"OFFICIAL" 2017 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ (Posts 1-8) - Page 322 - AVS Forum | Home Theater Discussions And Reviews
 136087Likes
post #9631 of 11822 Old 12-24-2018, 10:59 PM
Madmax67's Avatar
Quoted: 2104 Post(s)
Liked: 2417
Originally Posted by iafzal View Post
I was thinking it was the other way around, to go in a mode to deliver more current needed by 6 ohms. But it makes sense to add safety factors for higher current so UL can give you the sticker.
oh well that means my x4400h will run even hotter if pushed. Time to spend on a larger cooling fan.
My 4300H stays fairly cool but I have it in a fairly open air AV rack. Auto Eco mode with no external amplification or Eco mode On with an outboard amp should help as well. I run a mix of 8 and 6 Ohm speakers. If they are truly 6 Ohm nominal and fairly efficient it should be fine.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #9632 of 11822 Old 12-25-2018, 07:01 AM
Quoted: 39 Post(s)
Liked: 3
Regarding ventilation - I noticed in the first post that one of the 4400s "upgrades" compared to the 3400 is that it comes with two internal fans.
My question - does that mean it wont run as hot as the 3400? Or does that mean it runs much hotter and requires two fans to try and cool it? Should I expect one to run hotter and require more ventilation than the other?
Thank you.
WPJoe is offline
post #9633 of 11822 Old 12-25-2018, 08:05 AM
Ted99's Avatar
Quoted: 968 Post(s)
Liked: 435
Originally Posted by theaterofpain View Post
With the coming new year, it's time to do a first in AVS history and lock a thread of an EOL product line. Anything that anyone wanted to know about this AVR has been repeated ad nauseum and those late to the party are too lazy to read the first couple of posts or search the thread.
Now we're just getting ridiculous questions like: "Help! I want 5 zone audio, and I have the 6400 - can I get a new 4400 and connect it to zone 2 of the 6400 and then connect my brother's friend's buddy's 4300 that he wants to get rid of to zone 2 of the 4400, but then also control zone 1 of the 4400 using HEOS, but from an Airplay device?"
I own 2016, 2017, and 2018 Denon Receivers. At some point in time, each of the threads really devolve to new second hand owners with questions original owners dealt with in the first year--these really begin to peak shortly after the receiver goes into clearout pricing. About that point in time, I move the thread to the area of my "favorites" that I look at once a week, just in case something new has cropped up. The 2016 went there a while ago. I think it's time for the 2017 to go there, as well; as it's been a while since anything that hasn't been dealt with already has appeared on this 2017 thread. jd does a good job of answering questions from these new owners (usually by referring them to the first 6 posts) and I don't think I have anything to add. As a "for instance", there was another recent question about temps and the presence of the two on-board cooling fans. jd has answered this question in every Denon thread I've read and i'm sure he'll deal with it yet again.
JVC RS600 Chad-callibrated, 120" 1.3g in Batcave HT, Denon X8500 Polk LSiM703 fronts,
RTi-12 rears, LSiM 706 center, Monitor 40 Heights, Monitor 60 FW, FXiA4 Bi-pole sides,
LSiC CH, Infinity 6" VOG. 4X 12" subs w/mini DSP on sub 1 and nearfield 18" from sub 2.
Ted99 is offline
post #9634 of 11822 Old 12-25-2018, 09:57 AM
Quoted: 39 Post(s)
Liked: 3
Well that was me asking about the temps and the fans.
Keep in mind that these threads become hundreds and hundreds of posts. And sometimes the question was in 2017 or 2017 and 2018 - so its thousands.
I know its annoying to have to re-answer questions but I have also googled many terms in this thread to try and find the answer and have yet to find it...
WPJoe is offline
post #9635 of 11822 Old 12-25-2018, 10:16 AM
iafzal's Avatar
Quoted: 22 Post(s)
Thank you.
I am not aware if there are fans in x4400h. Will have to look closely for them It has vents on the whole top and does run hot. I am not in a closed cabinet but it is also not in an open shelf, only front is open and there are a couple of inch gap on each side. I am driving JBL590s + JBL surrounds. etc. The 590s are rated to 250W each and are 6 ohms with 92db effeciency. x4400h does get a work out driving the 590s and is quite hot after 30mins use at 50-70% volume. Recently I added a laptop cooler on top of it to suck hot air out and this has really helped. Even well after 1 hour of use it is cool to the touch except the areas where cooler does not cover to receiver. I may have to put two laptop coolers to cover the whole x4400h.
Anyway the cooler works exceptionally well.
Madmax67 likes this.
iafzal is offline
post #9636 of 11822 Old 12-25-2018, 10:20 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22163 Post(s)
Liked: 12033
Thank you.
Nope, it simply means the X4400H fans will protect the AVR should the internal temp go over 159F which ideally should never happen.
Also, neither model should run hot if provide with adequate ventilation to include 3-4" clearance on top and sides with an open front and back.
jdsmoothie is offline
post #9637 of 11822 Old 12-25-2018, 10:24 AM
Ted99's Avatar
Quoted: 968 Post(s)
Liked: 435
^^^jd may have taken a Holiday. The two internal fans only activate at a relatively high temp (jd has given the temp) as a last ditch effort to keep from frying the Amp output stages. They do not operate to keep the "normal" temps lower. Ask Denon why, it's never been revealed to us; but I suspect it's to keep the noise level low. jd has often said if you follow the guidelines in manual for clearance, you will be ok for temp, even if it feels "high" to you. If you have restricted clearance, aftermarket fans (thread is replete with examples) are the answer. In any event, Denon does not start up the internal fans until it's way too hot for ordinary use. My X8500 is in "free air" on top of the equipment rack, as was it's predecessor X4400, and both felt "warm" to the touch compared to other receivers I have owned. However I've had no problems and I don't use aux cooling fans. Many owners comment that their Denon receivers seem to be "too warm", but the internal fans are no help to this. jd has reported that the source of the heat is generally the video output stage, not the amplifiers and that is why we feel the heat even when the receivers are not being driven hard.
I see jd posted while I was composing this.
Ted99 is offline
post #9638 of 11822 Old 12-25-2018, 04:28 PM
iafzal's Avatar
Quoted: 22 Post(s)
I was comparing the x4400h spec with Marantz 6012/7012 and noticed this
Power Output (8 ohm, 20 Hz - 20 kHz, 0.08% 2ch Drive)105 W
Power Output (8 ohm, 20 Hz - 20 kHz, 0.05% 2ch Drive)125 W
https://usa.denon.com/us/product/hom...vers/avrx4400h
Why is it more power (Watts) at less distortion? I would think it should be the other way round.
iafzal is offline
post #9639 of 11822 Old 12-25-2018, 05:15 PM
theaterofpain's Avatar
Quoted: 260 Post(s)
Liked: 138
I admire JD for replying to the same questions over and over (another month to go before the next "cooling / temp" question comes up). He must be the most patient person ever. If it were me, I'd simply reply RTMFM or refer to page 1 of thread AVR manuals are probably the most in-depth manuals I've ever come across and the technical writing bar is high. Between that and a search of this thread, all answers lie within, so no sympathy for these hit-and-run newbs looking for a "thanks in advance" type answer. My original Phantom drone manual was like 30 pages of Engrish gibberish where you needed to actively read the DJI forums or look to YouTube for even the most simple answers - and that drone can kill people and bring down an airplane if you don't follow the instructions. So, yeah, I'm joking that this thread should be locked, but the fact that people can't be bothered to be bothered to look up stuff themselves, bothers me.
theaterofpain is offline
post #9640 of 11822 Old 12-25-2018, 11:15 PM
Madmax67's Avatar
Liked: 2417
Originally Posted by ted99 View Post
^^^jd may have taken a holiday.
Spoiler!
Ted99 likes this.
Madmax67 is offline
post #9641 of 11822 Old 12-26-2018, 12:58 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12033
Hah! I didn't get this way overnight. If you were to look at the first 2 years of my posting, you would see roughly every page I would say "Use the Search This Thread" feature. It was then roughly another 2 years before I started putting the information in the first few posts of the thread so that now I can either refer to them or just give the answer as I've learned that the majority simply want the answer.
post #9642 of 11822 Old 12-26-2018, 01:00 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12033
The X4400H/SR7012 are sister models using better quality components than the X3400H/SR6012 sister models.
post #9643 of 11822 Old 12-26-2018, 08:05 AM
DJ Lushious's Avatar
Quoted: 325 Post(s)
Liked: 116
x4400h here. Where at in the setup menu can the Ohm setting be modified? I couldn’t find it anywhere and all this talk had me curious to see what mine is set as.
DJ Lushious is offline
post #9644 of 11822 Old 12-26-2018, 08:32 AM
pbarach's Avatar
Quoted: 567 Post(s)
Liked: 338
Unless someone changed the setting on your unit, it's set to 8 ohms by default. Here's how to change it:
http://manuals.denon.com/AVRX4400H/N...SYrhoargxb.php
Denon x4400h, Samsung LED 1080p TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, Darbeevision, etc.
Headphone system: Focal Clear, Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1, Denon DVD-3910
pbarach is offline
post #9645 of 11822 Old 12-26-2018, 08:55 AM
iafzal's Avatar
Quoted: 22 Post(s)
Yes, knew that. Also Marantz better for music and Denon for HT.
My question why is it rated 125W at 0.05% but only 105W at 0.08% thd.
At higher Wattage THD also goes up.
5.1.4 Setup - Dedicated Media Room
Denon 4400
JBL590/520C/530/550P 5.1.x
MartinLogan MLT-2 x.x.4
Vivtek 2299 4K Projector
iafzal is offline
post #9646 of 11822 Old 12-26-2018, 10:50 AM
grubadub's Avatar
Quoted: 140 Post(s)
Liked: 135
i currently have the denon 1610 and i'm considering the x3400h. i have a 5.1 setup. which surrounds would i use on the 3400, side or back?
also, can i listen to pandora via bluetooth from my samsung s8 phone?
grubadub is offline
post #9647 of 11822 Old 12-26-2018, 10:59 AM
Quoted: 16 Post(s)
Liked: 0
Do the colored "Sound Mode" buttons at the bottom of the remote actually change the processing or the sound at all or are they just a way to set presets for different modes such as stereo, dolby, etc?
I have a MOVIE, MUSIC, GAME, and PURE button.
If I select Movie and choose Stereo, is it the same as the others set to stereo or do each of these modes process the sound differently? The manual makes it sound like there is processing... movie button for movies, music for music, etc...
calidus is offline
post #9648 of 11822 Old 12-26-2018, 11:40 AM
Madmax67's Avatar
Liked: 2417
I think you threw him off a bit bringing up the Marantz when asking a question about the Denon's listed power rating alone. That 105 Watt spec at higher distortion isn't even mentioned on page 317 of the X4400H's PDF manual so more than likely it's an error on the Denon website. Not the first time that's happened.
Madmax67 is offline
post #9649 of 11822 Old 12-26-2018, 11:41 AM
Madmax67's Avatar
Liked: 2417
A way to set presets for different modes.
Madmax67 is offline
post #9650 of 11822 Old 12-26-2018, 11:55 AM
gossamer88's Avatar
Quoted: 297 Post(s)
Liked: 180
Just noticed that when I raise the volume on my 3400, it shows on screen when playing HDR. This was on my Roku Ultra.
LG OLED 65C7P • Apple TV 4K • Roku Ultra 2018 • Oppo BDP-103 Blu-ray • LG UP970 UHD BD
Denon X3400H AVR • Paradigm Cinema 110 CT Speaker System
gossamer88 is offline
post #9651 of 11822 Old 12-26-2018, 01:52 PM
iafzal's Avatar
Quoted: 22 Post(s)
Yes seems like it.
I found the same issue on error Marantz 7012(sister with identical specs to x4400h).
The only explanation I have is that it was left over from Denon 3400 as THD for it is higher compared to 4400.
ID:	2500936   Click image for larger version
Name:	Denon x4400h.GIF
ID:	2500938   Click image for larger version
Name:	Denon x3400h.GIF
iafzal is offline
post #9652 of 11822 Old 12-26-2018, 03:09 PM
afrogt's Avatar
Quoted: 2093 Post(s)
Liked: 1394
It's supposed to display over HDR, that's normal. It doesn't work over Dolby Vision but Roku doesn't do Dolby Vision so you wont have that problem.
gossamer88 likes this.
Afro GT
afrogt is online now
post #9653 of 11822 Old 12-26-2018, 03:34 PM
velocci's Avatar
Quoted: 596 Post(s)
Liked: 42
Hi all, I just got my SVS PB-2000 subwoofer for my basement. I have a Denon 3400H AVR so I plugged it into the LFE port on the back of the sub right? I played a movie (Fantastic Beasts) and it wasn't as impactful as I thought it would be. I had to put it past half way on the back of the sub. what settings on the AVR do I need to change? I put the front speakers as small and the crossover at 80hz. it doesn't give me a crossover of the sub, just the front speakers, even though I did tell the AVR that I have a sub. Is there anything else I need to do? I don't want to run audyssey calibration yet.
Family Room: Onkyo TX-NR 646 AVR, Polk Audio RtiA3 fronts, Polk Audio CSiA4 center, BIC America F12 sub, Polk Audio RC-65i rears
Basement: Denon AVR-X3400 AVR, Klipsch RP280f fronts, RP450c center, SVS PB-2000 sub, Polk Audio RC-85i rears & surrounds
Www.jvpix.com
velocci is offline
post #9654 of 11822 Old 12-26-2018, 03:42 PM
robbierobot's Avatar
Quoted: 58 Post(s)
Denon 4400H having problems staying connected to wifi network. Have tried a soft reset of unit. Also tried network reset. What happens is it will connect to my network but drops connection soon after. Any ideas what else I should try? Thanks.
Sent from my SM-G955W using Tapatalk
robbierobot is offline
post #9655 of 11822 Old 12-26-2018, 07:36 PM
afrogt's Avatar
Liked: 1394
Did you plug in the microphone and run Audyssey after you connected the new sub? Doesn't sound like you did from your post.
You need to in order to calibrate your sub properly. if you don't have much time, just do 3 mic positions for now.
drh3b likes this.
Afro GT
post #9656 of 11822 Old 12-26-2018, 09:26 PM
Madmax67's Avatar
Liked: 2417
Yes seems like it.
It was. There was another poster here a few months ago who pointed out the Denon comparison section showed the X4400's specs for the X3400.
Madmax67 is offline
post #9657 of 11822 Old 12-26-2018, 09:36 PM
Madmax67's Avatar
Liked: 2417
Either keep raising the sub's physical gain knob or raise the sub levels within the receiver itself. Option->channel level adjust is source specific and setup->speakers->manual setup->levels-> test tone is universal.
Madmax67 is offline
post #9658 of 11822 Old 12-27-2018, 02:42 AM
velocci's Avatar
Quoted: 596 Post(s)
Liked: 42
I did not run Audyssey, but a couple of months ago i plugged in my BIC F12 and i noticed the impact right away. You would expect that the svs pb-2000 to be more noticable since its bigger and more powerful. I didn't run Audyssey then either and had both volumes in the middle.
Www.jvpix.com
velocci is offline
post #9659 of 11822 Old 12-27-2018, 03:08 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12033
How far is the unit from your primary router? Perhaps a second (closer) "bridge" router is in order (which I use as my router is at one end of the house and the AVR is at the other end)?
post #9660 of 11822 Old 12-27-2018, 03:10 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12033
1. "Crossover" only applies to speakers, not to the sub.
2. Why not run Audyssey?
2400h , 3.0 , 4 ohm , 4200 , 4300 , 4400 , 7.1 , 7.1 setup , 7.2 , alexa , atmos , Audyssey , avr , avr-s730h , avr-x2400h , avrs730h , bi-amp , blueray , bluetooth , connectivity , Denon , denon x2400h remote controller , dolby surround up mixer , dts neural up mixer , Emotiva , enhanced 4k , hdmi , help please , Home Theater , ipod , lan , lpcm 7.1 , multi ch in , Netflix , Pioneer , pre amp , pre out , ps4 , receiver , Samsung , setup , subwoofer denon test tone , wifi , x3400h , x520bt , xbox one , zone 2
