MultEQ Editor: New App for Denon & Marantz AV Receivers & Pre/Pros - Page 145 - AVS Forum | Home Theater Discussions And Reviews
 2655Likes
post #4321 of 5113 Old 07-02-2019, 12:17 AM
kaydee6's Avatar
Quoted: 57 Post(s)
Liked: 51
Originally Posted by audiofan1 View Post
Did you set them to small in the speaker configuration setting?
Yes, its set to small in the app. Problem only on the front speakers, when I set to 60hz, click Done and get back in, it still shows 40hz.
Center and surrounds are fine.
kaydee6 is offline
post #4322 of 5113 Old 07-02-2019, 05:40 AM
IMWhizzle's Avatar
Quoted: 987 Post(s)
Liked: 329
Can you manually adjust it in the setting menu on the AVR?
Klipsch Reference Premiere: 4 x RP-280's, 1 x RP 450C and dual R-115W's
Marantz 7011 AVR
LG OLED B6
Apple TV 4K
PlayStation Pro
IMWhizzle is online now
post #4323 of 5113 Old 07-02-2019, 06:29 AM
Perpendicular's Avatar
Quoted: 307 Post(s)
Liked: 146
I think there is a bug on 1.4.2. I cannot change the cross over frequency of my fronts from the 40hz set after calibration. It keep reverting to 40hz. Center and surround is okay.
I haven’t tried out this new firmware yet but with the previous firmware using iOS, I would change my speakers from the Large setting to Small and it would always revert to Small when I would change it back to Large. Though, the crossover frequency would stay put. It will be interesting to see what I get. I will play around with it later tonight.
Perpendicular is offline
post #4324 of 5113 Old 07-02-2019, 08:29 AM
kaydee6's Avatar
Quoted: 57 Post(s)
Liked: 51
I did another round of calibration and the front crossover remains unchangeable at 40Hz. I can change the cross over in the AVR, no problem.
Not a serious issue but the app is broken for me now.
kaydee6 is offline
post #4325 of 5113 Old 07-02-2019, 10:41 AM
Quoted: 24 Post(s)
Liked: 67
@j_at_audyssey ,
There is an update on the app to 1.4.2 on the iOS.
Could you share more information on what are the updates for this version?
The changelog in the app store does not detail specifics.
The app is developed by Denon & Marantz, I don't have any visual on their development. With all app development there is bug tracking and fixes with each update, the major feature is the addition of new receiver support.
ahblaza likes this.
j_at_audyssey is offline
post #4326 of 5113 Old 07-02-2019, 10:56 AM
Liked: 2
My avr was already calibrated by the app in the previous version.
If I update the app now, is it enough to simply apply the changes to the avr, or do I need to do a new calibration again?
wolverin1 is offline
post #4327 of 5113 Old 07-02-2019, 02:27 PM
pbz06's Avatar
Quoted: 1136 Post(s)
Liked: 927
If you didn't change anything in your setup, then no. The app being updated is just for bug fixes of the app interface, I don't think it's anything regarding the calibration analysis/results etc.
Sony XBR-77A9G / Panasonic DP-UB9000 / Marantz SR7011 / Def Tech 9060 Series
pbz06 is online now
post #4328 of 5113 Old 07-02-2019, 04:40 PM
rosstg's Avatar
Quoted: 243 Post(s)
Liked: 161
Yep, I just calibrated and I cannot change my fronts. Stuck on 40hz.
kaydee6 likes this.
OLED65B7P/ OPPO UDP-203/ DENON X4300H/ Klipsch RP 440c/ Klipsch RP 250f/ Klipsch RP 240s x4/ Klipsch RP 140sa/ Dual SVS PB-1000/ SVS SoundPath Isolation System/ Auralex Mopad riser for center channel/
rosstg is offline
post #4329 of 5113 Old 07-02-2019, 07:03 PM
Quoted: 307 Post(s)
Liked: 146
My problem in iOS seems to have been fixed. I’ll will run a new calibration in the next couple of days and will report if anything changes.
post #4330 of 5113 Old 07-04-2019, 01:38 AM
d4g
d4g's Avatar
Quoted: 41 Post(s)
Liked: 33
I can confirm the changing crossover bug exists. It always reverts back to 40.
d4g is online now
post #4331 of 5113 Old 07-04-2019, 03:48 AM
Liked: 2
Strange, I never encounter this issue and I had the last 2 versions of the app. I have'nt updated to the recent one yet.
post #4332 of 5113 Old 07-04-2019, 05:28 AM
T100's Avatar
Quoted: 64 Post(s)
Liked: 37
My Denon 6300H settings and my Marantz 7704 setting also reverts back to 40hz
T100 is offline
post #4333 of 5113 Old 07-04-2019, 12:37 PM
PG55's Avatar
Quoted: 200 Post(s)
Liked: 36
App and AVR Calibration
Hello.
If I run the Multi EQ app on my Marantz SR5012 and choose not to transfer the new calibration to the AVR will it affect the original calibration that is on the AVR prior to running the Multi EQ app?
PG55
LG-OLED 65C8PUA
Marantz-SR5012
Sony-UBP X-800, Roku Ultra 4K
Front L&R-Monitor Audio Silver 300's, Center-MA Silver C350, Surrounds-MA Silver FX
Sub Woofers-Paradigm Reference Millenia (2)
PG55 is offline
post #4334 of 5113 Old 07-04-2019, 01:49 PM
Quoted: 307 Post(s)
Liked: 146
Originally Posted by PG55 View Post
Hello.
PG55
No. It will only change once you upload (send) to the AVR from the app. Until then, your AVR Audyssey settings will remain intact.
PG55 likes this.
post #4335 of 5113 Old 07-04-2019, 09:15 PM
PG55's Avatar
Quoted: 200 Post(s)
Liked: 36
I ran Audyssey Multi EQ and sent the file to my computer. I would like to post it to get some feedback. It came over as a ".ady" file and I cannot figure out how to open it. Any suggestions on how to open it or to transfer the file in a useable format from my ipad to my computer?
LG-OLED 65C8PUA
Marantz-SR5012
PG55 is offline
post #4336 of 5113 Old 07-04-2019, 10:16 PM
Sal1950's Avatar
Quoted: 537 Post(s)
Liked: 664
Look into this, I haven't personally used it yet so I can be of little help.
https://www.avsforum.com/forum/90-re...app-files.html
Sony XBR75-X940D, Sony UBP-X800M2 UHD-BD, Xfinity X1 Voice DVR, Marantz AV-7703 Pre/Pro w/Auro, (3) Adcom GFA-545II amps, (2) Adcom GFA-535II amps for ATMOS speakers.
HSU Research 5.2 speaker system (4) HB-1 MK2, (1) HC-1 MK2, (2) STF-2,
Klipsch HT500 satellites (4) for ceiling mounted ATMOS playback
DIY Linux desktop w/Strawberry bit perfect media center. Emotiva Stealth DC-1 DAC
Sal1950 is online now
post #4337 of 5113 Old 07-05-2019, 01:13 PM
PG55's Avatar
Quoted: 200 Post(s)
Liked: 36
Understanding Audyssey Charts
Hello,
I ran the Audyssey Multi eq editor and being a novice I could use some help in understanding what the app did to my calibration. Below are the center channel and sub woofer charts. Before I upload it to my AVR I would appreciate some feedback. Did it improve the room correction results from the previous AVR calibration?
PG55
Name:	Center Channel.jpg
ID:	2587850   Click image for larger version
LG-OLED 65C8PUA
Marantz-SR5012
PG55 is offline
post #4338 of 5113 Old 07-05-2019, 01:22 PM
ratbuddy's Avatar
Quoted: 868 Post(s)
Liked: 1197
1.4.2 still has a broken frequency range slider on my Pixel 3 XL. I opened a ticket about a month ago on the Denon support site that the app sends you to. They replied once then ignored my responses. Not confident they'll ever fix it.
ratbuddy is online now
post #4339 of 5113 Old 07-05-2019, 02:28 PM
rec head's Avatar
Quoted: 302 Post(s)
Liked: 273
Hello,
PG55
When the app or AVR runs a new calibration your current Audyssey profile is disabled.
The graphs are without Audyssey and the predicted results.
There is an FAQ in my signature.
rec head is offline
post #4340 of 5113 Old 07-05-2019, 02:29 PM
rec head's Avatar
Quoted: 302 Post(s)
Liked: 273
They obviously don't know who you are.
jherring69 and Pfeffernuss like this.
rec head is offline
post #4341 of 5113 Old 07-05-2019, 02:30 PM
ratbuddy's Avatar
Quoted: 868 Post(s)
Liked: 1197
I get that you're just being a smartass, but that's no way to treat customers.
post #4342 of 5113 Old 07-05-2019, 02:47 PM
rec head's Avatar
Quoted: 302 Post(s)
Liked: 273
I meant it as you probably know more about the app than most of the people working on it and if you are reporting a bug then there is a bug.
The customer service and the app developers aren't great. I think it has been clear from the start they had no idea who would be using the app or how they would want to use it. They just got a list of things to do and made an app.
jherring69 and deafenears like this.
rec head is offline
post #4343 of 5113 Old 07-05-2019, 02:48 PM
ratbuddy's Avatar
Quoted: 868 Post(s)
Liked: 1197
Sorry, thought you were implying I was being an entitled Karen. That isn't my style
jherring69 likes this.
post #4344 of 5113 Old 07-05-2019, 02:54 PM
rec head's Avatar
Quoted: 302 Post(s)
Liked: 273
No problem.
FWIW I only throw digs at people I know IRL.
ratbuddy likes this.
rec head is offline
post #4345 of 5113 Old 07-05-2019, 03:12 PM
bigguyca's Avatar
Quoted: 1160 Post(s)
Liked: 971
Are you claiming that the MultEQ Editor is the first piece of code written in the manner? Can good programs only be written after years of requirements analysis, testing, etc., perhaps by high-paid consultants?
The available budget for MultEQ was apparently employed to field a working piece of software, instead of a set of PowerPoint slides and some documentation on a SharePoint server. We have both a useful tool and perhaps as important, access to the files from the AVR/AVP. These files allow programs by creative and innovative people, such as Ratbuddy's program. Ratbuddy's program among other features, displays the measurements for each microphone position across the entire frequency range for each speaker. This is really helpful in deciding at which frequencies to apply Audyssey by speaker.
Smartphones have much more processing power, memory and storage than AVR/AVP's. These capabilities provide the potential for much more sophisticated MultEQ versions in the future. Likely the current version of MultEQ is more sophisticated than the equivalent processes in AVR/AVP software.
bigguyca is offline
post #4346 of 5113 Old 07-05-2019, 10:30 PM
deafenears's Avatar
Quoted: 14 Post(s)
They can't even get the SSL/TLS certificate sorted for their website.
deafenears is online now
post #4347 of 5113 Old 07-05-2019, 10:44 PM
audiofan1's Avatar
Quoted: 2356 Post(s)
Liked: 2955
Despite its few quirks, the app rocks
audiofan1 is offline
post #4348 of 5113 Old 07-05-2019, 11:05 PM
JJ7
JJ7's Avatar
Quoted: 172 Post(s)
Liked: 106
I don’t seem to have this issue with iOS and X4300H.
JJ7 is offline
post #4349 of 5113 Old 07-06-2019, 04:55 AM
rosstg's Avatar
Quoted: 243 Post(s)
Liked: 161
I have the same AVR and I have the issue. It only happened after I reran the calibration though.
rosstg is offline
post #4350 of 5113 Old 07-08-2019, 09:59 AM
jdsnov73's Avatar
Quoted: 141 Post(s)
Liked: 46
I am getting the same issue, except my fronts will stay at 90hz. All other speakers I can change to whatever and it will stick. Was only trying to change the fronts to 80hz, so it's not far off, but it's odd some folks are seeing only 40hz for their fronts and I am only seeing 90hz for my fronts.
jdsnov73 is offline
Audyssey , Denon , Marantz , multeq editor app
