*Official* Marantz 2017 NR1508/1608, SR5012/6012/7012 owner's thread - Page 117 - AVS Forum | Home Theater Discussions And Reviews
 4073Likes
post #3481 of 4785 Old 01-05-2019, 04:16 PM
Liked: 0
Have you tried using one of the Audyssey Dynamic Volume settings (light, medium, heavy)?
Refer to post 3 of this thread and do each of the procedures for "Resetting the NR1608" stopping at the first one that resolves the issue. If still no joy, then warranty repair.
Hi JD,
Thanks for the advice. It seems, having checked my settings I must have fiddled with the Audyssey some time ago. I have Multi EQ set to Reference, Dynamic EQ set to On and Dynamic Volume set to Medium - please see attached photo...
If I don't want the AVR to make any adjustments at all, what should I have the EQ setting set to? OFF I guess?
I'll wait for your response first, adjust where necessary before trying the resets.
Thanks again
Rich
Richris is offline
post #3482 of 4785 Old 01-05-2019, 04:32 PM
rocky1's Avatar
Quoted: 454 Post(s)
Liked: 125
The unplugging/replugging worked like a charm.Connected..Checked for update and its telling me I'm up to date with latest firmware which is 5461-9131-8331-1184 ?
burts likes this.
Sony XBR65A1E,(Pioneer 500m relocated), AppleTv 4K,Marantz sr7012, System Audio Loudspeakers( sa1750 mains), ML Grotto.
Eastern Electric Minimax cd, Oppo UDP-203, Toshiba HD, Pro Ject 1expression Carbon TT.
rocky1 is online now
post #3483 of 4785 Old 01-05-2019, 08:47 PM
burts's Avatar
Quoted: 102 Post(s)
Liked: 29
Well thank you for that, I have been waiting for weeks for someone to answer me and post those numbers up
Hell I should forward you the emails with marantz support so they can put you through the ringer too, they claim we are not on the latest update
Anyhow I did the reset which made me do audyssey again, I set my surround heights as rear heights this time made a big differance
burts is offline
post #3484 of 4785 Old 01-06-2019, 06:01 AM
Liked: 0
Red face
Hi JD,
Thanks for the steer and advice. I now understand (a little more) about Dynamic EQ and Dynamic Volume re: variations in audio levels between adverts (commercials ) etc so have reset these to zero and off whilst maintaining the Audyssey at Reference. When I get the Bronze 6s and Surrounds I'll default the whole system noting these variations.
Thanks again. Really appreciate your help - no longer frustrated! https://www.avsforum.com/forum/image...face_smile.png
Rich
Richris is offline
post #3485 of 4785 Old 01-06-2019, 07:31 AM
jdsmoothie's Avatar
Quoted: 22581 Post(s)
Liked: 12288
Originally Posted by Richris View Post
Hi JD,
Rich
Indeed. Helps to understand the difference between the two technologies.
jdsmoothie is offline
post #3486 of 4785 Old 01-06-2019, 03:53 PM
Mike25690's Avatar
Location: Calumet, Michigan, in the U.P.'s Keweenaw Peninsul
Quoted: 12 Post(s)
Hello--I'm looking for some connection help; my SR-7012 is currently powering a 5.1 system, but I am bi-amping my front towers, so I'm in the 7.1 (bi-amp) mode. I want to add one pair of PSB Imagine XA Dolby Atmos-Enabled speakers to the system, which will sit on top of my front towers.
Looking in the manual (and this thread, which I've searched) I haven't found the proper settings/connections to do this. I want to keep the front towers bi-amped; those speakers are now connected to the Front R & L terminals, and the Height 2 R & L terminals, as shown in the manual. I'm thinking I can connect the new PSBs to the Height 1 R & L terminals, but what will I change the amp assign mode to, in order to correctly hear an Atmos soundtrack, and so that Audyssey will do a correct calibration?
Thanks in advance for any help anyone can provide.
"I will drag you, kicking and screaming if I have to, into the modern world!" -- Peter the Great
Samsung Q9FN(65"), Marantz SR-7012, Emotiva XPA-3 Gen 3, Pioneer LX-500, Def Tech BP2000,
CS9040, SR9080, SVS PB-13 Ultra, PSB Imagine XA, Panamax M5300
Mike25690 is offline
post #3487 of 4785 Old 01-06-2019, 04:31 PM
Mike25690's Avatar
Quoted: 12 Post(s)
I may have partially answered my own question; apparently I cannot bi-amp my front towers if I want to add front Atmos-enabled speakers. I am now guessing that I will run a single full range connection to my front towers, connect the PSB Atmos speakers to the Height 1 terminals on the AVR, and choose the '7.1 + Front B' amp assign mode; I can then choose a 5 channel floor layout, and select Dolby Front 2 channel from the Height menu. Does this sound like the correct way to do this, and will Audyssey recognize this kind of setup? (I don't have the PSBs yet to try them out). Thanks again for any help.
post #3488 of 4785 Old 01-06-2019, 05:15 PM
jdsmoothie's Avatar
Liked: 12288
Skip the bi-amp which isn't likely to add any benefit and simply go with the factory default setting of "7.1 + Zone 2".
post #3489 of 4785 Old 01-06-2019, 07:13 PM
Mike25690's Avatar
Quoted: 12 Post(s)
Thanks for the response; just to clarify, with the Amp Assign mode on 7.1 + Zone 2, I then see
floor layout = 5 channel; and in the Height section, I should choose Dolby Speakers, 2 channels, and Front Dolby under Height/Layout. Then, looking at the terminal configuration, it is showing the Atmos speakers connected to the Front Height terminals; I will not actually be using Zone 2. Does this sound correct?
Thanks again for the help.
post #3490 of 4785 Old 01-07-2019, 04:57 AM
jdsmoothie's Avatar
Liked: 12288
Yes.
post #3491 of 4785 Old 01-07-2019, 07:54 AM
Quoted: 4474 Post(s)
Liked: 5487
I'm seeing some interesting behavior that i'm curious if someone can explain. I have 7012 and noticing on some old STB content and also from Netflix, built in TV App when the menus are playing, the 7012 display will show Dolby Digital + but it sounds like Dolby Surround is coming out of the speakers. Specifically, i'm getting sound from all 7 speakers but the center seems to be very low. Almost like the old surround where you could increase the center spread. With Netflix, for example, once the movie starts, then the sound if perfect. I get the same issue from my cable box when watching old 1960- 70's movies. On my 7009, when I had it, it would switch to Dolby Surround when the signal changed and the center was normal volume.
I know this is difficult to explain, but does anyone know what i'm talking about? Are there any work arounds?
I have a Verizon FiOS STB, Marantz 7012, Dolby Atmos setup. (LF +C + RF) (LR + RR) (TL + TR) and a sub.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is offline
post #3492 of 4785 Old 01-07-2019, 09:27 AM
Quoted: 48 Post(s)
I am having a problem with my Marantz 5012. For the last week or so, the AirPlay function is not working. I like to stream music from my phone to the AVR. It has worked flawlessly up until now. The AVR is on my WIFI and I've tried resetting my modem. But nothing seems to work. The AVR will connect to my phone and the Airplay information will appear, but after about 5 seconds it disconnects. The AVR shows the latest firmware is installed.
Any suggestions on how to resolve this?
marantz545 is offline
post #3493 of 4785 Old 01-07-2019, 09:28 AM
fireman325's Avatar
Quoted: 47 Post(s)
Liked: 49
I need a bit of guidance. I have an SR6012 and I'm currently running mains, center, surrounds, and top mids. I'm thinking of adding front heights. According to the manual, the top mids and front heights both utilize the same speaker connections on the back of the AVR. Is it possible to add front height channels to my existing setup, and if so which speaker terminals would I plug them into on the AVR?
Steve
fireman325 is offline
post #3494 of 4785 Old 01-07-2019, 09:40 AM
scotttnz's Avatar
Quoted: 25 Post(s)
Liked: 42
The manual says to hook them up like this:
fireman325 likes this.
My Lounge System
TV: Samsung 82” NU8000|Sources: AppleTV 4K, Panasonic DP-UB420|Receiver: Marantz SR6012 5.1.4
Speakers: Wharfedale Diamond 8.3 fronts, Wharfedale Diamond 8 centre, AudioPro C5 rears,
4x Polk V60 in-ceiling, Polk HTS12 Sub
scotttnz is offline
post #3495 of 4785 Old 01-07-2019, 09:47 AM
fireman325's Avatar
Quoted: 47 Post(s)
Liked: 49
Attachment 2507240
I completely missed that in the manual. Thank you.
scotttnz likes this.
Steve
post #3496 of 4785 Old 01-07-2019, 10:19 AM
burts's Avatar
Quoted: 102 Post(s)
Liked: 29
Can anyone else post the latest firmware number from usa
Support still claims we are not on the latest
burts is offline
post #3497 of 4785 Old 01-07-2019, 10:34 AM
jdsmoothie's Avatar
Liked: 12288
Try doing a Network Reset on the AVR (p. 240 Owner's manual).
post #3498 of 4785 Old 01-07-2019, 10:53 AM
MagnumX's Avatar
Quoted: 1144 Post(s)
Liked: 663
Have you tried unplugging and replugging the 5012? (soft reset)
Have you verified the actual surround mode with the surround selection buttons or INFO button? In other words, DD+ is a carrier format, not a surround mode. You can have Dolby Surround enabled with DD+ or even Neural X or something else. I've noticed the 7012 is a bit strange sometimes once you change a mode for a given format as it will try to remember your last choice and this somehow changes other formats sometimes as well (I keep my default stored on a smart select button for this reason so I can easily switch back to the default mode with Auto-select based on format when I want it).
Click THEATER (Updated: May-22-2019) for pics: Epson 3100 3D Projector, DaLite 92" screen, 11.1.6 (Marantz SR7012 + Yamaha HTR-5960 + Onkyo ESPro) - Dialog Lift - PSB T45/B15/S50/X1T/CS500 Speakers & Def Tech PF-1500 15" sub; 2nd Room (Updated Apr-22-2019): 48" Plasma TV, Carver AL-III, Carver C-5 Pre-Amp, Technics SH-AC500D, Dual Carver TFM-35x Amps (Active Bi-Amp), Klipsch Surrounds ; Sources: PS4, LG UP875 UHD, Nvidia Shield (KODI), ATV4K, Zidoo X9S, LD, GameCube : Props (Updated 10-13-19)
MagnumX is online now
post #3499 of 4785 Old 01-07-2019, 11:27 AM
Liked: 5487
Yes. I also did a factory reset. It's strange because I looked in the 7012 online manual and it clearly shows the center spread audio option but when I go into the menus, it's not there. I'm guessing they updated the menu's but not the manuals? Also, anyone have the latest firmware version so I can double check what's on my unit.
John
John
jrref is offline
post #3500 of 4785 Old 01-07-2019, 12:33 PM
jdsmoothie's Avatar
Liked: 12288
John
<Center Spread> can only be enabled when using Dolby Surround on a stereo 2.0 source.
post #3501 of 4785 Old 01-07-2019, 02:26 PM
Liked: 5487
JD thanks.
So I factory reset the unit, made sure I had the latest firmware and re-ran Audyssey and it's better but tell me, i'm not going to see Center Spread in the menu unless I have a stereo 2.0 source?
John
jrref is offline
post #3502 of 4785 Old 01-07-2019, 03:05 PM
jdsmoothie's Avatar
Liked: 12288
JD thanks.
No, I made it up.
jrref likes this.
post #3503 of 4785 Old 01-07-2019, 06:04 PM
Liked: 0
I got a new crown xli1500 amp on sale for $199 and want to use it to power 2 additional front speakers. My current setup is 5.2 in my main zone then I have 2 outdoor speakers connected to my height #2 speakers for zone 2. Anyone familiar with adding an additional amp to your 7012 that has some pointers? Thanks!
Dutchcrunchster is offline
post #3504 of 4785 Old 01-07-2019, 06:04 PM
thadius65's Avatar
Quoted: 55 Post(s)
Liked: 24
Marantz SR7012 and Paradigms for Atmos Setup
Hello,
I have some really good paradigm monitors I am using for traditional 5.1 surround (Monitor 11 v3, Montior 5 v3, CC-370 v3 center and PS-1000 sub. I am getting a Marantz 7012 to upgrade to atmos and looking at in-ceiling to provide a 5.1.4. I have access to a good deal on (4) new in box Paradigm AMS-150SQ-SM v3 speakers. Specs are here:
https://www.paradigm.com/en/in-ceili...s/ams-150sq-sm
Could I please get some input as if these would be a suitable match? I wanted to do a 7.1.2, but i have no room on the sides of the seating areas.
Let me know what you think.
Ted
thadius65 is offline
post #3505 of 4785 Old 01-07-2019, 10:35 PM
da Choge's Avatar
No Audio Out with 2 HDMIs between Marantz and Oppo
Don't know if this has been a reported issue before. I have an OPPO UDP-205 and I tried using both the OPPO's HDMI (Audio Only) Out to the DVD HDMI input on the Marantz SR7012 while at the same time using the OPPO's HDMI (Video/Audio) Main Out to the Blu-Ray HDMI input on the Marantz. I wanted to use the HDMI (Audio Only) output of the OPPO (which is supposed to have a better jitter reduction circuit than the Main HDMI output) for music streaming from my Roon ROCK server. When I had both of them plugged in at the same time, it muted the audio (but not the video) output of the Blu-ray player when trying to play video discs. If I unplugged the HDMI cord [leading from the Oppo HDMI (Audio Only) Out to the Marantz DVD HDMI In] from the back of the Marantz, the sound returned. I know all the outputs on the OPPO are active all the time, but I didn't think there would be a muting interference when having both the Oppo HDMI Outs hooked up to different Marantz Source In's (and, of course, having only one Marantz source selected). Is this an expected behavior or am I doing something wrong? [This post may be more appropriate in the OPPO forum thread, as this could be a limitation of the OPPO]
- john
BDP-83 EAP (second group)
da Choge is offline
post #3506 of 4785 Old 01-08-2019, 04:04 AM
jdsmoothie's Avatar
Liked: 12288
- john
Easy enough to test by simply connecting the MAIN output on the Oppo to the TV to see if the same issue presents.
da Choge likes this.
post #3507 of 4785 Old 01-08-2019, 06:53 PM
PG55's Avatar
Quoted: 195 Post(s)
Liked: 35
I am just getting around to setting up my Sony X800 Blu Ray. I have run Audyssey in the Cable mode and have set Multi EQ XT on, Dynamic EQ off and Dynamic volume set to light.
I noticed that when I changed the input to Blu Ray and started the disc the Multi EQ XT, dynamic EQ and Dynamic volume are all set to off? Do I need to run Audyssey for each HDMI input or room correction is still good from previous Audyssey calibration and it is just these items need to be adjusted. This doesn't happen when I switch form the Cable input to TV Audio?
PG55
LG-OLED 65C8PUA
Marantz-SR5012
Sony-UBP X-800, Roku Ultra 4K
Front L&R-Monitor Audio Silver 300's, Center-MA Silver C350, Surrounds-MA Silver FX
Sub Woofers-Paradigm Reference Millenia (2)
PG55 is offline
post #3508 of 4785 Old 01-08-2019, 08:39 PM
da Choge's Avatar
Thanks JD for the response. So you're implying that if this test does work with the OPPO, then my problem is a Marantz incompatibility? I will test for that, but I almost don't need to; I'm pretty sure it will work the way you've suggested.
The dual HDMI output of the OPPO was primarily designed to work that way -- if you don't have a HDMI 2.0 compliant AVR but you do have a 4K HDMI 2.0 TV (or even a 3D TV), the Audio only from the OPPO is designed to go into your legacy AVR while the Main HDMI output (audio + video) is designed to hook up with your 4K (or 3D) TV, thus bypassing your non-compliant legacy AVR. In fact, I had my behemoth (weight-wise) older Onkyo AVR hooked up that way with the OPPO before I replaced it with the Marantz SR7012. However, for my present use (audio streaming from a music server), I want to use the Audio Only HDMI out from my OPPO to go into the Marantz at the same time the OPPO Main HDMI output is hooked-up with the Marantz (used as two different sources, of course) - that's when I get the "No audio output at all" problem I've run into. I will do some more experimenting, however, and check back.
- john
da Choge is offline
post #3509 of 4785 Old 01-09-2019, 06:20 AM
Liked: 1
- john
It is by design in Oppo UDP-205 to reduce any possible circuit noise. Using HDMI Audio Only will deactivate the audio in the OPPO Main HDMI. Like you and jdsmothie mentioned, you could connect the Marantz to your TV so you could have both audio. That's the way I've done it
jcbarreto is offline
post #3510 of 4785 Old 01-09-2019, 11:04 AM
da Choge's Avatar
This is what I was suspecting and I will probably end-up setting the system up this way and preserving the specialized OPPO HDMI Audio Only output to my AVR in order to get the best quality audio feed for music streaming, disc playback, and cable TV viewing. Was hoping to use only one HDMI input to the TV, so I wouldn't have to switch inputs if I wanted to use the Marantz setup screen/functions, but its not a big deal in order to achieve the best audio feed. Thanks for your input, JC.
- john
da Choge is offline
atmos , auro3d , bridging channels , clipping , dts:x , issue , Marantz , marantz sr 6012 , marantz sr7012 , sr7012
