MultEQ Editor: New App for Denon & Marantz AV Receivers & Pre/Pros - Page 138 - AVS Forum | Home Theater Discussions And Reviews
 2326Likes
post #4111 of 4365 Old 05-02-2019, 02:13 PM
pbarach's Avatar
Quoted: 562 Post(s)
Liked: 329
Originally Posted by ellisda1 View Post
Did my first run yesterday with no major issues. I do have a couple of questions I think I know the answers to:
1) I can opt to not apply room correction to my mains by reducing the "filter frequency range" to 0 - is this correct?
2) If I apply EQ only to the subs by reducing the filter frequency to 0 for all other speakers, I assume that the distance calculations/time alignment is maintained?
1. An easier way not to apply correct to your front mains is by choosing L/R BYPASS as your Audyssey setting in the AVR after calibration. Then it's easy to compare that to having Audyssey correction used on those speakers.
batpig, ahblaza and audiofan1 like this.
Denon x4400h, Samsung LED 1080p TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, Darbeevision, etc.
Headphone system: Focal Clear, Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1, Denon DVD-3910
pbarach is offline
post #4112 of 4365 Old 05-03-2019, 02:00 PM
Quoted: 327 Post(s)
Liked: 158
Confused about something here: if I set the filter frequency range to something lower than the midrange compensation frequency, will the midrange compensation still be applied?
Legacy Audio Silhouette Pro L/C/R
DefTech ProCinema 1000 SL/SR
DefTech Supercube III
Denon AVR790
Oppo PM-3
GIK bass traps and absorption
sunPin is offline
post #4113 of 4365 Old 05-03-2019, 02:35 PM
Quoted: 24 Post(s)
Liked: 64
It will still be applied to the flat target curve.
It will not affect the reference target curve, because you told it to not apply correction above a set frequency.
j_at_audyssey is offline
post #4114 of 4365 Old 05-03-2019, 03:17 PM
batpig's Avatar
Quoted: 4667 Post(s)
Liked: 4852
OK, interesting, so to clarify, the FLAT target curve will always get full-range correction even if you adjust the filter frequency range? So the changes in the App only apply to the Reference curve?
What about target curve adjustments? Do they also only apply to Reference whereas Flat is always "flat"?
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #4115 of 4365 Old 05-03-2019, 03:21 PM
Quoted: 24 Post(s)
Liked: 64
Everything done in the curve editor and filter frequency range only applies to the reference target curve. Flat is not affected.
Flat is always flat, with exception that if you enable MRC, it will have MRC.
post #4116 of 4365 Old 05-03-2019, 04:14 PM
batpig's Avatar
Liked: 4852
Interesting, I was not aware of that! Thanks for the info.
I'm a bit confused by this part -- MRC is enabled by default in the App, but Flat has never used MRC from what I can remember. So are you saying that if you use the App, and leave the MRC at the default "on" setting, then it will also apply to Flat?
I may have to break out my mic and laptop and measure to confirm!
Setup Guide and FAQ
batpig is offline
post #4117 of 4365 Old 05-03-2019, 04:19 PM
Quoted: 24 Post(s)
Liked: 64
Can confirm, MRC occurs in flat when using the app if you have MRC enabled.
In the non-app calibration MRC does not occur in flat and cannot be toggled.
Edit: Visual of Off vs Flat with MRC https://imgur.com/a/ABoe0ci
Perpendicular likes this.
post #4118 of 4365 Old 05-03-2019, 04:47 PM
batpig's Avatar
Liked: 4852
Very interesting! Thanks for checking on that, I thought for sure I remembered that MRC wasn't applied to Flat so it surprised me when you mentioned that.
Setup Guide and FAQ
batpig is offline
post #4119 of 4365 Old 05-03-2019, 06:35 PM
kaydee6's Avatar
Quoted: 56 Post(s)
Liked: 50
Thanks for info and confirmation. Good to know from the source!
Will there be further improvement on the app?
I believe many here would love to have the following implemented:
1. Finer control of the curve editor e.g. input numbers instead of using the fingers to drag
2. Global curve edit that applies change to all speakers
Also is there new development for the Audyssey room correction?
kaydee6 is offline
post #4120 of 4365 Old 05-03-2019, 06:36 PM
kaydee6's Avatar
Quoted: 56 Post(s)
Liked: 50
What's the consensus here pertaining to MRC?
Love or hate?
kaydee6 is offline
post #4121 of 4365 Old 05-03-2019, 07:22 PM
rosstg's Avatar
Quoted: 163 Post(s)
Liked: 136
Love or hate?
I don’t like it.
OLED65B7P/ OPPO UDP-203/ DENON X4300H/ Klipsch RP 440c/ Klipsch RP 250f/ Klipsch RP 240s x4/ Klipsch RP 140sa/ Dual SVS PB-1000/ SVS SoundPath Isolation System/ Auralex Mopad riser for center channel/
rosstg is offline
post #4122 of 4365 Old 05-03-2019, 07:50 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 600 Post(s)
Liked: 417
Originally Posted by giomania View Post
I finally got the graph to capture properly; I have an issue with my laptop making these with 5 dB increments on the vertical axis.
Here is the response I mentioned. The difference at that frequency is not that much, but I am sure there is room for improvement.
I have been playing around tonight with the distance settings, and verified that the distances @Mark Seaton used in 2010 are in fact the best distance settings, according to the REW SPL responses. What I captured tonight is like what you see above.
I have been playing around with the curve editor also, only for the subwoofer channel, to try and get rid of the slight dip (less than 5 dB), but it is only making things worse. Since I have four subs, that could be the complicating factor.
I need to listen to some material to decide if I should stop messing with it, but that dip is driving me nuts! It is a peak with Audyssey off.
Edit: I guess the main consideration here is that Audyssey is calculated based upon the measurements from 8 positions. While those 8 positions were still pretty close to the MLP, I was only measuring at the MLP, which is Audyssey measurement position #1 .
Mark
giomania is offline
post #4123 of 4365 Old 05-04-2019, 05:42 AM
rec head's Avatar
Quoted: 279 Post(s)
Liked: 244
I updated the FAQ with this info. Thanks.
@j_at_audyssey Can you please read over the FAQ in my signature and make sure there are no mistakes?
rec head is offline
post #4124 of 4365 Old 05-04-2019, 08:28 AM
adam2434's Avatar
Quoted: 292 Post(s)
Liked: 143
I'm sure this has been covered somewhere...
In the app, there is no Flat or Reference selection, only Roll Off 1 and Roll Off 2.
Are both Roll Off 1 and Roll Off 2 considered Reference, thus both have curve editor and filter frequency range adjustment capabilities?
pbarach likes this.
5.1 and 2.0 ch: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage and Dayton IO655 on patio. 2.1 ch: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2. 2.0 ch: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED. 2.0 ch: Klipsch Powergate/NHT SB3. Kitchen: Sonos Play5.
adam2434 is offline
post #4125 of 4365 Old 05-04-2019, 08:33 AM
DJB of Poole's Avatar
Quoted: 59 Post(s)
Liked: 27
I have finally got a tablet with a big enough screen to do some editing. Can I import the .ady file I created before on my Nexus 6p. It is on Google Drive but I cannot see an obvious import process into the app on the tablet.
DJB of Poole is offline
post #4126 of 4365 Old 05-04-2019, 10:31 AM
audiofan1's Avatar
Quoted: 2287 Post(s)
Liked: 2798
Love or hate?
I use it on my center only.
audiofan1 is offline
post #4127 of 4365 Old 05-04-2019, 10:36 AM
Rico66's Avatar
Yes, this only applies to Reference. The only thing that you can modify for Flat is MRC on or off (as mentioned above)
BTW, you can check the results once you uploaded to the AVR (under settings-speaker-Audissey). While the curve shown on the AVR is not very granular it still give a good idea what is happening (e.g. if you limit the range it just remains unchanged from then onwards)
Rico66 is online now
post #4128 of 4365 Old 05-04-2019, 01:15 PM
ellisda1's Avatar
Quoted: 69 Post(s)
Liked: 43
I know this is a stretch, but if we're wishing...
Audyssey can capture the frequency scans. The App shows before EQ, and the prediction for what the EQ'd curve would look like. I'd love to be able to run the App after the EQ has been applied and see if it matches the prediction. I'm too stupid and lazy to learn REW, and it looks like it should be simple to incorporate an "After Scan" somehow.
ellisda1 is offline
post #4129 of 4365 Old 05-04-2019, 01:15 PM
mtbdudex's Avatar
Quoted: 83 Post(s)
Liked: 1483
Since MRC is being brought up...
The fletcher munson curves on equal loudness the ear hears at various freq ...
ie. to hear “flat” , same spl at various freq, you really don’t want text book “flat” on chart, rather if by psychoacoustics your ear / brain hear like above .. then MRC enables that right?
MRC off
Toggle it on
MRC on
mtbdudex is offline
post #4130 of 4365 Old 05-04-2019, 02:14 PM
batpig's Avatar
Liked: 4852
I'm not following you Mike. What does MRC have to do with loudness compensation?
Setup Guide and FAQ
batpig is offline
post #4131 of 4365 Old 05-05-2019, 03:02 AM
mtbdudex's Avatar
Quoted: 83 Post(s)
Liked: 1483
I’ll ask my thoughts to Dr Toole is his thread . This thread is not appropriate.
mtbdudex is offline
post #4132 of 4365 Old 05-05-2019, 06:19 AM
adam2434's Avatar
Quoted: 292 Post(s)
Liked: 143
I'm still not 100% clear on this and will need to check the settings in my AVP...but I guess the app always sends a Reference calibration file to the AVR/AVP, since there is no Flat selection in the app. Basically, that would mean that the app can't create correction filters in a Flat context because there is no way to select Flat in the app.
Make sense or am I missing something?
adam2434 is offline
post #4133 of 4365 Old 05-05-2019, 03:33 PM
rec head's Avatar
Quoted: 279 Post(s)
Liked: 244
I think it all gets sent to the AVR where you make the choice.
rec head is offline
post #4134 of 4365 Old 05-06-2019, 05:55 AM
Quoted: 34 Post(s)
Liked: 31
Correct. The app sends both the reference curve with your tweaks and the flat curve (no tweaks except MRC on or off) to the AVR. You can choose reference, L/R bypass, flat or off in the AVR: Setup / Audio / Audyssey / MultiEQ XT32.
You can override distance, crossover, etc. also in the AVR, but note that if you re-send the curve from the app, those setting will revert to what you have in the app curve that you are sending.
giomania, ahblaza and audiofan1 like this.
Denon X4400H | Outlaw Model 5000 | Ascend Acoustics Sierra Towers RAAL Tweeter l/r | SVS Ultra center | SVS Prime Satellite surrounds | 2 x SVS SB2000 subs | Sony-XBR-65X950G
Ralps is offline
post #4135 of 4365 Old 05-06-2019, 09:49 AM
Quoted: 24 Post(s)
Liked: 64
Yes, Denon continues to work on the app.
Yes, there is new development for room correction, nothing that can be announced.
Number 5, the answer is no for the reference curve. If the target curve is not applied in the 2kHz region, there is no dip in that region.
Number 11, it's fixed in the current app, if your sub or speaker goes to 20 Hz, it will be flat.
Yes, both are for the reference setting in the receiver. It's an optional feature if you need more high frequency reduction in your room.
post #4136 of 4365 Old 05-06-2019, 11:20 AM
flamingeye's Avatar
Hello first time using the mutlEq app on my Marrantz av7704 using blustacks on asus pc , everything went fine no hiccups , but I no longer have the option to use flat on my Marrantz 7704 only the reference setting and L/R bypass will out put sound . is this to be expected when using the app? . also the only thing I changed in the app was MRC set to off on all speakers before sending to marrantz , O and roll off curve 1
flamingeye is offline
post #4137 of 4365 Old 05-06-2019, 12:40 PM
Rico66's Avatar
Try sending again to the AVR. I've had a few occasions as well, when Flat "didn't make it". Resending typically fixed that for me and Flat was available afterwards.
post #4138 of 4365 Old 05-06-2019, 01:31 PM
Quoted: 997 Post(s)
Liked: 261
Did my first run with the app. Need to learn how things work. I turned mrc off. What does leaving it on actually do? Here's a photo
Sent from my Pixel 3 XL using Tapatalk
Brian_Barros is offline
post #4139 of 4365 Old 05-06-2019, 02:27 PM
batpig's Avatar
Liked: 4852
MRC (midrange compensation) creates a small dip centered at 2kHz to help with directivity issues around the typical woofer/tweeter crossover point. For example, look at the right side graph of this image and notice the dip whereas it's flat on your graph:
You can also see in the graph that J from Audyssey posted above:
Your speakers appear to have a pretty smooth response from the "before" graph so you might want to experiment with cutting off the EQ correction above 500Hz. Put on some 2ch music and compare the "Reference" curve to "Bypass L/R" (which will EQ the sub but not the FR/FL speakers) and decide if you think the speakers sound better with or without Audyssey. If you think they sound better in "Bypass" mode, then limit EQ to 500Hz and resend the file.
ahblaza and Madmax67 like this.
Setup Guide and FAQ
batpig is offline
post #4140 of 4365 Old 05-06-2019, 02:34 PM
Quoted: 997 Post(s)
Liked: 261
Ok. Not sure hope to do any of that. I haven't had much time to mess around with that. Hopefully sometime this week
Audyssey , Denon , Marantz , multeq editor app
