*Official* Marantz 2017 NR1508/1608, SR5012/6012/7012 owner's thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 4122Likes
post #61 of 5232 Old 07-05-2017, 07:20 PM
Perpendicular's Avatar
Quoted: 307 Post(s)
Liked: 148
Originally Posted by g12345567 View Post
Does the USB on the new 2017 range support larger NTFS format derives or they still stuck with older FAT32 / 4gb maximum partition size?
As noted in the NR1508/NR1608 Owner's manuals, still limited to 2TB using FAT32.
This would be a frustration to me if I had to rely on the AVR to play files and didn't want to, or could not, convert my 2tb hard drives from NTFS to FAT32 without first purchasing replacement drives to convert existing drives.
JD? Without looking through a bunch of manuals, are all the Marantz and Denon models set up this way? I'd use flash drives if they were bigger and cheaper.
Perpendicular is offline
post #62 of 5232 Old 07-06-2017, 03:02 AM
jdsmoothie's Avatar
Quoted: 24162 Post(s)
Liked: 13352
Yes.
jdsmoothie is offline
post #63 of 5232 Old 07-08-2017, 10:11 AM
tomhorsley's Avatar
Quoted: 259 Post(s)
Liked: 218
Are there any hands on reviews of the 1608 yet? I know it claims to support all the latest HDCP and HDMI standards and Atmos, Dolby Vision, etc, but I'd really like to read about at least one example of someone actually using one of these successfully without all the incessant problems with handshaking, passthrough, and wot-not that I seem to read about everywhere cropping up with random different pieces of equipment not interoperating correctly. I've got an Oppo UDP-203 player and an LG OLED55B6P TV, and if I get a new receiver, I would like to be able to run everything through the receiver (instead of the setup I have now with split video/audio from the Oppo). The 1608 certainly looks good to me. The form factor would be convenient, and I'm not a big fan of earth shattering, window rattling sound so 50 watts per channel is plenty for me. But I'd just like to read about some real use before buying one.
tomhorsley is offline
post #64 of 5232 Old 07-15-2017, 02:52 AM
jdsmoothie's Avatar
Liked: 13352
Here's some good info regarding the Test Tone volume levels used by AVR EQ programs (eg. Audyssey) with some of my own edits to clarify the scales used specifically on Denon/Marantz AVRs/AVPs:
Originally Posted by Roger Dressler View Post
When calibrated, the 0db volume setting (on -78db to + 18db scale or "80" on 1-98 scale) means it is playing back at cinema reference level. Not only is that crazy loud, it is perceived as being even louder in a home setting, so it would be quite unnecessary to run the system at 0db. I happen to use -10db to -15db and that's plenty loud for movies. I use -20db to -30db for music. That's just me. You can decide what's right for you.
Those SPL figures, 85db and 105 dB, are related. 85 dB is the SPL produced by a signal recorded -20 dBFS (20 dB below full scale) in one channel. Full scale is 0 dBFS, or 20 dB above that, so 85+20=105 dB SPL, which is the peak SPL from any one of the main channels. Subwoofers are calibrated 10 dB higher than that to 115db.
85 dB is the calibration level for the signals used in cinemas (-20 dBFS), and it is quite loud. Too loud and disturbing when used at home, so the level of the test signal was reduced 10 dB (-30 dBFS), thus it plays at 75 dB SPL to attain the same calibration. The noise level generated in AV receivers/processors is intended for 75 dB, and there are many test discs which do the same (e.g., Spears & Munsil Part II, or any disc with THX calibration signals), but beware, some discs do not adhere to that standard.
post #65 of 5232 Old 07-16-2017, 05:13 PM
Quoted: 57 Post(s)
I see that Best Buy has the SR6011 on clearance (selling for $1119 - still not low enough for me). Hopefully this means the SR6012 will be announced soon (I want to pick up the SR6011 but hopefully for under 1K).
-D
DeepAction is offline
post #66 of 5232 Old 07-17-2017, 02:20 AM
jdsmoothie's Avatar
Liked: 13352
-D
August. However, with the SR6012 MSRP increasing $100 over the SR6011 MSRP, I would be surprised to see the clearance price to go much lower.
post #67 of 5232 Old 07-17-2017, 06:24 PM
Quoted: 33 Post(s)
Liked: 4
-D
I was at Best Buy today and saw the SR6011 priced at retail. I told the salesman I was hoping that since the 6012 was out that the 6011 would be on sale at a good price. He said that would happen in March. I assume he was just making that up.
Steam King is offline
post #68 of 5232 Old 07-17-2017, 07:38 PM
gondey99's Avatar
Quoted: 116 Post(s)
Liked: 42
-D
Try calling http://www.safeandsoundhq.com/ I got a good deal on the 5012
gondey99 is offline
post #69 of 5232 Old 07-17-2017, 11:42 PM
jdsmoothie's Avatar
Liked: 13352
The SR5012 is just now being released. The SR6012 won't be released until August.
post #70 of 5232 Old 07-18-2017, 06:49 AM
Transfix's Avatar
Quoted: 92 Post(s)
Liked: 29
Hey JD has there been anymore news on the differences in the 7011 vs 7012? or just 11 vs 12 all together?
When in Doubt...Go Flatout!
Transfix is offline
post #71 of 5232 Old 07-18-2017, 07:52 AM
jdsmoothie's Avatar
Liked: 13352
Other than the new features I have listed in post 1 of the 2017 Denon AVR Owner's thread, the specs of the SR7012 should be released sometime next month.
Transfix likes this.
post #72 of 5232 Old 07-20-2017, 03:16 PM
tomiy1's Avatar
Quoted: 57 Post(s)
Liked: 26
The SR5012 seems to be on Amazon already... kinda funny it's not on the Marantz website yet...
https://www.amazon.com/dp/B072ZJ9SRM...=1W496OPKXW2RT
tomiy1 is offline
post #73 of 5232 Old 07-20-2017, 04:09 PM
Quoted: 57 Post(s)
The SR6012 is also listed as being in stock on Amazon (but sold by a marketplace seller). This model is not supposed to be out until next month.
Edit: B&H also shows the SR6012 in stock now. Hope that is true because I have been waiting to grab the SR6011 on clearance ...
-D
post #74 of 5232 Old 07-20-2017, 06:05 PM
Quoted: 307 Post(s)
Liked: 148
I don't think Marantz's Web Guru updates their site very often. They still list the SR7011 as New on the US Website.
post #75 of 5232 Old 07-20-2017, 11:40 PM
jdsmoothie's Avatar
Liked: 13352
Not uncommon for dealers to get the new models a week before the Denon/Marantz web pages get updated; however, if you drill down a little deeper you'll note that none of the dealers listed show it available until July 26 which is when we expect our first shipment as well.
post #76 of 5232 Old 07-21-2017, 06:27 AM
Quoted: 112 Post(s)
Liked: 52
Interesting the Sr5012 is a hundred bucks more than the SR5011
dave2002ti is offline
post #77 of 5232 Old 07-21-2017, 09:52 AM
jdsmoothie's Avatar
Liked: 13352
Correct. The MSRP on the 2017 Marantz models are all at least $50 - $100 more than the 2016 models.
post #78 of 5232 Old 07-22-2017, 09:29 AM
riv359's Avatar
I found this pic of the Marantz SR8012 receiver, it also states having 192 kHz / 32-bit AK4458 DAC.
Name:	Marantz SR8012 inside_1500740834878.jpg
riv359 is offline
post #79 of 5232 Old 07-22-2017, 09:32 AM
riv359's Avatar
This is the link, it's in French.
http://www.avcesar.com/actu/id-22220...-dtsx-112.html
riv359 is offline
post #80 of 5232 Old 07-22-2017, 02:35 PM
PTV Programmer's Avatar
Quoted: 522 Post(s)
Liked: 145
Is the 1608 capable of Dolby Vision out fo the box or is it waiting for a firmware update?
PTV Programmer is offline
post #81 of 5232 Old 07-22-2017, 05:42 PM
jdsmoothie's Avatar
Liked: 13352
Out of the box.
post #82 of 5232 Old 07-23-2017, 03:46 AM
Liked: 0
Considering the 6011 can be had for round $1K now is the 6012 worth the $500 premium?
nyxagamemnon is offline
post #83 of 5232 Old 07-23-2017, 04:44 AM
Quoted: 57 Post(s)
So the SR-6011 is finally down to $999. I was hoping it would go lower (since the Denon X4300H with higher MSRP sold for $749/$799 at Frys. Either way is HEOS the only major difference in the SR-6012 (with MSRP of $1499) ? The specs for this new model don't seem to be out even with it showing up as being in stock at several online stores.
-D
post #84 of 5232 Old 07-23-2017, 08:38 AM
jdsmoothie's Avatar
Liked: 13352
-D
HEOS module and upgraded to same 32bit DAC used in the SR7011 as well as Dolby Vision on board.
post #85 of 5232 Old 07-23-2017, 12:30 PM
Quoted: 33 Post(s)
Liked: 4
How big a deal is 32 bit DAC? Would a newbie like me hear a difference in sound compared to the sr6011? Seems like I read that it wouldn't. Maybe depends on source?
post #86 of 5232 Old 07-23-2017, 02:29 PM
jdsmoothie's Avatar
Liked: 13352
If your budget supports the SR6011 ... then get that.
post #87 of 5232 Old 07-23-2017, 06:34 PM
Liked: 0
Regarding the 6011 vs 6012 I'd the new 32 bit dac and new amp circuit worth the $500?
The 6012 apparently has some new amp circuit in play as well.
post #88 of 5232 Old 07-23-2017, 10:32 PM
g12345567's Avatar
Correct me if I'm wrong.
From what I've read since vTuner internet radio has been replaced by TuneIn you can no longer add favourite internet radio stations to the Marantz.
I read to add custom radio stations on the new Heos enabled Marantz and Denon receivers you need to create a TunIn account on there web site. From there you can organise and add favourite internet radio stations. Then use the Heos phone/tablet app to access the stations setup in your TunIn.com account on your receiver.
g12345567 is offline
post #89 of 5232 Old 07-24-2017, 01:24 AM
jdsmoothie's Avatar
Liked: 13352
AFAIK, you as a user cannot add the radio station, rather the radio station itself must request to be added.
post #90 of 5232 Old 07-24-2017, 10:44 AM
Selden Ball's Avatar
Quoted: 4819 Post(s)
Liked: 2865
Don't forget HEOS. The external stand-alone HEOS box is about $400 on its own.
Selden
Selden Ball is offline
airplay , airplay problems , atmos , auro3d , bridging channels , clipping , distortion , dts:x , hdmi arc , issue , Marantz , marantz sr 6012 , marantz sr7012 , receivers , sr7012 , temperature
