Has anyone tried the ATI AT54XNC Class D amps? - AVS Forum | Home Theater Discussions And Reviews
 238Likes
post #1 of 643 Old 11-06-2016, 06:18 AM - Thread Starter
boe
boe's Avatar
Quoted: 1206 Post(s)
Liked: 545
Hello,
Due to the heat my amps generate, I was considering trying some Class D Amps. My current amps are 300 @ 8 ohms. I was considering the AT54XNC amps but can't find a single review of them.
boe is offline
post #2 of 643 Old 11-06-2016, 12:19 PM
M Code's Avatar
Quoted: 1079 Post(s)
Liked: 683
Great amplifiers, the Hypex N-core modules are incredible..
Just my $0.02...
blazar and bkdc like this.
M Code is offline
post #3 of 643 Old 11-06-2016, 12:32 PM
audiofan1's Avatar
Quoted: 2275 Post(s)
Liked: 2775
https://www.avsforum.com/forum/86-ult...hread-549.html
rhale64L7 seems to be the first with one and compared it to Theta Dreadnought , seems to be a great sounding amp! maybe he can shed some light on your query
post #10965
boe likes this.
audiofan1 is online now
post #4 of 643 Old 11-06-2016, 04:22 PM - Thread Starter
boe
boe's Avatar
Liked: 545
Thanks - you have an impressive knowledge of all posts on AVS! I just read his review. It gives me hope. I've contacted ATI to see if they have any sort of audition program. If I like them I'll probably give up my Anthems I love their sound but like all AB amps they run warm and so do I so I'd appreciate something cooler.
audiofan1 likes this.
boe is offline
post #5 of 643 Old 11-06-2016, 06:24 PM
A9X-308's Avatar
Quoted: 1792 Post(s)
Liked: 1483
Originally Posted by boe View Post
Hello,
Just my $0.02...
Assuming M is correct and they are NCore Hypex, they should be extremely good. Bruno Putzey who designed the modules is a very talented engineer.
There is a recent DIY build here which shows how well they measure and provides a bit more info on them; not exactly what you wanted but you might find it interesting, and even worth copying if you're at all handy and would like to save some $. You should check out the author's HT of the Month as well.
A9X-308 is offline
post #6 of 643 Old 11-06-2016, 07:59 PM - Thread Starter
boe
boe's Avatar
Liked: 545
Thanks. I'll check it out. Yipes - $1K per unit - I have 9 channels I'm wondering what the 200hz spike means.
krholmberg likes this.
boe is offline
post #7 of 643 Old 11-06-2016, 10:05 PM
GIEGAR's Avatar
Quoted: 977 Post(s)
Liked: 1669
Well, you could save a notional $2K straight away by abandoning the worthless passive bi-amping of your mains. Contrary to popular mythology, this will make no net electrical difference and hence make no actual difference the sound.
That's the 200Hz Sine wave test signal being fed to the amp.
Just cruising likes this.
GIEGAR is offline
post #8 of 643 Old 11-07-2016, 05:04 AM - Thread Starter
boe
boe's Avatar
Liked: 545
Thanks - why the big jump at that point and no other? Is that some point where it can't go beyond?
boe is offline
post #9 of 643 Old 11-07-2016, 06:57 AM
GIEGAR's Avatar
Quoted: 977 Post(s)
Liked: 1669
It's an RTA graph of a 200Hz (@ -29.6dBFS) fundamental input to the amp. It produces a few small harmonics (numbered), but these quickly sink to the noise floor of the amp (@ >-140dBFS). I'm no expert, but these look like an exceptionally quiet amp module.
GIEGAR is offline
post #10 of 643 Old 12-13-2016, 05:42 AM
madhuski's Avatar
Quoted: 1244 Post(s)
Liked: 791
Any other ATI n-core users out there?
I'm debating wether to go with this or a the Sunfire class H amp.
Both similar price & weight etc - I'm assuming my ears wont be able to tell the differrence between the two.
madhuski is online now
post #11 of 643 Old 12-13-2016, 10:27 AM
clydetheglide79124's Avatar
Liked: 4
Sunfire is a Class G amplifier (Tracking Downconverter - ie continuously variable rail voltage, unlike Class H which has a fixed number of different rail voltages - most Class H's have 2 different rail voltages, but some have 3 different rail voltages) that uses a Class AB output stage (Toshiba Bipolar Output transistors in push-pull configuration).
If you have a few hours, you can go to wikipedia and read and study, in depth, the various power amplifier designs and Classes. It is a very good read.
And no, I am not an electrical engineer. But I did stay at a Holiday Inn last night.
Lynkage and steven59 like this.
clydetheglide79124 is offline
post #12 of 643 Old 12-13-2016, 11:38 AM
DonH50's Avatar
Quoted: 3100 Post(s)
Liked: 3037
Uh, Class G switches the rails, Class H uses a continuously variable supply, at least when I took the class and designed the amp...
bigguyca likes this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #13 of 643 Old 12-13-2016, 12:16 PM
madhuski's Avatar
Liked: 791
That aside - are there any advantages of one over the other when comparing the Sunfire to the ATI?
post #14 of 643 Old 12-13-2016, 03:24 PM
Liked: 4
I exchanged a couple of emails with Jeff Hipps of ATI maybe 6 months ago concerning the new ATI Class D Hypex Module based amplifiers. He told me to read the Stereophile review of the nearly identical amplifier - Theta Digital Prometheus monoblock power amplifier http://www.stereophile.com/content/t...CDeRmYrJebl.97
I have never been a fan of Ice-Power amps or any other Class D amps. I am a Class AB guy. However, Jeff assured me these new ATI Hypex Module based amps are every bit as good as a traditional Class AB amp that I have always loved, and always owned (including a couple different ATI amps and Outlaw Audio amps). I must say the Stereophile review is a glowing review from a reviewer who, just like me, traditionally has NOT liked Class D amplifiers.
post #15 of 643 Old 12-13-2016, 03:56 PM
Kal Rubinson's Avatar
Quoted: 1193 Post(s)
Liked: 1034
Just finished a review of the ATI AT543. Should be in the March issue.
Sam S likes this.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #16 of 643 Old 12-13-2016, 04:03 PM
Liked: 4
Kal, thank you very very much!! I have been wanting to read some reviews of the new ATI Hypex Module based amps for awhile now. I have an extremely strong feeling these new ATI Class D amps are going to test very very similarly to the Theta Digital amp Stereophile reviewed in 2015 that I referenced earlier.
Anyways, thank you Kal!! Also, how in God's name have you been able to amass 29,400 posts here on avsforum.com ?? I am guessing you must have been a member here since the Civil War.
post #17 of 643 Old 12-13-2016, 04:59 PM
Liked: 1034
It will be in my column, MITR, because multichannel is not generally featured in the stand-alone reviews. I also covered the Theta Dreadnaught D a little while back.
Dunno. Guess that makes me old.
Kal Rubinson
post #18 of 643 Old 12-13-2016, 06:44 PM
DonH50's Avatar
Liked: 3037
Originally Posted by Kal Rubinson View Post
Dunno. Guess that makes me xxx prolific.
Fixed the typo...
DonH50 is offline
post #19 of 643 Old 12-13-2016, 06:53 PM
Milt99's Avatar
Quoted: 470 Post(s)
Liked: 469
Kal, what is the issue number of your Theta review?
I looked through my online versions and didn't see it.
I admit I'm lazy.
It ain't ignorance causes so much trouble; it's folks knowing so much that ain't so
Milt99 is online now
post #20 of 643 Old 12-13-2016, 07:01 PM
Liked: 1034
I admit I'm lazy.
Google says http://www.stereophile.com/content/m...88BeDhU4z6L.97
and http://www.stereophile.com/content/m...ThYDPemw9CK.97
Kal Rubinson
post #21 of 643 Old 12-13-2016, 10:48 PM
Quoted: 404 Post(s)
Liked: 293
I'm curious how these compare to the NAD M22/M27. The nCore noise floor just seems so appealing to me. Only other amp I've be considering would be the Benchmark AHB-2, but I'm not sure how I feel about the lack of SE inputs.
Are there any other quality nCore amps in the same price range?
amnesia0287 is offline
post #22 of 643 Old 12-14-2016, 06:25 AM
madhuski's Avatar
Liked: 791
Can you give us a one sentence preview?
post #23 of 643 Old 12-14-2016, 06:27 AM
Milt99's Avatar
Quoted: 470 Post(s)
Liked: 469
I forgot I'd already read it.
post #24 of 643 Old 12-14-2016, 06:55 AM
Liked: 1034
Nope.
Kal Rubinson
post #25 of 643 Old 12-14-2016, 07:22 AM
madhuski's Avatar
Liked: 791
Nope.
Rats- well, order placed!
post #26 of 643 Old 12-14-2016, 08:54 AM
Liked: 4
madhuski, it is good to hear you placed an order with ATI for one of their new Class D output amplifiers. Which model of ATI amp did you purchase, may I ask? The 200 Watts per channel (8 ohms) or 500 watts per channel (8 ohms) model? Please let us know what you think of the amp when you receive it. Thank you madhuski !!
post #27 of 643 Old 12-14-2016, 09:12 AM
madhuski's Avatar
Liked: 791
I want with the 200w model (AT527NC I think)
Looks like they have to make it, so shipping sometime next week
clydetheglide79124 likes this.
post #28 of 643 Old 12-15-2016, 06:51 PM
Milt99's Avatar
Quoted: 470 Post(s)
Liked: 469
Obviously, you're not at all familiar with Mr. Rubinson.
post #29 of 643 Old 12-15-2016, 07:33 PM
Liked: 1034
I don't deny that I enjoy the baiting but the real issue is that I am not permitted to release any comments from a review prior to publication. Ask me something objective.
Dave Vaughn and madhuski like this.
Kal Rubinson
post #30 of 643 Old 12-16-2016, 06:34 AM
Milt99's Avatar
Quoted: 470 Post(s)
Liked: 469
I'm aware of both points, Kal.
Objective?
I always assumed we read your column for the subjective content & JA did the objective portion, measurements.
I'll give it a shot.
How did the ATI measure vs the Dreadnaught?
