MultEQ Editor: New App for Denon & Marantz AV Receivers & Pre/Pros - Page 146 - AVS Forum | Home Theater Discussions And Reviews
 2441Likes
post #4351 of 4719 Old 07-08-2019, 11:04 AM
Spidacat's Avatar
Quoted: 280 Post(s)
Liked: 379
Hopefully everyone who is experiencing problems is reporting them to the app developer and/or Denon. I know responses to earlier issues weren't treated with high priority, but the more feedback the better chance we all have for a working, stable app.
Spidacat is offline
post #4352 of 4719 Old 07-09-2019, 10:09 AM
Quoted: 129 Post(s)
Originally Posted by jdsnov73 View Post
I am getting the same issue, except my fronts will stay at 90hz. All other speakers I can change to whatever and it will stick. Was only trying to change the fronts to 80hz, so it's not far off, but it's odd some folks are seeing only 40hz for their fronts and I am only seeing 90hz for my fronts.
Can’t we just send it to the avr and then change the xo in the avr menu?
Totemtimer is offline
post #4353 of 4719 Old 07-09-2019, 10:48 AM
jdsnov73's Avatar
Quoted: 141 Post(s)
Liked: 46
I'm sure you can. I'm new to the app and Audyssey in general. I was just pointing out I was seeing the same issue. I never actually sent the modified file to the avr yet, but I will and I'm sure I can just change the crossover setting in the AVR.
jdsnov73 is offline
post #4354 of 4719 Old 07-09-2019, 02:06 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 625 Post(s)
Liked: 382
Yes you can.
I experienced crossover and distance setting and anomalies that resulted in some incorrect transpositions from the app to the AVP when using it several months ago, and I just made the appropriate adjustments in the AVP.
Mark
Sent from my iPhone using Tapatalk Pro
jdsnov73 likes this.
giomania is offline
post #4355 of 4719 Old 07-10-2019, 09:52 AM
rec head's Avatar
Quoted: 294 Post(s)
Liked: 259
And rate it in the app stores making mention of what is wrong.
Spidacat likes this.
rec head is offline
post #4356 of 4719 Old 07-10-2019, 06:41 PM
D Bone's Avatar
Quoted: 328 Post(s)
Liked: 452
What? They released a new version of this app with bugs??
Whowoodathunk
pappaduke likes this.
D Bone is offline
post #4357 of 4719 Old 07-16-2019, 07:41 AM
prerich's Avatar
Quoted: 122 Post(s)
Liked: 79
I'm enjoying the app myself. Here's a graph of my subwoofers.
prerich is offline
post #4358 of 4719 Old 07-20-2019, 05:38 AM
Dave-T's Avatar
Quoted: 1167 Post(s)
Liked: 561
Is there a way I can send the calibration I from my iPhone to my iPad so I can take advantage of the larger screen? I have the Audyessy MultEQ app on both devices.
Dave-t
Dave-T is offline
post #4359 of 4719 Old 07-20-2019, 11:15 AM
BluesDaddy56's Avatar
Quoted: 554 Post(s)
Liked: 776
Dave-t
Yes, you can save to Google Drive or whatever might be the Apple universe equivalent and, once you've installed the app on your iPad, just choose that as location from which to load a configuration file. Or, I supposed, you could locate where the ady file is saved on the iPhone (I'm sure that info is in this thread), and then email it to yourself and access that email on you iPad and save the file to the iPad.
Display: Vizio P55-E1l Pre-pro: Marantz 7703; Amps: Emotiva XPA-2 Gen 2, Emotiva XPA-3 Gen 1, H/K AVR 520 (direct in to amps); Sources: Sony UBP-X700; X-box 1 S; Technics 1200 Mk II; Win10 PC for digital; Phono Preamp: Emotiva XPS-1; Speakers - LR: Philharmonic BMR LR, Center: Emotiva Airmotiv C2; Surrounds: Wharfedale Reva-2; Rear Surrounds: Wharfedale Diamond 220; Atmos: TF - Monoprice Alpha 8; TR - BIC VI-38; Subwoofers: dual Rythmik L22s
BluesDaddy56 is offline
post #4360 of 4719 Old 07-20-2019, 12:23 PM
wh0f4rted's Avatar
Hmmmm just upgraded my receiver and I was thinking about getting this app. The reviews on the Play Store make it sound like a poor investment of $20....is that still the case? Reading through this thread is seems like it's worth it IF it works...others are saying it's completely worthless! Should I roll the dice?
wh0f4rted is offline
post #4361 of 4719 Old 07-20-2019, 01:32 PM
pbz06's Avatar
Quoted: 1034 Post(s)
Liked: 870
It had a rough start and I think most of those are old reviews. It's been flawless for me every time.
pbz06 is online now
post #4362 of 4719 Old 07-20-2019, 03:35 PM
OJ Bartley's Avatar
Quoted: 481 Post(s)
Liked: 575
Has it really improved significantly? Even most of what I've read on avs (historically at least) has mentioned long slow calibrations, frequently dropped connections, and difficulty connecting. I will get it anyway, but I'll be a lot happier if it's not a total bugfest.
Sent from my SM-A520W using Tapatalk
OJ Bartley is offline
post #4363 of 4719 Old 07-20-2019, 04:51 PM
petetherock's Avatar
Quoted: 1711 Post(s)
Liked: 894
It’s been ok. You need good Wifi coverage..that’s it
petetherock is offline
post #4364 of 4719 Old 07-20-2019, 05:21 PM
pbz06's Avatar
Liked: 870
I've run countless calibrations over the last year between moving and testing and tweaking. It's just as fast as running it through the AVR (except when you upload it it to avr and it takes an extra 45 seconds at the end, and an extra 10 seconds between each mic position).
Not sure about the connection drops, mine is solid wifi and I stay about 15' away from the avr.
pbz06 is online now
post #4365 of 4719 Old 07-20-2019, 05:41 PM
flyinion's Avatar
Quoted: 486 Post(s)
Liked: 333
No issues at all on my iPad. Most of the issues I've read seem to be with older devices fwiw.
Pansonic TC-P60VT60 | Denon AVR-X4500H | Sony UBP-X800 | Chane A2.4 L/C/R | Chane A1.4 SR | SVS Elevation Atmos/height | SVS PB-2000 | Logitech Harmony 950 | Arris MX011ANM (Xfinity X1) | Apple TV 4K
flyinion is online now
post #4366 of 4719 Old 07-20-2019, 09:59 PM
Sal1950's Avatar
Quoted: 502 Post(s)
Liked: 573
It has improved significantly but some do have issues. You need a device with at least 8 gig of RAM for it to run smoothly.
But the larger question for me is, do you really consider $20 to be an "investment"? That's the cost of a couple of burgers and fries for you and a friend, it's the waiters tip for a steak dinner. The Auro update for my Marantz 7703 was 10X that at $200.00. In the big picture of HiFi I'm sure you spend that or more on one pair of interconnect cables.I think you get my drift, that's a totally disposable amount of money.
Sony XBR75-X940D, Sony UBP-X800M2 UHD-BD, Xfinity X1 Voice DVR, Marantz AV-7703 Pre/Pro w/Auro, (3) Adcom GFA-545II amps, (2) Adcom GFA-535II amps for ATMOS speakers.
HSU Research 5.2 speaker system (4) HB-1 MK2, (1) HC-1 MK2, (2) STF-2,
Klipsch HT500 satellites (4) for ceiling mounted ATMOS playback
DIY Linux desktop w/Strawberry bit perfect media center. Emotiva Stealth DC-1 DAC
Sal1950 is offline
post #4367 of 4719 Old 07-21-2019, 03:19 PM
OJ Bartley's Avatar
Quoted: 481 Post(s)
Liked: 575
Awesome, that's great to hear. Thanks guys!
post #4368 of 4719 Old 07-21-2019, 04:12 PM
RickD1225's Avatar
Quoted: 295 Post(s)
Liked: 1045
I just downloaded the app to use when I install my new Canton Vento speakers. I got my 890.2 towers, waiting for the Vento 866.2 center to arrive Tuesday to run Audyssey. Have it defeated for now as I have installed the towers. Looking forward to using the app. I ran Audyssey a few times when I got my Marantz AVR. The best version was when I shut off virtually anything that made noise, removed ticking clocks, unplugged the fridge, turned off the central A/C, etc. That run turned out to be the best. I downloaded it to a thumb drive, just in case.
Spoiler!
RickD1225 is online now
post #4369 of 4719 Old 07-21-2019, 08:37 PM
Sal1950's Avatar
Quoted: 502 Post(s)
Liked: 573
Keeping background noise at a minimum is always the best plan.
rosstg likes this.
Sal1950 is offline
post #4370 of 4719 Old 07-21-2019, 10:48 PM
IMWhizzle's Avatar
Quoted: 929 Post(s)
Liked: 308
Am I the only one who notice that the sub ht calibration (dual subs) is not being done correctly? Every time I double check the results after calibration in REW, the subwoofer in the back needs a 9ft raise in the receiver for getting a flat bass response. Without this adjustment, the sub bass and the 40hz kick is lacking (full of dips).
Klipsch Reference Premiere: 4 x RP-280's, 1 x RP 450C and dual R-115W's
Marantz 7011 AVR
LG OLED B6
Apple TV 4K
PlayStation Pro
IMWhizzle is offline
post #4371 of 4719 Old 07-21-2019, 11:04 PM
Quoted: 91 Post(s)
I use the sub distance tweak with my dual subs. REW shows that adding distance to one of the subs (in my case around 2,5 feet is enough) smoothens the response quite nicely. Measurements are 8-point with Audy (20 inch apart) vs 1-point (mlp) with REW so there might be that difference though.
timosilakka is offline
post #4372 of 4719 Old 07-22-2019, 04:45 AM
Dave-T's Avatar
Liked: 561
Thank you for the help I was apple to use air drop on my iPhone Tovar’s iPad and it worked perfectly. As soon as I did the transfer I did get the bug that everybody is talking about, the fronts default to 40Hz.
Dave-T is offline
post #4373 of 4719 Old 07-22-2019, 04:59 AM
IMWhizzle's Avatar
Quoted: 929 Post(s)
Liked: 308
True, but I measured all three seats including the MLP with REW and adding 9ft resulted in the flattest response including the flattest on the MLP.
Marantz 7011 AVR
LG OLED B6
Apple TV 4K
PlayStation Pro
post #4374 of 4719 Old 07-22-2019, 05:04 AM
Quoted: 91 Post(s)
Ok. I also plan to use multipoint REW in my next calibration. Just waiting for the crossover bug to be fixed in the app...
post #4375 of 4719 Old 07-23-2019, 07:07 AM
Pip
Pip's Avatar
Quoted: 312 Post(s)
Liked: 143
“sub distance tweak”?
Pip
Pip is offline
post #4376 of 4719 Old 07-23-2019, 12:39 PM
batpig's Avatar
Quoted: 4793 Post(s)
Liked: 5038
In many cases, the distance set by the sub will result in a dip around the crossover due to the LCR speakers being out of phase with the sub at those frequencies. Shifting the distance (which really is delay) of the sub can bring things into phase. In some cases you may also need to tweak the crossovers, e.g. due to phase anomalies you might get smoother response with a 60Hz or 100Hz crossover vs. the typical 80Hz.
An example from a recent recalibration, this is one of the front speakers crossed over to the sub. The red line is the default distance set by Audyssey (11.9ft). The blue line is with the sub distance adjusted to 9.9ft. You can see at the default distance there is a big suckout between 75-100Hz. The small 2ft adjustment to the distance mostly corrects that (although still not perfect, there's a little dip centered around 75Hz) and there's a little dip all the way up at 150Hz which is improved as well.
rec head and OJ Bartley like this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #4377 of 4719 Old 07-23-2019, 01:02 PM
Pip
Pip's Avatar
Quoted: 312 Post(s)
Liked: 143
Originally Posted by batpig View Post
In many cases, the distance set by the sub will result in a dip around the crossover due to the LCR speakers being out of phase with the sub at those frequencies. Shifting the distance (which really is delay) of the sub can bring things into phase.......
The red line is the default distance set by Audyssey (11.9ft). The blue line is with the sub distance adjusted to 9.9ft........ The small 2ft adjustment to the distance mostly corrects that......
Thank you so much for this explanation. Is there a standard rule of thumb regarding a starting point, Or is it pure trial and error? With two subs, should you change the distances for both, or only one?
Pip
Pip is offline
post #4378 of 4719 Old 07-23-2019, 01:21 PM
batpig's Avatar
Liked: 5038
The starting point is going to be the calibrated distance. In some cases it will look fine as is and you're done. If you see a big dip around the crossover region, then you can try adding a few feet, subtracting a few feet, see in which direction the dip gets better vs worse. Once you see it improve, then tweak in smaller (1ft) increments to hone in on the distance that gives the flattest response in the crossover region. And, like I mentioned, in some cases tweaking the crossover frequency can clean up a problem that the distance tweak doesn't quite solve (e.g. in my case things look better with a 100Hz crossover vs an 80Hz crossover).
Since you are integrating the subs relative phase to the speakers, you want to change the global distance of all the subs together as a combined unit. The multiple subs should be aligned to each other and EQ'd first, and then once that's done all you're concerned with is the blend of that optimized multi-sub unit to the speakers at the transition point.
Setup Guide and FAQ
batpig is offline
post #4379 of 4719 Old 07-23-2019, 01:59 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 625 Post(s)
Liked: 382
Pip
In addition to what batpig wrote, the sub distance tweak step by step instructions have been incorporated into Austin Jerry’s REW 101 Guide, which is critical to using REW successfully for novices.
batpig likes this.
giomania is offline
post #4380 of 4719 Old 07-25-2019, 02:17 PM
pbz06's Avatar
Liked: 870
If I use the app to limit the correction frequency (300hz), it doesn't matter then what I do with MRC or Target Rolloff 1 or 2, right?
But I can then just engage CinemaEQ which will still work to lower high end?
pbz06 is online now
Audyssey , Denon , Marantz , multeq editor app
