Marantz 7010 seems to have more than 7011 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #31 of 43 Old 10-20-2016, 01:15 PM
jdsmoothie's Avatar
Quoted: 22860 Post(s)
Liked: 12497
Originally Posted by Madmax67 View Post
Yep, free basic HEOS speaker. It's mentioned below the retail price for the receiver.
https://www.amazon.com/Marantz-SR701.../dp/B01LPP7ZT2
Correct. The current HEOS promotion applies to the (4) 2016 Denon and Marantz models with the built-in HEOS module (ie. Denon X4300H/X6300H and Marantz SR7011/AV7703).
Madmax67 likes this.
jdsmoothie is offline
post #32 of 43 Old 10-20-2016, 08:50 PM
Quoted: 190 Post(s)
It would be interesting to see what you finally decided...
Sent from my XT1562 using Tapatalk
HT 5.2.4 - Marantz SR6011 -> Elac B6.2 + Elac C5.2 + Elac B6 (surround) + JBL Control 1 (TM) + JBL B15 (RH) + Two SVS PB1000
Samsung Bluray Player
murlidher is offline
post #33 of 43 Old 10-21-2016, 02:09 PM - Thread Starter
landonsdad's Avatar
Quoted: 289 Post(s)
I called Marantz and found out the 7011 does have a slightly better DAC and dual band width (?) wireless (5.0), so I went with the 7011.
LG OLED65E6P Marantz 7011 ML Motion 50XT Center ML Motion 4's rear
landonsdad is offline
post #34 of 43 Old 10-21-2016, 02:38 PM
afrogt's Avatar
Quoted: 2222 Post(s)
Liked: 1464
Yes, 2.4Ghz and 5Ghz wireless.
Afro GT
afrogt is offline
post #35 of 43 Old 10-22-2016, 08:17 AM
jdsmoothie's Avatar
Liked: 12497
Not that I am aware of no ... rather it uses the exact same DAC.
post #36 of 43 Old 11-13-2016, 11:12 PM
EdQ
EdQ's Avatar
Quoted: 23 Post(s)
Liked: 68
Thanks for this thread. I was deciding on the same thing. I don't need HEOS, so getting $1000 off the 7010 made sense.
jrg6771 likes this.
Samsung 75" UHDTV | Marantz 7010 - Heights | Emotiva XPA-7 Gen3 | (2) AIRCOM T8 | HTPC with Blu-Ray
Front - Polk RTi12 | Center - Polk CSi5 | Surrounds - Polk RTi6 | Atmos - Polk S15 | Klipsch R-115SW | 7.2.4
EdQ is offline
post #37 of 43 Old 11-16-2016, 12:09 PM
bwilberg266's Avatar
Quoted: 33 Post(s)
Liked: 55
Originally Posted by Orijen View Post
I walked into my local retailer and asked to see the 6011 (I was not ready to spend $2100 on a 7010) The salesperson pointed to the rack at the 7010 for $1195 and that the new model 7011 was on the way is the reasoning for it's 1/2 off price...
Needless to say it's now all hooked up and I'm happy with it! Amazing difference in sound from a Pioneer 7.1!
Which Pioneer are you coming from? I am considering going to the 7010 from my trusty Pioneer SC-37. I am very happy with the sound, but want to make the move to Atmos (already have the speakers in the ceiling) and the SC-37 is just a lowly 7.1 receiver.
Epson 8350 | Silver Ticket 100" 16:9 Fixed Screen | Marantz 6011 | Emotiva XPA-5 | Elan z660 x 2 | Energy RC-LCR x 3 FL/C/FR | Monoprice Alpha 8" In Wall SLB/SRB | Monoprice Alpha 8" In Ceiling SL/SR |Monoprice Caliber 6.5" x 4 In Ceiling Atmos | PSA S3000i | SVS PB12 Ultra | Apple TV | miniDSP | Samsung K8500 | Synology DS213j Media Server
bwilberg266 is offline
post #38 of 43 Old 11-16-2016, 01:14 PM
Orijen's Avatar
Quoted: 83 Post(s)
Liked: 65
Still have it, my Pioneer VSX-9130TXH.. Paid $200 for it in 2009 NIB. Thing is a TANK! I might use it for a 5.1 in my computer room...
Love the 7010! Especially for the price!
Orijen is offline
post #39 of 43 Old 11-17-2016, 06:15 PM - Thread Starter
landonsdad's Avatar
Quoted: 289 Post(s)
Speaking of tanks, my 7011 is much lighter than my Denon 3808. Have they created a way to make them better and lighter, or does this mean they aren't made like they used to be?
Denon 38.25 pounds.
Marantz 30.4 pounds
The Marantz is about 20% lighter.
post #40 of 43 Old 11-17-2016, 10:17 PM
adrummingdude's Avatar
Quoted: 1104 Post(s)
Liked: 771
About the mic. I have a friend, in a band, who says he uses a $1000 mic. Could I use this in calibrating?
Not likely. Your friend's mic is most likely a large diaphragm condensor of some sort, and is almost certainly marketed as a vocal mic. Mics, like speakers, are never ruler flat. Vocal mics also typically have a lift in the 15khz range whereas measurement mics may not. More importantly, your friend's mic probably has a cardioid or hyper cardioid pickup pattern, and the mics that come with AVR's are omnis.
Programs like audyssey account for the characteristics of a specific mic they are designed to be used with.
Besides, not knowing what your friends mic actually is (LDC's run off of phantom power, electrets are battery powered, dynamics aren't powered), I would be wary of plugging a $1000 mic into a mystery port on a consumer AVR. Wouldn't want to damage it.
HT: KEF Reference 1 - Anthem AVM60 & MCA525 - Martin Logan Focus - DefTech XTR-20BP - Dual SVS SB16 Ultra
Office 2CH: KEF LS50 - Crown - Bluesound
Stage: Allen & Heath Dlive s5000 - Westone AMPRO 30 - AKG mics - Crown Amps
WAF is currently at DEFCON ORANGE
adrummingdude is offline
post #41 of 43 Old 01-18-2017, 09:22 AM
saevox's Avatar
1. The SR7010 can use the Audyssey Pro Kit ($700USD) while the SR7010 will be able to use the new Audyssey app ($20USD) when released later this year with similar Audyssey EQ curve editing functionality.
2. Audyssey DSX simulates audio to Front Wide speakers which is no longer supported on any 2016 major brand AVR to include the SR7011.
3. Both models are DLNA capable (in fact most AVR models for the past few years are Wifi capable).
4. Both models can use the newer 2016 Marantz Remote app.
5. Front Wide speakers dropped on the SR7011 so no longer need 13 pre-outs, rather only 11.
HEOS provides powered Wifi/Bluetooth audio to other rooms either via the HEOS app or via the HEOS module built-in to the SR7011. Current HEOS promotion features a FREE HEOS 1 HS2 (MSRP $199) or $200 credit towards a larger HEOS 3/5/7.
If you have no need for either HEOS or the Audyssey app, the SR7010 would be the more cost effective purchase as it's on clearance.
https://www.amazon.com/Marantz-SR701.../dp/B014MWT9YY
@jdsmoothie you mentioned the sr7010 will be able to use the new audyessy app. Was that a typo or is the 7010 and 7011 both supported?
Also is the app out? I can not seem to find it.
Sent from my SM-G930P using Tapatalk
saevox is offline
post #42 of 43 Old 01-18-2017, 10:17 AM
jdsmoothie's Avatar
Liked: 12497
Oops! Yup ... typo, sorry.
Only the 2016 models (ie. SR7011) will be able the use the new Audyssey app which has not yet been released.
post #43 of 43 Old 12-09-2017, 04:17 AM
Quoted: 23 Post(s)
Liked: 2
You can see their comparison here: https://www.zkelectronics.com/compar...SR7010/U.S.A./
zukaka is offline
