MultEQ Editor: New App for Denon & Marantz AV Receivers & Pre/Pros - Page 50 - AVS Forum | Home Theater Discussions And Reviews
 2543Likes
post #1471 of 4935 Old 10-02-2017, 06:56 PM
gregcss's Avatar
Quoted: 212 Post(s)
Liked: 62
Originally Posted by citsur86 View Post
Gotcha. I missed that, my fault. I guess seating area is around 6 feet. So the mic positions do in fact match the diagram. But (there’s always a bit), MLP is basically on one side, not the middle. So do I move the starting position to that side and go to middle of couch one way and past arm rest on the other?
Good question. My MLP is the right side of a two person couch. I put the mic 12-18" (give or take) away from that spot for positions 2-8 and dont care much about the other seat. But that's just me, let's see what others do.
gregcss is offline
post #1472 of 4935 Old 10-03-2017, 05:36 AM
jdsmoothie's Avatar
Quoted: 22557 Post(s)
Liked: 12277
Yup. MLP is where "YOU" set.
ahblaza and bmcn like this.
jdsmoothie is online now
post #1473 of 4935 Old 10-03-2017, 10:12 AM
Bass and Hi-Fi Enthusiast
citsur86's Avatar
Quoted: 1988 Post(s)
Liked: 973
Got it - so I will redo Audyssey one of these days with 8 positions starting at my MLP. So positions relative to couch will be middle of couch on one side to a foot or so past end of couch on other side. I'll try it with both app and AVR as well to see what I wind up with.
vn800art likes this.
| 7.2.4 Photos (Updated Photos 1/5) | Frequency Response | Visual: LG 65” B7A OLED | Elite VMAX-2 Electric 120" | Optoma GT1080 Proj |
| AVR/Amps: Marantz SR-6011 9C | Audio Source AMP-100VS | iNuke 1000DSP; TTs: 4x AuraSound Pro |
| Center: B&W CM Center 2 S2 Ed | Fronts: 2x B&W 684 S1s | Side Surrounds: 2x B&W 685 S1 |
| Front/Rear Heights: 4x Polk T15 | In-Ceiling: 2x Micca M-8C | Subs: 2x Rythmik FV15HP |
citsur86 is offline
post #1474 of 4935 Old 10-03-2017, 11:46 AM
jdsmoothie's Avatar
Liked: 12277
Keep in mind .. that some members find that keeping all mic positions within 6" - 1' of the first mic position works best for them.
post #1475 of 4935 Old 10-03-2017, 11:49 AM
citsur86's Avatar
Liked: 973
Got it - I will give that a try first then. If results aren't as good as I expect - I will try to go to a foot and a half or so.
citsur86 is offline
post #1476 of 4935 Old 10-03-2017, 02:20 PM
twinturboaudi's Avatar
Quoted: 94 Post(s)
Liked: 32
Is anyone using this app with the marantz 7012? Wondering how stable it is. Reviews haven't been that great with it.
twinturboaudi is offline
post #1477 of 4935 Old 10-03-2017, 02:32 PM
bmcn's Avatar
Quoted: 2212 Post(s)
Liked: 3112
Many negative reviews posted on this thread are from those unable or unwilling to follow either Audy's instructions or suggestions from other actual users.
krabapple, s44 and Falconsfan71 like this.
bmcn is offline
post #1478 of 4935 Old 10-03-2017, 02:57 PM
ahblaza's Avatar
Quoted: 2458 Post(s)
Liked: 3400
Would I benefit from this App with the measurements I just took of my Center + sub bass response graphs, I don't even have the 4300 installed yet or the App downloaded, these measurements were taken at various spots around the MLP, I use a tight Audy mic placement within 1' of first spot. Also I use all eight. I'd like to be able to add a custom low end bass response house curve with the App. Guys are saying it doesn't roll of the bottom end below 20Hz, I guess I could find out. Thanks.
Name:	ALL C+ SUB 80 Hz XO 5dB new.jpg
ID:	2292146   Click image for larger version
Name:	AVERAGE C+ SUB 80 Hz XO new.jpg
marco1975 likes this.
ahblaza is offline
post #1479 of 4935 Old 10-03-2017, 04:40 PM
gregcss's Avatar
Quoted: 212 Post(s)
Liked: 62
Is that reading 85.7db @ 5hz?
gregcss is offline
post #1480 of 4935 Old 10-03-2017, 05:25 PM
ahblaza's Avatar
Liked: 3400
Yes, I think a bit more, I've read 110dB at 6Hz till the mi8c ran out of headroom, I have to change the gain setting on the UMIK-1 so I can measure higher to do some compression sweeps. these are some random measurements when I was trying to find the best spot for a single sealed sub 7201. Not real good results but not bad with no EQ......at least out to 50Hz
Top graphs sub only, bottom Center +Sub
Name:	C+SUB BOTTOM SUB ONLY TOP.jpg
ahblaza is offline
post #1481 of 4935 Old 10-04-2017, 01:46 AM
marco1975's Avatar
Quoted: 319 Post(s)
Liked: 235
True -the App is still Unstable for many users, i been doing some testing many time on
my Marantz 7011+Rotel Rmb-1575 and untill now i find it to be unstable.
marco1975 is offline
post #1482 of 4935 Old 10-04-2017, 02:06 AM
marco1975's Avatar
Quoted: 319 Post(s)
Liked: 235
For the below 20HZ Roll-off, well -lets just say its a question of luck , as u could see from the differents result that has been posted, personally i have the 20HZ Roll-off issue.
But Keep in mind even if u don,t run into the 20HZ Roll-off issue ,it might be a problem for you to customize the low end bass below 20HZ, because i could see in your graph that your bass extend far below that , and if u are thinking about boosting below 20HZ, i think the App. has a limit boost that stops at 20HZ, well more like 25HZ i would say that is my experience with the App.
ahblaza likes this.
post #1483 of 4935 Old 10-04-2017, 04:47 AM
rec head's Avatar
Quoted: 296 Post(s)
Liked: 268
It probably depends on the phone/tablet too. I've mentioned it in the thread but making sure the app and AVR are up to date helps. The next thing is to do a network reset on the AVR. I have a Denon but I'm guessing the Marantz has the same feature. If you follow those steps ahead of time it should be pretty stable. The number of complaints has really fallen since the introduction of version 1.0 of the app. I actually returned the app the first time I bought it just to send the message to the developers that v1.0 was unstable garbage.
rec head is offline
post #1484 of 4935 Old 10-04-2017, 09:09 AM
marco1975's Avatar
Quoted: 319 Post(s)
Liked: 235
Getting the App. to run is one thing , but we still seeing conflicting results from the App. such as the crossover/roll-off/inconsistency and anomalies in the response elc.
still a good and stable software, should never force people to perform Network/AVR. Reset elc. everytime they want to use it. (that if it even works)
post #1485 of 4935 Old 10-04-2017, 01:26 PM
bmcn's Avatar
Liked: 3112
Originally Posted by rec head View Post
...I actually returned the app the first time I bought it just to send the message to the developers that v1.0 was unstable garbage.
...for you.
bmcn is offline
post #1486 of 4935 Old 10-04-2017, 01:32 PM
citsur86's Avatar
Liked: 973
Why would you perform a network/AVR reset each time? I’ve never done this. Is guidance to do so?
ahblaza likes this.
citsur86 is offline
post #1487 of 4935 Old 10-04-2017, 01:51 PM
marco1975's Avatar
Quoted: 319 Post(s)
Liked: 235
No not the guidance, but there has been many cases where the App. woudn,t connect or work properly unless the user perform a Network/AVR. reset.
personally i had to do that 4 times on 4 different occasions for no obvious reason.
but i just mentioned that in regard to the App. still being unstable for some.
post #1488 of 4935 Old 10-04-2017, 03:29 PM
rec head's Avatar
Quoted: 296 Post(s)
Liked: 268
I quoted who I was responding to. They asked if the app was stable even though what he was read was negative. jdsmoothie has been recommending it and it has helped me so I recommend it too. I have had the app fail enough times after doing 6-8 positions on a 7.2.4 configuration that it is worth <5 minutes to do the reset at the beginning. The network reset has helped me a lot with stability.
rec head is offline
post #1489 of 4935 Old 10-04-2017, 04:34 PM
ahblaza's Avatar
Liked: 3400
Could you give the quick answer how to do a network reset, too lazy to look it up, thanks.
ahblaza is offline
post #1490 of 4935 Old 10-05-2017, 06:17 AM
rlb
rlb's Avatar
Quoted: 2264 Post(s)
Liked: 1913
To prove a point, it took a little less than 2 minutes for me to find this in post 5 of the primary 2016 Denon thread:
Discrete network chip only reset (settings retained)
1 - With the AVR powered ON, select "Online Music" as the input source.
2 - Simultaneously press/hold the: S720W/S920W/X1300W/X2300W/X3300W - "TUNER PRESET CH + / TUNER PRESET CH -; X4300H/X6300H - "DIMMER+ ">" (right arrow)" buttons on the front panel
3 - Hold the buttons for a few seconds until the display reads "Network Restart" and then release the buttons. The process will take a few minutes.
Sony XBR75Z9D, Samsung 65F9000 , Yamaha CX-A5200 & Outlaw 770
Samsung K8500, OPPO 103-D, Genie 2 and C61Ks, Roku Ultra, ATV4K, and Harmony Elite
rlb is offline
post #1491 of 4935 Old 10-05-2017, 06:19 AM
marchewd's Avatar
Quoted: 38 Post(s)
For those doing the network reset every time, are you connected via wired or wireless?
Sent from my SM-G930V using Tapatalk
marchewd is offline
post #1492 of 4935 Old 10-05-2017, 12:54 PM
rec head's Avatar
Quoted: 296 Post(s)
Liked: 268
Wired. Everything else on my network is solid. Never tried wireless.
rec head is offline
post #1493 of 4935 Old 10-05-2017, 12:59 PM
marchewd's Avatar
Quoted: 38 Post(s)
I wonder if the upnp is causing the issue when you have to do a network reset. The reset would cause different ports to get opened up. I'm still finishing my room, so I haven't unboxed by new 7703 yet. I did buy the app to try out though.
marchewd is offline
post #1494 of 4935 Old 10-07-2017, 02:43 PM
banyar's Avatar
Quoted: 219 Post(s)
Liked: 88
hi guys.
can the denon s720w use this app?
banyar is offline
post #1495 of 4935 Old 10-07-2017, 03:04 PM
marco1975's Avatar
Quoted: 319 Post(s)
Liked: 235
Originally Posted by banyar View Post
hi guys.
Yes -The Denon AVR-S720W is ready, to use with MultiEQ Editor App
post #1496 of 4935 Old 10-07-2017, 05:20 PM
Quoted: 202 Post(s)
Liked: 109
Forgive me if this has already been covered, but how easy is it to adjust the target EQ curve? I never liked how bright Audyssey made my speakers (I have tried all the recommended fixes for this to no avail), so I would probably upgrade my receiver soon if I could properly tame the treble through the app.
Can you only adjust it graphically by dragging sliders? Is there a more repeatable way to enter in specific dB cut for a given frequency range? Does it apply it universally to all speakers, or can I do it for individual speakers/pairs?
Thank you!
bochoss is offline
post #1497 of 4935 Old 10-07-2017, 05:52 PM
bobknavs's Avatar
Quoted: 2328 Post(s)
Liked: 1657
hi guys.
Yes.
https://usa.denon.com/us/product/hom...ulteqeditorapp
bobknavs is offline
post #1498 of 4935 Old 10-07-2017, 06:56 PM
banyar's Avatar
Quoted: 219 Post(s)
Liked: 88
thank you guys...
banyar is offline
post #1499 of 4935 Old 10-08-2017, 05:11 AM
gregcss's Avatar
Quoted: 212 Post(s)
Liked: 62
Thank you!
This is not a direct answer to your questions, but I found that limiting the EQ up-to 500hz helped tame the brightness audyssey "added".
gregcss is offline
post #1500 of 4935 Old 10-08-2017, 05:52 AM
bmcn's Avatar
Liked: 3112
Thank you!
The sliders aren't too precise. As Greg mentioned, using the app to limit Audy's range to LFs is very effective.
bmcn is offline
Audyssey , Denon , Marantz , multeq editor app
