Lyngdorf MP-50 | 12 Channel AV Processor; 9.1.6 with matrixed Wides and Top Middles - Page 106 - AVS Forum | Home Theater Discussions And Reviews
 1278Likes
post #3151 of 3167 Old 01-14-2020, 06:31 PM
Liked: 5
Originally Posted by Fredstwofeet View Post
Thank you very much for these settings. They sound fantastic. Update went without a hitch and so far no issues.
You're welcome. I like the sound of the curves too!
randomrunner is offline
post #3152 of 3167 Old 01-14-2020, 07:07 PM
Quoted: 13 Post(s)
Liked: 2
I should have said phantom center
Anyway, I updated to 3.6.6 and it works now!
I told it my setup is 9.1.4 but on Auro 3D it shows audio as 5.1.4.
On 3.6.6 MP-50 too.
I always listen to 48khz Dolby DD 5.1 with either DSU or Neural:X post processing.
My speaker setup is 7.1.4.
It used to show me 7.1.4 Dolby Surround or 7.1.4 Neural:X
Now it's always Dolby Surround
Do you think Lyngdorf implemented the Dolby restrictions on upmixers with this new FW?
ref.: https://www.audioholics.com/audio-te...upmixing-atmos
7.2.4 setup using: Lyngdorf MP-50, 2 Anthem MCA525, 2 Goldenear Triton One, Goldenear SuperCenter XXL, 2 MartinLogan Motion 15, 6 MartinLogan FX, Sony XBR65X900F
Avsaddiction is offline
post #3153 of 3167 Old 01-14-2020, 07:59 PM
Quoted: 874 Post(s)
Liked: 736
3.6.6 fixed the ATV4k center issues for me as well. Nice quick turnaround, I wonder how much of the software they do in-house.
I guess you have to fix issues quickly when you also sell systems for $200k. The Emotiva support plan doesn't work in that price bracket
Really like the Voicing file editing and the rest of the small changes. Nice to get the MP-60 software updates for this old model as well.
Lyngdorf MP-50 | Yamaha MX-A5200 | Ascend Sierra Towers | Ascend Sierra Horizon | Ascend Sierra Lunas | Ascend HTM-200SE | SVS SB-13 x4
duckymomo is offline
post #3154 of 3167 Old 01-15-2020, 06:48 AM
Quoted: 400 Post(s)
Liked: 112
Originally Posted by Marc Alexander View Post
Guys, I am having no audible issues with 3.6.3 here. This may have something to do with the fact that I performed a factory reset after updating to 3.6.1.
Reverting to 3.0.9 is the probably the best option for most... unless you don't mind reinitializing RoomPerfect.
Ultimately, I do believe it is worth updating for the new functionality. Here are the new homescreen tone and level adjustment controls.
Marc-
How did you access that screen?
daimler2015 is offline
post #3155 of 3167 Old 01-15-2020, 08:56 AM
Marc Alexander's Avatar
Quoted: 5868 Post(s)
Liked: 5432
Originally Posted by daimler2015 View Post
Marc-
It's part of the home screen (I cropped the jpg…. sorry). Just scroll down, it's below the volume/inputs/post-processing/voicing/etc. but above the media player. As of 3.6.1 of course.
daimler2015 likes this.
Marc Alexander is online now
post #3156 of 3167 Old 01-15-2020, 12:41 PM
Whoracle's Avatar
Quoted: 25 Post(s)
Even though there has been two new software lately, I've still got problems with the distorted vocal and non working web-interface Only me or what?
Whoracle is offline
post #3157 of 3167 Old 01-15-2020, 12:51 PM
noah katz's Avatar
Quoted: 2258 Post(s)
Liked: 829
Do you have 3.6.6?
Regardless, here's release info posted elsewhere:
Originally Posted by joerod View Post
Yes l, this was fast! Long weekend...
You know the drill:
3.6.6 Release Notes:
- Fixed missing Center channel on PCM multi-channel soundtracks.
- Fixed possible crash at system boot-up.
- RoomPerfect Focus position names are now correctly stored.
- Web page and front Info display would indicate 9.1.4 when decoding 9.1.6.
Send me a PM with your email and I will shoot it to you.
If I have sent you then before then just send me an email and I will reply with it.
“joerod, is having +trims normal with RoomPerfect on the MX-160? To this extent? It is not normal on the MP-50 IME. The numbers do “not jive with at all with my expectations based on the speaker sensitivities.”
Yes, the “+ Trims” is normal now. It’s the new way that Lyngdorf is trying to display the relative differences.
They tried to explain it in their Release Notes, even though it doesn’t specifically say “+” or “-“.
They were just trying to reassure people that the change they see is OK.
https://lyngdorf.com/downloads/lyngd...p-60-software/
MP50/60: Note regarding RoomPerfect gains in installer menu – “Channel gain” page:
/The RoomPerfect levels you see on the gains page, have been normalized in recent Software. That means the channel that plays the loudest is displayed as 0dB.
//So the absolute number is not important, what you can see from them, is the difference between the channels. And if LFE is 0dB, that means it's the one we've measured to be the highest. If he looks at the differences between the channels, they should be the same as with old SW.
I have a message into “support” for you. First question though is which hdmi cable are you using? Second, in the menu (set up) for the 170 do you have HDR enabled? Make sure your hdmi out matches your main out in the set up GUI. Let’s see if getting an image solves Atmos.
Noah
noah katz is offline
post #3158 of 3167 Old 01-15-2020, 01:03 PM
Whoracle's Avatar
Quoted: 25 Post(s)
Do you have 3.6.6?
Yup tried both 3.6.1 and 3.6.6, had to revert back to 3.0.9
RapalloAV likes this.
Whoracle is offline
post #3159 of 3167 Old 01-15-2020, 02:12 PM
Joey_'s Avatar
Quoted: 61 Post(s)
Liked: 2
strange! it works for me at least.
Joey_ is offline
post #3160 of 3167 Old 01-15-2020, 02:58 PM
Liked: 5432
Did you try a factory-default while on 3.6.x?
post #3161 of 3167 Old 01-15-2020, 03:50 PM
Whoracle's Avatar
Quoted: 25 Post(s)
yeah I have tried factory resetting both before and after the update, makes no difference for me.
Whoracle is offline
post #3162 of 3167 Old 01-15-2020, 05:39 PM
Liked: 5432
I forgot to mention rebuilding your config from scratch after the default. Uploading the old config could be contributing.
Have you contacted [email protected] ?
post #3163 of 3167 Old 01-16-2020, 04:05 AM
Whoracle's Avatar
Quoted: 25 Post(s)
Tried the web-interface directly after the factory reset with no old config loaded. I have a dialog with Lyngdorf about this.
Whoracle is offline
post #3164 of 3167 Old 01-18-2020, 09:30 AM
Quoted: 13 Post(s)
Liked: 2
Just wanted to let you know you are not alone.
I also tried 3.6.6 and I'm loosing center channel (or is very attenuated) when upmixing Dolby 5.1 to Auro-3D with an Auro 10.1 speaker setup (height fronts and surrounds + top).
No problems with 3.0.9.
I suppose these versions are betas?
post #3165 of 3167 Old Yesterday, 08:57 AM
Whoracle's Avatar
Quoted: 25 Post(s)
That is "good" to hear I guess, that means it's possible to get the problems fixed sooner. Have you reported this to Lyngdorf?
Whoracle is offline
post #3166 of 3167 Old Yesterday, 09:29 AM
Quoted: 13 Post(s)
Liked: 2
No, I have not. I have lost faith in them.
Here is my take on the MP-50, after 1 year of usage:
I regret having bought the unit for nearly thirteen thousand canadian dollars, thinking that I would have a unit that would vastly outperform my Anthem MRX1120 that is nearly a third of the price.
The MP-50 performs very well but I thought that it would be nearly flawless with the software.
It is not. I had all kinds of behavior over the year, trying different speaker/post-processor configurations. Contacted support (through my dealer and directly) with unsatisfactory responses.
And then these latest software update, that bring problems so serious that we have to revert back to prior version to keep what we had.
I know many will say they have no problems. I say good for them. For that price, I wanted better software and support.
To quote someone else regarding the MP-50, it is indeed a "black box full of assurance".
Regards
post #3167 of 3167 Old Yesterday, 07:51 PM
Liked: 5432
I'm sorry you haven't been satisfied. I don't remember dealing with any MP-50 issies in 2019. What issues have you had with 3.0.9 (11/08/2018)? It seems to have been rock solid.
While I don't find the Lyngdorf SSPs to be worth their list prices, street prices here in the US have been relatively reasonable.
lyngdorf , mp-50 , owner's , processor , surround
