Yamaha RX-A3070 / A2070 / A1070 Aventage Owners' Thread - Page 164 - AVS Forum | Home Theater Discussions And Reviews
 16305Likes
post #4891 of 5010 Old 06-20-2019, 06:53 AM
lennyp's Avatar
Quoted: 83 Post(s)
Liked: 32
I just replace my plasma TV with a Sony A9F with eArc firmware update. I have it set up with eArc/Arc between the A9f and my 3070 (2.70 firmware) using a new 10' certified Monoprice 4k HDMI cable (suppose to support ethernet per description). All my external sources go into the 3070 to the TV. For sound to work using the TV apps I had to turn on CeC/Brava Sync. I didn't think it would be necessary, but so be it.
I am occasionally getting no sound when switching from using TV internal apps to using my external apps like cable box. In order to restore sound, it looks like I need to get the 3070 to recognize the change of sound source. One method was to bring up the 3070 menu (input) and simply exiting it. That usually toggles the sound back on. Also turning everything off and back on works as well. Not sure how to fix this or what is causing it to happen.
My AppleTV 4k reports my cable is ok for 4k/Dolby Vision.
Any thoughts on this? I am not sure how the eArc is suppose to work or if there are any bugs I am not aware of.
PSN: maleficent127
lennyp is online now
post #4892 of 5010 Old 06-20-2019, 07:42 AM
bwillcox's Avatar
Quoted: 896 Post(s)
Liked: 509
I confess that I can't be much help you. But I find CeC to be very hit-and-miss depending on your system and components. I've never gotten it to work on any of my systems and have consequently given up on using it (and consequently, ARC). I rarely use any TV apps, but when I do, I go with an optical S/PDIF cable for audio from the TV to my AVR. Of course this does limit what audio you can pass through.
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X800M2, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X800M2, Roku Ultra
bwillcox is online now
post #4893 of 5010 Old 06-20-2019, 08:02 AM
lennyp's Avatar
Quoted: 83 Post(s)
Liked: 32
Thank-you for your reply. I agree with you. I've avoided CeC and didn't think it was necessary with the Sony/Yamaha eArc combination. The apps on the TV are really good and updated being part of the Sony/Android TV environemnt and convenient to search, access and use. I have my PS4 Pro, AppleTV 4K and two DVRs, that the TV can't replace. If I can find the cause, maybe I can do something with my Harmony to "fix" it. It doesn't happen all the time, which makes it worse.
I might try another cable and unplugging everything and see if that clears anything up.
PSN: maleficent127
post #4894 of 5010 Old 06-20-2019, 02:45 PM
rlb
rlb's Avatar
Quoted: 2255 Post(s)
Liked: 1904
Originally Posted by purplerain View Post
The H24 I have was updated in Feb of this year
Like Horace Clark, prior poster, I have 2 C61Ks and the Genie 2. I've had them for a year, and have never had dropouts with DTV dolby digital. I also have the Z9D and a Yamaha. Prior to the current directv receivers, I had the HR24 and HR44; and never had an audio problem with them.
Personally, I would replace the HR24 with current technology; although, it's probably not the problem. Plus, I would start checking the signal path; from dish, dtv cables and connectors (they can go bad), the DTV receiver, and HDMI cables.
You should not have to go to PCM to get good audio.
Horace Clark likes this.
Sony XBR75Z9D, Samsung 65F9000 , Yamaha CX-A5200 & Outlaw 770
Samsung K8500, OPPO 103-D, Genie 2 and C61Ks, Roku Ultra, ATV4K, and Harmony Elite
rlb is offline
post #4895 of 5010 Old 06-20-2019, 02:55 PM
purplerain's Avatar
Quoted: 219 Post(s)
Liked: 89
This has been a known issue for several years (audio dropouts). All my cables are brand new and even tried other new certified cables. Connection is perfect and so is the RG6 cable
*ENTERTAINMENT PURPOSES ONLY*
*TV: Sony XBR65Z9D* - *BD Player: Pioneer UDP-LX 500* - *AVR: Yamaha RX-A3070* - *Audio System: (2) Funk Audio 6.1P’s towers - (2) Funk Audio 3.4D’s surrounds - (1) Funk 18.0C sub*
purplerain is offline
post #4896 of 5010 Old 06-21-2019, 01:18 PM
rlb
rlb's Avatar
Liked: 1904
In may be a known issue; but not with many users. From what I've read, those with the problem frequently have it resolved by changing from "native" to outputting 1080i (because it results in fewer handshakes).
However, back to the question on your original post. I just reset my dtv receiver to output pcm. Checked my Yamaha and I was receiving 2 channel pcm. On the same program I had been receiving DD 5.1.
Finally, it's obviously your decision; but as I've said, I would update to current technology.
rlb is offline
post #4897 of 5010 Old 06-22-2019, 07:15 AM
purplerain's Avatar
Quoted: 219 Post(s)
Liked: 89
I went into the H24 and disabled native and only checked 1080i...I'm waiting on a single speaker to test it out Monday. Thanks
post #4898 of 5010 Old 06-22-2019, 07:21 AM
bridge4d's Avatar
The Audio dropouts are a known issue in certain setups when Dolby Audio is enabled. It tends to be worse on certain channels for some reason. On my HR54 STARZ channels are unwatchable unless I turn off Dolby Audio. But the cables might also play into this. I've had handshake and HDMI switching issues the past few weeks I've been trying to diagnose. I get the handshake issues when changing channels on DTV. The audio tunes in/out and my samsung TV gives me the rotating "searching" ring. I've found that if I bring up the DTV guide or Menu it stabilizes and finally tunes in sometimes. When that doesn't work I have to change the channel or turn the receiver on/off. I bought a HDMI tester and found that I had a bad cable from the receiver to the Samsung TV. I also found that a couple of my Certified, enhanced, 4K, top 'o the line, blah, blah, blah HDMI cables were cheap trash and didn't have all the shielded pins and some had a weak signal.
Handshake issue taken care of, now if I could only get the HDMI switching fixed. Looks like it's going to have to be taken in for service.
purplerain likes this.
bridge4d is offline
post #4899 of 5010 Old 06-25-2019, 07:45 AM
Quoted: 109 Post(s)
Liked: 54
Originally Posted by Craig Mecak View Post
A mono audio source, when decoded by Dolby Surround, should only send a signal to the centre channel.
Other speakers like your surrounds and overheads should remain silent. Mono audio is perfectly in phase between channels, and once decoded, should be anchored to the centre channel.
A stereo signal source, on the other hand, has phase differences, which the Dolby Surround decoder will use to extract and send certain sounds to the other speakers.
I think you're overthinking things.
It turns out to be more complicated. Long story short, I'm keeping my mono mode--it beats Dolby Surround on some older movies. I'm not sure why, but some mono movies are in a stereo container, so to speak. Some of their soundtracks say mono in the Plex settings page, and some report stereo, although I don't think there has been any attempt to create a fake stereo image.
Using Dolby Surround on most mono movies, I'm getting sound in all speakers, although very, very faintly. It sounds better, and more natural in my mono mode with the surrounds and overheads turned off.
Not trying to argue, just following up.
Bill Wolfer is offline
post #4900 of 5010 Old 06-27-2019, 07:59 AM
purplerain's Avatar
Quoted: 219 Post(s)
Liked: 89
Question XLR connection
My subwoofer has 2 XLR connections only, can I connect one of these inputs into the 3070 XLR (I see there are only a left/right XLR)?
So far, I had to use an adapter (XLR to RCA) to connect my RCA cable to my XLR on the sub and the RCA end to the 3070
post #4901 of 5010 Old 06-27-2019, 08:41 AM
PioManiac's Avatar
Quoted: 3278 Post(s)
Liked: 8192
The RX-A3070 XLR connections are for Analog Stereo INPUT sources
Only the Sub-1 + Sub-2 pre-outs are used for Subwoofers.
If you want to use Both XLR inputs on your Funk Audio sub
Get a simple RCA Y-Splitter and another RCA>XLR adapter
(you will see a +6dB gain)
purplerain and junior00027 like this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #4902 of 5010 Old 06-27-2019, 09:05 AM
purplerain's Avatar
Quoted: 219 Post(s)
Liked: 89
Originally Posted by PioManiac View Post
The 3070 XLR connections are for Front L/R speakers only.
Only the Sub-1 + Sub-2 pre-outs are for Subwoofers.
Thank you Sir...
So what you are saying is: my present Canare LV-77S RCA sub cable that is connected to my 3070 sub 1 and the other end of the RCA is connected to the Neutrik NA2MPMF (3-Pole XLR male to RCA female adapter) adapter that goes into the Funk XLR. Get another Neutrik and plug that into my Funk #2 XLR. So I will have 2 Neutrik adpaters plugged into my Funk's XLR 1 and 2, then the Y splitter ends will be plugged into both of the Neutrik's, then I will have one single cable running from the other end of the Y splitter directly onto sub 1 on the 3070?
post #4903 of 5010 Old 06-27-2019, 09:13 AM
PioManiac's Avatar
Liked: 8192
Thank you Sir...
Correct!
RX-A3070 Sub-1 pre-out>RCA cable>Y-splitter> Two XLR Adapters>Funk Sub.
If you have an SPL meter, you will see a +6dB gain in output due to doubling of the input signal.
The RX-A3070 XLR connections are for Analog Stereo INPUT sources only, (not outputs)
(The new RX-A 3080 adds two XLR outs, but they are for Front L/R speakers only.
post #4904 of 5010 Old 06-27-2019, 01:25 PM
a5ian300zx's Avatar
Quoted: 610 Post(s)
Liked: 194
I tested a ruipro fibre hdmi cable on the yamaha rxa 3070 just kept getting constant single loss, flickering and snow flake effect when viewing 4k material.
Spoke to the retailer and he said that it could be related to the yamaha not sending enough power via the hdmi.
Is this true as I have not heard of that before, if so how do I adjust the settings?
Sent from my Samsung Note 9 using Tapatalk
TV: Sony 65" A1E OLED Surround: Yamaha RXA3070 + Orbs Audio Mod 4/2 7.1.2 + SVS SB12-NSD Stereo: Yamaha AS500 + Kef Q300 Processor: DVDO Iscan Mini + Darbee 5000S Players: Oppo UDP-203 / Dune Solo 4K / Apple TV 4K / VU+ Ultimo 4K NAS: Qnap TVS-871 Pro i7 10GBE
a5ian300zx is offline
post #4905 of 5010 Old 06-27-2019, 02:20 PM
rdgrimes's Avatar
Quoted: 3824 Post(s)
Liked: 3044
Typical retailer BS. The cable is simply not up to the task. You don't mention the length of the cable. But if the cable is not able to deliver 18Gbps steady over whatever length, you get exactly what you have described. Lengths over 20' are generally recommended for optical HDMI, and only optical.
OTOH, THESE are certified to 30'. Yours is optical but that doesn't mean its good enough. The world is full of expensive cables that claim to be more than they are.
a5ian300zx and junior00027 like this.
rdgrimes is online now
post #4906 of 5010 Old 06-27-2019, 02:21 PM
Glenee's Avatar
Quoted: 336 Post(s)
Liked: 358
I am running a Monoprice fiber HDMI 50 feet on a 3070 and no problems.
a5ian300zx likes this.
Nothing's Impossible if you don't have to do it yourself ! Glenee
Glenee is online now
post #4907 of 5010 Old 06-27-2019, 02:26 PM
a5ian300zx's Avatar
Quoted: 610 Post(s)
Liked: 194
It was 5m length of the below cable they meet all the criteria.
https://www.ruipro.com/shop/ruipro-hdmi-fiber-cable-6m/
I have returned them for a full refund and went back to the copper ones which I will buy longer length.
Thanks for the reply.
post #4908 of 5010 Old 06-27-2019, 02:35 PM
PioManiac's Avatar
Liked: 8192
Monoprice Premium Certified HDMI cables are Solid performers for 18Gbps up to 25 feet.
My Yamaha has no issues with 4K UHD/HDR 24P 4:4:4 12Bit to my OLED 6' (2.0m) and my JVC projecotor 25' (7.5m) at the same time...
post #4909 of 5010 Old 07-02-2019, 01:25 PM
purplerain's Avatar
Quoted: 219 Post(s)
Liked: 89
Question BD player with Zero Signal
Getting a new BD player (Pioneer LX500) and on the rear panel (LX500), there’s a socket labelled Zero Signal, which is designed to ground audio and video signals and help maintain signal quality as it passes through the player into your AV receiver. I was told: "Simply connect one end of a standard analogue interconnect to the Zero Signal socket on the player and attach the other to an analogue audio or video socket on the rear of your home cinema amp." Question is, where do I connect it on the 3070 and do I need to change any settings? Thank you
Also, is a standard analogue interconnect cable the same as Monolith's by Monoprice digital audio coaxial cable?
post #4910 of 5010 Old 07-02-2019, 01:35 PM
bwillcox's Avatar
Quoted: 896 Post(s)
Liked: 509
This sounds like simply an additional ground connection between the player and your AVR. I would expect that you could use a standard analog audio cable (with RCA plugs on each end, assuming that's what's on the player) and connect it to one of the unused analog inputs on your 3070.
post #4911 of 5010 Old 07-02-2019, 03:08 PM
purplerain's Avatar
Quoted: 219 Post(s)
Liked: 89
Does it matter which one? Thank you
post #4912 of 5010 Old 07-03-2019, 05:28 AM
bwillcox's Avatar
Quoted: 896 Post(s)
Liked: 509
I wouldn't think so, but I don't own one of the Pioneer players so I'm not sure what the connection on its end is like. I'd probably pick an unused input if it was me. BTW, have you asked this question on a forum thread for the player? Maybe someone there with actual experience can help.
post #4913 of 5010 Old 07-07-2019, 05:37 AM
Liked: 0
Yamaha RX-A2070 Bluetooth Headphone Remove
I can add one BT headphone to the system but can not remove it so I can add a different one. My assumption is you can only have one headphone paired at a time since I am unable to add a second one. I have tried almost everything I can think of but can not figure out how to delete it. Thanks in advance for any help!
Spyder14 is offline
post #4914 of 5010 Old 07-10-2019, 01:41 PM
Quoted: 107 Post(s)
Liked: 78
Question - I plan on buying a refurbished A2070 for around $800, which seems like a good deal compared to buying the A2080 new. Are there any important features I'd be missing going with a slightly older model?
sakete is offline
post #4915 of 5010 Old 07-10-2019, 03:44 PM
Deckard71's Avatar
Quoted: 371 Post(s)
Liked: 112
Important? No. Only Alexa, a more modern UI and the intelligent voice. 800$ is a steal
Displays: LG 65C7V - Optoma HD20 - Panasonic 50PZ80 - Samsung 32C650 - LG M2380D
Speakers: Focal Aria 948- Focal Aria 906 - Focal CC900 - BK XLS200 MK2 - B&W CCM362
Electronics: Roksan K3 - Yamaha RX-A2070 - Oppo 203 - PS4 Pro
Deckard71 is offline
post #4916 of 5010 Old 07-10-2019, 05:47 PM
Quoted: 107 Post(s)
Liked: 78
Thanks. How about YPAO, is that unchanged in the 80 range?
sakete is offline
post #4917 of 5010 Old 07-10-2019, 06:16 PM
PretzelFisch's Avatar
Quoted: 472 Post(s)
Liked: 289
Really your better off with the 2070 it has more features that the 2080 removed.
Chuck666 likes this.
PretzelFisch is offline
post #4918 of 5010 Old 07-11-2019, 05:35 AM
bwillcox's Avatar
Quoted: 896 Post(s)
Liked: 509
Can't say that I agree. I own and use both and find that I don't miss any features, that I ever use, on the 2080. I do, however, find that I use the Surround:AI on the 2080 often as it significantly enhances my ability to hear and understand dialog, esp when there's sound effects.
rlb likes this.
post #4919 of 5010 Old 07-11-2019, 05:58 AM
PioManiac's Avatar
Liked: 8192
I agree 100%
I was looking to upgrade my old 3050, but when the 3080 was announced I saw too many features disappear (that I used)
....scrambled to find one of the last remaining 3070's instead, and got it for $700 less than the new stripped down 3080.
My biggest issues were removal of 4 of the Scene settings (Down from 12 to 8)
The loss of the Front HDMI output (for a temp connection for REW, Go-Pro or cam corder)
You can no longer apply the Neural:X up-mixer on any Dolby encoded bitstream source.
The things added to the 3080 were of no use to me at all:
AI ...heard it, not impressed at all.
Extra HDMI out for third display, I only need 2 for an OLED and Projector
Two XLR Outputs (for Front L/R Speakers only)
Deckard71 likes this.
post #4920 of 5010 Old 07-11-2019, 06:26 AM
Quoted: 107 Post(s)
Liked: 78
I agree 100%
Thanks. I'll mainly be using it in a 2ch setup + sub, for music primarily, and sometimes for movies/tv. I may actually just go for the A1070 instead as that should provide plenty of power for the speakers I plan on purchasing (Revel F35 or F36, undecided still), and I can get the 1070 for $600. The price difference can then go to a sub.
PioManiac and ChromeJob like this.
sakete is offline
7.1 , atc smc11 , extend , firmware update , lg c8 , sony ubp-x800 , Yamaha , yamaha 3070 , yamaha a-s1100 , yamaha rx-a2070 , yamaha rx-a3070
