Seeking advice on upgrade? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #31 of 34 Old 12-18-2016, 03:41 PM
matticus008's Avatar
Quoted: 55 Post(s)
Liked: 66
Originally Posted by synccoil View Post
right ( HDPC ) that why outside of bandwith limitations S/PDIF cant pass modern lossless multi channel protected audio content or we might well ditch the HDMI cables use CAT 5/6 wire or instead 8- 24 ga copper wire zip cords or a bundle of telco wire pairs that may have the bandwidth or no ?
No.
matticus008 is offline
post #32 of 34 Old 12-18-2016, 04:41 PM
synccoil's Avatar
Quoted: 437 Post(s)
Liked: 163
Originally Posted by matticus008 View Post
No.
care to provide a reference that contradicts my Wikiopinion reference that says S/PDIF doesen't support lossless multi Chanel protected audio formats or no ?
If not I will go with what I posted for now.
bandwidth wise at let us say 6-12 ft we could just bundle up Telco POTS wire pairs to the appropriate data pin-outs like maybe Audio Quest,Kimber Cable or Monster Cable with exotic metal wires for the fools ..... but not thats the point here .
cheers
synccoil is offline
post #33 of 34 Old 12-18-2016, 08:54 PM
Quoted: 55 Post(s)
Liked: 66
You're missing the point. Neither S/PDIF nor HDMI ARC support multichannel audio above DD 5.1 or DTS 6.1.
Neither allows for 7.1 audio. Neither carries TrueHD or HD Master. HDMI ARC is literally S/PDIF implemented over HDMI. They carry the same audio formats at the same bitrates and have the same bandwidth limitations. Start here if you're still confused.
HDCP version compatibility of devices is 100% irrelevant to HDMI ARC, because none of the compatible formats implements HDCP in the first place.
post #34 of 34 Old 12-19-2016, 02:42 AM
synccoil's Avatar
Quoted: 437 Post(s)
Liked: 163
synccoil
Be that as it may (and I belive it is it is ),Thanks Now I finally get it
I think I was conflating one of the HDMI standards and audio formats with HDMI ARC WRONG !
had a small bird for dinner >>>>the small crow are more tender !
synccoil is offline
