Pre out receiver ? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By zorax2
  • 1 Post By yanks1
  • 1 Post By bigguyca
post #1 of 8 Old 02-17-2017, 05:31 AM - Thread Starter
mig7979's Avatar
Quoted: 21 Post(s)
Liked: 8
Pre out receiver ?
Hello guys hope everyone is having a fabulous friday, so i bought a denon x2300w to realize it doesn't have pre out so i'm thinking of returning the item because i will like to have that option. So the question is do i have to return it to get one with that option or is there a way around it if i want to add an amp in the near future.
mig7979 is offline
post #2 of 8 Old 02-17-2017, 05:51 AM
zorax2's Avatar
Quoted: 302 Post(s)
Liked: 348
You'll need to return it. The Denon X3300 will give you preouts and a better version of Audyssey (XT32) as well.
eljaycanuck and mig7979 like this.
7.2.4 with Denon X4300W, ATI 2005 & 1807 Amps, Kef Reference 203 Mains, 202c Ctr, 201 Surr, Ci200RR-THX Top Rears, Q300 Frt Hts, E301 Rear Surr, Power Sound Audio PSA dual S3600i Subs,
GIK & DIY Acoustics, JVC X790/RS540 Projector, Stewart Neve 100" Screen, Panasonic Blu-Ray DMP-UB900, Xbox One X, Crowson Transducers, INSTEON, UDI ISY994i, Amazon Echo
zorax2 is offline
post #3 of 8 Old 02-17-2017, 05:58 AM
Quoted: 1043 Post(s)
Liked: 843
yep, return
mig7979 likes this.
yanks1 is offline
post #4 of 8 Old 02-17-2017, 06:37 AM - Thread Starter
mig7979's Avatar
Quoted: 21 Post(s)
Liked: 8
Yeah that's what I'm thinking
mig7979 is offline
post #5 of 8 Old 02-17-2017, 11:38 AM
jdsmoothie's Avatar
Quoted: 22923 Post(s)
Liked: 12542
The Denon X3300W is the lowest model with any main zone pre-outs, while on the Marantz side, the slim-line models NR1506/1607 both have FL/FR pre-outs while the SR5011 is the lowest model with a full set of 7.2 pre-outs.
jdsmoothie is offline
post #6 of 8 Old 02-17-2017, 12:11 PM
bigguyca's Avatar
Quoted: 1195 Post(s)
Liked: 997
If you are interested in Yamaha then Costco.com has a unit with pre outs for less than $500.
https://www.costco.com/Yamaha-TSR-78...100308760.html
mig7979 likes this.
bigguyca is offline
post #7 of 8 Old 02-18-2017, 12:06 AM
Quoted: 153 Post(s)
Liked: 69
If you don't care for full 7.2channel preouts and only listen to music in 2channel stereo. Just use zone 2 preouts, set the volume control on it to variable, connect external amp to zone 2 L/R preouts, done. The only thing is zone 2 preouts don't have any bass/treble or bass management controls. Also, the sound quality is not as clean as main zone for some reason. I am currently using zone 2 preouts from my denon avr x1100w to feed a pair of KRK rokit8 G3 studio monitor speakers. Zone 2 on these lower end units don't support digital audio signals from HDMI, coaxial, or optical. The only audio that's supported are analog, network streaming, and USB.
I suggest returning the avr x2300 and getting the avr x3300. The avr x3300 has full 7.2channel preouts and also the better audyssey xt32 I believe.
Word of advice, Yamaha receivers have very weak preout Vrms output. I've tested several units and the zone 2 preouts on all of them produce stronger signal output than the main 7.2 preouts. Yamahas usually clip/unit shuts-off right after reaching 2Vrms, while most denons/marantz/pioneer units I've tested can do much better. Higher Vrms means stronger audio signal going into your external amplifier to fully drive/max out the amplifier's potential. Having more Vrms headroom is a good thing, just like having more wattage headroom is a good thing. When you need it, it's there.
nbp_civic is offline
post #8 of 8 Old 02-18-2017, 05:13 AM - Thread Starter
mig7979's Avatar
Quoted: 21 Post(s)
Liked: 8
Thanks for the info I'm looking n the process of returning so I can get the right one
mig7979 is offline
