Lyngdorf MP-50 | 12 Channel AV Processor; 9.1.6 with matrixed Wides and Top Middles - Page 51 - AVS Forum | Home Theater Discussions And Reviews
 1241Likes
post #1501 of 3018 Old 10-29-2017, 11:32 AM
Marc Alexander's Avatar
Quoted: 5560 Post(s)
Liked: 5159
Originally Posted by arisholm View Post
After looking at those graphs: Not an option to move the subs to different locations? These significant variations indicate that placement is quite "sub-optimal" regardless of time/phase alignment issues:-)
@duckymomo I have to agree. Which corners are the subs placed in? Are the other corners available? Did you try catacorner placement?
Originally Posted by ARROW-AV View Post
Perhaps add a MiniDSP into the mix?
Originally Posted by duckymomo View Post
I already do, but I wanted to simplify things and it seems like waste to not be able to use AUX 1-4 for LFE subs. Most people buying this processor will also use it for movies, where Left/Right/Front/Back subs is extremely unlikely to give you better performance (especially at multiple pos)then time aligning and then EQing as one LF channel.
I should have added that the MP-50s bass management solution with 2-4 subs using the aux outputs greatest advantage is when using x-overs above 80Hz. I've found that even though my surrounds and heights are rated down to 75Hz they start bottoming out at close to reference levels with 80Hz crossover. I am using 125Hz crossovers now.
The Unbroken scene from the 2015 Atmos demo-disc is a good demo of directional bass with the MP-50s stereo bass management.
I agree that with a standard 80Hz crossover, there is not much benefit over just using the LFE out and a MiniDSP or similar.
Marc Alexander is offline
post #1502 of 3018 Old 10-29-2017, 11:45 AM
artur9's Avatar
Quoted: 1014 Post(s)
Liked: 395
Originally Posted by Marc Alexander View Post
No, when I try to add a front or rear sub it automatically adds Left and Right. There is no way to configure one front and one rear. I believe this will be remedied by Lyngdorf in a future software release.
Do the subs have to be identical for this to work and sound well?
artur9 is offline
post #1503 of 3018 Old 10-29-2017, 11:54 AM
Quoted: 860 Post(s)
Liked: 716
Opposing front and back corners. I can assure you that many tens of hours were spent placing and measuring 100s of different combinations.
I'm still confused I guess why there's a problem when the end result is what matters and it's +/- 3dB from 18-115hz. I could easily add more filters and make it +/- 1dB, but I don't see or hear the need.
Marc Alexander likes this.
Lyngdorf MP-50 | Yamaha MX-A5200 | Ascend Sierra Towers | Ascend Sierra Horizon | Ascend Sierra Lunas | Ascend HTM-200SE | SVS SB-13 x4
duckymomo is offline
post #1504 of 3018 Old 10-29-2017, 12:28 PM
Liked: 5159
My bad, I didn't click "see more" so I didn't see the second WITH EQ graph. It looks great! Nevermind.
post #1505 of 3018 Old 10-29-2017, 12:28 PM
Liked: 5159
In general, yes.
post #1506 of 3018 Old 10-29-2017, 03:55 PM
Liked: 5159
Thanks for the clarification. Though I also read that some people think that Auro2D should support the rear surrounds ;-)
I think that would be a nice option at least for stereo music processing.
But I definitely lack a clear understanding of how the different post-processing options are intended to be used (on what source material, and for what speaker configs). Can anyone recommend a good overview/intro read on this (the MP-50 user manual is not exactly useful in this regard:-)
The D+M & Yamaha manuals do a good job summarizing all of the different processing modes. I recommend the CX-A5100, X6400H, and AV7704 manuals.
@Nalleh clarified how the D+M processors behave in regards to Auro and rear surrounds. (I was incorrect)
Originally Posted by Nalleh View Post
With D&M models up to 2017 there are only two ways to get sound from rear surrounds:
1. In Auro 3D mode, using only 2 heights(ie front heights), or 7.1.2.
2. Using Auro 2D mode which disables all height, or 7.1.
PS: in native Auro, ONLY on 13.1 tracks.
In which case am I right that with respect to Auro-2D being fed a stereo or 5.1 audio signal that audio should be emanating from the back surrounds?
Correct. At least on D&M.
And as i said you could get up to 7.1.2 from stereo(Auro 3D), which is many music enthusiasts favourite setting.
I wonder what happens with the MP-50 if configured for 7.1.2? I am not at home so I can't test it out at the moment.
arisholm likes this.
post #1507 of 3018 Old 10-29-2017, 04:25 PM
noah katz's Avatar
Quoted: 2137 Post(s)
Liked: 774
TMK, only Harman does true "SFM" which generally requires 4 sub locations.
I believe that's the case even using"SFM" loosely to mean any attempt to smooth the combined response of two or more subs by varying their relative levels and/or delays.
Have you read the bass management section of the MP-50 manual? The manual is a bit incomplete IMO but bass management is covered in-depth. My recollection is that single front & rear subs should be supported. This is one of the things I am discussing with Lyngdorf.
I just read the BM section, and don't see anything about single front or rear subs, just what you said about assuming a L/R pair - "The front and rear subwoofers in the speaker setup provide a way to add more than a single sub to the system."
Trinnov Optimizer is a step up from RoomPerfect IMO and can implement MSO parameters.
It is in the sense that it can use its PEQ to apply MSO parameters, but AFAIK it also doesn't do any relative level/delay adjustments between multiple subs to smooth their combined response.
You might find this interesting if you haven't already seen it:
https://www.avsforum.com/forum/113-su...l#post55023438
Noah
noah katz is online now
post #1508 of 3018 Old 10-29-2017, 04:38 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1959 Post(s)
Liked: 2370
I was told at CEDIA that the SDP-75 is not available for purchase outside of a full JBL Synthesis system utilizing their design and installation services. I would be happy to be wrong, but I haven't seen anyone in the forum who owns the SDP-75P purchased outside those parameters.
That doesn't seem to be true. I've got Revel Salon 2 x 6 + a Voice 2 and a pair of ATI 6007 amps and have been offered pricing to purchase a SDP-75 without any additional strings attached. The kit containing the calibration microphone is also available for end users to purchase so I could do my own calibration. If I paid them to install and calibrate the system, it would be considered a JBL Synthesis system, even without using their amps. If I did my own calibration, it wouldn't be considered an official Synthesis system. This has been discussed a fair amount in the relevant threads over the last several months. Ultimately, I just don't want to spend in the ballpark of $20K for a pre-pro as the depreciation is just too steep. I'm much more willing to spend money on speakers and amps.
The MP-50 and McIntosh MX-160 sibling are choices I'm pondering, but I'm not sure I want to spend that much on a pre-pro either, especially when they don't have full 18Gbps 4K support and the upgrade path remains an unknown quantity. For now, I'm hoping my Denon AVP-A1HDCI lasts until I make a decision.
gsr is online now
post #1509 of 3018 Old 10-29-2017, 05:26 PM
Quoted: 860 Post(s)
Liked: 716
Great!
What's your thoughts on the EQing the subs before RP question? I think I've read something about Lyngdorf not recommending it because it changes the power response of the room.
post #1510 of 3018 Old 10-29-2017, 05:29 PM
noah katz's Avatar
Liked: 774
Seems like that's a good thing if it makes it smoother.
Noah
post #1511 of 3018 Old 10-29-2017, 06:31 PM
Quoted: 860 Post(s)
Liked: 716
Yea, that's how I feel based on the published research, my love for data, and my brain. But Lyngdorf's approach is different and I'm trying to keep an open mind.
post #1512 of 3018 Old 10-29-2017, 08:57 PM
sdurani's Avatar
Quoted: 7354 Post(s)
Liked: 6414
Yup, only Harman does SFM because they patented it. SFM can work with 2 or 3 subs.
Sanjay
sdurani is offline
post #1513 of 3018 Old 10-29-2017, 09:02 PM
sdurani's Avatar
Liked: 6414
Keep in mind that SFM makes no attempt to smooth the combined response of multiple subs. Instead, it simply tries to maximize seat to seat consistency. The response might look like crap, but it is the same crap in every seat. Making the response smooth happens in the next step: equalization (made easier by the fact that you have the same peaks & dips in every seat, courtesy of SFM).
Sanjay
sdurani is offline
post #1514 of 3018 Old 10-29-2017, 09:07 PM
noah katz's Avatar
Liked: 774
Right you are; I should have said, vary relative amplitude and phase to reduce spatial variation from modal effects.
Noah
post #1515 of 3018 Old 10-29-2017, 09:18 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 659 Post(s)
Liked: 611
For now........;-)
RUR is offline
post #1516 of 3018 Old 10-29-2017, 09:42 PM
sdurani's Avatar
Liked: 6414
Originally Posted by RUR View Post
For now........;-)
Hey quickdraw, I'd teed that up for Stuart.
Sanjay
sdurani is offline
post #1517 of 3018 Old 10-30-2017, 04:05 AM
We're Nuts About AV
ARROW-AV's Avatar
Quoted: 4117 Post(s)
Liked: 6655
Love it!
ARROW-AV is offline
post #1518 of 3018 Old 10-30-2017, 05:46 AM
madhuski's Avatar
Quoted: 1390 Post(s)
Liked: 884
If anyone is interested, I translated the NEC1 IR codes into HEX (for those of us with URC remotes...)
Spoiler!
HTPCat likes this.
Selling in AVS classifieds
FS: McIntosh MX-160 Processor
madhuski is online now
post #1519 of 3018 Old 10-30-2017, 11:25 AM
sdrucker's Avatar
Quoted: 1677 Post(s)
Liked: 1352
Bang...but I am looking forward to the future of multi-sub optimization, whatever it will be...Here’s to subwoofer crap consistency...
Marc Alexander and sdurani like this.
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Speakers: PSB Imagine T3 LCR, Imagine T Wides/Side Surround 1, T2 Side Surrounds, Imagine XB rears, Image B6 screens, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 13.4.6
HAA HT1 and HT2 Certification
sdrucker is offline
post #1520 of 3018 Old 10-30-2017, 11:38 AM
sdurani's Avatar
Liked: 6414
Any algorithm that can make the peaks & dips the same in every seat gives every equalizer a big head start.
Sanjay
sdurani is offline
post #1521 of 3018 Old 10-30-2017, 11:46 AM
sdrucker's Avatar
Liked: 1352
Arrow
Especially true once you get outside of a single MLP optimization (or even a single row of three seats) and consider a multi-row setting.
sdrucker is offline
post #1522 of 3018 Old 10-30-2017, 01:10 PM
the7mcs's Avatar
Quoted: 490 Post(s)
Liked: 220
Anyone here wants to follow that rule of do good unto your neighbors and buy one of these for me as a christmas present? ;-)
the7mcs is online now
post #1523 of 3018 Old 10-30-2017, 06:14 PM
Liked: 5159
I don't think there is any reason to use SFM loosely. I should not have done so.
You are right, auxiliary subs are meant to be added in stereo pairs.
Little is known regarding RoomPerfect's sub calibration algorithms. I haven't had the time to attempt to analyze/reverse-engineer it yet.
post #1524 of 3018 Old 10-30-2017, 06:50 PM
Liked: 5159
In my limited understanding of the Trinnov Optimizer and the JBL/Revel anechoic data I would find it hard to resist the Altitude16 at a minimum in your case.
RoomPerfect is attempting to achieve the same goals but is doesn't have the luxury of anechoic data or pre-room-correction EQ. It can only determine a speaker's in-room power response via measurements.
http://lyngdorf.com/news-what-is-room-correction/
http://www.mariobon.com/Glossario/__...oomPerfect.pdf
I attended the Dirac presentation/training at CEDIA 2017 and they are also now preaching about the preservation of speakers' power response. Also in-room with Dirac.
I went with the MP-50 for several reasons. I felt it offered the best music SQ short of a Theta Casablanca. I decided prioritize SQ over features: Audyssey XT-32 is just not good enough for critical music listening (it's good enough for movies IMO). The app has been dissapointing (I have a Denon X4300H which is very similar in SQ to the Marantz AV7702mkII the Lyngdorf replaced) The Trinnov A16 is still twice what I was prepared to spend. A fully functional Emotiva RMC-1 was too far away (given Emotiva's history). I also prefer Lyngdorf's implementation of Focus positions and voicings to the Dirac solutions.
If you want the most out of your Revels, I feel like anything other than Trinnov is a compromise. If the Trinnov solutions are too expensive, RoomPerfect or Dirac are the next best options.
OzHDHT and acidjazz1 like this.
post #1525 of 3018 Old 10-30-2017, 07:02 PM
Liked: 5159
Great!
I would lean towards not EQing before RP (time-align only). You could then A/B using RP bypass to compare RP's result to your manual EQ (REW and most importantly your ears). You could save your result then test with your EQ engaged prior to running RP. These are things I want to test but haven't had the time.
Originally Posted by logdog333 View Post
Does everybody really happy with the bass you get from LFE channel sub? 18" sub owners especialy?
Are you still seeing sub-optimal LFE response via RoomPerfect? Your post got lost a bit in the dts excitement. But, I vaguely remembered it and doubled back.
post #1526 of 3018 Old 10-30-2017, 07:15 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 2370
Yeah, I hear you. If I were to decide to go with Trinnov I would probably opt to spend the extra for the JBL version as there are some extra features that would be worthwhile given that I have the Revel speakers. It just kills me to spend so much on a pre-pro knowing how little it would be worth in just a few years.
The Emotiva RMC-1 seems like a really good budget option, but we’ll see what and when they deliver.
gsr is online now
post #1527 of 3018 Old 11-01-2017, 08:12 PM
Liked: 5159
I am about to dig into the new firmware and put DTS:X, Neural X, and Neo X through the paces!
I thought I would let everyone know that the Mytek ADC96 works very well with the MP-50 (I'm connecting via AES/EBU). I purchased it because of several positive testimonials specifically with Vinyl.
I was surprised to read this reviewer giving the ADC96 (Mytek's entry level ADC) the nod over even the Benchmark ADC-1!
https://mytekdigital.com/download_li...ers_(ADCs).pdf
The MP-50 w/external ADC makes for an SSP that is equal to or better than the McIntosh MX160 for a few grand less.
post #1528 of 3018 Old 11-01-2017, 08:32 PM
RapalloAV's Avatar
Quoted: 2228 Post(s)
Liked: 773
Marc have you not played round with DTS-X Neural X yet?
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild, plus new LED ceiling install Christmas 2018
RapalloAV is online now
post #1529 of 3018 Old 11-03-2017, 07:00 AM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6655
Hi everyone,
I have an update regarding the issues with respect to the latest firmware update 3.0.0
Good news and bad news.
Bad news first... Further to the malfunctioning DTS Neural:X and Auro-2D, the playback/decoding functionality of the native encoded DTS:X is unfortunately also malfunctioning.
Specifics as per follows:
(1) SURROUNDS encoded DTS:X audio plays back / emanates out of both the SURROUNDS speakers and the FRONT L/R speakers
(2) FRONT HEIGHTS/TOPS encoded DTS:X audio plays back / emanates out of both the FRONT HEIGHTS/TOPS and the FRONT L/R speakers
(3) REAR HEIGHTS/TOPS encoded DTS:X audio plays back / emanates out of both the REAR HEIGHTS/TOPS and the BACK SURROUNDS speakers
I have filed an additional report with Lyngdorf regarding this.
The good news is that they are on the case regards resolving all of these issues; wherein, it would appear that these issues are not in fact their fault, but the blame resides with Analogue Devices who it would appear have right royally screwed up updating the respective chipset regards adding the DTS:X, Neural:X and Auro-2D functionality, where all three are malfunctioning! Good job Analogue Devices! Brilliant!
However, please be reassured by the fact that Lyngdorf took action immediately following receipt of my report and they are already making headway regarding fixing the various issues.
I will be sure to post updates on here as soon as I receive them.
ARROW-AV is offline
post #1530 of 3018 Old 11-03-2017, 08:47 AM
Nalleh's Avatar
Quoted: 2651 Post(s)
Liked: 3640
Hi everyone,
Did you try both «height» and «top» setups? Because it is a well known fact that DTS:X is encoded in a 7.1.4 setup with heights, not tops. And if you have a setup with tops, they will bleed down to the ear level speakers to try to phantom to where the heights would be.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 12xJBL 12" w/6xSLAPS M12 downfiring VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is online now
lyngdorf , mp-50 , owner's , processor , surround
