*Official* Marantz 2017 NR1508/1608, SR5012/6012/7012 owner's thread - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 4078Likes
post #1441 of 4834 Old 05-20-2018, 05:36 PM
Quoted: 108 Post(s)
Liked: 50
Originally Posted by Dennis L. View Post
Thanks for the suggestions. I have a Denon 4308CI in my den and a lot of the menu options are familiar with the Marantz. I'm using the Marantz to drive a passive soundbar under my OLED LG TV. The Denon is way too big and I came across the Marantz when I searched for a short receiver. I could not believe the features. I had tried two different powered soundbars (Martin Logan Cadence and Vision X) and had problems that were not solvable. And then the price dropped a lot. Sold !!!
I'm only going to have a 3.1 setup initially (I want to hear what Virtual:X sounds like. running wires for surrounds is probably either a very difficult day-long project or I get wireless speakers ($$$). I saw in the manual there was no option for 3.1 -- I presume the Audyssey set up will accept that.
My biggest fear was if the amps had enough oomph.
I'm sure you will find the amps to be powerful enough... It's a real surprise how much power this thing actually has...It weighs 18+ pounds! So big power supply.
Not sure about the various configurations allowed. I'm running a 2.1 setup so I really don't know. But I rmemeber seeing Audyssey has many configs to choose from so hopefully your needs will be covered.
Come back and let us know how you like the 1608 after you get it all set up.
rlwings is offline
post #1442 of 4834 Old 05-20-2018, 06:09 PM
Transfix's Avatar
Quoted: 92 Post(s)
Liked: 29
Can anyone shed some light as to why my on screen menu is no longer showing transparent? Not it has a solid background. I didn't change any of the video settings recently. The only thing I did was do a MultiEq calibration.
Thanks !
When in Doubt...Go Flatout!
Transfix is offline
post #1443 of 4834 Old 05-20-2018, 06:12 PM
Quoted: 108 Post(s)
Liked: 50
Thanks !
The transparent effect only happens up to 4K 30P resolution... if you turned on enhanced or increased your monitor HZ say to 60P, than transparency goes away.
rlwings is offline
post #1444 of 4834 Old 05-20-2018, 06:28 PM
Transfix's Avatar
Quoted: 92 Post(s)
Liked: 29
My settings are exactly the same as before and it worked before the calibration.
Transfix is offline
post #1445 of 4834 Old 05-20-2018, 06:33 PM
Quoted: 108 Post(s)
Liked: 50
Then maybe a cold boot of all devices will work... Otherwise if nothing changes nothing changes...Unless something changed.
rlwings is offline
post #1446 of 4834 Old 05-20-2018, 06:52 PM
Transfix's Avatar
Quoted: 92 Post(s)
Liked: 29
Wink
A cold boot = unplugging the power for a bit and then a restart or is there another method?
Transfix is offline
post #1447 of 4834 Old 05-20-2018, 06:54 PM
Quoted: 108 Post(s)
Liked: 50
That'll work... incl. the tv....plug back turn on and wait 10 minutes...especially for smart tv to boot back up.
rlwings is offline
post #1448 of 4834 Old 05-20-2018, 07:42 PM
Transfix's Avatar
Quoted: 92 Post(s)
Liked: 29
Thanks bud!
One last question. Is it recommended to have Video Conversion and I/P Scaler on ?
Transfix is offline
post #1449 of 4834 Old 05-20-2018, 08:04 PM
Quoted: 108 Post(s)
Liked: 50
Thanks bud!
Video Conversion should be on...And I\P scalier usually off if your tv does a good job doing the upscalling, like name-brand 4K tvs like Sony, Samsung, lg, etc. You can try both to see which picture looks better. But it's not causing your problem.
rlwings is offline
post #1450 of 4834 Old 05-21-2018, 06:31 AM
jdsmoothie's Avatar
Quoted: 22734 Post(s)
Liked: 12381
Thanks bud!
<Video Conversion> MUST be enabled in order for the GUI to be able to overlay on the video.
jdsmoothie is offline
post #1451 of 4834 Old 05-21-2018, 07:46 AM
Scott Oakley's Avatar
Quoted: 220 Post(s)
Liked: 142
Cool HEOS Speaker Portability
Hello,
Are any of the HEOS speakers portable, ie: run on lithium battery and are re-chargeable?
Thank you,
Scott
Panasonic 2013 55VT60
Marantz SR-5012 AVR
B&W 805 Speakers
Velodyne 10" Sub
TiVO Premiere
Scott Oakley is offline
post #1452 of 4834 Old 05-21-2018, 07:50 AM
jdsmoothie's Avatar
Liked: 12381
Originally Posted by Scott Oakley View Post
Hello,
Thank you,
Scott
Only the HEOS 1 can be powered by using the HEOS 1 Go Pack which sits under the HEOS 1 and can power the HEOS 1 for up to 6 hours on a full charge. I used to take my HEOS 5 outside on the patio and plug it into an outlet when we had guests, but now simply use my HEOS 1 and a Go Pack which is much more convenient.
https://usa.denon.com/us/heos-1-go-pack
Scott Oakley likes this.
post #1453 of 4834 Old 05-21-2018, 08:08 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6754 Post(s)
Liked: 6752
If it does not have enough power you can add some amps
Cleveland Plasma is online now
post #1454 of 4834 Old 05-21-2018, 08:19 AM
jdsmoothie's Avatar
Liked: 12381
The NR1608 is a 7CH model so can do from a 2.0 to 7.2/5.2.2 setup.
post #1455 of 4834 Old 05-21-2018, 10:32 AM
Quoted: 35 Post(s)
Liked: 4
Marantz + Martin Logan
Best Buy just called. The soundbar won't be in until tomorrow and the receiver is at the wrong Best Buy. So they will hand deliver to my home tomorrow to make up for it.
One thing I was curious about. With the Marantz 1608 - can I dial in Sirius XM directly in the receiver or do I need to use the Heos APP? In other words, can I program the remote to go directly to Sirius?
Dennis L. is offline
post #1456 of 4834 Old 05-21-2018, 11:01 AM
Quoted: 220 Post(s)
Liked: 142
Cool
Yes, I agree with that logic. Couple things:
1. Subjectively, how is the sound of the 1, particularly fullness/bass?
2. You DO end up with synched music inside & outside, right?
Scott
Marantz SR-5012 AVR
B&W 805 Speakers
Velodyne 10" Sub
TiVO Premiere
post #1457 of 4834 Old 05-21-2018, 11:03 AM
Quoted: 108 Post(s)
Liked: 50
It seems that all but Tunein need to be controlled by the app. But I think once its onscreen, you can control using remote as well...But not sure about Sirius... I think you can also store favorites in HEOS system which can also be navigated by the remote... Not sure if you can make Sirius or it's songs favorites.
rlwings is offline
post #1458 of 4834 Old 05-21-2018, 11:13 AM
jdsmoothie's Avatar
Liked: 12381
Scott
1. At lower volume levels, works for me just fine, however, if you do have an outdoor plug, you may want to consider the HEOS 5.
2. Correct.
post #1459 of 4834 Old 05-21-2018, 11:15 AM
jdsmoothie's Avatar
Liked: 12381
Once a networking stream is passed to the AVR from the HEOS app, it can be saved to a HEOS favorite which can then be selected from the AVR directly the next time.
post #1460 of 4834 Old 05-21-2018, 01:00 PM
Oilmanmojo's Avatar
Quoted: 83 Post(s)
Liked: 43
crackling or distortion on left front channel
I have recently noticed that my left front channel occasionally has a distortion (crackling like a possible damaged speaker) particularly on atmos or Dolby 7.1 sound modes. I swapped out the speakers thinking i did have a damaged speaker only to find that it is the same. My next move was to replace the speaker wire and still occasionally get this issue. Has anyone else experience this on the Marantz SR7012?
Oilmanmojo is offline
post #1461 of 4834 Old 05-21-2018, 03:38 PM
Quoted: 108 Post(s)
Liked: 50
Yes, I've recently experienced this 'blown speaker sound' on my new Marantz 1608... After careful speaker switching and other testing I finally determined that something was wrong with the receiver's left front channel.
So I took it back to Best Buy and got a replacement... Problem completely went away.
If you hear crackling distortion from the tweeter during high pitched sounds and you know your speaker is not blown, than most probably its a faulty amplifier within the receiver.
rlwings is offline
post #1462 of 4834 Old 05-21-2018, 05:10 PM
Quoted: 35 Post(s)
Liked: 4
Wow..thanks. I did not see that in the manual.
post #1463 of 4834 Old 05-21-2018, 07:34 PM
Transfix's Avatar
Quoted: 92 Post(s)
Liked: 29
Hey JD, I’ve gone through every menu trying to figure out why the display now is solid black when up until a few days ago the menu was always transparent. I also noticed not when I switch to TV Audio for content playing from my TV (ARC) it now says the name of my tv (Panasonic) on the front display and before it would say TV Audio.
This all happened when I did my most recent MultiEQ calibration from the app.
Transfix is offline
post #1464 of 4834 Old 05-21-2018, 07:37 PM
jdsmoothie's Avatar
Liked: 12381
The menu won't overlay on 4k video rather only 1080p video.
post #1465 of 4834 Old 05-21-2018, 07:51 PM
Transfix's Avatar
Quoted: 92 Post(s)
Liked: 29
The menu won't display on 4k video rather only 1080p video.
The menu transparency you mean ?
Transfix is offline
post #1466 of 4834 Old 05-21-2018, 07:53 PM
jdsmoothie's Avatar
Liked: 12381
Correct ... "overlay."
post #1467 of 4834 Old 05-21-2018, 07:58 PM
Transfix's Avatar
Quoted: 92 Post(s)
Liked: 29
Thanks and sorry been racking my brain trying to figure what I changed.
Transfix is offline
post #1468 of 4834 Old 05-22-2018, 12:22 PM
XBRSteve's Avatar
Originally Posted by XBRSteve View Post
I have an HTPC connected to my SR5012 which replaced my Pioneer VSX-52. The issue I am having is that my PC does not have truehd or dtshd as an option when connected to the SR5012, it worked fine with my Pioneer. Any ideas?
In order for the AVR to receive DD TrueHD or DTS HD, the source must be set to "bitstreams"
with Secondary Audio set to OFF.
The source (htpc) is bitstreaming but only has the option of dts and Dolby digital. Other uncompressed formats are no longer available in the windows sound configuration menu.
Sharp Elite Pro 60
Pioneer Elite VSX-52 Receiver
Pioneer Elite  BDP-62FD BluRay
XBRSteve is offline
post #1469 of 4834 Old 05-22-2018, 12:55 PM
jdsmoothie's Avatar
Liked: 12381
Then that would be an HTPC setting issue .. nothing wrong with the AVR.
post #1470 of 4834 Old 05-22-2018, 01:48 PM
ox1216's Avatar
Quoted: 38 Post(s)
WTF?!!! Marantz 6012 / Audyssey Prob
So my Integra DTR 70.1 from 2009 gave out and it broke my heart..I loved that thing!! It was simple for me to use..Pluged in the mic, calibrated my room and put in the blu ray and was really happy!! Did the same thing with a Marantz I just purchased (6012) only thing is now my speakers (particularly the center channel) sound like everyone is under water...The only remedy is switching the mode from Dolby HD, to "Multi Ch Stereo" but I feel like I missing something and its overcompensating across all channels. On the Integra I loved watching movies with "Uncompressed Audio in True HD or DTS"...I'M super frustrated but I'm sure Im doing something wrong.
Set up is a dedicated room..Polk SRS fronts, Klipsch Reference series center 64 and 2 sides, Outlaw LFM1-ex
Any help would be great!!!
Alan
ox1216 is offline
airplay , airplay problems , atmos , auro3d , bridging channels , clipping , dts:x , hdmi arc , issue , Marantz , marantz sr 6012 , marantz sr7012 , sr7012
