Originally Posted by
Brucey
No offense taken! I just wasn’t sure what I was suppose to look for or how to read these graphs. I think I know what to look for now trying to get as close to 0db from 0-80hz, even if it’s not as smooth, While everything above that doesn’t matter as much.
Yes, the goal is to avoid (as much as possible) the crazy dips / nulls since you can't boost your way out of them. Big peaks can be brought down to flatten the overall response.
As an example, here's my graph with 2 subs up front. I have this big peak at 30Hz due to a room resonance, but all of the dips are 5dB or less in magnitude so easy for Audyssey to flatten out the response. Things get uglier above 120Hz but who cares? the sub doesn't play that high.
Brucey
I do have two subs. And the first graph was them in them in each of the 2 front corners. The second graph was them on each side of the tv away from walls and corners. I’ll keep tinkering. Thanks!
Hmm, if that's with 2 subs then they are not in phase with each other, you should be able to get a much better response than that.
The corner loading (1st graph) gives you maximum bass energy, but also energizes the room modes which is why you see such crazy swings from peak to dip. That said, if you get the phase nailed down having subs in different corners should provide a much smoother response if the 2 subs are balancing instead of combining to reinforce the same peaks/dips.
I would keep experimenting, but try flipping the phase 180 on one of the subs then re-run Audyssey and see how it looks. You might end up with a slightly flatter response. If the subs have variable phase knobs, you can experiment and try different settings (as a quick test just run Audyssey with the minimum 3 positions, even unplug the other speakers except Front L/R so it only takes a few minutes to measure the 2.1 setup in 3 positions). I bet you'll find a setting that fills that dip in.
