NAD 758 v3 - Page 133 - AVS Forum | Home Theater Discussions And Reviews
 6291Likes
post #3961 of 9889 Old 08-21-2018, 01:34 PM
markus767's Avatar
Quoted: 5650 Post(s)
Liked: 2694
Originally Posted by richardsim7 View Post
Turns out it's a DTS spec, AVRs configured with 7.1 will matrix 5.1 DTS signals to use the rear surrounds. This explains why my old Sony AVR used to do this, but at the time I never questioned it
Wasn't aware of that. Thanks for the info.
richardsim7 likes this.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #3962 of 9889 Old 08-21-2018, 02:41 PM
tjcinnamon's Avatar
Quoted: 1811 Post(s)
Liked: 490
Originally Posted by blackspider View Post
Got a reply from NAD to help me choose a unit which doesn't have the AM230 issue, thought would share ti here so would help others.
Bad news is my dealer in my country has units only in this serial range. So guess i m out of luck for now. This is the reply-
"To test for digital noise, connect the Optical out from a 4K TV to one of the Optical inputs on the T758V3. Select Netflix and watch a movie. listen carefully during quite passages for noise in the background while the move is streaming.
Service bulletin T758V3-SB2018-01 applies to units within serial number ending “….T75810101 - ….T75812769”. Unit with higher serial numbers have had the hardware updates completed.
The serial number is labeled on both ends of the shipping box and the rear panel of the unit"
is this just the optical out issue or the Atmos static issue as well?
NAD 758 v3 with Dirac 7.4.4 + Rotel 976 + Panamax M5300-PM
Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
DIY MBMs: VRK Build thread + 2x Rotel 981 (bridged)
Sub: 2x Rythmik LVX12 + MiniDSP
DIY Room Treatments: Dutch Floral Prints
tjcinnamon is offline
post #3963 of 9889 Old 08-21-2018, 03:16 PM
richardsim7's Avatar
Quoted: 1392 Post(s)
Liked: 1821
richardsim7 is offline
post #3964 of 9889 Old 08-21-2018, 10:22 PM
Quoted: 294 Post(s)
Liked: 35
your serial number is within the range? Check & let us know.
blackspider is offline
post #3965 of 9889 Old 08-21-2018, 11:27 PM
A.Ik's Avatar
Hi guys,
I'm sorry if this is the wrong thread but I'm moving soon and needed some help with speaker placement. I'll be using the NAD t758 v3 (paired with as of yet undecided speakers) in an open floor plan living room. I'm a bit uncertain as to what would be the ideal speaker configuration and placement. The house is being built so I'm hoping to get the speaker wiring done beforehand. I was thinking 5.2.4 but I'm not sure where i would place the surrounds and overhead speakers. Ideally I'd like for them to be ceiling mounted (or even in ceiling) except for the front 3 which would be floorstanding plus center channel. The ceiling is 11 feet high. Hope I've given enough info to go on. I'm mostly concerned with how far apart (with my admittedly limited knowledge) it look like the surrounds would need to be, would the NADs room correction be of any help? I'm honestly not even very certain of where the surrounds should go.
A.Ik is offline
post #3966 of 9889 Old 08-22-2018, 01:40 AM
Liked: 1821
Originally Posted by A.Ik View Post
Hi guys,
Surrounds should be at ear level, so if you put them in the ceiling, then don't bother with Atmos as you won't gain any benefit
Here's Dolby's layout guide for 5.1.4
More detail here
A.Ik likes this.
post #3967 of 9889 Old 08-22-2018, 02:07 AM
markus767's Avatar
Liked: 2694
Hi guys,
Better ask in one of the dedicated threads. If good sound is really important to you, the floorplan would look something like this (use on/in-wall speakers instead of freestanding speakers for the fronts):
XpanD, A.Ik, flax and 2 others like this.
Markus
post #3968 of 9889 Old 08-22-2018, 04:45 AM
KenM10759's Avatar
Quoted: 3435 Post(s)
Liked: 1916
Hi guys,
This is why theaters don't gel with open floor plans.
Sorry, but it's the truth. You can get it to work, though just how well it works is a matter of how much you're willing to compromise to get speakers closest to where they really should be. The other factors we have to deal with are acceptance of others (spouse) in the home to having audio equipment around that isn't particularly discrete. Others here have pointed out that location of the speakers is important. I will say that at least the NAD's Dirac Live will give you the best chance of making whatever speaker placement you can get sound its best. Good choice there.
As mentioned, you need to have the "bed layer" at ear level. Do whatever you can to achieve that. In-wall speakers can be far better for the front three than ceiling speakers. You can find "aim-able" ceiling speakers, but they never give you the same immersive effect as properly placed free-standing or in-wall speakers. Mixing ceiling speakers for the bed layer with ceiling speakers for Atmos is an abject lesson in how to get mushy voice-of-God sound.
A.Ik and richardsim7 like this.
KEF R500, R200C, R100, R50, SVS SB2000 sub, NAD T758v3 AVR, LG UP875 4K BlueRay, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer. Office: NAD M10, KEF LS50, KEF Kube 10b, Pro-Ject RPM1 TT w/ Ortofon 2M Red. Guest room: Hafler 300 L-R, KEF Reference Model 100 center, KEF iQ10 surrounds, modded M&K V-90 sub, Bluesound Vault 2.
KenM10759 is offline
post #3969 of 9889 Old 08-22-2018, 08:13 AM
Quoted: 294 Post(s)
Liked: 35
Cheers.
Ok just to update on this, got another mail saying not all units in this range are affected. Thought would update otherwise everyone in this serial no range will get paranoid & start contacting their dealers even when there is no issue.
post #3970 of 9889 Old 08-22-2018, 08:29 AM
Liked: 1821
That's what we've been saying from the beginning, not every unit has the problem, even those within that range of serial numbers
methnen likes this.
post #3971 of 9889 Old 08-22-2018, 02:08 PM
tjcinnamon's Avatar
Liked: 490
I have the Atmos issue (I don't use optical so I don't know if I have that) and my serial number is within that range.
post #3972 of 9889 Old 08-22-2018, 02:09 PM
tjcinnamon's Avatar
Liked: 490
does anyone know if NAD watches this thread at all? Not to suggest it means posting here will or won't do anything, I'm just curious if they use it for feedback and sentiment.
post #3973 of 9889 Old 08-22-2018, 03:41 PM
Liked: 1821
You'd like to hope so, but you never know, why not email and ask?
post #3974 of 9889 Old 08-22-2018, 06:05 PM - Thread Starter
atlantasteve's Avatar
Quoted: 23 Post(s)
I am looking for assistance with speaker placement and Dirac settings in the Atlanta area. Does anyone have a recommendation for someone to help me? Please PM if you have a suggestion.
atlantasteve is offline
post #3975 of 9889 Old 08-22-2018, 09:19 PM
rukus29's Avatar
Quoted: 285 Post(s)
Liked: 147
Delayed/no audio while streaming with roku
Has anyone else experienced an issue where the audio does not play when starting a show or movie via a roku? Just started testing my 758v3 with actual video sources today besides Apple Music. Hooked up a roku - besides the cable not passing anything beyond 1080p despite being high speed certified, when I start a show/movie, the audio does not kick in. In particular things with 5.1 streams. I can force it by manually setting listening mode to stereo or enhanced stereo, after which it automatically switches back to Dolby surround after which the audio kicks in shortly thereafter. this happened with Netflix,, hbo go, etc.
I can’t Test if this happens when playing Blu-ray’s on my Blu-ray since it’s a uhd player and doesn’t work with my current hdmi cable (again, despite being high speed certified).
Thoughts?? Between the cable rubbish and this audio issue, I’m at my wit’s end today!
rukus29 is offline
post #3976 of 9889 Old 08-22-2018, 10:08 PM
A.Ik's Avatar
More detail here
Thank you all for your suggestions and advice. I'm looking a bit more into it and trying to find a nice way to get the surrounds at ear level, if possible. Are wireless kits viable without any performance loss (something like this https://www.svsound.com/products/sou...audio-adapter? I know this would require another amp.
A.Ik is offline
post #3977 of 9889 Old 08-23-2018, 12:18 AM
Liked: 1821
Does the cable have the hologram?:
If you end up going wireless for the surrounds, go with active speakers, saves you getting another amp for them
The AVR setup should take their latency into account and bring everything together so should work ok
post #3978 of 9889 Old 08-23-2018, 02:49 AM
Delija's Avatar
Quoted: 415 Post(s)
Liked: 285
I use some cheap (almost "no name") HDMI 1.4 cables (7 + 5 meters long) which I bought long time ago as a temporary solution - no holograms and/or certificates , and 4K HDR and also ARC work flawlessly on Anthem AVR and LG OLED. I've also tried Yamaha AVR - it works. I'm pretty sure it would work on NAD, too.
HDMI 1.3 cable won't work, of course, but 1.4 and 2.0 cables are the same.
Anthem MRX 720 | Parasound Halo A21
Dynaudio Contour 60 | Dynaudio Excite X28 | Dynaudio Emit M20 | 2x SVS SB16-Ultra
LG OLED65C7V
Delija is online now
post #3979 of 9889 Old 08-23-2018, 04:19 AM
rukus29's Avatar
Quoted: 285 Post(s)
Liked: 147
Yup. Package looked like this
rukus29 is offline
post #3980 of 9889 Old 08-23-2018, 04:21 AM
Liked: 1821
I'm assuming that's the cable between the AVR and TV, is the cable between the UHD-BD Player and the AVR premium certified as well?
post #3981 of 9889 Old 08-23-2018, 04:46 AM
rukus29's Avatar
Quoted: 285 Post(s)
Liked: 147
Same cable, just 3ft instead of 20
rukus29 is offline
post #3982 of 9889 Old 08-23-2018, 04:54 AM
pottscb's Avatar
Quoted: 315 Post(s)
Liked: 127
Yes, search Roku on this thread for my previous posts on this. I occasionally got a Roku screen that said it was an HDMI handshake issue and NAD is the culprit as I plug the same stick directly into a pj and it doesn't do it. If the audio doesn't come back on within 15 sec (it usually does) I can almost always stop then restart the show and it fixes it...only some shows are affected. Pretty annoying.
pottscb is offline
post #3983 of 9889 Old 08-23-2018, 05:45 AM
rukus29's Avatar
Quoted: 285 Post(s)
Liked: 147
Wow ok, just searched. I saw someone else posted earlier than you with similar problem as well. Someone else replied to him that he had same roku but wasn’t experiencing any problems. This is so frustrating. Leads me to believe maybe this is a cable issue?
I’m using roku ultra -> NAD -> JVC RS420/x570. I haven’t been this frustrated getting av gear set up in a long time.
What cables do you use and how long are they? My 3ft cable from roku to NAD is Monoprice certified premium and the 20ft cable from NAD to PJ is a random Best Buy ‘high speed’ Cable (which doesn’t pass anything more than 1080p in my setup) - I spent the better part of two hours trying to get the Monoprice 20ft high speed certified cable working yesterday and was so focused trying to get it to pass more than 1080p that I didn’t Test if this audio issue also happened when it was in the chain. I’ve got a few more 20ft high speed cables coming today and tomorrow to Test but I’m ready to throw the roku, the NAD, and the JVC pj off a bridge and go pick up hdmi 1.4 versions of everything.
rukus29 is offline
post #3984 of 9889 Old 08-23-2018, 06:09 AM
markus767's Avatar
Liked: 2694
I switched to active HDMI cables long time ago. Haven't had any HDMI cable issues since then.
Markus
post #3985 of 9889 Old 08-23-2018, 06:14 AM
rukus29's Avatar
Quoted: 285 Post(s)
Liked: 147
Have two different Monoprice active ‘high speed’ (not certified) cables arriving tomorrow. Can’t wait for the fun testing them!
@pottscb , what does your connection/equipment and cable chain look like?
rukus29 is offline
post #3986 of 9889 Old 08-23-2018, 08:59 AM
tbaucom's Avatar
Quoted: 407 Post(s)
Liked: 117
Tone Defeat
Does turning on tone defeat bypass DIRAC or leave DIRAC engaged and simply bypass the bass/treble tone controls in the AVR?
tbaucom is offline
post #3987 of 9889 Old 08-23-2018, 09:01 AM
Liked: 1821
The latter
post #3988 of 9889 Old 08-23-2018, 09:45 AM
markus767's Avatar
Liked: 2694
The latter
It's also just a "feature" for naive audiophools. The control is digital so there's nothing to "bypass"
neo_2009 and richardsim7 like this.
Markus
post #3989 of 9889 Old 08-23-2018, 10:54 AM
ttn333's Avatar
Quoted: 190 Post(s)
Liked: 119
You need a fiber optic hdmi for longer runs. It's hit and miss with other cables.
NAD T758v3, Emotiva XPA-3, XPA-5, UPA-5, JTR Triple 12 LP L/C/R, Htm-6 surrounds, Volt 6 atmos, SVS PC13 Ultra and JTR Cap 2400 ULF - Denon x2400h, Elac Debut F5, Elac Debut C5, Elac Debut A4, Klipsch r-12swi - Stereo Totem Mite
ttn333 is offline
post #3990 of 9889 Old 08-23-2018, 10:58 AM
rukus29's Avatar
Quoted: 285 Post(s)
Liked: 147
Never really heard of folks needing to go to fiber optic for a 20 ft run. 25-30+ is where I’ve heard it needed for reliable playback. That said, I’ll try the three other non-fiber ones I have on the way and hope it fixes both the video and hdmi sync issues (even though the roku and NAD are only connected by a 3ft run and I don’t see how a cable run from pj to AVR should impact audio sync between AVR and roku).
rukus29 is offline
