Goodbye separates hello which AVR? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-18-2016, 01:39 PM - Thread Starter
mpauline's Avatar
Quoted: 86 Post(s)
Liked: 24
Selling off my pre/pro and a multichannel amp to free up some money to purchase some preowned B&W 803D3's
I would like the ability to add a 4K projector in the next two years when they come down in price and possibly put in ATMOS ceiling speakers. I currently have a Marantz 7702mkii and run seven channels, two subs, and two height.
Looking for suggestions on a good quality AVR. It will not need to power the front soundstage as I have a three channel Krell for that. I am not biased towards any particular brand of AVR just something that is decent build quality. Honestly with my 50 year old ears I probably don't need to buy the most expensive model.
mpauline is offline
post #2 of 4 Old 12-18-2016, 03:53 PM
zorax2's Avatar
Quoted: 296 Post(s)
Liked: 333
You're not going to hear a difference in sound quality in direct mode on any new mid-range or higher AVR (https://www.avsforum.com/forum/90-rec...listening.html). It will come down to the feature set you require and your preferred sound correction system.
The Denon 4300 is a really good value and will run the 9 channels you have. It has 11 channel processing so you can use your Krell amp and you can add 2 more speakers in the future if you desire. I use a Denon 4200 as a pre/pro with ATI amps and I (nor others) couldn't hear a difference between it and the $4,000 Marantz 8802 in direct mode meaning they'll also sound the same after Audyssey assuming they use the same microphone (the Audyssey mics have had some variances in them). I had a 7703 (sold it), 8802 (returned it) and will likely get a 4300 to upgrade from my 4200 as I need 11 channel processing for 7.2.4. I found out there was no need to spend the extra money for the 7703 and 8802 - the 4200 sounded identical.
I think you'll also appreciate the upcoming Audyssey app which will allow you to tailor Audyssey.
7.2.4 with Denon X4300W, ATI 2005 & 1807 Amps, Kef Reference 203 Mains, 202c Ctr, 201 Surr, Ci200RR-THX Top Rears, Q300 Frt Hts, E301 Rear Surr, Power Sound Audio PSA dual S3600i Subs,
GIK & DIY Acoustics, JVC X790/RS540 Projector, Stewart Neve 100" Screen, Panasonic Blu-Ray DMP-UB900, Xbox One X, Crowson Transducers, INSTEON, UDI ISY994i, Amazon Echo
zorax2 is offline
post #3 of 4 Old 12-18-2016, 04:42 PM
Mashie Saldana's Avatar
Quoted: 1252 Post(s)
Liked: 1090
Look for a Marantz SR7010, they are extremely good value now since they are the 2015 model.
Mashie Saldana is online now
post #4 of 4 Old 12-18-2016, 07:30 PM
Quoted: 411 Post(s)
Liked: 294
Considering what the 7702mk2 is selling for new, will you really be saving much money doing this? Maybe just swap to a cheaper amp if the current one is that expensive?
amnesia0287 is offline
