Denon AVR X330W Audyssey hanging - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-14-2017, 12:26 PM - Thread Starter
RamHemiTX's Avatar
Quoted: 16 Post(s)
Anybody else have this problem? I added a new CC and went through the calibration again. I've been staring at this for 20 minutes. Anyone else have this issue yet?
RamHemiTX is offline
post #2 of 11 Old 01-14-2017, 04:29 PM - Thread Starter
RamHemiTX's Avatar
Quoted: 16 Post(s)
I've updated the firmware now but still having the same issue.
post #3 of 11 Old 01-14-2017, 07:14 PM
Is this still on, with the button "Next" disabled, even after you unplug the microphone, as instructed?
You do unplug it, right?
viorel is offline
post #4 of 11 Old 01-14-2017, 07:56 PM
afrogt's Avatar
Quoted: 2507 Post(s)
Liked: 1641
do a processor reset and see what happens.
Afro GT
afrogt is offline
post #5 of 11 Old 01-15-2017, 06:42 AM
jdsmoothie's Avatar
Quoted: 24612 Post(s)
Liked: 13842
Analyzing data should take no more than a minute or two. If the mic has been disconnected as directed, then reset the microprocessor (post 5 of the 2016 Denon AVR Owner's thread).
https://www.avsforum.com/forum/90-rec...l#post43790578
jdsmoothie is offline
post #6 of 11 Old 01-16-2017, 05:03 AM - Thread Starter
RamHemiTX's Avatar
Quoted: 16 Post(s)
Guys, I appreciate the responses. The reset was something I remembered from my 2112 but could not remember the procedure. I did however try something different.
I discovered that the problem seems to have been mic placement. I was moving the mic too far between seating positions inadvertently. I went through setup and made sure I stayed within 2 feet of the original position (like the instructions say) and it worked fine. If I go through setup again and have the positions too far apart it freezes.
post #7 of 11 Old 03-20-2017, 09:54 AM
fuhkinay's Avatar
Quoted: 34 Post(s)
Liked: 25
Interesting. I had the same problem this past weekend with my new X3300W. It froze at 70%. I tried at least 5 times. I also did a firmware update. No luck. I have an RMA with Crutchfield, but they are out of stock for another 3 weeks. Maybe I will give it another try with the mic positions closer together. The receiver seems to work fine now that I unplugged it for ten minutes, but I have to skip the Audyssey setup. I did have weird jagged lines when I powered it off after it froze at 70% and then powered it back on. Unplugging it seemed to fix that.
fuhkinay is offline
post #8 of 11 Old 04-01-2017, 03:26 PM
fuhkinay's Avatar
Quoted: 34 Post(s)
Liked: 25
Got my replacement unit a few weeks early. Set it up yesterday and all is well. Not sure if the new unit fixed it or the fact that I paid very close attention to mic placement. I used a tape measure to make sure I was within 2 feet.
fuhkinay is offline
post #9 of 11 Old 04-02-2017, 09:06 AM
jasonsong's Avatar
Quoted: 494 Post(s)
Liked: 185
That is pretty weird. Sounds like the measurements it took just messed up the software.
jasonsong is offline
post #10 of 11 Old 02-07-2020, 02:01 PM
Liked: 0
Hi guys same problem with my x3500h
How i can solve? I thought that i solved with the last update but i recently update my config and again same problem.
Finnedgang is offline
post #11 of 11 Old 06-03-2020, 02:42 AM
Moderator
rboster's Avatar
Quoted: 1840 Post(s)
Liked: 2786
Please take all questions to the thread linked below
https://www.avsforum.com/forum/90-re...rt-ii-842.html
FS: RUIPRO 8K Fiber DisplayPort Cable 33 feet : https://www.avsforum.com/forum/211-a...d-support.html
rboster is online now
Closed Thread Receivers, Amps, and Processors
