Yamaha RX-A3070 / A2070 / A1070 Aventage Owners' Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 16378Likes
post #31 of 5343 Old 05-30-2017, 09:24 AM
Hresna's Avatar
Quoted: 193 Post(s)
Liked: 139
Originally Posted by Hresna View Post
I've seen this said before - is it known for certain that Atmos decoding disregards the speaker positioning? Does the manual actually say this? It would be a real shame...
Yamaha and Dolby both confirm this.
Thanks, I was sure you'd have a source.
I wonder if we'll ever get fully object-based decoding specific to the position of the speakers... or is that what this Auro 3D and so on is supposed to deliver...
LG 65B7P
Yamaha Aventage A3060
Oppo UDP-203
PS4 Pro SSD
B&W 600 series 7.2.4 Atmos
Hresna is offline
post #32 of 5343 Old 05-30-2017, 09:47 AM
jdsmoothie's Avatar
Quoted: 24615 Post(s)
Liked: 13847
Nope. Auro 3D is channel based.
jdsmoothie is offline
post #33 of 5343 Old 05-30-2017, 06:26 PM
bwillcox's Avatar
Quoted: 1074 Post(s)
Liked: 635
Originally Posted by jsmiddleton4 View Post
"Unlikely that 64 bits adds to speed"
Sure it does. Can take a much bigger "word" all at once and therefore get to the end results way faster.
Nope, not in the world of computer science/engineering I've been working in for the past 50 years.
dvrraju and ChromeJob like this.
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X800M2, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X800M2, Roku Ultra
bwillcox is offline
post #34 of 5343 Old 05-30-2017, 07:32 PM
jsmiddleton4's Avatar
Quoted: 1038 Post(s)
Liked: 374
Been around since adding an NEC V20 sped up our first generation XT's myself. If a 64 bit processor is not able to perform the math calculations faster then someone is a very lousy programmer.
jsmiddleton4 is offline
post #35 of 5343 Old 05-30-2017, 07:34 PM
Liked: 374
post #36 of 5343 Old 05-31-2017, 05:22 AM
Hresna's Avatar
Quoted: 193 Post(s)
Liked: 139
64-bit processing
I have a computer engineering background, but I will caveat that I don’t work in the hifi industry. Without being overly technical, it is unlikely that the 64-bit DSP in this instance will be for speed.
Some applications of larger operands can increase computing efficiency by, say, working on “more data” at the same time, as was suggested by the increased word size. However, I do not think the algorithms for DSP would not lend themselves well for this.
The extra bits are almost surely used, at least in part, to create “headroom” in the manipulation of the data (in this case waveforms) to minimize distortions (like “rounding errors”). This is similar to how audio tracks are mastered in studio, using much greater bit-depth and sample rate than is available on the published track – not because the studio needs to hear “better quality” audio than they publish, but rather, that the mixing and mathematical algorithms applied to the digital audio needs this headroom in order to prevent information loss through application of the algorithms, etc. The final product can then safely be resampled at the target bit-depth and sample rate with no real loss of information or quality. The extra "bits" in this case really just amounts to adding "significant figures" to the numbers being crunched.
With most audio being at 16 or 24 bits, it is not evident that 64bit processing (over 32bit) would be substantially or even audibly better, but it certainly will not hurt.
bwillcox, madbrain and staplehead like this.
LG 65B7P
Oppo UDP-203
PS4 Pro SSD
Hresna is offline
post #37 of 5343 Old 05-31-2017, 07:39 AM
goonstopher's Avatar
Quoted: 335 Post(s)
Liked: 72
Balanced INPUTS and not OUTPUTS?!
Did I miss something or did they just day f-it and skip any market research/ user needs?!?
bombertodd likes this.
goonstopher is offline
post #38 of 5343 Old 05-31-2017, 08:24 AM
ChromeJob's Avatar
Quoted: 2250 Post(s)
Liked: 1175
I read on the Mediamonkey forum, in a discussion of advantageous ripping formats and settings, someone mentioned ripping FLAC at 48000 Hz sampling as the "extra bits" provide DSPs data to process with. I presume that means that DSPs wouldn't including their own data-doubling stage. Or maybe some do, and anything greater than 44100 Hz sampling bypasses it.
Not sure why I do it, as I hardly use Yamaha's Enhancer of lossless formats, and usually play in Straight mode.
I don't profess to know much beyond rudimentary basics of audio compression and processing, so apologies if I've munged something.
“Ever heard of the Sullivan Act?” “Oh that's all right, Detective, we're married.”
Are you new to the forum? => Please read forum FAQs and stickies. Like posts that help you. Respect our fine Moderators. And RTFM, always.
ChromeJob is offline
post #39 of 5343 Old 05-31-2017, 07:33 PM
kavanoz's Avatar
Quoted: 13 Post(s)
Bits and pieces of audio samples
I was trying to learn about SACD and it's DSD format and came across this article. There is another one on the same site for DSD.
http://www.mojo-audio.com/blog/the-24bit-delusion/
kavanoz is offline
post #40 of 5343 Old 06-05-2017, 01:13 PM
Eric Lebel's Avatar
Will it support the newly announced Airplay 2 ?
seffys likes this.
Eric Lebel is offline
post #41 of 5343 Old 06-07-2017, 06:05 AM
ay221's Avatar
Quoted: 25 Post(s)
If I have a 7.1 setup and I might add 2 upfiring speakers. My receiver is strictly for watching movies on blu-ray. Will there me much difference on the 3070 vs the 2070?
ay221 is offline
post #42 of 5343 Old 06-12-2017, 08:37 AM
Scarriere's Avatar
Quoted: 128 Post(s)
Liked: 74
I'm a bit sad that the 3070 won't have 13.1 processing. I was wanting x.x.6 and had hoped the new Aventage would have that.
No, I can't afford a Trinnov.
Scarriere is offline
post #43 of 5343 Old 06-12-2017, 09:30 AM
Hresna's Avatar
Quoted: 193 Post(s)
Liked: 139
Since you have a 7.1, you clearly value your surround sound. I, like you, contemplated the same upgrade recently (though I purchased a 3060 as my base, because of its other improvements in the 2016 line over the 2060). After messing with PSB XAs in my HT space, I realized what I always-needed-but-didn't-know-existed is actually 4 atmos speakers in the ceiling.
In all the threads it is vaunted that the difference between 7.1.2 and 7.1.4 is night and day, and I believe it. I'm cashing in the XAs to ceiling speakers (my ceiling is fiberglass tile so the XAs just didn't work and it is easy enough to install ceiling speakers).
I guess my point is, if you're like me, chances are you'd end up wishing you'd gone for 11 channel processing.
That said, if my XAs had worked properly, maybe I would have just stuck with .2 as the "modest, low-fuss middleground". Who knows, but this is my story.
ay221 and staplehead like this.
LG 65B7P
Oppo UDP-203
PS4 Pro SSD
Hresna is offline
post #44 of 5343 Old 06-12-2017, 04:34 PM
ay221's Avatar
Quoted: 25 Post(s)
I think I might go with the 3070 for the added flexibility. Hopefully nothing comes out in the next couple of years connection wise where an upgrade would be desired. But with 4k and 3d pass-through, I think I should be ok.
Hresna likes this.
ay221 is offline
post #45 of 5343 Old 06-13-2017, 11:16 AM
billmich's Avatar
Quoted: 399 Post(s)
Liked: 81
I have a 3010, cant wait to upgrade to this
has anyone seen what are the differences between this model and the 3060
what was added, what was deleted, what was tweaked?
EDIT: Looks like they dropped a component input , as well as the component and composite outputs for this year,
dropped front composite input
billmich is offline
post #46 of 5343 Old 06-15-2017, 08:54 PM
wernd's Avatar
Quoted: 14 Post(s)
Pulled the trigger on this beast last night from Crutchfield. It's been painful the last few months not having a receiver that can handle 4k, currently running an A3040 so mostly just a video upgrade I guess. It would be nice if the new ESS chips made a difference but I doubt that they will
wernd is offline
post #47 of 5343 Old 06-16-2017, 04:01 AM
LeoB's Avatar
You are absolutely right, and it is audibly better!
I went through several Aventage receivers before buying RX-A3060 and could not use any equalization in the upper-mid frequency range because of an audible distortion those filters would introduce. None of this problem with 3060 and 64-bit processing.
LeoB is offline
post #48 of 5343 Old 06-16-2017, 05:00 AM
Hresna's Avatar
Quoted: 193 Post(s)
Liked: 139
I think this makes you the first actual "owner" in the thread - which model did you get, 3070? It's not available here in Canada til August. Let us know what you think...
LG 65B7P
Oppo UDP-203
PS4 Pro SSD
Hresna is offline
post #49 of 5343 Old 06-16-2017, 07:47 AM
bwillcox's Avatar
Liked: 635
I've got one "on order" (well, reserved) at a local store here in Austin, Tx as well. They are currently expecting to get some in the first or second week in July. I'm replacing my 3050 (for DV support, mainly).
bwillcox is offline
post #50 of 5343 Old 06-17-2017, 12:19 AM
jdsmoothie's Avatar
Liked: 13847
It won't be released in the USA until July rather only pre-orders can be taken at this time.
post #51 of 5343 Old 06-17-2017, 09:47 AM
dllhg's Avatar
Quoted: 132 Post(s)
Liked: 25
So is there any real noticeable "upgrade" with the 3070 over the 3060 ? Only $200 more retail but you can find the 3060 for as little as $1500 open box. Fry's lists the 3070 at $1999.
Im ready to pull trigger on new AVR for my new HT room I am finishing. I dont want to wait unless there is something really worth waiting for.....
HT #1 Yamaha AVENTAGE 1080 /Dalite 133 built in ceiling / Ben Q W1500 / SVS PB1000 Sub / Bose (LOL I know)
HT#2 Seaton Catalyst 12C L/C/R / JVC RS4500 / Yamaha 3070 / DYI 160 inch wall screen.
65 in Panasonic Plasma in bedroom
dllhg is offline
post #52 of 5343 Old 06-17-2017, 11:22 AM
jdsmoothie's Avatar
Liked: 13847
Again .. considering the A3070 hasn't even been released (July), no way to tell if there is any noticeable audio quality difference.
However, no difference in price from when the A3060 was first released.
post #53 of 5343 Old 06-17-2017, 02:50 PM
dllhg's Avatar
Quoted: 132 Post(s)
Liked: 25
I guess I should ask if there is any real feature upgrades to this unit ? I saw they have two XLR inputs but not for speakers like one of the Marantz I was looking at had.
dllhg is offline
post #54 of 5343 Old 06-17-2017, 06:43 PM
Hresna's Avatar
Quoted: 193 Post(s)
Liked: 139
Dolby Vision out of the box. 3060 won't get it til "late in the year"
ChromeJob likes this.
LG 65B7P
Oppo UDP-203
PS4 Pro SSD
Hresna is offline
post #55 of 5343 Old 06-18-2017, 12:14 AM
jdsmoothie's Avatar
Liked: 13847
Better quality 32bit DACs as well as 32bit DACs now on the Presence channels as well. Also, the XLR inputs are for sources not speakers.
post #56 of 5343 Old 06-18-2017, 07:45 PM
PhantomDriver's Avatar
Hmmm - that doesn't appear to be so. Note that the first post by wse and the Yamaha 3070 info site both have a caveat on DV:
4K Ultra HD Full Support
Darker blacks, whiter whites, and more vivid colors. This AV receiver completely supports with latest HDMI® standards. Thanks to transmission of 4K video at 60 frames per second pass-through, you can fully enjoy the high definition video quality of 4K without degradation. It also adheres to the HDCP 2.2 copyright protection standard for 4K video transmission. It also supports HDR (High Dynamic Range) Video including Dolby Vision and Hybrid Log-Gamma which provides incredible contrast, smooth tone and rich, bright colors. Furthermore it supports the wider color gamut of BT.2020 pass-through. This AV receiver is also compatible with 3D, Audio Return Channel and CEC for easy operation. *Dolby Vision and Hybrid Log-Gamma will be available via future firmware update.
PhantomDriver is offline
post #57 of 5343 Old 06-19-2017, 04:49 AM
Hresna's Avatar
Quoted: 193 Post(s)
Liked: 139
Originally Posted by PhantomDriver View Post
Hmmm - that doesn't appear to be so. Note that the first post by wse and the Yamaha 3070 info site both have a caveat on DV: <snip>
Ah, then I stand corrected. I don't regret at all, then, springing for the 3060 when they came down in price a month ago. Didn't want to wait until August.
The 3070s may get additional firmware updates in their life that the 2016s wouldn't. One Yamaha rep claimed (to my dealer) the 3070 would support eARC though this couldn't be corroboroated from any of the literature or other dealers. It seems quite plausible it could be enabled in firmware since the manufacturers would have known how it was going to be implemented in the HDMI 2.1 spec. Actual full HDMI 2.1 support would likely require new hardware.
PhantomDriver likes this.
LG 65B7P
Oppo UDP-203
PS4 Pro SSD
Hresna is offline
post #58 of 5343 Old 06-19-2017, 07:21 AM
jdsmoothie's Avatar
Liked: 13847
Yamaha has released an early shipment of the A3070 units so may start to see some reviews here soon.
Tom Bley likes this.
post #59 of 5343 Old 06-20-2017, 10:08 AM
CortlandApple13's Avatar
Liked: 0
Does anyone know online retailers with the RX-A3070 in stock now?
Victor
CortlandApple13 is offline
post #60 of 5343 Old 06-20-2017, 10:35 AM
jdsmoothie's Avatar
Liked: 13847
Victor
I can PM you if interested.
7.1 , amplifer , atc smc11 , extend , firmware update , Klipsch , lg c8 , pre amp , rx-v1000 , sony ubp-x800 , Svs , Yamaha , yamaha 3070 , yamaha a-s1100 , yamaha rx-a2070 , yamaha rx-a3070
