MultEQ Editor: New App for Denon & Marantz AV Receivers & Pre/Pros - Page 26 - AVS Forum | Home Theater Discussions And Reviews
 2912Likes
post #751 of 5527 Old 05-28-2017, 07:32 PM
marco1975's Avatar
Quoted: 368 Post(s)
Liked: 266
Originally Posted by citsur86 View Post
Yes I have 2 Rythmik FV15HPs which go down to 12hz in single port mode which is what I use to EQ. So we will also be able to see, at least in my case, whether the app is rolling off under 20hz. I would be very surprised if that happened but we will see!
very good subs. i hope everything will work out fine for u.
good luck
marco1975 is offline
post #752 of 5527 Old 05-28-2017, 07:32 PM
d4g
d4g's Avatar
Quoted: 41 Post(s)
Liked: 33
Does it look ok.
d4g is offline
post #753 of 5527 Old 05-28-2017, 07:33 PM
d4g
d4g's Avatar
Quoted: 41 Post(s)
Liked: 33
Mind you I have 2 sub 15 but only using one hehhehe
d4g is offline
post #754 of 5527 Old 05-28-2017, 07:56 PM
marco1975's Avatar
Quoted: 368 Post(s)
Liked: 266
sound cool pal why not use them both?
sorry but that graph u have posted for the sub. dosn,t realy tell much , as thise is an averaging represantation of the response over the whole listenig arial, can,t u measure with something like Rew?
in any case i can,t see that u have any ugly peaks that u should worry about and it seems the kit is doing very good job
ahblaza likes this.
post #755 of 5527 Old 05-28-2017, 10:54 PM
Bass and Hi-Fi Enthusiast
citsur86's Avatar
Quoted: 1992 Post(s)
Liked: 987
After comparing Audyssey XT32 between the app and the AVR, here are my conclusions:
1. AVR Calibration resulted in much better dual subwoofer integration as is shown in my REW charts a bit down below.
2. Crossovers and Distances were set ever so slightly differently. Channel Volume was considerable.
3. My Subwoofer channel was not cut short at 20hz, it still extends down to 12Hz following Audyssey in both cases.
Here is my supporting work. I ran Audyssey first through my Marantz SR6011, then I ran sweeps with REW. Then I ran Audyssey through the MultEQ Editor App and followed that by running more sweeps. Sweeps were taken in MLP (Main Listening Position) and SLP (Secondary Listening Position) for both. Also note, in both cases, regardless of what Audyssey determined, I set Fronts, Centers, and Surrounds to 80Hz and left Front Heights and Rear Heights to what Audyssey set. I also made sure all speakers were set to small.
First let's take a look at Speaker Config between the two. App set Front and Center to Small while AVR set the to Large
Here is the AVR:
Here is the App:
Now the Distances between the two. Pretty close here
Here is the AVR:
Here is the App:
Now the Levels between the two. These were somewhat large differences.
Here is the AVR:
Here is the App:
Crossovers were not real high or different. No issue here for me.
Here is the AVR:
Here is the App:
Now to the measurements. First lets take a look at MLP Sub Frequency Response - Clearly the AVR wins here.
Here is the AVR:
Here is the App:
Now to the measurements. Next lets take a look at MLP Full Frequency Response - I tend to favor the app between these two.
Here is the AVR:
Here is the App:
Finally - for MLP - lets take a look the waterfall graphs - not too much different here - bad ringing from my room below 25Hz
Here is the AVR:
Here is the App:
I posted all these same measurements for SLP below as well if you want to take a look. Filenames are marked so you will know what you're looking at. Now to rerun AVR Audyssey once more. I'm going to hold off on using the app for now.
ID:	2160498   Click image for larger version
ID:	2160506   Click image for larger version
ID:	2160514   Click image for larger version
ID:	2160522   Click image for larger version
ID:	2160538   Click image for larger version
ID:	2160546   Click image for larger version
ID:	2160554   Click image for larger version
ID:	2160562   Click image for larger version
ID:	2160610   Click image for larger version
ID:	2160618   Click image for larger version
ID:	2160626   Click image for larger version
ID:	2160634   Click image for larger version
ID:	2160650   Click image for larger version
ID:	2160658   Click image for larger version
ID:	2160666   Click image for larger version
ID:	2160674   Click image for larger version
nathan_h, marco1975 and MarcusSwe like this.
| 7.2.4 Photos (Updated Photos 1/5) | Frequency Response | Visual: LG 65” B7A OLED | Elite VMAX-2 Electric 120" | Optoma GT1080 Proj |
| AVR/Amps: Marantz SR-6011 9C | Audio Source AMP-100VS | iNuke 1000DSP; TTs: 4x AuraSound Pro |
| Center: B&W CM Center 2 S2 Ed | Fronts: 2x B&W 684 S1s | Side Surrounds: 2x B&W 685 S1 |
| Front/Rear Heights: 4x Polk T15 | In-Ceiling: 2x Micca M-8C | Subs: 2x Rythmik FV15HP |
citsur86 is offline
post #756 of 5527 Old 05-29-2017, 12:36 AM
Marc Alexander's Avatar
Quoted: 5850 Post(s)
Liked: 5424
The issue is being looked into by D+M; however, appears to be more of an issue for some users much more so than others.
I think the issues are a bit more widespread than they may realize. Only a small fraction of users even have thr ability to check with a mic & software.
ahblaza and marco1975 like this.
Marc Alexander is online now
post #757 of 5527 Old 05-29-2017, 04:10 AM
jdsmoothie's Avatar
Quoted: 23177 Post(s)
Liked: 12711
Hard to say, although there are only a few posters in this thread who are reporting large crossover differences between the AVR and app, while some others like citsur86 are seeing only minor differences.
jdsmoothie is offline
post #758 of 5527 Old 05-29-2017, 04:47 AM
marco1975's Avatar
Quoted: 368 Post(s)
Liked: 266
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
thats somehow tell us that the rolloff is more of an issue then being intentionally included in Curve. which is i was also afraid of (another issue to be fixed) but we realy need some more tester and see more result.
but in any case i have to say Wow that the Audy. AVR. is doing much better job at Eqing your subs, more smoother response and integration! (that even bring the App. more into questioning)
Nice work my freind, thanks for sharing.
ahblaza likes this.
post #759 of 5527 Old 05-29-2017, 04:54 AM
marco1975's Avatar
Quoted: 368 Post(s)
Liked: 266
U are absolutely right on that my freind!
post #760 of 5527 Old 05-29-2017, 06:01 AM
marco1975's Avatar
Quoted: 368 Post(s)
Liked: 266
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
just wanted to say , that in the full Frq. resoposne test, the graph for the AVR. result it show the full range from 10hz-20K allright ,but in the App test. the graph for the result it only show from 10hz-300Hz , i think some how u had re-uploaded the App. subs Curve for the full frq. test against the AVR. full req. test could i please i ask u to post the full range result for the App. as well? so we can better compare them? Thanks
post #761 of 5527 Old 05-29-2017, 06:09 AM
citsur86's Avatar
Liked: 987
Whoops had the wrong link in there. Please disregard what it was before.
citsur86 is offline
post #762 of 5527 Old 05-29-2017, 11:23 AM
bmcn's Avatar
Quoted: 2302 Post(s)
Liked: 3221
...3. My Subwoofer channel was not cut short at 20hz, it still extends down to 12Hz following Audyssey in both cases...I'm going to hold off on using the app for now.
Nice work, thanks. To understand your thought process, the combined response of all speakers using the app looks slightly better than the AVR's, but you chose the AVR because its subs only response is much flatter than the app's? I've grappled with this and concluded the combined response was more important than sub(s) only.
bmcn is offline
post #763 of 5527 Old 05-29-2017, 11:28 AM
citsur86's Avatar
Liked: 987
Originally Posted by bmcn View Post
Nice work. To understand your thought process, the combined response of all speakers using the app looks slightly better than the AVR's, but you chose the AVR because its subs only response is much flatter than the app's? I've grappled with this and concluded the combined response was more important than sub(s) only.
I went back and forth on this last night for a while. I think that the app calibration is slightly better in some places and worse in others for the full response. Because of that, I ultimately chose to go with the AVR calibration. Also, the issues I'm hearing about with the app and the fact that its so new steers me away from it for the time being. I will redo the app calibration after each update the app or AVR gets and compare.
Another reason is that I've worked for almost a year with a UMIK-1 and miniDSP 2x4-HD to get my rooms gnarly issues under control - to little success. Seeing the sub response handled with Audyssey made me just have to choose it!
citsur86 is offline
post #764 of 5527 Old 05-29-2017, 11:35 AM
bmcn's Avatar
Liked: 3221
...Also, the issues I'm hearing about with the app and the fact that its so new steers me away from it for the time being...
Not quibbling, your measurements apparently disproved the much lamented LF rolloff "issue" which i think would improve your overall confidence level in the app.
Completely understand that.
bmcn is offline
post #765 of 5527 Old 05-29-2017, 11:37 AM
citsur86's Avatar
Liked: 987
Not quibbling; your measurements apparently disproved the much lamented rollover "issue" which i think would improve your overall confidence level in the app.
Understand that.
Yeah that is true. But the fact that they were different to such considerable degrees, especially the channel levels, has me wanting to hold off for a bit. I do think there are some bugs to iron out. And in the meantime, I'm very happy with the AVR Calibration I wound up with.
ahblaza and bmcn like this.
citsur86 is offline
post #766 of 5527 Old 05-29-2017, 12:06 PM
Liked: 5424
JD, most concerning to me is just how different the FRs of the AVR vs the App are measuring. I have faith the x-over issue will be resolved. I think the few users with measurement mics have to be vocal regarding the FR issue which ALL users may be suffering from.
post #767 of 5527 Old 05-29-2017, 12:07 PM
citsur86's Avatar
Liked: 987
How do I go about opening a ticket or otherwise reporting my findings?
citsur86 is offline
post #768 of 5527 Old 05-29-2017, 01:58 PM
jdsmoothie's Avatar
Liked: 12711
Given time ... I'm sure D+M will resolve the current issues.
ahblaza likes this.
post #769 of 5527 Old 05-29-2017, 03:29 PM
imureh's Avatar
Quoted: 3111 Post(s)
Liked: 4031
Think you open a case with Denon support.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #770 of 5527 Old 05-29-2017, 03:40 PM
citsur86's Avatar
Liked: 987
Submitted a case with a link to my comparison post in this thread.
nathan_h and ahblaza like this.
citsur86 is offline
post #771 of 5527 Old 05-29-2017, 03:46 PM
imureh's Avatar
Liked: 4031
Great. Hopefully when they see enough of these cases, they will do something about it.
post #772 of 5527 Old 05-29-2017, 04:20 PM
marco1975's Avatar
Quoted: 368 Post(s)
Liked: 266
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
Here is the AVR:
Here is the App:
if u don,t mind me asking , which curve did u use for measuring the AVR. full frq. response Falt or reference? was DynEQ On during the test for the AVR. ? i hope that if u can use the same smoothing amount for both graph for a better comparion. thanks
post #773 of 5527 Old 05-29-2017, 04:21 PM
citsur86's Avatar
Liked: 987
if u don,t mind me asking , which curve did u use for measuring the AVR. full frq. response ? was DynEQ On during the test ? i hope that if u can use the same smoothing amount for both graph for a better comparion. thanks
I used the Audyssey curve with Dynamic EQ on in both cases.
citsur86 is offline
post #774 of 5527 Old 05-29-2017, 04:44 PM
marco1975's Avatar
Quoted: 368 Post(s)
Liked: 266
ultimately u want this kind of test without any kind of fuzzy boosting such as dyneq/dynvol elc.
but to be honest with u , to me they look both close in the full frq. rang test, i guess the App. looks a bit nicer because the graph smoothing?
nice work thanks
post #775 of 5527 Old 05-29-2017, 04:50 PM
citsur86's Avatar
Liked: 987
nice work thanks
There probably is an audible difference between the two, but probably not a better or worse one. The sub frequencies were clearly better with the AVR Audyssey runs though.
I may play more this week and if I do, I'll turn off Dynamic EQ and Dynamic Volume before running my REW sweeps. But given it was on in both, it's probably fine. Apples to apples.
citsur86 is offline
post #776 of 5527 Old 05-29-2017, 05:17 PM
marco1975's Avatar
Quoted: 368 Post(s)
Liked: 266
Sure Absolutely fine! however the graph smoothing is very important to be identical. on both graph
post #777 of 5527 Old 05-30-2017, 12:13 AM
gurkey's Avatar
Quoted: 289 Post(s)
Liked: 181
nice work thanks
What do you mean by "fuzzy boosting" ?
DynamicEQ ist just a "not so simple loudness correction" function to compensate for the well known deficiencies of human hearing (known since early last century as Fletcher Munson correction algorithm) whilst DynamicVolume is a dynamic compressor mostly for late night listening and dialogue enhancement (no "boosting" at all).
gurkey is offline
post #778 of 5527 Old 05-30-2017, 02:57 AM
CBdicX's Avatar
Quoted: 1684 Post(s)
Liked: 402
"Save" to buy the app now ?
Hi, i am just interested to bump the mid freqencies like the "Denon Dialog Enhancement" option, is bumping the mid freq. in 3 steps.
Read some problems but looks like it all has to do with subwoofers, i do not use a subwoofer.......
CBdicX is offline
post #779 of 5527 Old 05-30-2017, 04:22 AM
marco1975's Avatar
Quoted: 368 Post(s)
Liked: 266
Sure. but it,s still called a (Boosting process) just more an advance and smarter way of doing it. and the fact its gonna allway add its own thing in the order to compensate, and which sounds mixer don,t have in mind when they mix a sound track for the movie.
But anyway this is realy another topic , and we don,t wanna start it here
post #780 of 5527 Old 05-30-2017, 04:58 AM
gurkey's Avatar
Quoted: 289 Post(s)
Liked: 181
No.
It compensates for hearing deficiencies of the human hearing at listening levels below 85 db (reference level), where most sound tracks are been mixed originally, thus resulting in a statistically perceived "linear" frequency response for the listener at lower (below reference level) listening levels.
Because it does this in correspondence with the listener adjusted actual listening level it is labelled as "dynamic".
Has really nothing to do with your interpretation of "boosting".
PS.: There is a difference in terms of measuring and listening: if you are listening to a sound track your probably will have DynamicEQ engaged, but if you are measuring the response of the system, you probably will need to switch DynamicEQ off, because your mike doesn't have that deficiency problem of human hearing. It records rather "linearly", never mind the frequency deviations of your individual mike.
gurkey is offline
Audyssey , Denon , Marantz , multeq editor app
