NAD 758 v3 - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 6344Likes
post #541 of 10060 Old 11-23-2017, 11:45 PM
markus767's Avatar
Quoted: 5651 Post(s)
Liked: 2696
Originally Posted by Nyal Mellor View Post
Not really. You are basically telling everyone that the Arcam and other units based off it are broken, which they are not.
They are not exactly broken but they are useless in situations where one needs different crossover points for different speaker groups which is probably 95% of all cases.
The bass management assymetry can be worked around.
What you are repeatedly missing is that most people don't have the knowledge to do so. It would require taking a multitude of measurements around the listening position using a multitude of different target curves and crossover settings (which can't be done with Arcam AVRs by the way). Then pick the best combination. Guess you're offering that as a service. I'm just offering a straight forward approach with DL that produces near perfect results without a tedious process and without additional costs.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #542 of 10060 Old 11-23-2017, 11:50 PM
markus767's Avatar
Liked: 2696
I have formed no opinion on the relative merits of the two units in question. I was quoting your response to another poster.
I've asked philipbtz what he considers "better" about the Arcam (which he didn't answer) but you implied it would be "sound quality". So much for having "formed no opinion"...
In my line of work I need to trust my ears, and I have put the time into training them. I do not need blind evaluations to form an opinion about sound quality or evaluate a room for it's acoustic deficiencies.
The golden ear "I'm an expert" gem, "I know what I hear and what I hear applies to everybody else and is free of any bias whatsoever"
I've worked as a mixing engineer for years and I know exactly when to trust my ears and when to resort to something more reliable and useful namely measurements.
HTPCat, mtosic and neo_2009 like this.
Markus
post #543 of 10060 Old 11-24-2017, 04:06 AM
markus767's Avatar
Liked: 2696
Originally Posted by richardsim7 View Post
Ok, but have you (or anyone) heard both the Arcam, and the NAD? Preferably side by side?
Looking forward to your impressions as you're the only one owning both devices.
Who knows, Arcam might have applied special audiophile pixie dust that makes their gear sound superior despite major technical limitations in bass management
neo_2009 likes this.
Markus
post #544 of 10060 Old 11-24-2017, 04:09 AM
richardsim7's Avatar
Quoted: 1417 Post(s)
Liked: 1852
Well, it'll come down to the DACs really. I'm using an external amp to remove that from the equation too
Had a quick listen to the NAD last night, I like. Will listen to the Arcam today and do some A-B-ing. Then will get my brother involved so I can get him to do some blind testing
rjyap likes this.
richardsim7 is online now
post #545 of 10060 Old 11-24-2017, 04:19 AM
markus767's Avatar
Liked: 2696
Sure, might as well be pixie dust applied to the DACs
How have you set up both units for this test?
Markus
post #546 of 10060 Old 11-24-2017, 04:20 AM
Liked: 1852
Well, DACs definitely sound different, I know that much for sure
The fact that CD players can sound different is a ****in mystery to me though
Stereo, speakers set to large, playing a variety of music
post #547 of 10060 Old 11-24-2017, 04:27 AM
markus767's Avatar
Liked: 2696
So what's the player for each device? How is it connected to the AVR? How are the AVRs configured? How do you switch between AVRs?
Markus
post #548 of 10060 Old 11-24-2017, 04:29 AM
Liked: 1852
VLC Player, HDMI
Swap AVRs by swapping HDMI cable and swapping the RCA plugs at the power amp end
Actually, will install foobar with WASAPI (bit perfect) output...
post #549 of 10060 Old 11-24-2017, 04:32 AM
markus767's Avatar
Liked: 2696
VLC Player, HDMI
That switch probably takes too long. It should be instant A/B.
Markus
post #550 of 10060 Old 11-24-2017, 04:37 AM
Liked: 1852
Probably. Might be able to get ahold of a Phono splitter with buttons, that'd help with that part. Not much I can do about the HDMI cable bit though
Like I said, set to just stereo, left and right, set to large. No Dirac or anything
Will level match them too
post #551 of 10060 Old 11-24-2017, 08:40 AM
Nyal Mellor's Avatar
Quoted: 544 Post(s)
Liked: 384
I agree with you that most people don't have the requisite knowledge.
Before running any automagic room correction you should have a good idea of how the various speakers and subs measure nearfield without the room's influence. Then you can make intelligent decisions about the target curves and the magnitude of boost and cuts applied.
Blindly flattening response an octave below crossover when the speaker? How many speakers are flat to 40?
No need to do what you suggest to work around asymmetrical bass management, just use an asymmetrical target curve with high pass leg using a 12dB/oct slope with FC at XO.
DL does a very good job, but still has limitations. One not very often discussed is how good it is at "full range" correction, when it is limited by the size of the measurement mic. The mic does not measure the room response correctly, even with a correction file applied due to mic directionality.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #552 of 10060 Old 11-24-2017, 08:41 AM
neo_2009's Avatar
Quoted: 354 Post(s)
Liked: 265
Sorry for the off-topic, but this thread is interesting: DAC blind test: NO audible difference whatsoever.
nathan_h and richardsim7 like this.
neo_2009 is online now
post #553 of 10060 Old 11-24-2017, 08:43 AM
CruelInventions's Avatar
Quoted: 1235 Post(s)
Liked: 1443
It's got to be precise too (within a .10dB), otherwise you'll hear very subtle differences in volume not as a volume difference, but as differences in sound character. It's just the nature of our hearing mechanism and an aspect which further helps cement the common false narrative of different dacs and amps having their own unique sound signatures.*
*Not including in this all the dacs and amps which purposefully have sound signatures, I'm talking the majority where accuracy to the incoming signal is a primary goal
The first principle is that you must not fool yourself and you are the easiest person to fool. ~ Richard P. Feynman
CruelInventions is online now
post #554 of 10060 Old 11-24-2017, 08:48 AM
Quoted: 544 Post(s)
Liked: 384
I never said anything about lack of bias. I said I am confident in my hearing abilities. Many others are too...like you use your ears to judge how to EQ a recording-or do you use measurements to make all recording decisions and then use blind tests to allow evaluation of whether EQ1 or EQ2 is better?
post #555 of 10060 Old 11-24-2017, 08:51 AM
Liked: 1852
Well, unfortunately the AVRs don't have that level of adjustment, so I got them as close as I could to each other.
So far (not blind tested) I'm seriously struggling to tell a difference between the two. The only conclusion I'm getting from this is: I love my speakers
post #556 of 10060 Old 11-24-2017, 09:08 AM
Quoted: 544 Post(s)
Liked: 384
If we start discussing the merits of ABX and AB and blind testing we could easily devour another 50+ pages and not get anywhere...no point rehashing that discussion here.
Personally I'm going to accept the validity of both measurements and biased sighted hearing tests, and leave it at that.
post #557 of 10060 Old 11-24-2017, 09:18 AM
Liked: 1443
Yes, that approach better suits your professional interests.
post #558 of 10060 Old 11-24-2017, 09:32 AM
Quoted: 544 Post(s)
Liked: 384
No different than the enthusiast who can't afford a Datasat LS10 wanting to believe that his NAD 758 sounds identical. It's an unfortunate form of scientific reductionism based on simple assumptions (biases) that is all over AVS.
Obviously I work in the audio video industry so I'm a snake oil salesman right? Ha ha...
SteveC356 likes this.
post #559 of 10060 Old 11-24-2017, 10:27 AM
markus767's Avatar
Liked: 2696
Thanks for finally acknowledging that very fundamental fact.
Below the Schroeder frequency this doesn't apply as the response is completely swamped by the room.
Nobody said you should blindly follow something or someone. You don't seem to follow the discussion. Please read the link we're discussing.
If it only were that easy. There's this thing called phase response. You can't just draw a line in the target curve editor and expect a 12dB Butterworth or Linkwitz-Riley or Bessel or... Furthermore the fundamental fact at the beginning of your post applies.
Mic size? Are you using a large diaphragm condenser mic? There's really not much to discuss as Dirac Research didn't disclose their tech. If you believe that correction should be limited to low frequencies then DL lets you do just that.
Markus
post #560 of 10060 Old 11-24-2017, 10:30 AM
markus767's Avatar
Liked: 2696
So which one is it? Both can not be true at the same time.
You're confusing sound creation with sound reproduction. The mother of all audiophool fallacies.
Markus
post #561 of 10060 Old 11-24-2017, 10:37 AM
markus767's Avatar
Liked: 2696
It's pretty naive to think price would be directly related to sound quality these days. There's a ton of proper blind tests that show the opposite. If it would be true then why don't we see manufacturers doing more (any!) ABX testing? Would be the number one killer argument.
Markus
post #562 of 10060 Old 11-24-2017, 10:56 AM
Quoted: 544 Post(s)
Liked: 384
@markus767 please post for all a summed response for an assymetrical bass management filter like the one in the Arcam so all can see what magnitude of errors we are talking about in this endless back and forth...
post #563 of 10060 Old 11-24-2017, 10:57 AM
markus767's Avatar
Liked: 2696
The speaker manufacturer! He has the magic pixie dust that makes every AVR, DAC or whatever electronics sound the same Or maybe there really is no significant difference between competently designed and bug free (unfortunately rather the exception than the rule) electronics these days? This would be very bad news for dealers that see their profits dwindle.
Markus
post #564 of 10060 Old 11-24-2017, 11:07 AM
markus767's Avatar
Liked: 2696
Discussed in the link I've posted. Are you telling me now that you've entered this discussion without reading it?
Markus
post #565 of 10060 Old 11-24-2017, 11:10 AM
markus767's Avatar
Liked: 2696
Blasphemy!
Markus
post #566 of 10060 Old 11-24-2017, 11:12 AM
Quoted: 544 Post(s)
Liked: 384
This one: https://mehlau.net/audio/dirac-live-avr-crossover/ ?
It doesn't have anything in it related to my question.
post #567 of 10060 Old 11-24-2017, 11:15 AM
markus767's Avatar
Liked: 2696
You still haven't read it.
Markus
post #568 of 10060 Old 11-24-2017, 11:26 AM
Quoted: 544 Post(s)
Liked: 384
There's nothing in there beyond a portent of doom at the bottom "Some AVRs present a mixture of 6dB, 12dB or 24dB filters which can produce disastrous results"
I thought it might be useful for people to see what kind of magnitude of errors we are talking about with assymetrical bass management slopes. Certainly not "disastrous".
Anyway and regardless, my point of joining the discussion was to provide a counterbalance to your portents of doom and Arcam bashing.
Reality is:
1) that most people are fine using 80Hz crossovers all around and do not need flexibility to specify crossovers for individual channel groups independently
2) distortion introduced by assymetrical bass management slopes is low and in any event can be worked around
We agree and are on same page about symmetrical bass management slopes being ideal when using DL.
Maybe a more useful line of discussion for us all to have on the forum would be how to improve DL? At least that's a constructive addition. Maybe if anyone's inclined they can start another thread. We clearly have enough ammuition now from all the DL implementations we have seen and you have picked apart.
post #569 of 10060 Old 11-24-2017, 11:49 AM
HTPCat's Avatar
Quoted: 783 Post(s)
Liked: 490
What I don't understand is why do you feel the need to defend Arcam from bashing (your words, not mine)? Arcam has done nothing to help themselves here, repeatedly talking with smoke and mirrors to stubbornly defend their product only to come back much later and reverse course only to screw that up as well.
richardsim7 likes this.
HTPCat
"I have a need to feed the hole with more Audio & Video toys"
HTPCat is offline
post #570 of 10060 Old 11-24-2017, 12:19 PM
markus767's Avatar
Liked: 2696
You're assuming all AVRs would have the same bass management filters. That assumption is wrong. I've seen filters that haven't been inverted (it shouldn't be news to you that some require this) which results in a deep cancellation notch. Still doesn't qualify for "disastrous"?
]Anyway and regardless, my point of joining the discussion was to provide a counterbalance to your portents of doom and Arcam bashing.
I'm not bashing Arcam. Just stating the facts. They brought this upon themselves.
Reality is:
Do you have data to support that claim? I have data that suggests the opposite. Happy to post exampkes next week when my Mac is back from repair.
Again, not relevant to most people buying DL for AUTOMATED room correction.
Please stop bashing Arcam and the upcoming Lexicon AVRs
There's not much to discuss. Any room correction should also optimize the crossover region between subs and sats. I've stated this numerous times. But this would require the room correction code to integrate with bass management. You tell me why this hasn't happened yet. Audyssey had this sketched out years ago.
HTPCat and neo_2009 like this.
Markus
