 Post(s)
What did you end up setting it to?
post #165 of 216 Old 03-05-2019, 09:45 AM
gpzbc's Avatar
Quoted: 43 Post(s)
Liked: 32
I would have to look but I believe it is 90. But every airflow situation is different.
Having it set at 90 keeps it in the mid 70s under normal circumstances. Then in the low 80s when I am cranking.
gpzbc is offline
post #166 of 216 Old 03-10-2019, 08:34 AM
dmb12679's Avatar
Quoted: 596 Post(s)
Liked: 298
If you have it set to 90, the fan shouldn't even turn on until about 85, so if your avr is running between 70-80 is the aircom fan ever even kicking on?
dmb12679 is offline
post #167 of 216 Old 03-10-2019, 08:48 AM
gpzbc's Avatar
Quoted: 43 Post(s)
Liked: 32
Yes, it does. The Smart Mode works a little differently. Give it a try.
gpzbc is offline
post #168 of 216 Old 03-10-2019, 09:04 AM
MechEE's Avatar
Quoted: 81 Post(s)
I use an AC Infinity blowing air out of my cabinet and a cut hole at the bottom for intake. I switch it on/off via the Denon 12V remote trigger using a switched AC outlet box so it’s always running while the Denon is on. Works great!
dmb12679 likes this.
MechEE is offline
post #169 of 216 Old 03-10-2019, 09:22 AM
dmb12679's Avatar
Quoted: 596 Post(s)
Liked: 298
Mine must not get as hot as yours or something. I've got it set for 90 in smart mode with max fan speed of 3 and it doesn't start until 86, T10
dmb12679 is offline
post #170 of 216 Old 03-10-2019, 11:33 AM
MrBobb's Avatar
Quoted: 229 Post(s)
Liked: 107
Closed cabinets need cold intake toward the bottom (a good slit between door and cabinet can do the job but can always drill more holes on the bottom-most shelf) and hot exhaust on top (most common top-rear).
MrBobb is offline
post #171 of 216 Old 03-10-2019, 12:13 PM
gpzbc's Avatar
Quoted: 43 Post(s)
Liked: 32
Yea, my setup runs a little hot. It can heat up quickly but Smart Mode manages it well.
gpzbc is offline
post #172 of 216 Old 03-10-2019, 01:37 PM
Jonas2's Avatar
Liked: 1806
But does it run after the Denon shuts down? It should - you're building heat after shutdown. I'd consider plugging it into always live power so that it can run until it drops/maintains the temp. to the happy level to which you have it set. Probably not a big deal, but.....
That sounds about right - 86 for speed 1, 88 for speed 2, 90 for speed 3 if you're in 2-dgree increments....yeah?
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #173 of 216 Old 03-10-2019, 02:00 PM
MechEE's Avatar
Quoted: 81 Post(s)
It turns off right when the AVR turns off, which is the trade-off. But it keeps the AVR cooler throughout the entire viewing (it doesn’t wait until its already hot before it turns on, unlike the “smart” controller systems), and I am less concerned about the AC Infinity fan being off once the AVR is no longer dissipating power (off), and I’ve usually had the system running for a bit without high audio output after viewing and prior to shutting it down anyway.
And to be clear: once the AVR is turned off, I’m no longer “building heat” as the power electronics are no longer receiving / dissipating any more power. The core power consuming amplifiers can only drop in temperature at that point, not increase (unless something even hotter than them is bringing some additional thermal energy over!). Neighboring cooler components may rise in temp a bit (heated by the amps that are slowly cooling).
MechEE is offline
post #174 of 216 Old 03-10-2019, 07:11 PM
Jonas2's Avatar
Liked: 1806
Sorry, I should have said it differently - you're not making new heat - the components are still radiating and not cooling as quickly as they would if they still had the air moving over them - and are still quite warm to hot and will remain so a lot longer than otherwise. Wouldn't worry too much about neighboring components.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #175 of 216 Old 03-11-2019, 06:02 AM
Mactavish's Avatar
Quoted: 143 Post(s)
Liked: 141
What is the switched AC outlet you have that can be 12v triggered? I’d like to do the same. Thanks
Mactavish is offline
post #176 of 216 Old 03-11-2019, 08:24 AM
MechEE's Avatar
Quoted: 81 Post(s)
I used this: https://dlidirect.com/products/iot-power-relay
You also need a mono 3.5mm jack cable with the wires exposed on one end to attach to the green terminal block of the relay.
Mactavish likes this.
MechEE is offline
post #177 of 216 Old 03-11-2019, 08:41 AM
Ricoflashback's Avatar
Quoted: 1796 Post(s)
Liked: 1272
I run the AC Infinity fans (two) with the thermostat set at 89 degrees. I do not have my AVR or any other component in an enclosed rack - - which really requires some forethought on how you are cooling everything in it. The fans run after my AVR has been turned off and that takes care of any built up (radiating) heat. My first set of fans only lasted two years - - so I just bought new ones. They are not that expensive and work like a charm.
Home Theater Setup
SONY 75X900F & 49X900E, BenQ W1080ST, Denon X5200 & Emotiva XPA-3
AudioSource 100VS, OPPO 103 & Samsung K8500, 9.1.4 Setup - Speakers - Studio 60's,
V.2 (FL/FR), CC-690 (C), V.5, ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub,
Cornered Audio (FH/RH), Definitive Technology (Front Wides)
Ricoflashback is offline
post #178 of 216 Old 03-11-2019, 04:04 PM
Kevin. W's Avatar
Quoted: 238 Post(s)
Liked: 107
I have one for my Denon X8500H. Set to Auto and 85oC. When systems of the unit will run till temperature comes down.
LG OLED65B7P.
Denon X8500H
OPPO 203 4K
Paradigm Prestige 95F, 55C, 25S and Prestige 1000SW.
Kevin. W is offline
post #179 of 216 Old 03-16-2019, 04:45 PM
Mactavish's Avatar
Quoted: 143 Post(s)
Liked: 141
Thanks again, installed today, works great with my Denon 3500. If anyone gets one of these and you don’t have the 3.5mm mono plug, here is one with cable for $7. I cut the female end off, the white and colored internal cables are both POSITIVE/TIP, the tiny clear one is Negative/sleeve.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
gpzbc likes this.
post #180 of 216 Old 03-16-2019, 07:11 PM
indebtbassfreak's Avatar
Quoted: 1448 Post(s)
Liked: 2778
Is there a general consensus on what the optimal operating temperature is in our avr's? Just like a thermostat in our vehicles. If we over cool our avr's running "0"MV for example,,,, is there a drawback or risk to our equipment not operating at its intended temperature? Is running to cool as bad as too hot? The other day i ran thirty+ minutes at "0" MV with potent tunes and never went beyond 96 degrees with my AC set at 90.
Sorry if this has been addressed,,, if so i will delete.
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
aircom , cooling fan
