Owner's thread for the Sony STR-DN1080 AVR - Page 72 - AVS Forum | Home Theater Discussions And Reviews
 2206Likes
post #2131 of 2729 Old 11-03-2018, 02:58 PM
Liked: 0
Hi there, I just set up my first home theater system and the installation went as smooth as can be expected. I am facing an issue however when my Optoma UHD60 is sometimes responding to my DN1080 remote control. For instance, sometimes when I press the right arrow button on the Sony remote, the projector menu button pops up. They're connected with a Ruipro HDMI optical cable.
Has anyone else has any issues with this and is there any fix?
buntym is offline
post #2132 of 2729 Old 11-04-2018, 10:41 AM
grolschie's Avatar
Quoted: 105 Post(s)
Liked: 32
Do they share the same remote code or something? With you AVR turned off, what happens when pointing the remote at the projector and pressing the arrow button?
StrRemote Pro for Sony STR-DN1080 (Android) |
Sony STR-DN1080 | Acoustic Energy Aegis Neo 3 |
Xbox One S
grolschie is offline
post #2133 of 2729 Old 11-05-2018, 02:20 PM
Liked: 0
Speaker selection
Hi all....I am buying this unit after 2 failed Onkyo. I have a set (like 7.1)of 8ohm speakers.....I notice the specs for the receiver points to 6ohms but will this unit be fine with those speakers?
khidbz is offline
post #2134 of 2729 Old 11-05-2018, 05:47 PM
BPlayer's Avatar
Quoted: 417 Post(s)
Liked: 169
8ohm are the optimal speakers to use. It also works with 6ohm speakers.
BPlayer is offline
post #2135 of 2729 Old 11-06-2018, 10:08 AM
Adidas1's Avatar
Quoted: 16 Post(s)
Originally Posted by Adidas1 View Post
Since receiving the amp 2 days ago i had 2 occasions where the amp was OFF, i pointed the remote control towards the unit but it wouldnt turn on (there was nothing between the remote and the amp). I had to press the power button on the amp to start it.
Any idea why?
Sent from my ONEPLUS A6000 using Tapatalk
Ok, so today i decided to reset the receiver to factory defaults. After restoring it, when i turned it off using the remote i noticed the red standby led, It wasnt there before when i turned off the receiver.
Then i remembered that when i connected the receiver for the first time when i got it, i saw the red standy led. But after updating the firmware i didn't see it anymore. I think that the firmware update somehow messed things up.
Anyway, now that the red standby led is visible, I'll see if the power on issue i had is reproduced.
Note to self: reset the receiver to factory default after each firmware update.
Adidas1 is offline
post #2136 of 2729 Old 11-06-2018, 03:30 PM
mrdjman's Avatar
Quoted: 269 Post(s)
Liked: 191
If I'm not mistaken, I think Sony suggests that in the directions. I have all of my settings written down in a text document so I don't have to fiddle around with it...just plug the settings in and go.
mrdjman is offline
post #2137 of 2729 Old 11-06-2018, 05:45 PM
grolschie's Avatar
Quoted: 105 Post(s)
Liked: 32
That won't record the auto-cal EQ data though, right?
Xbox One S
post #2138 of 2729 Old 11-06-2018, 08:31 PM
Adidas1's Avatar
Quoted: 16 Post(s)
Of course, i calibrated it again and changed the settings as i need.
Adidas1 is offline
post #2139 of 2729 Old 11-06-2018, 11:45 PM
Quoted: 241 Post(s)
Liked: 81
Its state depends on settings. https://helpguide.sony.net/ha/strdn1...001224862.html
priitv8 is offline
post #2140 of 2729 Old 11-07-2018, 12:04 AM
Adidas1's Avatar
Quoted: 16 Post(s)
Adidas1 is offline
post #2141 of 2729 Old 11-07-2018, 03:03 AM
mrdjman's Avatar
Quoted: 269 Post(s)
Liked: 191
Well, you manually write everything down (or take pics of the various screens)… I think you can see what things are set as by auto cal. Auto cal doesn't work with mine due to the 'non-standard' positioning of my speakers (although, it worked the first time I ran it, but I digress...).
mrdjman is offline
post #2142 of 2729 Old 11-12-2018, 11:18 AM
Adidas1's Avatar
Quoted: 16 Post(s)
Well, have a new issue, this time with USB sound drops every ~7 seconds.
Scenario:
1. Receiver connected to LG TV via hdmi
2. USB DOK connected to front of receiver
3. Play a song from the DOK
4. TV is open and receiver UI displayed on screen
5. Using TV remote switch to a different hdmi input, for example watch TV
what happens is that while USB music is playing, every 7 seconds there is a drop in sound.
When i return the TV input to show the receiver UI, sound drops stop.
* Tried same scenario with hdmi cable connected to my PC that is streaming music. Did not happen.
Does this happen to you?
Adidas1 is offline
post #2143 of 2729 Old 11-12-2018, 10:15 PM
grolschie's Avatar
Quoted: 105 Post(s)
Liked: 32
Big files? Fast USB drive?
Xbox One S
post #2144 of 2729 Old 11-12-2018, 10:30 PM
Adidas1's Avatar
Quoted: 16 Post(s)
Flac files. Sandisk Fit 128 GB, USB 3.1
Adidas1 is offline
post #2145 of 2729 Old 11-12-2018, 11:32 PM
WontonNoodle's Avatar
how did you guys fix the problem of height channels not producing any sound for any DTS:X tracks? the only way to get sound from the 2 height channels is if you set it to 5.1.2 FH.
https://us.community.sony.com/s/ques...language=en_US
WontonNoodle is offline
post #2146 of 2729 Old 11-12-2018, 11:45 PM
animeking's Avatar
Quoted: 301 Post(s)
Liked: 91
Any updates on the 1080 / 810 DTS:X through upfiring or ceiling speakers issue? I just bumped into this issue today and I'm not too happy about it.
Better yet, does anyone know what the technical limitation is? Would love to know why the receiver can't support upfiring or ceiling mounted DTS:X content.
animeking is offline
post #2147 of 2729 Old 11-13-2018, 12:59 AM
Quoted: 241 Post(s)
Liked: 81
This FH and FD stuff is not about content. It is about receiver configuration.
I set and left mine in FH, adjusted the distance of front height speakers and listen to both DTS:X and Atmos.
priitv8 is offline
post #2148 of 2729 Old 11-13-2018, 08:55 AM
Adidas1's Avatar
Quoted: 16 Post(s)
Scenario:
Ok. Seems kind of Handshake issue between the receiver and my LG TV (PK550).
Tried the following, in all these cases, sound drop reproduced:
1. Different DOK
2. Different HDMI cables
3. Connect the cable to a different HDMI port on the TV
4. TV input set to different input then showing receiver UI
In these cases sound drop did not reproduce and media played OK:
1. Disconnect HDMI cable from receivet
2. Disconnect HDMI cable from TV
3. TV turned off
4. TV input set to show receiver UI
Any known handshake issues with this receiver and LG (not only) TV's?
Adidas1 is offline
post #2149 of 2729 Old 11-13-2018, 10:39 AM
Liked: 0
Home Screen
I have my LG OLED hooked up to my Sony STR1080 in my basement. I had to use HDMI over HDbaseT to get the signal all the way there. So this ends up getting plugged into the TV Optical input on the receiver. I also have a FireTV hooked up into the receiver into one of the HDMI inputs (SAT/CATV I think).
My questions is... since I cannot use the TV HDMI inputs, how can i access the home screen menu on the receiver?? It is the only way to access/change some features.
Petro Petropoulos is offline
post #2150 of 2729 Old 11-13-2018, 06:02 PM
lol same here when I played a DTS X movie and heard 0 sound coming out of the height speakers. I can't believe this hasn't been made a bigger deal or even touched upon in any reviews. Makes you wonder how believable reviews can be... like this is a huge bug. setting the config to FH when your speakers are actually behind/above you would change the sound quite a bit wouldnt it?
post #2151 of 2729 Old 11-14-2018, 03:10 AM
Quoted: 241 Post(s)
Liked: 81
[QUOTE=WontonNoodle;57104502]
You can call me half-deaf, but I dont hear significant difference!
Only things I did after changing from FD to FH:
1) autocal again
2) speaker distance set to total sound travel from speaker to ceiling + down to listener.
I assumed the main difference between the two settings is the delays.
At any rate, my Atmos experience did not get worse and I got DTS:X. So I am happy with the result.
priitv8 is offline
post #2152 of 2729 Old 11-14-2018, 09:41 AM
Liked: 6
This is the exact receiver I am looking to purchase based on reviews. I'm glad everyone has great things to say about them.
steve1971 and Rodney Nicotine like this.
Strukkalvis is offline
post #2153 of 2729 Old 11-15-2018, 05:18 AM
steve1971's Avatar
Quoted: 565 Post(s)
Liked: 512
If you get it you wont be disappointed. I've had my 1080 for a few month's now and I am loving it. The Atmos and DTSX is unreal. When I first set mine up I Auto Calibrated it and made a few adjustments of my own and havent touched the settings since.
Rodney Nicotine likes this.
steve1971 is offline
post #2154 of 2729 Old 11-15-2018, 06:16 AM
gusbuf's Avatar
Sony significantly drops price on this receiver
As of today, major price drop on this Sony STR-DN1080. I am close to buying. What is everyone's overall satisfaction during your ownership? DO you regret not getting something from Denon, Yamaha, Pioneer, or Onkyo? I will be using in a 16x22 family room with just a 5.1 speaker setup. Speakers are on-wall B&W FPM-5's for center and two fronts, FPM 4's for the surrounds, and B&W PV-1 sub. ALso currently have a 7 year old Sony KDL60-EX700 TV which I may be replacing soon as well. All thoughts and opinions greatly appreciated!
gusbuf is offline
post #2155 of 2729 Old 11-15-2018, 06:26 AM
Adidas1's Avatar
Quoted: 16 Post(s)
I owned for a few months a Denon AVRX2300WBKE2. i returned it because i felt it doesn't have enough power. i had to turn the volume dial almost till the end to hear at high volume.
the Sony got lots of power, volume dial is at 30% and i can hear at high volume.
Adidas1 is offline
post #2156 of 2729 Old 11-15-2018, 08:54 AM
buckycat's Avatar
I replaced a Denon AVR 1913 with the Sony and couldn't be happier.
buckycat is offline
post #2157 of 2729 Old 11-15-2018, 10:55 PM
Quoted: 241 Post(s)
Liked: 81
It is especially good fit, if you also have a Bravia TV.
The only thing, I am longing for on this AVR, is the missing display of currently decoded and playing speakers. More expensive ES-series models have this (except for the bottom-line STR-ZA810ES, which is basically relabeled DN1080).
Stream and decoding info could be visible on OSD as well.
priitv8 is offline
post #2158 of 2729 Old 11-16-2018, 01:54 PM
GonzarTheGreat's Avatar
Liked: 1
1. Different DOK
3. TV turned off
Yes, what this guy said. I have seen similar where it was somehow losing the handshake every 5-10 seconds between new Sony TV/this 1080 receiver/USB, and the TV would then try and switch to using its speakers instead. It seems to have had something to do with ARC between the two, and it cuts the channel out while they re-establish the handshake and who is doing what. Swapping the cable fixed for me.
Inadvertently, I did learn later that if I told the TV to disable its speaker capability completely, the old cable worked again. I speculate this eliminating the handshake/voting contest issues that sometimes happen with ARC and new devices in the chain.
Good luck!
GonzarTheGreat is offline
post #2159 of 2729 Old 11-17-2018, 02:14 PM
is there a way to automatically set it so that when you play a 7.1 movie with a 5.1.2 setup that it switches to 7.1 without having to go into the menu and change the speaker layout? if you play 7.1 with 5.1.2 set up it just plays sound out of the 5 speakers nothing out of the 6th and 7th speaker.
post #2160 of 2729 Old 11-17-2018, 02:57 PM
610
Liked: 0
Have you tried using the Atmos upmix?
610 is offline
avr , back speakers no sound , dolby atmos , harmony , receiver advice , receiver setup , remote , Sony , str-dn1080 , sync , television , xbox one x
