2M views 15K replies 2K participants last post by  iafzal
#1 · (Edited)
"OFFICIAL" 2017 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ (Posts 1-8)
2017 Denon AVR models ---> S530BT/S730H/S930H/X1400H/X2400H/X3400H/X4400H/X6400H
The Denon + Marantz Group (ie. D+M Group) USA has started to release information on the new 2017 Denon models starting with the three new "S" series models. The lower "X" series will be announced next with the higher "X" series announced later this summer and released in August/September. A new “flagship” model to replace the X7200WA (ie. X8500H) may be announced at CES 2018 (Jan) and then released in the spring of 2018 with 13 on board amps and will have its own separate Owner's thread.
What's new or to be added via firmware update for the 2017 models?
S530BT
- HDMI Control/ARC/TV Audio Switching (added for the first time on this lowest model)
- Bluetooth Auto-Select (ON/OFF – prevents Bluetooth devices from powering on the AVR or selecting Bluetooth source when in range)
- Restart - (pressing/holding the power on button in lieu of having to pull power cable)
- 4K Signal Format (not a setting on this model rather it simply internally factory defaults to Enhanced (4K/60Hz video) and cannot be changed
- AK4458VN 32 bit DAC (primary); X4400H/X6400H feature (2ea)
- PCM5100 32 bit DAC (Network); also for X4400H/X6400H
- Bluetooth Version 3.0, Class 1 - increased from 33' up to 98ft/30m
- Audyssey MultEQ Editor iOS/Android phone app ($20) - (first introduced for use with the 2016 models) using the Audyssey mic included with the AVR, provides the ability to customize target curves, save them on the phone/tablet and send back to the AVR as needed generally only taking about 90 seconds vs. the roughly 5 minutes to load from a USB thumb drive
- The "H" series AVRs include a HEOS module which will allow streaming the (currently) 12 music services using the HEOS iOS/Android app to the "H" series AVR as well as allow streaming 2CH sources from the AVR (analog only on X2400H and lower and analog/digital on the X3400H and higher) to one or up to 32 HEOS wireless speakers placed around the home
- Auto Update - (default - OFF), allows for firmware updates while the unit is in Standby
- SAVE & LOAD (to USB; replaces Web Control SAVE/LOAD)
- DTS:X & DTS Neural:X pre-loaded at factory
- 4K Signal Format (Standard (default)/Enhanced; Note: Enhanced setting must be used when passing 4K/60Hz video)
- Disable Zone 2 access from the remote control
- TV Sound Grouping (fixes 1 second audio delay experienced when playing cable/sat box audio to the surround speakers and HEOS speakers in other rooms) - April 12, 2017 firmware update
- Dolby Vision HDR (on board)
- Hybrid Log Gamma (HLG) - (firmware update Sep 2017)
- ALAC up to 192kHz sampling frequency
- Airplay 2 (firmware update August 2018)
- Auto Low Latency Mode (ALLM) (firmware update August 2018)
- Voice Control Agents - Alexa, Google Assistant, Apple Siri, Josh.ai
- DTS Virtual:X - via firmware update ETA November (simulates height/surround from DTS and PCM audio only when no Height/Top/Dolby speakers are configured; Note: Unable to use Audyssey when DTS Virtual:X is selected on these models)
- Spotify Connect via FREE Spotify account - firmware update (Aug 2019)
- eARC (X3400H/X4400H/X6400H) - added via October 30, 2018 firmware update; HD audio (Dolby TrueHD/DTS HD-MA (note Atmos over DD+ is not HD audio and so is able to pass over the current ARC) from an eARC capable TV back to the AVR) - Note an HDMI w/Ethernet cable must be used.
X4400H/X6400H
- Auro 3D - installed at the factory (the 3rd 3D audio codec in addition to Atmos and DTS:X); able to use Dolby enabled speaker configurations (Front Dolby/Surround Dolby/Back Dolby) although unable to use Top Surround/Voice of God when using them; Note also the Owner manuals incorrectly reflect Auro 3D/AuroMatic audio being able to play to Surround Back speakers.
- Denon's AL32 processing (upgrade over AL24 processing on the X4300H/X6300H)
- Bass Sync
- 5.1 CH full bi-amp -FL/FR/C/SL/SR (X6400H only)
- DTS Virtual:X - via firmware update ETA Summer 2018 (simulates height/surround from DTS/PCM audio when no Height/Top/Dolby speakers configured; able to use Audyssey MultEQ XT32, but unable to use any other Audyssey feature (ie. Dynamic EQ, Dynamic Volume, LFC))
What was dropped from the 2016 models?
- Web Control
- vTuner - must use TuneIn (on board or using HEOS app) for internet radio which doesn't allow the user to manually add new stations as is the case with vTuner
- iPod/iPhone connectivity via USB
- Video Select (iPod/USB)
- Component Video upscaling (other than 480i/576i; X3400H)
X6400H
- HD Radio
- All "S" series models have a 2 year warranty if purchased new/open-box from an authorized dealer
- All "X" series models have a 3 year warranty (2 years in Canada) if purchased new/open-box from an authorized dealer
- All refurbished models have a 1 year warranty if purchased from an authorized refurb dealer
Note: Although all models feature two subwoofer pre-outs, only the X3400H/X4400H/X6400H have independent subwoofer volume control of each subwoofer.
Denon model web page info and Owner manual links
- S530BT - MSRP $279, 5.2 CH, 70W, HDMI In/Out (5/1)
This is a 5CH AVR which features Bluetooth, but is not a networking model. Firmware updates would be installed via the USB jack. It includes a mic for a basic (ie. non-Audyssey) single position speaker/sub calibration. It can display the GUI over 2D/3D video sources input to HDMI1 and HDMI2 and pass through 4k/60Hz video from HDMI3/HDMI4/HDMI5 but cannot display the GUI over 4k video. It can use the “Denon 500 Series Remote” Bluetooth remote app.
http://usa.denon.com/us/product/hometheater/avreceiversht/avrs530bt
http://manuals.denon.com/AVRS530BT/NA/EN/index.php
Press release on the S530BT and S730H and S930H - http://www.digitaltrends.com/home-theater/denon-s-series-receivers-avr-s930h-avr-s730h-avr-s530bt/
- S730H - MSRP $479, 7.2 CH, 75W, HDMI In/Out (6.1) - avail April
Upgrading from the S530BT adds 1 more HDMI input and two more audio channels for a 7CH model and the lowest model to feature Audyssey MultEQ (6 mic positions), networking, DSD via USB/network source, Atmos/DTS:X 5.2.2, DTS:X and uses speaker posts, 32 bit DAC, and an on board Denon HEOS module (allows streaming of HEOS app music services to the AVR as well as streaming PCM 2.0 source from the AVR to HEOS wireless speakers set up around the home). Firmware updates are installed via a network connection or USB. It can display the GUI over 2D/3D video from all HDMI inputs, but not over 4k video. . It features 5.1 + Zone 2 capability using the Surround Back speaker posts for Zone 2. A new SAVE/LOAD config file via USB feature has been added. There are no Zone 2 pre-outs. No noticeable difference in power; however, audio quality should be improved after running Audyssey. This is the lowest model that can use the new Audyssey MultEQ Editor iOS/Android app ($20) as well as the lowest model that will be receiving the HLG firmware update.
http://usa.denon.com/us/product/hometheater/avreceiversht/avrs730H
http://manuals.denon.com/AVRS730H/NA/EN/index.php
- S930H - MSRP $579, 7.2CH, 90W, HDMI In/Out (8/2, main/main outputs) - avail April
Upgrading from the S730H adds 2 more HDMI inputs, 1 more main zone monitor output (eg. when using a TV and PJ), 2 component video inputs / 1 output, 4k/30Hz upscaling, on board. No noticeable difference in either power or audio quality. Although unable to display the GUI on 4k video, able to display the volume bar/Info on 4k video (except Dolby Vision) but only at 24/30Hz, not at 60Hz and only when Video Mode is not set to "Bypass".
http://usa.denon.com/us/product/hometheater/avreceiversht/avrs930H
http://manuals.denon.com/AVRS930H/NA/EN/index.php
- X1400H - MSRP $599, 7.2CH, 80W, HDMI In/Out (6/1) - avail May
This model has the same features as the S730H but adds: improved audio quality using the higher Audyssey MultEQ XT (8 mic positions), Zone 2 pre-outs, Crestron/Control 4 interface, and also as the lowest "X" series model adds 1 more year of warranty (total 3 years). Not able to display GUI or volume bar/Info on 4k video.
http://usa.denon.com/us/product/hometheater/avreceiversht/avrX1400H
http://manuals.denon.com/AVRX1400H/NA/EN/index.php
Press release on the new X1400H and X2400H ---> http://www.bigpicturebigsound.com/Denon-AVR-X1400H-and-AVR-X2400H-AV-Receivers.shtml
- X2400H - MSRP $799, 7.2CH, 95W, HDMI In/Out (8/2, main/main outputs) - avail May
This model has the same features as the S930H but adds: improved audio quality using the higher Audyssey MultEQ XT, Zone 2 pre-outs, RS-232, Crestron/Control 4 interface, ISF (Day/Night) calibration settings (to be set by an ISF calibrator) and 1 more year of warranty (total 3 years). Although unable to display the GUI on 4k video, able to display the volume bar/Info on 4k video (except Dolby Vision) but only at 24/30Hz, not at 60Hz and only when Video Mode is not set to "Bypass".
http://usa.denon.com/us/product/hometheater/avreceiversht/avrX2400H
http://manuals.denon.com/AVRX2400H/NA/EN/index.php
- X3400H - MSRP $999, 7.2CH, 105W, HDMI In/Out (8/3, main/main/Zone 2 outputs) - avail July
Upgrading from the X2400H adds: Zone 2 custom settings (bass, treble, HPF, stereo/mono), 12v trigger (1), DSD over HDMI, Zone 2 HDMI Monitor output, HDMI/digital PCM 2.0 audio to Zone 2 speaker posts/pre-outs/HEOS speakers, analog --> HDMI conversion, 4k/60Hz upscaling, and the lowest model with 7.2 main zone pre-outs (however, there is no further expansion beyond 7CH (ie. 7.1 or 5.1.2) processing using an external amp). No noticeable difference in power, but much better audio quality using the much more advanced Audyssey MultEQ XT32 and Sub EQ HT (when using 2 subs; independent sub level/delay). The Audyssey Low Frequency Containment (LFC) feature drops down to the X3400H from the higher models which helps to reduce the impact of lower frequency waves passing through walls (great when watching at night with others asleep nearby or if living in an apartment with thin walls). Although unable to display the GUI on 4k video, able to display the volume bar/Info on 4k video (except Dolby Vision).
http://usa.denon.com/us/product/hometheater/avreceiversht/avrx3400H
http://manuals.denon.com/AVRX3400H/NA/EN/index.php
- X4400H - MSRP ($1599), 9.2CH, 125W, HDMI In/Out (8/3, main/main/Zone 2 outputs) avail Aug
Upgrading from the X3400H adds: 2 additional on board amps for 9CH on board processing (ie. 7.1.2 or 5.1.4; with capability to expand to 11CH processing (ie. 7.1.4) using an external 2CH amp), 11.2 main zone pre-outs, Zone 3, a 2nd 12v trigger, front panel display of speaker inputs (or outputs), PHONO input, metal front panel with 2 line display, Custom 2 CH main zone settings (using FL/FR or dedicated Front B; LARGE/SMALL; crossover settings, sub – on/off, distance, level), two internal cooling fans, Auro 3D/Auromatic ($199 upgrade on previous years models) with the ability to use it with Dolby enabled upward firing modules and Surround Back speakers, AL32 Processing, Bass Sync; Remote Control able to store preset codes from other mfr devices (see below) and the ability to add Auro 3D Voice of God/Top Surround via the Subwoofer pre-out 2 only. Although unable to display the GUI on 4k video, able to display the volume bar/Info on 4k video (except Dolby Vision).
https://usa.denon.com/us/product/hometheater/receivers/avrx4400H
http://manuals.denon.com/AVRX4400H/NA/EN/index.php
Remote Control Preset Codes: http://manuals.denon.com/AVRX4400H/preset/AVRX4400HPresetCodes.pdf
- X6400H - MSRP ($2199), 11.2CH, 140W, HDMI In/Out (8/3, main/main/Zone 2 outputs) avail Aug
Upgrading from the X4400H adds: 2 additional on board amps, more robust amps, mfr'd in Japan, gold plated connectors, Dialog Enhancer, two internal cooling fans, 5.1 CH full bi-amp -FL/FR/C/SL/SR, and Auro 3D Voice of God/Top Surround via either the Subwoofer pre-out 2 or the Surround Back L speaker post. Although unable to display the GUI on 4k video, able to display the volume bar/Info on 4k video (except Dolby Vision).
https://usa.denon.com/us/product/hometheater/receivers/avrx6400h
http://manuals.denon.com/AVRX6400H/NA/EN/index.php
Remote Control Preset Codes: http://manuals.denon.com/AVRX6400H/preset/AVRX6400HPresetCodes.pdf
Welcome to the Official 2017 Denon AVR-S/X models thread (S530BT/S730H/S930H/X1400H/X2400H/X3400H/X4400H/X6400H).
If this is your first visit to this thread, and you want to ask a question about one of the 2017 Denon AVR models, either one that you own or one that you are thinking of buying, please provide the following information to allow for better responses to your questions:
(a) Identify the model number in question (eg. X2400H), as there are 8 different models (S and X series) discussed in this thread. Also if you have not posted in several days since your initial post, please post the model # again so we don't have to back track to learn which model you are referencing.
(b) Identify what you've done so far to troubleshoot the issue and what the front panel is displaying if an audio issue, (also take a few minutes to review the Troubleshooting section provided in post 3 as your question may already be answered there,
(c) Unless you indicate what settings have been changed, the assumption will be that all settings are on the factory defaults (ie. usually "Auto"),
(d) If the advice given seems to simplistic or obvious, don't shoot the advice giver as we have no idea of the level of your technical understanding,
(e) If there is no response to your post, it either means no one knows the answer or it has simply been overlooked so please repost if you still haven't resolved your issue,
(f) If you post a question in this thread and are given advice and either it or some other advice (eg. Denon phone support, Denon "Ask a Question" email support) resolves your issue, have the common courtesy to post back what solution resolved your issue so others can learn from it as well,
(g) If the issue is not user error or not just a misunderstanding on how the AVR works, please call Denon support so the issue is registered,
(h) When responding to another post that is providing assistance to you, please press the "Quote" button in the lower right corner of that other poster's response so that response is also listed with your new post to provide some context, and,
(i) If you don't live in either the USA or Canada, please either indicate your country location in your profile or your post as some Denon models from other regions in the world differ in configuration from their USA/Canada counterparts otherwise responses made in this thread are in regards to the USA/Canada models only.
See less See more
#3,585 ·
I have had kind of of a similar network problem with my x2400h.
Disconnect the network cable from AVR and try to run only the Network Setup step from Setup Wizard and you should see the option to scan wireless network but probably you will not find any wireless networks. After you have completed this step I think you will be able to do a proper network reset.
It seems that the microprocessor reset doesn't include a network reset.
the description and solution for my problem is at post number 3417 in this topic, maybe it will help you
Thank you for reply, u gave me hope it is not hardware problem, after few days and numerous resets (chip and network) it worked!!!
Cheers!
#3,590 ·
Got the update on mine as well, says mainly overall stability and performance fixes. No details yet?
Q about that btw: My router only has 4 LAN inputs, and all of them are used, which means my 3400H is connected via WiFi atm. I can disconnect one cable and replace with the Denon, but it's kind of a hassle to do so.
Long story short, how safe is it to update firmware via WiFi?
#3,591 ·
Although a "wired" update is obviously more reliable, if the WiFi signal is strong ... shouldn't be a problem.
#3,592 ·
Signal is strong, only thing that worries me is what happens if it suddenly gets disconnected during the update... Then I could be stuck with a lemon.
But I guess the chances are low for that. Are there any details on the firmware update at this time? Safe to update now or wait a few more days to get feedback?
#3,593 ·
G
you can add a 5 port ethernet switch. take one of the LAN ports from your router, and plug it into the the switch. plug your AVR into the new switch. You can find one online / computer store ~$10
  • Like
Reactions: joe221
#3,595 ·
While I am not a total fan of HEOS so far, there is at least one benefit: accessing the music I have on my NAS. Accessing via the HEOS app is much better than on my AVR-x4000. I may just re-rip all my music. is anyone using Jriver and a 2017 AVR-X ?
how's it working?
update: accessing the NAS from the HEOS app is flakey. I don't have any trouble selecting Tidal content, and the NAS is directly connected to the router ( Linksys WRT 1900 AC) and the receiver is a wired connection, so wi-fi isn't the culprit.
#3,596 ·
I like lemons for lemonade but not as a piece of audio equipment:eek: Only way I would use a wireless update, or even a hard wired implementation, is IF all my gear was running off a UPS, which they are;) We don't lose power often but it happened without any warning last month, not due to weather but for maintenance :)
Old guy who no longer has deep pockets;) Hope it works out well for you.
#3,599 ·
It is actually .. especially considering it may take awhile for the download.
No. There is zero chance the firmware update starts to update the flash blocks until after the entire file is downloaded to the unit (either from wifi, wired, or usb).
The concern seemed to be bricking the unit because of a wireless signal drop out. That wouldn't happen.
The file may fail to download if your wifi fails but you won't brick your unit.
If you lose power on the unit in the middle of the firmware update (when it's actually overwriting the flash memory) that could happen. Along with a slew of other random things but losing wifi won't brick your unit.
#3,600 ·
Maybe add a gigabit switch? They aren’t expensive.
