NAD 758 v3 - Page 248 - AVS Forum | Home Theater Discussions And Reviews
 6343Likes
post #7411 of 10056 Old 02-12-2019, 09:21 AM
Quoted: 67 Post(s)
Liked: 31
Originally Posted by DrFreemen View Post
Turn off the receiver, disconnect the USB Hub from usb, download and unzip the firmware file, format the usb flash in fat32, copy the firmware file to usb, connect the usb flash to the receiver and turn it on.
Thanks for quick help. Unfortunately I am still stuck at 99% DSP upgrade. I am now trying an older Firmware but I think I have to return the device :-/
TV: Panasonic 65DXW904 || Receiver: NAD T758 V3 || Console: Sony PS4, Nintendo Switch || Front: Dynaudio Special Forty || Rear: Canton GLE 410 || Sub: Klipsch R-115 SW
SpoOokY83 is offline
post #7412 of 10056 Old 02-12-2019, 09:23 AM
richardsim7's Avatar
Quoted: 1417 Post(s)
Liked: 1852
Probably just needs updating via serial, which you dealer should be able to do
DrFreemen likes this.
richardsim7 is online now
post #7413 of 10056 Old 02-12-2019, 09:28 AM
Quoted: 67 Post(s)
Liked: 31
The dealer is just some kind of online seller with a very small office and no local support. He has just opened a support ticket and I am asked to bring the receiver back tomorrow. I will be notified once the new device has been delivered.
What a great start with NAD
post #7414 of 10056 Old 02-12-2019, 09:33 AM
Quoted: 36 Post(s)
Liked: 9
Do not rush to return the receiver, my first update via Wi-Fi also stopped at 99% DSP upgrade and so it was two days, and on the third day it was updated without any problems.
DrFreemen is offline
post #7415 of 10056 Old 02-12-2019, 09:38 AM
Quoted: 67 Post(s)
Liked: 31
A busy update server might be the root cause but I also tried the USB update and also this, and an older version, got stuck at 99%. Just again attached my old Denon and the NAD is already packed up.
Don't want to waste two more days and so I decided to return the unit. Next time I will just do the USB update to be on the safe side.
post #7416 of 10056 Old 02-12-2019, 09:41 AM
smbsocal's Avatar
Quoted: 61 Post(s)
Liked: 80
My first upgrade took a long long time for it to complete, I forget how long exactly though. I had got everything unboxed connected and tested. After that point I wanted to try out the BluOS and Dirac so I did the update and it took so long I thought I bricked it. I was kicking myself but I just let it run and it finally finished. If I had to guess it took over an hour to apply. How long have you waiting for it to get through that last 99%?
smbsocal is offline
post #7417 of 10056 Old 02-12-2019, 09:46 AM
Quoted: 67 Post(s)
Liked: 31
Well, the DSP upgrade is step 4 or 5 out of 9. The DSP upgrade takes approx. one second for each percentage. Then I waited like 10 Minutes at 99% and nothing happened. Is this last % really taking longer?!?
post #7418 of 10056 Old 02-12-2019, 09:53 AM
Quoted: 36 Post(s)
Liked: 9
Usually, the whole update process lasts 20 - 30 minutes. The first time I waited about an hour, then rebooted the receiver and tried again.
post #7419 of 10056 Old 02-12-2019, 09:56 AM
Quoted: 67 Post(s)
Liked: 31
Have you noticed that it takes very long from 99% to 100% during DSP upgrade?
I am now trying again and I will just leave the device on for an hour or so. Tomorrow I will bring it back to the dealer in case it still doesn't work.
Edit: Ok, again stuck at 99%. I will now wait for an hour or so.
post #7420 of 10056 Old 02-12-2019, 10:02 AM
Quoted: 36 Post(s)
Liked: 9
I don’t remember exactly now, but the transition from 99% to 100% did not exceed 1 minute.
post #7421 of 10056 Old 02-12-2019, 10:12 AM
butch666's Avatar
Quoted: 42 Post(s)
Liked: 24
Sorry buddy, but you are not exactly being helpful here.....
butch666 is offline
post #7422 of 10056 Old 02-12-2019, 10:15 AM
Quoted: 67 Post(s)
Liked: 31
I just had a chat with a very nice guy from NAD called Bob. He told me to plug the USB drive directly into the Receiver and not the dongle. If that doesn't work I would have to upgrade via RS232. Can anybody tell me how to do it? I do not have such a cable so I would buy one. Is a USB to RS232 cable okay? And what would I have to do once I have it?
post #7423 of 10056 Old 02-12-2019, 10:20 AM
Liked: 1852
Yeah USB to Serial is what you want, Bob should be able to guide you through the process (he'll send you some RS232 specific files)
post #7424 of 10056 Old 02-12-2019, 10:22 AM
Quoted: 67 Post(s)
Liked: 31
Hmmm, he told me that an NAD dealer with such a cable could do the update for me. He did not offer to send some files over. Can't I download the files from the web somewhere?
Edit: In the download section of the 758 I can download an EXE file. Is that related to the RS232 updating?
post #7425 of 10056 Old 02-12-2019, 10:39 AM
Quoted: 36 Post(s)
Liked: 9
Yes. The video on this page shows the process of firmware update via USB to RS232 cable: https://nadelectronics.com/mdc-4k-video-upgrade/
richardsim7 and SpoOokY83 like this.
post #7426 of 10056 Old 02-12-2019, 10:59 AM
Quoted: 67 Post(s)
Liked: 31
Alright, now I only need a USB to RS232 cable .
post #7427 of 10056 Old 02-12-2019, 11:22 AM
Quoted: 1463 Post(s)
Liked: 286
New subs seem anemic
I just got a pair of SVS PC4000 that I currently only use one at a time but have tried them both. I’m noticing that the strong subs don’t really blow me away and I fact I feel and hear the sonos sub I have a lot more at a similar listening level. I’m trying to diagnose to see if there is something not set up properly with the NaD 758 connections. I have the rca going from the nad sub pre out and into the PC4000 LFE input. I have the receivers crossovers at 80 for the three speakers attached (towers and center). I have the speakers set to small and sub turned on. The Subs volume is -10 which is pretty high. I have to play the receiver pretty loud to notice the bass (-25 or louder). The sub is set in standard mode. While I hear the bass it isn’t very loud unless I go into the tone controls in the NAD and put the bass on about 6DB or higher (up from 0). Is this right to raise this level or is this a improper boost and not recommended? Listening to BluOS tidal mostly but have also watched Netflix through Apple TV.
Anything I’m missing from receiver side?
Haven’t run Dirac yet but not sure that should affect amount of bass I’m feeling/hearing
Thanks in advance!
Anything I’m missing? I just feel I should hear more from a 2.5 grand ported sub...
Sony 75Z9D, Samsung 65JS9500
Monitor Audio Gold 200(2), Gold 350, Gold 50(2), Gold CT280-IDC(4). SVS PC4000(2).
NAD 758, Anthem MCA-5
Apple TV 4K, Nvidea Shield. Mac Mini (2018). Samsung UHD BluRay and X-Box One X. 14 Sonos
Chirosamsung is offline
post #7428 of 10056 Old 02-12-2019, 02:13 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1758
Originally Posted by brian6751 View Post
Originally Posted by willemd View Post
Does anyone know if NAD are working on a Dirac enabled T758/T777 successor in a form factor with a large touch screen?
Like the new M10, but in a 7.1.4 setting? I've been thinking about buying new gear for a while now, but the small 1990s styled screen of the current models is holding me back a bit. It doesn't help that you'd need a phone or tablet to control BluOS. I currently use an antiquated Logitech Squeezebox Touch, and its touch screen makes it a lot faster to change my radio channel or Spotify track compared to having to unlock my phone and load the app - or give a tablet to my guests if they want to change something. I really hope NAD can produce something like that in 2019.
I know the pre-pro M17 has a touch screen, but I believe it's really limited compared to the M10, and it's also a bit too expensive for my taste.
I dont think you will see something like that since these devices are geared around the assumption you have a screen already.
The screen on the M10 allows you to do normal functions like Play/Pause, Next Track, Volume, etc. but you cannot use it to browse music
Why not just dedicate a tablet for the job? Seems like that would be easier than having a screen on the AVR.
I agree. I think an AVR, which inherently handles video, is assumed to be used with a screen. I can see your use case, but it would add to the cost...
Also, your phone or tablet will be much more capable then the screen and the built-in functions of the AVR/Amp ever could be.
willemd likes this.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is offline
post #7429 of 10056 Old 02-12-2019, 02:18 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1758
Are these subs placed in different locations?
post #7430 of 10056 Old 02-12-2019, 02:39 PM
tjcinnamon's Avatar
Quoted: 1822 Post(s)
Liked: 497
Thanks in advance!
I've had issues with the LFE output appearing to be low (I haven't confirmed) but with a MiniDSP HD and Crown XLS2002 which has a .775v setting I was not able to have my subs even keep pace with my mains. However, connection to a MiniDSP (nonHD) or directly to the sub plate amp.
Also, tone controls only effect things above the crossover non-LFE channels. That tone control is not a great set up.
Also, others have complained about Dirac low bass output especially coming from Audessy when use DEQ.
What I do is run the LFE through something that handles the output properly (in my case the MiniDSP nonHD or direct connect) and then I boost my sub gain knobs by about 6dB and then boost Dirac by another 6dB.
NAD 758 v3 with Dirac 7.4.4 + Rotel 976 + Panamax M5300-PM
Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
DIY MBMs: VRK Build thread + 2x Rotel 981 (bridged)
Sub: 2x Rythmik LVX12 + MiniDSP
DIY Room Treatments: Dutch Floral Prints
tjcinnamon is offline
post #7431 of 10056 Old 02-12-2019, 03:47 PM
Liked: 286
I’m only using one at a time but have tried them both. Will use as duel eventually
post #7432 of 10056 Old 02-12-2019, 04:10 PM
Liked: 286
Thanks in advance!
None of this is with Dirac enabled.
Are you saying that even when I set the crossover at 80 and speakers at small the OSD menu that bumps up the bass level and the speaker level bass part that can be upped BOTH only work on the towers and not the actual subwoofer??
post #7433 of 10056 Old 02-12-2019, 04:15 PM
Liked: 286
Thanks in advance!
I bought a MiniDSP 2x4 HD-why wouldn’t that work the same or better then the original MiniDSP that you are using to boost the levels?
So, to confirm, you are saying that the only proper way for me to get proper bass amount of my PC4000 is not through the NADs speaker levels (even the sub part) or the tone controls (bass part) but instead use a MiniDSP 2x4 HD and then increase levels? What is the best way to hook that up to the NAD and sub and do I need a computer to up the levels the way you describe?
post #7434 of 10056 Old 02-12-2019, 04:55 PM
carminepesce's Avatar
Quoted: 217 Post(s)
Liked: 175
Thanks in advance!
Not to contradict or disagree about others findings but I’m using only a single PB-1000 with the NAD RoomFeel Curve & have PLENTY of bass.
Vizio M55-e0 Display Oppo 103D
NAD T758v3
SVS PB-1000 Sub
Wharfedale Diamond 220, 220c 210 system
carminepesce is offline
post #7435 of 10056 Old 02-12-2019, 04:58 PM
Quoted: 217 Post(s)
Liked: 175
Also, Dirac sets my sub to -1db & my sub’s volume knob is just a tick off 12 o’clock.
NAD T758v3
SVS PB-1000 Sub
post #7436 of 10056 Old 02-12-2019, 05:03 PM
Liked: 1
Thumbs up This actually works...
The NAD remote app, not the actual remote control
Try pulling the power cable out the NAD and plugging it back in (or switch off at the wall)
Strangely this works.
I had a T758v3 installed this evening by Sevenoaks Sound & Vision and all working when they left.
An hour later the ARC sound from LG OLED 55E6 no longer working at all. Trying to watch the news using satellite tuner within LG OLED thus met with silent pictures unless switching to TV internal speaker. CEC equally seemingly disabled.
Switching TV, Bluray, NAD all off and then pulling out NAD power cable and putting it in again left one with all remaining off. Switching LG TV on now woke up the NAD and ARC sound back along with CEC control.
Hope this does not require regular fixing but useful to be able to do if need be.
Thank you for the advice.
radiata is offline
post #7437 of 10056 Old 02-12-2019, 05:17 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1758
But I'm asking about the locations. If the subs are in different locations and the bass from the much more powerful sub is lacking, it is very likely you are getting different results due to mode-induced bass cancellations:
You likely have cancellations at your seat at otherwise impactful frequencies. Measuring would tell you for sure.
In the meantime, without changing any other settings, swap the location of the sub you are saying is lacking with the one you think sounds stronger. See if results change.
post #7438 of 10056 Old 02-12-2019, 05:34 PM
Liked: 286
So minus one is the sub almost full blast right? What’s the 12 o clock thing do? Wonder if I should do that on mine. The SVS have an app.
post #7439 of 10056 Old 02-12-2019, 05:41 PM
Liked: 286
Attachment 2524832
Neither sub sounds stronger. Had them in the same location at different times. It is not a matter of it sounding like a bull at the MLP bit rather there is no strong hard pounding no matter where in the room (open concept) as I thought there would be with a sub that strong. That’s why I was wondering if putting the NAD speaker settings for the sub up 4-6 DB might be what’s needed or some other setting in the receiver since the sub is already set at either -5 or -10.
Also, I do notice the sub sounds louder when the receiver is loud (-15 or so) but thought there would be a way to get deep bass freq with moderate listening levels
post #7440 of 10056 Old 02-12-2019, 05:49 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1758
Have you tried making the sub curve steeper in Dirac?
