MultEQ Editor: New App for Denon & Marantz AV Receivers & Pre/Pros - Page 208 - AVS Forum | Home Theater Discussions And Reviews
 3581Likes
post #6211 of 6469 Old 05-15-2020, 01:42 PM
PG55's Avatar
Quoted: 268 Post(s)
Liked: 41
Originally Posted by PG55 View Post
If I go from DV off to DV light it raises my volume?
Audyssey Zen desk response to my to DV raises my volume:
From Audyssey Zen desk-Customer Support TeamFebruary 26, 2019 18:41
Hello,
Dynamic Volume can greatly increase the level of quiet content. It does this so that loud content is not as jarring.
When Dynamic Volume is turned off all the levels are as the content is made. With Dynamic Volume loudness is made to keep content from drastically changing.
It is normal.
LG-OLED 65C8PUA
Marantz-SR5012
Sony-UBP X-800, Roku Ultra 4K
Front L&R-Monitor Audio Silver 300's, Center-MA Silver C350, Surrounds-MA Silver FX
Sub Woofers-Paradigm Reference Millenia (2)
PG55 is offline
post #6212 of 6469 Old 05-16-2020, 02:59 AM
Quoted: 172 Post(s)
Liked: 99
Originally Posted by Fant View Post
Having a problem with the app on my x3600h ... A month ago I was able to use it fine. But now whenever I try to a calibration, it says starting test on the front left speaker and sits there for like 5-10 min and then I hear the test tone. Then the tone is on the one speaker for 5-10 minutes before it moves on.
The in reciever calibration works fine so I don't think it's the mic. The reciever is hardwired and I'm using the Android version if the app. I've also tried resetting the reciever to factory settings. Anyone seen this before?
Sent from my ONEPLUS A6013 using Tapatalk
Hello! Android user here, too! My phone is a Huawei P30 pro on Android 10, same behaviour, plus touching the "progress" (up on the right ) will end in multiple progress entries, messing up the calibration. Moreover, doing a cal with a slow wifi device that works for all the other aspects (Windows machine with MEMU android emulator), if I try to only send the cal to the Avr with that phone, transfer stalls. Resolved using Windows as said and an old phone with lower Android version ( maybe 7, didn't check it) to speed transfer to the AVR.
Hope this helps. How are you progressing?
Regards
Alessandro
Marantz Sr7011, Galactron Mk10b, Pioneer VsxLx50, Behringer NU3000dsp. Klipsch Cornwall, Wharfedale 9.1, Klipsch CP-6, 4xJblCS1214 in 2 double boxes, V.B.S.S. with Dayton PA460-8. Sony UbpX800, Lg Up970, Nvidia Shield ATV 2015, FireTv 4K, 2 Onkyio Dolby Surround ES600 pro, 2 Anleon MX200 Minimixer, Hisense 55M5500. 110 inches rolling screen, excelvan cl720d.
vn800art is offline
post #6213 of 6469 Old 05-16-2020, 06:21 PM
MagnoliaMOE's Avatar
Quoted: 30 Post(s)
Not sure where I should post this question. I posted on the Omnimic thread but no responses yet. I have an AV8805 and have setup using the MultEQ Audyssey app. I was trying to measure the bass response in the grenade scene on World War Z. At the 1:05:20 mark. I have a MartinLogan Balanced Force 212. Is this reading correct. Or is it even the correct way to measure using ominic. I got a peak of 15 Hz. Is it distortion that is resulting in this peak. BalancedForce is rated at 18 Hz +/- 3 db. Sorry if what I did is not the right way to measure. Welcome any feedback.
MagMo
Sony 65 A1E OLED, LG 55 B6 OLED, Oppo UDP-205, Marantz AV-8802A, Marantz MM8077, Marantz MM7055, PS3 (Fatty SACD), MartinLogan Theos, MartinLogan Motif-X, MartinLogan Montage, MartinLogan Descent-i, MartinLogan ElectroMotion FX2, MartinLogan Motion 2, MartinLogan Helos 12 (4 for Atmos).
MagnoliaMOE is offline
post #6214 of 6469 Old 05-17-2020, 12:08 AM
CBdicX's Avatar
Quoted: 1764 Post(s)
Liked: 431
Hi, my last visit here is 3 year ago
Never bought the app and now run a Denon X4500H.
Have 2 questions.
First I do the Audyssey run and it will sent the data to the app.
On this run, do I need to make adjustments in the app prior for the run, or is the first run "automatic" like the standard Audyssey run ?
In the app I can make a change like using the MRC or not.
When I make a change and like it, do I need to sent the data again to the receiver ?
I have a SVS app for my SB16, here I just make the change and its done.
Thx
CBdicX is offline
post #6215 of 6469 Old 05-17-2020, 12:15 AM
drh3b's Avatar
Quoted: 2456 Post(s)
Liked: 5467
Have 2 questions.
Thx
You do everything thing from the app. You do the Audyssey run from the app, and then make the changes in the app, and then upload to the x4500h. You can't use the Audyssey run from the x4500h.
Check out the first post, there should be a link to the FAQ there.
CBdicX and Jimmy2Shoes like this.
My Stuff.
Spoiler!
drh3b is offline
post #6216 of 6469 Old 05-17-2020, 04:59 AM
Kai Winters's Avatar
Quoted: 231 Post(s)
Liked: 315
Have 2 questions.
Thx
Yes you can...but I suggest you create a copy of your audyssey run...you do this within the app. Then you can make adjustments to the copy and send it to the avr. You can switch back and forth without having to edit the original run.
Your SVS settings have some similarities to the app...you can have several different schemes and easily switch back and forth to see what sounds better, etc. Or have a different setting for TV, Stereo, Movie use, etc. Again it is up to you. The SVS app works a bit faster but there is less for it to do.
CBdicX likes this.
TV: Sony XBR 65X950G, AVR: Marantz SR5014, Speakers: front/Paradigm Prestige 15B bookshelf, center/Paradigm Prestige 45C, surround/Paradigm Atom, sub/SVS SB3000, DVD: Panasonic DP-UB820P-K Disk Player, Media Player: Zidoo Z9S & Roku Streaming Stick +, Remote: Logitech Harmony Ultimate Home
Kai Winters is offline
post #6217 of 6469 Old 05-17-2020, 06:59 AM
Quoted: 172 Post(s)
Liked: 99
@CBdicX so quoting
Unquote
If you like what the SVS App has done most (and, in this regard, not owning those sw, I don't know if it works together with the other speakers and integrates the sw in there ) than you run the MultEq app without any restriction, make a copy of the cal as has been said, then load the copy and go to the MultEq frequency filter tab (cannot tell the exact English for that, sorry), choose Sw, slide the vertical limit from 250Hz to 20Hz, from right to left and save (never forget to always hit DONE at each step). So at all effects Audissey will not touch your Sw.
Hope this helps
Regards
Stay healthy
Alessandro
CBdicX likes this.
vn800art is offline
post #6218 of 6469 Old 05-17-2020, 10:20 AM
PoorSignal's Avatar
Quoted: 354 Post(s)
Liked: 88
I got a new phone and had to redownload the app. Is it possible to download what is on the denon to the app so I edit what is saved on there ?
PoorSignal is offline
post #6219 of 6469 Old 05-17-2020, 10:24 AM
MrKyle's Avatar
Quoted: 187 Post(s)
Liked: 98
I don’t believe so, I think the data is stored on your individual device used to run the calibration.
Living Room - XBR77A9G / X800M2 / X4500H / ATV4K
Klipsch RF-7 iii - RC-64 iii - 4x CDT 5650 II - 2x R-5800 W II
2x HSU VTF-15H Mk2 / miniDSP 2x4HD
Bedroom - 65VT30
MrKyle is offline
post #6220 of 6469 Old 05-17-2020, 10:48 AM
Quoted: 347 Post(s)
Liked: 343
Yes you can upload the calibrations via e-mail or google drive, then download them on the new phone
MrKyle likes this.
Jimmy2Shoes is offline
post #6221 of 6469 Old 05-17-2020, 10:57 AM
MrKyle's Avatar
Quoted: 187 Post(s)
Liked: 98
Ahh that’s right, Was trying to do something on my phone the other day and forgot about being able to upload/email from another device.
I read his question as downloading the current Audyssey settings from the AVR to the app, which I don’t think is possible?
Jimmy2Shoes likes this.
Bedroom - 65VT30
MrKyle is offline
post #6222 of 6469 Old 05-17-2020, 11:15 AM
Quoted: 347 Post(s)
Liked: 343
Well if you reset the AVR, the calibration file .audy will fill in all the Speaker setup and Audyssey calibration, but won't save things like HDMI settings and or AVR settings
galonzo and MrKyle like this.
post #6223 of 6469 Old 05-18-2020, 06:54 AM
MarkyM's Avatar
Quoted: 290 Post(s)
Liked: 251
IOS App Not Working With 2 Subs
Hi,
I just added a second sub and the (IOS) app (v1.4.8) doesn't seem to want to play nice with 2 subs.
My AVR is a Denon X3400H that has XT32 with the dual sub feature and everything is set properly. Yes, the closest sub is on Sub 1.
When the app goes through the sub check near the beginning of the process, the audio for the second sub starts late, just near the end of that part of the process so it may not see enough there, causing the following issues. I then do get the separate adjustment screens for the 2 subs to get their level into green area.
During the first measurement it seems to find them both but then the 2 subs are blinking together and from that point on, the chirps are heard only on Sub 2. It really seems quite confused.
Is there anything I can do?
--Mark--
LG OLED55C6P, Panasonic UB-820, Sony UBP-X800, Zidoo X9S, Denon AVR-X3400H, vintage Carver M1.0T amp, Axiom M60v3 Mains, VP100 Center & M2v3 Surrounds. Original SVS 20-39pci Cylinder sub. Polk RC60i Top Middle Atmos. Desktop system: Fully restored (by me) vintage Marantz 2275 stereo receiver from 1976 driving a pair of Chane A1.5s, RSL Speedwoofer 10S, MiniDSP DDRC-24 (Dirac Live).
MarkyM is offline
post #6224 of 6469 Old 05-18-2020, 10:38 AM
JohnnytheSkin's Avatar
Quoted: 131 Post(s)
Liked: 78
Is there a situation looking at the room correction graphs where MRC should be left enabled?
Sent from my Pixel 4 XL using Tapatalk
JohnnytheSkin is offline
post #6225 of 6469 Old 05-18-2020, 02:11 PM
RickD1225's Avatar
Quoted: 376 Post(s)
Liked: 3326
^^^^ yes, when it sounds better to you in your room with your setup.
Spoiler!
RickD1225 is offline
post #6226 of 6469 Old 05-18-2020, 02:42 PM
pbz06's Avatar
Quoted: 1595 Post(s)
Liked: 1384
I think it's more of a listening preference, as opposed to a graph. But if you measure and see that there's also a "dip" in your speaker's response at that same region, then maybe you will benefit to keep the MRC enabled (because "correcting" it may alter the natural response of the speaker). However, I don't think I would necessarily use the pre-cal graph from the App for that, and would rather use REW.
JohnnytheSkin, galonzo and rosstg like this.
Sony XBR-77A9G / Panasonic DP-UB9000 / Marantz SR7011 / SVS PB-4000 / Def Tech 9060 Series
pbz06 is offline
post #6227 of 6469 Old 05-18-2020, 02:58 PM
Quoted: 131 Post(s)
Liked: 78
Thanks! I kind of figured it's a preference thing, but the bipole Klipsch surrounds I have show a dip in that range roughly the same size. I've tried it both ways and honestly can't tell a difference which is why I was wondering if there was a right/wrong answer vs preference.
post #6228 of 6469 Old 05-18-2020, 03:00 PM
rec head's Avatar
Quoted: 392 Post(s)
Liked: 393
Originally Posted by MarkyM View Post
Hi,
--Mark--
It will only measure them separately the first time. After that they are pinged together.
galonzo likes this.
rec head is offline
post #6229 of 6469 Old 05-18-2020, 04:49 PM
MarkyM's Avatar
Quoted: 290 Post(s)
Liked: 251
Thanks, but when it does that, only one of them plays for the rest of the measurements. It's very strange and makes no sense. I went through to the finish and the distances were set to the same super high value (25.7 Ft.) and they sounded like crap.
I have used this same version of the app for months with 1 sub and everything is fine.
Is this a known bug? If not, I can't figure out what I'm doing wrong?
Has someone else successfully used the app with 2 subs on XT32 with the dual sub feature?
MarkyM is offline
post #6230 of 6469 Old 05-18-2020, 06:01 PM
sjm817's Avatar
Quoted: 925 Post(s)
Liked: 408
Did you try onboard avr cal and see if you have same issue?
sjm817 is offline
post #6231 of 6469 Old 05-18-2020, 07:48 PM
pbz06's Avatar
Liked: 1384
Yea, I've tried both and could never tell a difference anyway. I think since I watch/listen to mostly movies, it's harder to pick up a difference of a couple dB's at a specific frequency range when there's so much sonic information.
galonzo likes this.
pbz06 is offline
post #6232 of 6469 Old 05-19-2020, 05:11 AM
MarkyM's Avatar
Quoted: 290 Post(s)
Liked: 251
Not yet but good idea. Thanks.
MarkyM is offline
post #6233 of 6469 Old 05-19-2020, 07:21 AM
Lesmor's Avatar
Quoted: 857 Post(s)
Liked: 390
Yes and it works fine
Lesmor is offline
post #6234 of 6469 Old 05-19-2020, 04:01 PM
Sal1950's Avatar
Quoted: 623 Post(s)
Liked: 947
Looks like your already aware of the "closest sub" bug, other than that it works fine for my duals. Does sound like something is going wrong with the distance measurement unless they are 25.7 feet away? Did you get the sub levels set correctly so it falls in the softwares range of measurement?
Whats happening is when the subs are pinged individually they set the distance and levels at the MLP correctly. Then the two subs are mono'd and eq'd for a flat response at the MLP.
Sony XBR75-X940D, Samsung UBD-K8500, Xfinity X1 Voice DVR, Marantz AV-7703 Pre/Pro w/Auro, (3) Adcom GFA-545II amps, (2) Adcom GFA-535II amps for ATMOS speakers.
4 JBL HDI-3600 speakers, 1 HDI-4500 center channel & (2) HSU STF-2 subwoofers.
Klipsch HT500 satellites (4) for ceiling mounted ATMOS playback
DIY Linux desktop w/Strawberry bit perfect media center. Emotiva Stealth DC-1 DAC
Sal1950 is offline
post #6235 of 6469 Old 05-19-2020, 04:20 PM
pbz06's Avatar
Liked: 1384
I use the 2 sub outs (Marantz), one for each sub, and it works great for me. I am not familiar with the "closest sub" bug with the app since it appears to work as normal.
For troubleshooting purposes, did you try swapping the connections so what used to be Sub 1 is now Sub 2 (and vice versa)?
pbz06 is offline
post #6236 of 6469 Old 05-19-2020, 04:29 PM
Sal1950's Avatar
Quoted: 623 Post(s)
Liked: 947
I'm not sure if the bug actually exists any more, it was found by members here 2 or 3 years back and there have been many updates since then.
In any case you want to have the sub that is closest to the listeners chair plugged into Sub #1 , otherwise back then the measured distances would be computed wrong..
pbz06 likes this.
Sal1950 is offline
post #6237 of 6469 Old 05-19-2020, 04:32 PM
Lesmor's Avatar
Quoted: 857 Post(s)
Liked: 390
is there still a bug with dual subs?
watching the app at the start of a calibration there is no indication that the app pings one sub then the other
but it definitely does on the internal calibration
Lesmor is offline
post #6238 of 6469 Old 05-19-2020, 04:45 PM
Sal1950's Avatar
Quoted: 623 Post(s)
Liked: 947
I don't know for sure, it's too much work to reverse the connections, run the setup again and see if it's still there. And then do it all over again to fix it again if it is. LOL
Sal1950 is offline
post #6239 of 6469 Old 05-19-2020, 05:38 PM
sjm817's Avatar
Quoted: 925 Post(s)
Liked: 408
The closest sub was certainly a real bug. I had it. The closest sub had to be on sub1. Im fairly certain it was corrected in an update but could not say for certain. Doesnt hurt to just have closest sub connected to sub1 anyway. Another way to check is the distances in app or avr based cal should be the same.
sjm817 is offline
post #6240 of 6469 Old 05-20-2020, 01:22 AM
Quoted: 117 Post(s)
Liked: 62
Maybe I'm stating the obvious but the sub distances are not actual distances because the the time delay is diffent then the other speakers With 2 subs that time delay can be magnified. No? .
Rich 63 is offline
Audyssey , Denon , Marantz , multeq editor app
