The "OFFICIAL" Yamaha RX-A870 / RX-A770 / RX-A670 Aventage AVR Owners' Thread - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 528Likes
post #511 of 548 Old 05-10-2019, 02:39 AM
chros73's Avatar
Quoted: 421 Post(s)
Liked: 199
Originally Posted by chros73 View Post
Which mode would you select instead of this and how? (I looped through the available upmixers, and this "Neo Cinema" was the best out of them.)
I went into settings and searched for parameters for them but basically couldn't find any. So I either have to use one of them or try to output DPLII upmixed 5.1ch PCM audio from PC.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(04.10.25+PC4:4:[email protected]/24/25/29/30/50/59/60Hz)
chros73 is offline
post #512 of 548 Old 05-11-2019, 10:09 AM - Thread Starter
ChromeJob's Avatar
Quoted: 2200 Post(s)
Liked: 1154
Originally Posted by Marde View Post
I have a couple questions about the Apr 16 2019 firmware update/s.
... Also, if you have a 70 series, please share your firmware version number prior to the April update, and the version number after this update (( If you know it )).
The firmware versions, at least the ones that I can get info on, are posted in post number 1.
“Ever heard of the Sullivan Act?” “Oh that's all right, Detective, we're married.”
Are you new to the forum? Please read forum FAQs and stickies. Like posts that help you. RTFM, always.
ChromeJob is offline
post #513 of 548 Old 05-22-2019, 09:09 AM
xiaNaix's Avatar
Quoted: 52 Post(s)
Liked: 45
My RX-A770 updated to firmware v2.70 last night but no information on Yamaha's site about it yet.
Sony BDP-S6700 (Region Free) | Dune Solo 4K | Zidoo X9S
Epson Home Cinema 3100 | Silver Ticket STR-169110 110" Screen
Yamaha RX-A770 | Chane A2.4 L-C-R | Fluance XLBP Wide Dispersion Bipolar Rears | Hsu VTF-2 MK5 Sub
xiaNaix is offline
post #514 of 548 Old 05-22-2019, 06:06 PM
Quoted: 20 Post(s)
Ditto. Just updated my RX-A770 with v2.70 this evening. Took about 10 minutes. Still no info regarding v2.70 on Yamaha's support website. Looking for eARC info.
Media Room - ISF calibrated Panasonic TC-P55VT30, Panasonic DMP-BDT-310 Blue Ray player, Yamaha RX-A770BL, 7.1 Definitive Technology Sound System with Mythos 7,Dual Super Cube 2000's, DT 6.5STR ceiling speakers, Harmony Elite.
JNMNL52 is offline
post #515 of 548 Old 05-26-2019, 05:31 PM
Quoted: 135 Post(s)
Liked: 26
Trying to find the setting to change the display to the audio codec being processed instead of what input it's on... does anyone know how to do that?
Right now it says Shield - it used to say Atmos/TrueHD or something similar.....
enkrypt3d is offline
post #516 of 548 Old 05-27-2019, 01:34 AM
Kris404's Avatar
Quoted: 31 Post(s)
Liked: 31
Keep cycling through 'Info' button on the remote
ChromeJob likes this.
Kris404 is offline
post #517 of 548 Old 05-28-2019, 07:27 PM
Quoted: 20 Post(s)
V2.70 firmware is now posted on the Yamaha support website. Appears to be eARC only.
xiaNaix and chros73 like this.
JNMNL52 is offline
post #518 of 548 Old 06-02-2019, 11:42 AM - Thread Starter
ChromeJob's Avatar
Liked: 1154
Unless you've been waiting for eARC support and plan to use it, I recommend NOT UPDATING to the latest firmware. Owners of the RX-v*83 series (which shares firmware with the RX-a*70 models) have reported issues with HDMI IN audio.
chros73 likes this.
post #519 of 548 Old 06-03-2019, 03:31 AM
chros73's Avatar
Quoted: 421 Post(s)
Liked: 199
Thanks, I wanted to upgrade it today but I'll postpone it (I had DD+ ARC dropouts from Netfilx yesterday).
chros73 is offline
post #520 of 548 Old 06-06-2019, 07:06 PM
qposner's Avatar
Quoted: 49 Post(s)
Receiver is detecting sub twice as far as it is and a crossover question
Today I decided to run a YPAO self test on my Yamaha RX-A770. I set my sub volume at 50% and turned the crossover all the way to its ingest setting (120) as directed. When I looked at the results, YPAO set my Polk Monitor 70 mains to large. The distances for all speakers were relatively accurate but it had my SVS sub at 16 feet away when it is 8 at most. Any idea why this may be happening? Also, should I assume the receiver will set the crossovers appropriately for the mains and sub and just leave the setting on the sub at 120? Thanks!
qposner is offline
post #521 of 548 Old 06-06-2019, 07:16 PM
eriksells916's Avatar
Quoted: 701 Post(s)
Liked: 255
I have not used ypao but l will take a stab at the distance issue so you can at least try some different options. It might have something to do with your mains being set to large?
eriksells916 is offline
post #522 of 548 Old 06-06-2019, 07:22 PM
smcmillan2's Avatar
Quoted: 1034 Post(s)
Liked: 887
Kick the volume up to ~75% on the SVS and run YPAO again.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #523 of 548 Old 06-06-2019, 07:29 PM
PioManiac's Avatar
Quoted: 3391 Post(s)
Liked: 8655
Distance is completely irrelevant,
The only thing "actually" being measured is the time it takes for the signal sent by the avr
to be processed by the amp/processor and produce a sound wave that eventually reaches your mic at the MLP.
The sub channel has a different signal path then the rest of your speakers and room calibration software is designed
to make sure all sounds are time aligned to arrive at your ears at the same time. (IOW, don't mess with it)
From a similar discussion here: https://www.avsforum.com/forum/90-re...l#post58078358
Originally Posted by PioManiac View Post
Calibration Software (YPAO/Audyssey/MCACC etc.)
measures the time it takes for sound signals to travel from the processor, to the speakers, then the sound waves to the mic.
The sub signal also has to pass through it's own amplifier/processor before sending a rather long Low Frequency wave to the mic.
The distance of your powered subwoofer may have been identified by your automatic setup as being further away than it physically is.
This is to compensate for phase matching with your other speakers. Even if the physical distance is closer than the setup microphone identified,
it is not advisable to change the subwoofer distance unless something really doesn’t sound right.
There are also a number of factors and room/furniture influences that will affect the time it takes for those sound waves to reach your MLP.
The "Distance" number is just a reference and should not be used to measure any physical locations of speakers or subs in your room.
What the software is actually doing is measuring delay for how long a sound signal takes to reach your mic, and subsequently your "ears"
Adding More Distance will apply less Delay to the Signal, Reducing the Distance will apply More Delay to the Signal.
After running YPAO, go into manual setup and set all speakers to small (regardless of their physical size)
and set your speaker crossover to 80Hz, Do not re-run calibration after making manual changes.
There is no crossover setting for subs in a Yamaha, (so set your sub output to full range, let the AVR do the rest)
The Sub(s) automatically get all frequencies below the crossover point for speakers set to small
and that gets summed with the LFE channel, in Yamaha's that's automatically <120Hz
Bass Management 101
zeuspaul, ChromeJob and chros73 like this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #524 of 548 Old 06-17-2019, 03:40 AM
chros73's Avatar
Quoted: 421 Post(s)
Liked: 199
... I had DD+ ARC dropouts from Netfilx yesterday
Strangely enough now it's gone (works fine). Has anybody experienced this?
chros73 is offline
post #525 of 548 Old 06-19-2019, 12:49 PM
Liked: 2
Hi guys, new to this forum, but I’ve read all 18 pages. I have a quick question I’m hoping someone can help answer.
I have a 5.1 setup with the RX-A770. Speakers are Klipsch RF-82 II, RC-62 II, RB-61 II and SVS PB-2000.
I’ve noticed that when I’m watching a movie through my PLEX server that in some scenes the volume fluctuates with the background noise. For example, I was watching a movie yesterday and there was a scene with a lot of rain. You could hear the dialogue fine, but the volume for the rain in the background seemed to be fluctuating a lot, almost like it was cutting out then coming back in. I thought maybe it might be a poor audio track from the movie conversion, so I tried another movie and experienced something similar. All the movies I put on my server use original audio, no conversions/compression.
Now I don’t know if it is caused from the PLEX server or the receiver. I had a thought today though, the original audio for a lot of the newer movies I have is 7.1 and I play them back through the “straight” setting on the receiver. Could this be the issue? Does it seem like its cutting out at some points because some of the tracks are meant for speakers that I don’t have setup? Or is the receiver smart enough to know I’m playing back a 7.1 track on a 5.1 setup and adjust accordingly?
I’ll try another movie tonight and test it on a sound program (Movie theater: Standard, spectacle, etc) instead of “straight” and see if that makes a difference.
chros73 likes this.
Halewafa is offline
post #526 of 548 Old 06-20-2019, 03:18 AM
chros73's Avatar
Quoted: 421 Post(s)
Liked: 199
Welcome to the forum!
Good question, I also have a 5.1 setup (Polk Audio speakers, front speakers with bi-amp mode) and with lossless audio (usually 7.1ch) I also use Straight mode. Although I haven't noticed any issue in the last year (nor with my previous RX-A830).
Questions:
- what's your playback device? (external device, TV, etc)
- are you sure that the audio doesn't get converted on the fly by the Plex server? (note that I haven't used Plex)
- if the above is fine then check some settings on your amp that still used in straight mode: dynamic normalisation, etc.
chros73 is offline
post #527 of 548 Old 06-20-2019, 08:10 AM
Liked: 2
Questions:
Thanks for the response!
1. I'm using the PLEX app on a Roku Ultra plugged in via HDMI to the receiver, which is then going into my TV (Sony 75X900F).
2. This I'm not 100% sure about. I know for a fact that the video is streamed in the original format, but I can't seem to find anything on the audio part (might need to head over to the PLEX forums to get that answered).
3. How do I check settings on my amp? I don't have an external one, just whats in the receiver
I guess the best way to test this would be to find a scene in a movie where this occurs and then play that movie straight from the bluray disc and see if its still present.
chros73 likes this.
Halewafa is offline
post #528 of 548 Old 06-22-2019, 06:52 AM
BlackLightning3's Avatar
Quoted: 36 Post(s)
I know that I have had issues trying to stream with Plex or the Roku media player app. It always gives me the worst quality. I use BubbleUPnP to access what's on my media server and cast it to my TV or Blu-Ray player if I don't want to play it directly on them. It doesn't degrade the quality because it's functioning more like a remote telling the player which file to play directly.
PSN - Escobar
Yamaha RX-A870 Fronts: Bowers and Wilkins 704 S2 Rosenut Center: Martin Logan Motion 8i Rears: Martin Logan Motion 4 Front Heights: Martin Logan Motion 2 Subwoofers: 2 x Definitive Technology Supercube 2000
Sony 55" A8F, Panasonic UB820
BlackLightning3 is offline
post #529 of 548 Old 08-12-2019, 03:48 AM
chros73's Avatar
Quoted: 421 Post(s)
Liked: 199
Guys, I wanted to ask you about this multiple times already, but yesterday I faced it again:
dynamic range compression (normalisation) doesn't work with DTS-X (lossless) audio at all (it does with TrueHD, DTS-HDMA, DTS, AC3, etc.)
If you know any solution (setting) for this problem ... It's just problematic to watch any DTS-X content during the night this way
chros73 is offline
post #530 of 548 Old 08-15-2019, 08:35 AM
AL B BACH's Avatar
Quoted: 17 Post(s)
Liked: 5
AV Receiver Web Setup Features
AV Receiver Web Setup Features You May Not Know About - Audioholics
"receiver's IP address"/setup/ in a web browser to get to.
https://www.youtube.com/watch?v=rwTe...jjmsV8qzhI%3A6
chros73 likes this.
A: Yamaha RX-A770BL, Technics SL-Q300, Philharmonic AA+ & AA Center, 5-Panasonic SB-HEP20, Dayton SUB-1200 & Pioneer SW-8 w/AOSHIKE 100W TPA3116 Amp
V: Panasonic TC-P50S60 Plasma, Sony BDP-S3200, Fire TV Stick 4K, Roku SS 3800R, Chromecast 1 w/UGREEN Ethernet Adapter, CM4221HD hacked & CM7777 Preamp
R: Logitech Harmony Smart Control, Echo Input & Panasonic SC-NP10, TP-Link Archer C9
AL B BACH is offline
post #531 of 548 Old 08-15-2019, 08:56 AM
chros73's Avatar
Quoted: 421 Post(s)
Liked: 199
Cheers, that's how I automated my previous and current Yamaha ARV as well
chros73 is offline
post #532 of 548 Old 08-22-2019, 08:37 AM
Quoted: 44 Post(s)
Liked: 2
Question about pass-through Yamaha RX-A870
Hello,
I recently acquired a Yamaha RX-A870 receiver and am currently redoing my family room with this receiver as the heart. I want to be able to play sources through my TV, in some cases, with surround sound, and in others without. This receiver has Standby Pass Through yes? SBPT is fairly new to me...
Am I correct in understanding that if I plug in my 4K Firestick into the receiver and connect my Xbox, Blu Ray player and Cable box via HDMI to the receiver, and then just have a single HDMI going to the TV, not only can I have these all play in HD/4K on the TV as well as surround sound (typical HDMI switching, which I'm familiar with), but it can also do the same with the receiver off and just using the speakers from the TV?
If so, that would be awesome. I've been looking for an easy way to get all of my sources to be able to play in surround/not surround without going through hoops with optical cables.
However, one question I have, how does the receiver know which signal to pass through if its off/on standby? Is it similar technology to what my TV does, like the latest activity/item that's turned on, etc is what will display?
Sorry if my questions don't make 100%, but this is an exciting possibility!
midfidude is offline
post #533 of 548 Old 08-25-2019, 09:36 AM - Thread Starter
ChromeJob's Avatar
Liked: 1154
Standby pass through is pretty simple. You switch the inputs that are being “passed” to the TV with the remote; the AVR responds to the remote input switch even though it’s in standby mode.
You may also be able to do it with the AV Controller app for Android and iOS but I haven’t tried that in ages.
chros73 likes this.
post #534 of 548 Old 08-28-2019, 02:08 PM
Liked: 0
Additional amp for 9.1.2
Hello all - I tried to search for an answer to my inquiry below but could not find one...
I have the 770. I have a 9.1.2 speaker set-up in my room (center, fronts, 2 ceilings, L/R surround, L/R back surround). Obviously, since the 770 can only power 7 channels, it cannot power all those speakers at once. For ATMOS and DTS-X in particular, my back surround speakers are dropped during playback.
I also have an extra amp that I'm not using. I'd like to use that amp to power two of my speakers so that all 9 could be active at the same time, again particularly during ATMOS and DTS-X playback. Is there a way to integrate that amp into the 770's configuration options? Would it involve using the Zone2-out outputs?
Or is all that impossible? Thanks for whatever help anyone can provide.
weiland444 is offline
post #535 of 548 Old 08-30-2019, 07:23 AM
Liked: 0
Yamaha RX-A770 switching to 'Airplay'
Hi All,
I have a problem with a house sitter and my A/V unit that has never happened before.
I have the Yamaha RX-A770 amp with an AppleTV (Version3) connected to it to play Netflix.
The problem being encountered now is that even though our house minder gets to the Netflix screen and can scroll around (hearing the clicks as she moves), when she selects play, the movie starts momentarily and then the amp switches to the 'AirPlay' channel so that you can't hear or see anything.
The Apple forums were hopeless and I'm wondering if anybody here has any insight as to why the amp is switching to 'Airplay' rather than staying on the HDMI3 channel input that the AppleTV is connected.
Kind regards and thanks for your help.
Paul.
Shingleking is offline
post #536 of 548 Old 08-30-2019, 12:14 PM
Quoted: 500 Post(s)
Liked: 253
Not able to check just now but if i remember correctly your apple tv might be set to output to airplay instead of HDMI. Ill try and check later to see if i find where.
Leeliemix is offline
post #537 of 548 Old 08-30-2019, 01:04 PM
Quoted: 500 Post(s)
Liked: 253
Originally Posted by Shingleking View Post
Hi All,
Paul.
Settings -> Video and Audio -> Audio Output - if its on airplay choose HDMI
post #538 of 548 Old 08-30-2019, 01:23 PM
jdsmoothie's Avatar
Quoted: 23472 Post(s)
Liked: 12907
Not possible. The A10X0 and lower 7CH models are fixed at 7CH processing (ie. 7.1 or 5.1.2). The A20X0 is a 9CH model that can do 7.1.2 or 5.2.4 but no further expansion beyond 9CH. The A30X0 is the only model that can do a 9.1.2 or 7.1.4 setup but requires adding an external 2CH amp in order to do so.
jdsmoothie is offline
post #539 of 548 Old 09-01-2019, 10:33 AM
Liked: 0
Leeliemix,
Thanks, you legend. All sorted! 👍
Paul.
post #540 of 548 Old 09-02-2019, 09:12 AM
Liked: 0
Thanks for the reply? I figured it might be a fixed processing issue. Are those Yamaha model numbers?
aventage , bluetooth , newbie , RX-A750 , rx-a770 , setup help , Yamaha
