NAD 758 v3 - Page 170 - AVS Forum | Home Theater Discussions And Reviews
 5858Likes
post #5071 of 9070 Old 10-11-2018, 05:29 AM
Liked: 5
Hello, is there already a solution for the non existing test tone for the sub channel in dirac? i only get a sweep and not a pink noise.
Stryda77 is offline
post #5072 of 9070 Old 10-11-2018, 05:43 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1258
Originally Posted by kbarnes701 View Post
Originally Posted by Delija View Post
There is no much sense discussing about that without measurements.
There is not much point discussing any aspect of in-room audio without measurements, I agree. But absent measurements we can speculate and perhaps proceed by trial and error, which is all we can do. Unfortunately not everyone has the capability of measuring their room and/or properly interpreting the results, so what should we do in those cases -just give up?.
However, I am sure that this does not apply to Molon, and once his new unit arrives he will be able to provide us with a full set of REW and Dirac graphs which will, hopefully, explain what is going on. Meanwhile, simply moving the listening position around the room while playing bass-heavy content is a reasonable way to determine if MLP is sitting in a null.
There has to be a reason for his 'thin' bass. I do not believe that Dirac Live is causing it as such, or many others would be reporting similar problems and they are not (certainly not in the 'real' Dirac Live thread which has been running for years). However, something is clearly going on within DL if switching DL off restores the bass. It may be a faulty implementation or user error, or who knows what, but fundamentally it cannot be an issue with DL as such. Given that the 758v3 has not exactly been a standard-bearer for Quality Control, it is even possible that the unit itself had a fault. In that case, the issue will just disappear when he installs his new unit.
There must be an explanation and measurements will certainly throw some light on it (assuming they are performed properly of course). It is an interesting problem and one which, I am sure, we will collectively be able to help resolve.
I have no nulls and lost bass impact.
I would like to see if applying Dirac's impulse response adjustments to the main speakers only and not the subs restores my bass impact, but we're not given that option.
By the way, can you point me to the "real Dirac Live thread"? I have searched several times over the last year but concluded that one doesn't yet exist.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is offline
post #5073 of 9070 Old 10-11-2018, 05:54 AM
richardsim7's Avatar
Quoted: 1311 Post(s)
Liked: 1682
https://www.avsforum.com/forum/90-re...-live-box.html
Agenor likes this.
richardsim7 is online now
post #5074 of 9070 Old 10-11-2018, 06:14 AM
tjcinnamon's Avatar
Quoted: 1798 Post(s)
Liked: 483
I think that Dirac needs to allow the user to restrict impulse corrections to a certain range, just as we can with frequency response. I would like to apply it to my speakers but not my subs. That is what I want to see in version 2.
Given that Dirac 2 is supposed to be modular (modules releasing annually), I'd put it in for a request and perhaps you'll see it (for a fee, I'd assume) in future modules.
NAD 758 v3 with Dirac 7.4.4 + Rotel 976 + Panamax M5300-PM
Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
DIY MBMs: VRK Build thread + 2x Rotel 981 (bridged)
Sub: 2x Rythmik LVX12 + MiniDSP
DIY Room Treatments: Dutch Floral Prints
tjcinnamon is offline
post #5075 of 9070 Old 10-11-2018, 06:19 AM
kbarnes701's Avatar
Quoted: 7738 Post(s)
Liked: 7024
Of the hundreds, maybe thousands, of people using Dirac Live (in the other thread) nobody has had this issue and nobody has felt any need to futz with the impulse response measurements/correction. This, to me anyway, points to a problem with the 758v3 rather than with Dirac itself.
Sure:
This thread has been going for 4 years. Ostensibly it's a thread about the miniDSP DDRC-88A, but since the only purpose of that unit is to implement Dirac Live, much of the thread is about Dirac itself. There are some very knowledgeable contributors there.
kbarnes701 is offline
post #5076 of 9070 Old 10-11-2018, 07:16 AM
Liked: 1682
Always so quick to point fingers at the NAD aren't ya?
There's nothing wrong with Dirac on the T758v3.
It's either their particular unit (unlikely), their measurements when running Dirac (possible), or their expectations of Dirac (most likely)
pixphipau likes this.
post #5077 of 9070 Old 10-11-2018, 08:40 AM
carminepesce's Avatar
Quoted: 204 Post(s)
Liked: 162
I’m still waiting for a response from NAD regarding this very issue. I’ll post soon as they reply.
Vizio M55-e0 Display Oppo 103D
NAD T758v3
SVS PB-1000 Sub
Wharfedale Diamond 220, 220c 210 system
carminepesce is offline
post #5078 of 9070 Old 10-11-2018, 09:05 AM
kbarnes701's Avatar
Liked: 7024
I don't think so. It is a fine unit, so long as it works as described, but in this case, if we eliminate Dirac itself, which seems reasonable since the issue has not once been reported in the 4 year old Dirac thread, all that is left is the unit itself -- with the caveats below.
That isn't what Molon reports. I have known this member for a long time and he knows what he is doing and I have complete confidence in his reports. So I know that if he says his bass is 'thin', it is thin. He says when he switches Dirac out, his bass is no longer thin. If it isn't Dirac, then it is the 758v3 (with the caveats below).
But a clear prime suspect nonetheless.
Possible for a novice user, but Molon has been using Dirac Live long before the 758v3 came along.
Well, nobody expects Dirac to make their bass 'thin' so I can't see that as even a possible runner, let alone most likely.
post #5079 of 9070 Old 10-11-2018, 09:06 AM
Liked: 5
Ok, great. I also submitted a ticket regarding the problem.
Stryda77 is offline
post #5080 of 9070 Old 10-11-2018, 12:28 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1258
That's the thread for another piece of hardware that also runs Dirac, like the NAD. It's not a dedicated Dirac Live thread. It's only a matter of time before someone starts one.
post #5081 of 9070 Old 10-11-2018, 12:33 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1258
Possible, but my point still stands - give us control of it, just like frequency response. That's the only way I'll know.
post #5082 of 9070 Old 10-11-2018, 12:36 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1258
Least likely, when expectations don't factor into this at all - in my case, just comparing to my previous setup with Audyssey XT32.
I'm not ready to comdemn the T758 v3 just yet, but I won't have time to fiddle for a while. To be continued...
post #5083 of 9070 Old 10-11-2018, 01:06 PM
Quoted: 16 Post(s)
Liked: 6
Some food for thought concerning T758 V3 and "thin" sounding bass...
Many AVRs use 4th order low pass and 2nd order high pass crossovers which give a slight bump just below the XO and a little more support from the mains below the XO which can could make the bass sound more full. This NAD per an earlier post from Markus uses 4th order low and high pass which sum flat at the XO.
From Markus document on the subject, the XO should be set 1 octave higher from where the mains start to taper off. Makes sense since the XO will cause the mains to drop off 24db 1 octave below the setting. Having tried that the bass was still slightly "thin" sounding. So I tried basing the crossover on the speaker manufacturer's spec vs REW or Dirac measurement to eliminate effect of room gain from consideration. At that point everything sounded as it should. YMMV.
Of course this would not explain why not using dirac would have the desired effect and measurements will be the only way to know what's going on.
kbarnes701 and HTNUT1975 like this.
jstert is offline
post #5084 of 9070 Old 10-11-2018, 01:27 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1258
That could explain issues around the crossover - but my observations are mostly well below the crossover. Specifically, I'm not feeling the bass like I used to, or the floor rumble, even at the same or higher SPL than I used before. It's most obvious from 15-60Hz.
My mains go into the lower 50s and I am crossing them at 80 as that gets me the smoothest XO right now.
Also, my curve overall is great - I'm getting more midbass than with Audyssey, simply because I didn't have curve control before.
So what I'm going to do is run another set of measurements, maybe with a different grouping, and see if I get a different result. When I get time. Some other things are changing as well - and I'll reassess again after those changes are made.
post #5085 of 9070 Old 10-11-2018, 03:15 PM
zeus33's Avatar
Quoted: 1782 Post(s)
Liked: 1764
....... Given that the 758v3 has not exactly been a standard-bearer for Quality Control, it is even possible that the unit itself had a fault. In that case, the issue will just disappear when he installs his new unit.
I'm pretty sure it wasn't the 758's fault considering Molon was running 2 DDRC-88As at the time.
kbarnes701 and richardsim7 like this.
zeus33 is offline
post #5086 of 9070 Old 10-11-2018, 03:20 PM
kbarnes701's Avatar
Liked: 7024
post #5087 of 9070 Old 10-11-2018, 05:04 PM
Molon_Labe's Avatar
Quoted: 3206 Post(s)
Liked: 3852
Keith,
Sorry for the confusion, but I was bassing (get it) the thin comment from my experience with Dirac via the MiniDSP. My NAD 777v3 arrived yesterday but it is still in the box. I hope to get it online some time next week. I also ordered another UMIK-1 so I will be able to provide REW measurements. However, I plan to move the (2) dual 18" boxes near field. With two 24" in the front corners and four 18" directly behind me, thin better not be in my vocabulary in the near future.
Soulburner likes this.
AVP - Trinnov Alt16
Speakers - JBL M2 (3), JBL 708p (4), JBL 705i (4)
Subs - (2) Deep Sea Sound 24" & (2) Dual Stereo Integrity 18"
Video - Sony 55es
Screen - Seymour 127" A/T 16:9
Molon_Labe is online now
post #5088 of 9070 Old 10-11-2018, 05:27 PM
brian6751's Avatar
Quoted: 1686 Post(s)
Liked: 1676
I just hooked my 758 up and tried running Dirac. I get all the way to where you drag and drop the project but when I drop the project into the slot it starts to load a little but then it just hangs and I have to restart the avr. Anyone have any idea what the issue could be? I’m on a Mac. Dirac full version. Ethernet adapter. Thanks.
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is offline
post #5089 of 9070 Old 10-11-2018, 06:34 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1258
And all updates have completed?
post #5090 of 9070 Old 10-11-2018, 06:36 PM
brian6751's Avatar
Liked: 1676
I believe so. BluOS is on 3.0. The T758 is on 2.07
Any other updates?
FOR SALE:
post #5091 of 9070 Old 10-11-2018, 06:38 PM
Liked: 1682
Any other updates?
That a typo?
I think these are the latest versions:
MCU v2.08
DSP v1.10
Video v1.09
BluOS v3.0.0
post #5092 of 9070 Old 10-11-2018, 06:40 PM
brian6751's Avatar
Liked: 1676
That a typo?
MCU v2.08
DSP v1.10
Video v1.09
BluOS v3.0.0
Nope. Here’s a screenshot
FOR SALE:
post #5093 of 9070 Old 10-11-2018, 06:40 PM
Liked: 1682
Ho boy, that don't look right at all...
Contact NAD support
post #5094 of 9070 Old 10-11-2018, 06:46 PM
brian6751's Avatar
Liked: 1676
Contact NAD support
I don’t see anywhere to get more up to date firmware either.
FOR SALE:
post #5095 of 9070 Old 10-11-2018, 06:48 PM
Liked: 1682
I'm assuming "check for upgrade" doesn't show anything useful?
You can try upgrade the firmware in the BluOS part of the menu, but not sure that'll do anything
post #5096 of 9070 Old 10-11-2018, 06:56 PM
brian6751's Avatar
Liked: 1676
Right “check for update” says nothing is available. Updating in the BluOS section looks for something on USB
FOR SALE:
post #5097 of 9070 Old 10-11-2018, 06:56 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1258
Just updated mine.
As of now:
v2.08
v1.10
v1.09
v3.0.0
@brian6751 , is your 758 a v3?
post #5098 of 9070 Old 10-11-2018, 07:03 PM
brian6751's Avatar
Liked: 1676
Just updated mine.
As of now:
v2.08
v1.10
v1.09
v3.0.0
Yep it’s a V3
FOR SALE:
post #5099 of 9070 Old 10-11-2018, 07:05 PM
Liked: 1682
Yeah I'd contact NAD support and see what they say. Chances are they'll tell you to get your dealer to upgrade it via serial (though if you happen to have a USB to serial cable they might send you the software to do it yourself)
Could always try a factory reset as a last resort?
post #5100 of 9070 Old 10-11-2018, 07:21 PM
brian6751's Avatar
Liked: 1676
NAD 758 v3
Did factory reset. No change
FOR SALE:
