NAD 758 v3 - Page 389 - AVS Forum | Home Theater Discussions And Reviews
 7132Likes
post #11641 of 12079 Old 05-02-2020, 12:39 PM
tjcinnamon's Avatar
Quoted: 2170 Post(s)
Liked: 656
Originally Posted by Soulburner View Post
Yes, my fans run when using external amps. It's programmed to, for some reason.
That's odd. I didn't get it. Figured if there was less or no load on the amp, there would be less heat. I haven't tried it in a while. Perhaps it's been fixed in a firmware?
77" C9 + NAD 758 v3 with Dirac 7.6.4 + Rotel 976 + Panamax M5300-PM
Speakers: Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
Subs1: 2x LRK Build Thread + 2x Rotel 981 (bridged); retired: VRK Build thread
Subs2: 2x Rythmik LVX12; 2x Dayton HF 12's Ultra-NearField + Crown XLS 2002
MiniDSP HD & Non; DIY Room Treatments: Dutch Floral Prints
tjcinnamon is offline
post #11642 of 12079 Old 05-02-2020, 02:49 PM
System92's Avatar
Does this receiver support Dolby Vision passthrough?
System92 is offline
post #11643 of 12079 Old 05-02-2020, 03:20 PM
richardsim7's Avatar
Quoted: 1674 Post(s)
Liked: 2256
Yes
System92 likes this.
richardsim7 is online now
post #11644 of 12079 Old 05-03-2020, 04:52 AM
Quoted: 46 Post(s)
Originally Posted by markus767 View Post
Yes, the "Rhye distortion" is happening before the signal is reaching the amps/preamp outputs. The distortion issue you are seeing is obviously something different.
Which hopefully means NAD can fix the "Rhye" issue with a software release. I do use external amps on the mains which explains why I couldn't hear this other new distortion. I must say I have never heard the fan.
Sent from my SM-N950F using Tapatalk
richardsim7 likes this.
ph73 is offline
post #11645 of 12079 Old 05-03-2020, 04:55 AM
Quoted: 46 Post(s)
Originally Posted by Chirosamsung View Post
Is there anybody that has used one of their DIRAC slots for single seat/narrow one person measurement and other slots for wider dispersion, long couch/multiple people measurement and did you notice a big difference at the MLP between the two?
Nope. Let us know if you try it.
ph73 is offline
post #11646 of 12079 Old 05-04-2020, 03:22 AM
hemo cave's Avatar
Quoted: 31 Post(s)
Hi,
I need your help. My setup is a Goldenear SuperSat50 ( left and right ) with the big reference center, Sub is the Supersub X and the rare speakers along with the atmos ones are supersat 3 ( setup is 5.1.2 ) we wont be upgrading. We only use it for Movies. its in our lounge and never listen to the movie at high volumes.
I have an option to buy the following 3 receivers for around the same price :
- NAD T 758 V3
- Marantz 7013
- Marantz 6014
- Denon X3600
- Yamaha RX-A2080
I have used Marantz before and i really liked the Audyssey dynamic EQ, Makes my surround/Atmos speakers come alive at low volumes.
Which one would you think i should go for?
( All the extra features and HDMI I/O is not important at all ), Just sound quality for movies and surround effects.
Thank you.
hemo cave is offline
post #11647 of 12079 Old 05-04-2020, 03:28 AM
markus767's Avatar
Quoted: 6700 Post(s)
Liked: 3585
Originally Posted by hemo cave View Post
Hi,
- NAD T 758 V3
- Marantz 7013
- Marantz 6014
- Denon X3600
- Yamaha RX-A2080
Thank you.
The Denon measured excellent: https://www.audiosciencereview.com/f...-review.12676/
If you want to experiment with room correction then the NAD 758 v3.
neo_2009 likes this.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #11648 of 12079 Old 05-04-2020, 05:37 AM
Quoted: 143 Post(s)
Liked: 53
... but if you do not listen at reference volume levels, measurements mean almost nothing. The NAD measured very, very bad on that page. Nonetheless, it sounds sooo much better than it's predecessor, a Denon 3500 with XT32. Dirac Live is miles ahead if you ask me. Bass response, sound imaging and overall homogeneity is just great. DynEQ or something similar does not exist but I did never felt I would need it in contrast to the Denon which sounded dull and lifeless without.
The NAD has it's flaws e.g. HDMI handshake issues but I can live with it doe to the sound which I just love!
nucky, antakar and blackspider like this.
TV: Panasonic 65DXW904 || Receiver: NAD T758 V3 || Console: Sony PS4, Nintendo Switch || Front: Dynaudio Special Forty || Rear: Canton GLE 410 || Sub: Klipsch R-115 SW
SpoOokY83 is online now
post #11649 of 12079 Old 05-04-2020, 08:06 AM
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
But is Dirac so much better than XT32? Would we be able to distinguish a proper calibration using both tools?
Or is XT32 trickier to use, thus a regular user will have worst results, while with Dirac its easier to achieve a better result?
neo_2009 is offline
post #11650 of 12079 Old 05-04-2020, 08:26 AM
tjcinnamon's Avatar
Liked: 656
Hi,
- NAD T 758 V3
- Marantz 7013
- Marantz 6014
- Denon X3600
- Yamaha RX-A2080
Thank you.
I missed DEQ as well but the Dirac soundstage is better. With some apps you can pump the surrounds if needed after Dirac Calibration. You "should" be able to bump the surround/tops with the curves in Dirac. It's technically not advised but if you like augmented surrounds that may work.
That did not work with version 2.2 and below but perhaps 2.5.3 will have corrected that issue.
post #11651 of 12079 Old 05-04-2020, 08:43 AM
Quoted: 143 Post(s)
Liked: 53
I would say yes! XT32 is also good at flattening bass response. But Dirac gives such a huge benefit when it comes to precisely defining the sound stage in a regular room. Each instrument can precisely be localised not only horizontally but also in the distance. Everything seems to be 3D whereas with XT32 the sound was sticking to the speakers.
An it’s the other way round. XT32 is so much easier to use in contrast to Dirac. But once you know what to do, it is pretty easy to get good results.
I would prefer the NAD with all its flaws over Denons in a blink of an eye.
sb01gt likes this.
post #11652 of 12079 Old 05-04-2020, 08:58 AM
markus767's Avatar
Liked: 3585
No it did not and it never will be "corrected" as DL filters are located downstream of bass management. Channel levels need to be raised upstream of bass management if the listener is unhappy with how the recording was mixed.
Markus
post #11653 of 12079 Old 05-04-2020, 09:01 AM
neo_2009's Avatar
Quoted: 405 Post(s)
Liked: 307
Without measures, i don't even trust my own ears
neo_2009 is offline
post #11654 of 12079 Old 05-04-2020, 09:07 AM
markus767's Avatar
Liked: 3585
True. Audyssey MultEQ is virtually foolproof. Dirac Live is way more difficult to learn. It's a pity that Dirac didn't take the chance to improve usability in version 2 when they started rewriting the app some years ago.
Markus
post #11655 of 12079 Old 05-04-2020, 01:02 PM
Guest
Quoted: 32 Post(s)
Liked: 1
NAD support has informed me: "Please know that the amplifier and preout stage are engineered in series so they must work in tandem. Even if only the preouts - or headphone jack - are used the amplifier will remain active."
Jarvismcjigglestein is offline
post #11656 of 12079 Old 05-04-2020, 08:02 PM
Quoted: 1599 Post(s)
Liked: 313
@markus767 I know increasing the height channels should not work and haven’t been corrected BUT I have twice (including last week) added 2 slots to my NAD of DIRAC filters that are the same (roomfeel) except that in the second slot I have added a 5dB increase in the height channels but following the same curve.
I toggle them back and forth with both movies, tv and Music and it is significantly louder and more noticeable in my ceiling speakers when the roomfeel with a 5dB height increase is playing vs the regular roomfeel.
It is not placebo and it is not subtle. The volume is noticeably louder when in MLP and with ears close to the speakers in ceiling when toggling.
How is this possible if what you say is true?
Sony 75Z9D (5.2.4) Samsung 65JS9500
Monitor Audio Gold 200(2), Gold 350, Gold 50(2), Gold CT280-IDC(4). SVS PC4000(2).
NAD 758, Anthem MCA-5
Apple TV 4K, Nvidea Shield. Mac Mini (2018). Samsung UHD BluRay and X-Box One X. 14 Sonos
Chirosamsung is offline
post #11657 of 12079 Old 05-04-2020, 08:04 PM
Liked: 313
I am amazed that out of all the Dirac users no one on this forum has directly compared the single seat to the wife couch corrections to see if there is much difference in the same room at the MLP.
I will get to it eventually to find out...just didn’t think I’d be the first after this long of the receiver being sold
post #11658 of 12079 Old 05-04-2020, 10:29 PM
Quoted: 143 Post(s)
Liked: 53
I did it!
The difference was noticeable. My default measurement is "Sofa narrow" and I compared it against "Chair". The latter was significantly closer to the sound without Dirac. It almost sounded like Audyssey XT32 limited to approx. 500 hz correction. Bass response was tight but the sound stage was not that good. Sound was sticking to the speakers and there was no depth in the sound stage. "Sofa narrow" produces the great sound stage I so much love. Sound was natural and kept the characteristics of my speakers while broadening sound stage and giving it a certain depth. Every instrument can clearly be localized. It may be that in a very good listening environment "Chair" is closer to the "original" sound but in my typical L-shaped living room "Sofa narrow" is a significant benefit!
Agenor likes this.
post #11659 of 12079 Old 05-04-2020, 10:50 PM
markus767's Avatar
Liked: 3585
I never said that "increasing the height channels should not work". It will, just the redirected low frequencies going to the sub won't be raised by the same amount because they follow a different target curve. And that's why I don't recommend raising speaker levels with the target curve.
Markus
post #11660 of 12079 Old 05-05-2020, 06:14 AM
stretchyandy's Avatar
Liked: 7
So time for my first post here on this forum after many hours of reading.
I've just pushed the order button for a T58 V3 here in Sweden since I found a good deal. This thread and all of it's contributors have been a good help in the decision making.
I'm hoping that it will be a good step-up from my Denon AVR-2310 that I have hade since 2009. Even though I don't have Atmos or 4K and still are running a 5.1 setup.
Hopes are that it will arrive before the weekend so I have some time setting it up while the kids are away. Already have my Umik-1 and put in a order fur a USB to Ethernet adapter which I hope will work.
I'm will be sure to follow the Dirac guide provided by @markus767
In the meantime I just wanted to thank you all for your efforts being put in to this thread i'ts been a great read so far!
richardsim7 and antakar like this.
stretchyandy is offline
post #11661 of 12079 Old 05-05-2020, 10:33 AM
tjcinnamon's Avatar
Liked: 656
I think with the tiny amount of bass sent to those channels it may not have much an impact.
post #11662 of 12079 Old 05-05-2020, 10:38 AM
Quoted: 143 Post(s)
Liked: 53
It has an impact. Let’s say your crossover is 100 hz for the speakers. That means that bass Is being played by the sub with its individual target curve. If you now raise the target curve of the speakers, everything below 100 hz will not be loud enough and sound will become thinner.
post #11663 of 12079 Old 05-05-2020, 11:02 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 2408
It's also problematic because Dirac will often adjust channel levels to counter the changes you made to the curve. It looks infinitely tweakable, but that is an illusion created by the UI.
System 1: Samsung Plasma | Denon X4500H | Hypex Ncore NC252MP | Buchardt S400 | Polk LSiM 702 F/X | Heights TBD | Subs TBD Rythmik
System 2: Laptop | NAD T758 v3 | PSB Imagine B
System 3: PC | Micca OriGen G2 | Mackie MR624
Soulburner is online now
post #11664 of 12079 Old 05-05-2020, 11:13 AM
Quoted: 143 Post(s)
Liked: 53
Not with latest version anymore. After adjusting target curve the volumes are not changed for compensation anymore.
Soulburner likes this.
post #11665 of 12079 Old 05-05-2020, 11:17 AM
markus767's Avatar
Liked: 3585
That behavior was fixed in 2.5.2. See https://mehlau.net/audio/dirac-live-2/
Soulburner and richardsim7 like this.
Markus
post #11666 of 12079 Old 05-05-2020, 11:40 AM
Liked: 313
I have not found this to be a problem as switching between the 5dB louder is significantly louder in the ceiling speakers then the regular unedited curve. So I’m not sure that Dirac has corrected the levels as you say
post #11667 of 12079 Old 05-05-2020, 12:01 PM
Liked: 313
I have my crossover at 80 and don’t find this to be an issue at all...YMMV
post #11668 of 12079 Old 05-05-2020, 12:45 PM
Liked: 2256
post #11669 of 12079 Old 05-05-2020, 12:46 PM
tjcinnamon's Avatar
Liked: 656
Originally Posted by richardsim7 View Post
for tops, I would not mind that curve. They will send little to LFE.
post #11670 of 12079 Old 05-05-2020, 12:49 PM
markus767's Avatar
Liked: 3585
No offense meant but I don't think you really understand what I have been trying to describe in numerous posts. So I give up for now and post the signal flow chart once again. It really doesn't get clearer or easier than that:
That's great you don't find that to be an issue but it doesn't change the fact that redirected bass from your raised speakers isn't raised by the same amount.
Name:	Bass Management.png
Markus
