"OFFICIAL" 2017 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ (Posts 1-8) - Page 140 - AVS Forum | Home Theater Discussions And Reviews
 136217Likes
post #4171 of 12268 Old 03-21-2018, 11:06 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22568 Post(s)
Liked: 12282
Originally Posted by Quicksilv3r View Post
No it’s not stated. CEC is hit or miss just like the ARC feature. You could get a pallet of 50 Denon receivers and maybe 3/4 could turn off via CEC and the other 1/4may not. It’s the flakiness of HDMI CEC. It’s not perfect.
So true ... regardless of AVR brand.
jdsmoothie is offline
post #4172 of 12268 Old 03-21-2018, 02:46 PM
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
Would you guys say the x4400 is compatible to the yamaha rx-a2070?
Sent from my SM-G935T using Tapatalk
Joe879 is offline
post #4173 of 12268 Old 03-21-2018, 03:09 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12282
Originally Posted by Joe879 View Post
Would you guys say the x4400 is cmarison to the yamaha rx-a2070?
Yup. Except it can expand to 7.1.4 using an external 2CH amp whereas the A2070 cannot.
Madmax67 likes this.
post #4174 of 12268 Old 03-21-2018, 03:14 PM
aaranddeeman's Avatar
Quoted: 1874 Post(s)
Liked: 676
Originally Posted by Madmax67 View Post
That's the way mine was shipped as well. Everything was fine.
Opened the box and as expected all the supporting styrofoam is cracked/broken. That tells how much dumping around of the box must have happened during the shipment.
There is no visible anything that is worry some on the unit itself. I am going to leave it tonight (to get it to room temperature) and will connect tomorrow.
aaranddeeman is offline
post #4175 of 12268 Old 03-21-2018, 04:43 PM
Liked: 6
3400
just fyi- I purchased a 3400 from bb and got no video output at all. tried everything I could think of and finally called tech support. they had me got through everything I had already tried, hooked me up with a tech2 who told me to replace it. the 2nd unit acted exactly the same way - with tech support giving the exact same response. so I took it back got a Yamaha a1070 and no problems at all.
think I'm burnt on d&m.the Marantz sr8001 that this unit replaced had to be sent down to sacramento 2x at a total cost of almost $500 for repairs+ shipping. I lost 2 hdmi inputs over the last year which is what led me to replace it before it crapped out completely(the Yamaha a3090 that the Marantz replaced is still in use by my grandson).
anyway, if you get no video out on this unit(imagine some of the others in the same series use same electronics) don't waste your time troubleshooting it, just take it back and replace.
fyi bb(we don't have magnolia) shipping is stellar got the first unit next day and the 2nd unit 2days after I took the 1st in at 4:30 pm.
mik2h is offline
post #4176 of 12268 Old 03-21-2018, 06:36 PM
Matt2026's Avatar
Quoted: 907 Post(s)
Liked: 25735
Not denying the fact that doing so provides more protection, rather simply that some do and some don't. Best to ask first if important.
Do you double box
Regards, Ken (Retired)
7.1.2) Denon 4520CI; Aircom T-8, Samsung 55H8000; OPPO 203; 6x SVS Ultra BS,
Ultra Center; FH 2xPolk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nak RE-1, CR7A, BD F7500, Denon 300F/Ortofon 2M Bronze;
Matt2026 is offline
post #4177 of 12268 Old 03-21-2018, 11:01 PM
Madmax67's Avatar
Quoted: 2218 Post(s)
Liked: 2515
Originally Posted by nihilan View Post
I hear you. Is it actually stated anywhere that CEC is NOT supposed to power on Denon receivers? I would have gone with another manufacturer in that case.
What CEC powers on and off doesn't have anything to do with Denon. It's a half baked standard that holds no 2 manufactures to the same implementation. It's broken by "design" not by Denon. See what I did there.
PJL99 likes this.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #4178 of 12268 Old 03-21-2018, 11:07 PM
Madmax67's Avatar
Liked: 2515
Make sure to shake the receiver in your hands a bit if you can to see if anything is loose inside the unit when you take it out of the styrofoam. One other owner had something break loose inside his receiver during shipping and shaking it once out of the box made him aware of it early to attempt a replacement.
Madmax67 is offline
post #4179 of 12268 Old 03-21-2018, 11:50 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12282
Originally Posted by Matt2026 View Post
Do you double box
Yes, of course. We've seen what UPS can do.
azz7686 likes this.
post #4180 of 12268 Old 03-21-2018, 11:57 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12282
No video from two brand new units would most likely point towards either a setting issue or an HDMI cable issue rather than two defective units. Was the source 1080p or 4k? If 4k, then were you using "Premium" certified 4k/18gpbs HDMI cables? Did you try changing the <4k Signal Format> setting to "Enhanced"?
post #4181 of 12268 Old 03-22-2018, 03:49 AM
rjruby's Avatar
Quoted: 42 Post(s)
Liked: 39
I've had problems in the past with CEC powering on the AVRs when I power on the TVs in my two home theater systems, one is a Denon AVR and the other is a Yamaha AVR.
In both cases it was another device connected to the AVR that was causing the problem. On the Denon it was a Roku Ultra. On the Yamaha it was an Android IPTV box. Had to install one these https://www.amazon.com/Lindy-HDMI-Ad.../dp/B00DL48KVI on each of those devices to correct the problem.
The Denon AVR was working fine with the Roku Ultra until the Roku got a firmware update. Then the problem started.
rjruby is offline
post #4182 of 12268 Old 03-22-2018, 04:04 AM
rolltide1017's Avatar
Quoted: 496 Post(s)
Liked: 491
The last 2 times I have powered on my S930H, it has displayed an ad for the HEOS/Denon AVR mobile apps. It’s the same one that was displayed during the initial setup. No video is displayed or audio plays until you click “Next” twice and then click “Done”. How can I stop this ad from displaying in the future?
PSN ID: CrimsonNagus
XBL GT: Crimson Nagus
rolltide1017 is offline
post #4183 of 12268 Old 03-22-2018, 04:11 AM
Liked: 676
Thanks. I will give it a shake before I connect it tonight.
post #4184 of 12268 Old 03-22-2018, 04:14 AM
Liked: 676
Yeah. Call me OCD, but I also like my original packaging as pristine as the unit itself.
The (intact) integrity of the package makes it reusable without a hitch in case you need to ship it for something else.
post #4185 of 12268 Old 03-22-2018, 04:24 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12282
In speaking with Denon CSR, it turns out this message should only appear upon initial setup; however, has been reported to continue displaying beyond setup on some units. Refer to post 5 and do a microprocessor reset to try to stop the message from appearing again.
post #4186 of 12268 Old 03-22-2018, 05:11 AM
Liked: 0
Denon S730 Lip Sync Issues...
Forgive me if this is somewhere on this forum – I didn’t find it (though I found plenty of helpful stuff throughout the years -- in other words, long-time reader, first-time poster.)
I’m having lip-sync issues on certain devices sometimes, and it’s the "sometimes" that’s making it hard to ID the issue.
I just upgraded from a Pioneer Receiver (no 4K) to the Denon AVR S730h. And I added a Sony UBP X8004k blu ray player. My TV is a Vizio 4k m-series. With the Pioneer, I didn’t use the CEC ARC function because it would control my Pioneer settings when I didn’t want it to.
The Denon works great, but sometimes the lip-sync is off on the Sony Blu-rays (4K and standard), and once in a while on the Vizio's YouTube and Amazon apps. (No issues with the DVR or Roku). And sometimes it works fine. I’ve tried disabling ARC, and either way the issue persists. The Denon has a feature to adjust for lip sync, but I don’t want to have to pause every movie and try to fix the issues.
Do I need a new HDMI cable connecting the Denon and Vizio? (I have a 4k-enabled cable.) Is it an issue with the Denon, Vizio, or Sony player?
mflanny is offline
post #4187 of 12268 Old 03-22-2018, 06:39 AM
Aliens's Avatar
Quoted: 2085 Post(s)
Liked: 3161
Roku
I didn't find an answer in my search and the 4400 manual wasn't clear. I currently have my Roku stick connected via HDMI on the TV, with audio optical out to the Marantz receiver. The TV supports ARC while the older Marantz does not. In order to have audio when I watch through the Roku, I have to go into my receiver input setup to change the TV audio function mode. Is there a much simpler way to do this with the 4400, IOW, where the audio and video are combined into one?
Aliens is online now
post #4188 of 12268 Old 03-22-2018, 06:42 AM
Astennu's Avatar
Quoted: 144 Post(s)
Liked: 43
Originally Posted by elfeoblu View Post
one final question if i may...I will get a pair of ELAC atmos modules this weekend...I'm thinking of placing them on top of the surrounds and leaving the paradigm Micro bookshelf speakers as front height. Will this give me a more "enveloping" sound experience? I currently have a pair of cheap bookshelf speakers as Rear height and I do "feel" a fuller sound with atmos movies etc but I hope using the ELAC would make it even better! I got greedy, I know!
I hope nobody tells me to also get ELAC for the front!!! my ceiling is only 8-9 feet high and flat. I sit about 12 feet away from my 65 inch tv
thanks
E
I'm no fan of atmos modules that use reflection via with the sealing to get the sound to the listening position. I rather have cheaper speakers mounted on the wall/sealing.
As for your current bookshelfs they are similar to my Jamo S622's. since they have smaller drivers they need to cross over at higher frequency's (90-100Hz)
Bigger bookshelf's can do more bass (crossover at 60Hz) and play louder if needed.
i have not tested a lot of atmos content yet. so far i do not get the feeling that the Jamo's are insufficient for the height effect's. But i will have to do some more testing. Maybe i might upgrade them to SVS Prime bookshelf's but they might be to heavy for the current mounts and they are way bigger.
So far the Height effect's are not as detailed as music / speech so in my opinion it's less important to use really expensive speakers for the height channels. The rear surround speakers are more important. And in my opinion for movie's the center speaker is the most important and after that the front speakers.
mrtickleuk likes this.
HT Setup: Sony 75X940E - Denon X4400W 5.2.4: - SVS Ultra Bookshelf (Front) - SVS Ultra Center - SVS Prime Bookshelf (surround) - 4x Jamo S622 (Height) - Dual SVS PC2000 Sub's
Astennu is offline
post #4189 of 12268 Old 03-22-2018, 07:29 AM
gossamer88's Avatar
Quoted: 298 Post(s)
Liked: 180
Why not connect the Roku directly to the 4400?
LG OLED 65C7P • Apple TV 4K • Roku Ultra 2018 • Oppo BDP-103 Blu-ray • LG UP970 UHD BD
Denon X3400H AVR • Paradigm Cinema 110 CT Speaker System
gossamer88 is offline
post #4190 of 12268 Old 03-22-2018, 07:37 AM
Ted99's Avatar
Quoted: 980 Post(s)
Liked: 441
Every purchase I have made from AVScience came double-boxed.
JVC RS600 Chad-callibrated, 120" 1.3g in Batcave HT, Denon X8500 Polk LSiM703 fronts,
RTi-12 rears, LSiM 706 center, Monitor 40 Heights, Monitor 60 FW, FXiA4 Bi-pole sides,
LSiC CH, Infinity 6" VOG. 4X 12" subs w/mini DSP on sub 1 and nearfield 18" from sub 2.
Ted99 is offline
post #4191 of 12268 Old 03-22-2018, 07:59 AM
zinfella's Avatar
Quoted: 388 Post(s)
Liked: 289
Denon S730H into LG 65C7P HDMI 2, ATV4K into Denon HDMI 3. 730 setup as 3.1, R&L front, center, and SW speakers. So, watching Blade Runner 2049, done in Dolby Atmos, what should my Denon display be showing? I know that I don't get Atmos as setup, but I'm not sure what I should be getting. During the movie I experienced subdued volume in parts of the movie, at some points the volume was turned all the way up. When I paused the movie the volume from the ATV4K nearly blew the roof off. Perhaps I should have altered the audio setting? OTOH, since there's no OSD with 4K content, I'm at a loss WRT just what my options are with the 730.
zinfella is offline
post #4192 of 12268 Old 03-22-2018, 08:40 AM
Quoted: 496 Post(s)
Liked: 491
First I've heard of this. Try setting the "Upgrade Notification" setting (p. 201 Owner's manual) to OFF. Otherwise, I will try to find out and respond back with the result in this post.
I changed that setting and will see how it goes. Thanks.
post #4193 of 12268 Old 03-22-2018, 09:06 AM
nihilan's Avatar
Quoted: 115 Post(s)
Liked: 42
Thanks for the feedback. Any idea why the HDMI adapter solved the problem? I just may try that. I was a little suspicious of my TV (Sony X900E), but I tried using the Apple TV with the TV unhooked, and it still didn’t work.
nihilan is offline
post #4194 of 12268 Old 03-22-2018, 09:09 AM
michaelcoker's Avatar
Quoted: 57 Post(s)
Liked: 3
Do I need certified HDMI cables for my Denon to work properly on a 1080p tv
I was going to wait until I picked up a 4k tv to upgrade my hdmi cables
Sent from my iPhone using Tapatalk Pro
michaelcoker is offline
post #4195 of 12268 Old 03-22-2018, 09:27 AM
Matt2026's Avatar
Quoted: 907 Post(s)
Liked: 25735
Thanks JD
Matt2026 is offline
post #4196 of 12268 Old 03-22-2018, 09:47 AM
0100010's Avatar
Quoted: 54 Post(s)
Liked: 50
Some devices "absorb" HDMI CEC messages; meaning they receive it, but don't forward it on to the next / other devices in the chain like they should. That device linked above, if memory serves has the CEC pin (13?) not connected at all, so it prevents whatever is behind it from interacting with CEC completely.
Insert signature here.
LR : E65-C3 | HW-MS750 | SWA-W700
HT : ES 120" | JVC RS-520 | Oppo-203 | Denon X3400H 5.1.2 | ELAC A4.2 B6.2 C6.2 F6.2 & VTF-15MK2
0100010 is offline
post #4197 of 12268 Old 03-22-2018, 09:56 AM
Quoted: 47 Post(s)
Liked: 40
I watched The Dark Knight, and in some scenes I could barelyhear the conversations. Maybe it was theway it was filmed. These are mysettings:
FL -6.5
FR -7.5
C -8
SW -8.5
SL -6.5
SR -4.5
SBL -8.5
SBR -10.0
Should I bump up the center speaker?
TV – Sony XBR-65X930E, Legacy Sony KDL-52XBR9, Receiver – Denon AVRX3400H
Fronts - Klipsch R-28F, Center - Klipsch R-25C
Surrounds – El Crapo, Surround Rears – El Crapo
Sub – SVS PB12-NSD
Blu-ray Player –Sony UBPX700, Legacy Panasonic DMP-BD210, Remote – Legacy Harmony 1
Artie Barnes is offline
post #4198 of 12268 Old 03-22-2018, 10:52 AM
zinfella's Avatar
Quoted: 388 Post(s)
Liked: 289
FL -6.5
FR -7.5
C -8
SW -8.5
SL -6.5
SR -4.5
SBL -8.5
SBR -10.0
Similar to the issue I had with Blade Runner 2049, which I had to run at near full volume, and all the way up at times. I will say that it did sound good and with great bass most of the time, like when it wasn't having those subdued volume scenes. For me, 2049 was a rental from iTunes.
I'm hoping that JD will have an answer for this. Meanwhile, I'm gonna call Apple Care to see what they might know.
Artie Barnes likes this.
zinfella is offline
post #4199 of 12268 Old 03-22-2018, 11:26 AM
Quoted: 20 Post(s)
Liked: 2
Dear All,
I am having issues with my Denon X4400h.
I have the Receiver connected to Samsung F8500 via HDMI 3 (ARC). All Anynet options on TV are off since I use the Harmony 650.
The receiver keeps on turning back on after I press off on my Harmony 650 to turn off all devices.
If I click on Help on my Harmony 650 it goes through the options to turn of the receiver again and it works but does anyone have any ideas on why
ski pete is offline
post #4200 of 12268 Old 03-22-2018, 11:38 AM
zinfella's Avatar
Quoted: 388 Post(s)
Liked: 289
I pretty much drew a blank with Apple Care. The person that I talked to, while very courteous, had no answers, save to say that they saw 2049 in a theater, and it had audio issues, in their opinion. Of course I can't argue with that, but maybe someone more knowledgeable could.
zinfella is offline
2400h , 3.0 , 4 ohm , 4200 , 4300 , 4400 , 7.1 , 7.1 setup , 7.2 , alexa , atmos , Audyssey , avr , avr-s730h , avr-x2400h , avrs730h , bi-amp , blueray , bluetooth , connectivity , Denon , denon x2400h remote controller , dolby surround up mixer , dts neural up mixer , Emotiva , enhanced 4k , hdmi , help please , Home Theater , ipod , lan , lpcm 7.1 , multi ch in , Netflix , Pioneer , pre amp , pre out , ps4 , receiver , Samsung , setup , subwoofer denon test tone , wifi , x3400h , x520bt , xbox one , zone 2
