StormAudio I.ISP 3D.16.12 16-Channel Integrated AV Processor Hands-On - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 441Likes
post #631 of 874 Old 04-01-2019, 06:56 AM
Quoted: 833 Post(s)
Liked: 667
Originally Posted by Bigmoviefan View Post
If you do not know what steering is in a PrePro, you need to educate yourself on this subject. Or just not comment on things you know nothing about .
I know exactly what you are claiming "steering" is, and it's wrong. The idea that somehow one processor using Dolby or DTS decoders will magically move sounds to different channels "better" than other products using the same decoders. If a sound is flagged for a channel, it will go to that channel or it will fail Dolby and DTS certification. Every product goes through the same testing and has to meet the same standards. There's no massaging or "custom written code" of the decoder to get a better result. It's pass/fail, there are no letter grades.
The only appropriate use of "steering" is when discussing/comparing the different up-mixers and formats. There is real and non-imaginary difference between them and how they steer sounds to the different channels.
None of the above has anything to do with how the unit sounds. That's an entirely different discussion and there are a number of other reasons that can make one product sound different from another.
Lyngdorf MP-50 | Yamaha MX-A5200 | Ascend Sierra Towers | Ascend Sierra Horizon | Ascend Sierra Lunas | Ascend HTM-200SE | SVS SB-13 x4
duckymomo is offline
post #632 of 874 Old 04-01-2019, 07:10 AM
rblnr's Avatar
Quoted: 192 Post(s)
Liked: 171
DSP chips are the same, codecs are the same, everything should sound the same. Amps sound the same, receivers the same as separates, and so on. Electrical and software engineers coming up w/different designs and implementations are just spinning their wheels to meet a price point and keep their jobs because it doesn't really matter.
Yet in so many cases, they don't sound the same whether or not they should. And it's demonstrable, though I would not try this w/cables
Put excellent processors into the same system and they often sound different. The Storm, as an example, sounds obviously better than either the AVM60 or Marantz 8802/5 (both of which I like, but for different reasons) and Datasat, and this is clear (to audiophiles and 'civilians' alike) from moment one. It's not something you have try to listen for.
It'd be great if an inexpensive receiver or processor sounded the same as a good high end prepro and amp. Some stuff is stupidly over-priced and lousy value. But there are a lot of great products out there, and the awful truth is, by and large, you get what you pay for.
As the above post notes, processors are complex. We can try to isolate reasons why this or that sounds better (or doesn't), but few, if any of us, are hardcore hardware or software engineers w/the background and experience to dissect in this way. And it's never just one thing or the other, it's implementation and how it all works together, like any other complex product or system. Maybe all those electronic/software guts that engineers sweat over actually add up to something. Storm, as an example, loads/unloads codecs on the 6 DSPs in a particular way they believe improves the presentation. You can't look at a spec sheet or REW graph (which has value) and really know how something sounds. Which is why I find it odd at best when people speak authoritatively about products they haven't heard and certainly haven't compared side by side. And that's my final point with regard to these forums, and it seems rather obvious to me anyway -- don't comment on how something sounds if you haven't heard it.
G-Rex, LydMekk and Bigmoviefan like this.
HT/Music Atmos setup with Scaena line arrays and Storm Audio processor
http://www.outreachav.com
Dealer for Paradigm/Anthem, NAD, Hegel, Storm Audio, PS Audio, more... PM about demos/specials
rblnr is offline
post #633 of 874 Old 04-01-2019, 07:28 AM
rblnr's Avatar
Quoted: 192 Post(s)
Liked: 171
And yet compare the presentation of an 8802/5 vs. an AVM60 and you will find the 60 does a noticeably better job of precise placement and tracking of discrete effects. Maybe it's a verbiage thing as we're trying to use words to describe sound, but 'steering' works for me.
Bigmoviefan likes this.
rblnr is offline
post #634 of 874 Old 04-01-2019, 07:36 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 649 Post(s)
Liked: 577
Please define "load" and "presentation" for us Rob. How does Storm "load" codecs differently than other processors and how does Storm objectively improve "presentation"?
sdrucker and Wookii like this.
RUR is offline
post #635 of 874 Old 04-01-2019, 07:45 AM
rblnr's Avatar
Quoted: 192 Post(s)
Liked: 171
It will only load one codec at a time. Meaning, if you choose Auro, it will offload Dolby or whatever codec was on the DSP and replace it w/Auro, so only one thing at a time is on the DSP. Engineers there will tell you this is an advantage. How this exactly influences the sound, I cannot tell you. It would be impossible (for me anyway) to separate that out from other elements affecting the sound.
rblnr is offline
post #636 of 874 Old 04-01-2019, 09:04 AM
noah katz's Avatar
Quoted: 1817 Post(s)
Liked: 631
Originally Posted by Apgood View Post
For Dirac the correction filters are calculated in you computer so assuming you are using the same version of Dirac with the same feature set enabled the correction filter should be pretty much the same regardless of the processor...
Seems to me that the RC is likely the biggest contributor to variable results, given the infinite possibilities for mic placement.
Well that's a head-scratcher, as it implies that the s/w is executed differently.
Noah
noah katz is offline
post #637 of 874 Old 04-01-2019, 10:14 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 649 Post(s)
Liked: 577
How is it an advantage, Rob i.e. what's the objective improvement?
You don't know what Storm means when they claim better "presentation"?
RUR is offline
post #638 of 874 Old 04-01-2019, 10:55 AM
Quoted: 33 Post(s)
I'm not interested in the technical details as a consumer, I just like the sound. I was able to test Arcam / NAD / Datasat and Trinnov 16, the Storm was the best sounding processor for me.
[email protected] likes this.
[email protected] is offline
post #639 of 874 Old 04-01-2019, 11:00 AM
Wookii's Avatar
Quoted: 2860 Post(s)
Liked: 2048
You did well to find a dealer with all five processors in the same room who could switch them quick enough to A-B, well done.
Wookii is offline
post #640 of 874 Old 04-01-2019, 11:10 AM
sdrucker's Avatar
Quoted: 1601 Post(s)
Liked: 1245
Yup, that would be something to hear: a level matched A/B setup using the same speaker gear and content.
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Speakers: PSB Imagine T3 LCR, Imagine T Wides/Side Surround 1, T2 Side Surrounds, Imagine XB rears, Image B6 screens, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 13.4.6
HAA HT1 and HT2 Certification
sdrucker is offline
post #641 of 874 Old 04-01-2019, 11:19 AM
rblnr's Avatar
Quoted: 192 Post(s)
Liked: 171
As noted above , I can't tell you exactly how that particular bit of methodology translates into this or that specific improvement. I'll ask an engineer next time I'm in conversation w/one.
As for better presentation, I can tell you that what you get over several other processors in (very) short; more dimensionality (a denser surroundfield that's feels more immersive and engaging), a sense of speed and ease, and more resolution across the board but particularly in low level details.
I know some of you seem to want a 'this translates to that', so-called objective answer, I'm sure the engineers can give you some of that but the bottom line is how it sounds and like many things it is more than the sum of its parts.
I will drop further down the esteem level of some: I've owned processors (as well as other components) since the B&K AVP2000 back in the stone age. Brands owned include ADA, Marantz, Anthem, Classe, Theta, et al., many long before I was a dealer (it's a second job that's fun, usually ) Throughout the years I've come across some components that have some real magic -- they break down the illusion of reproduction and transport somehow -- it's uncommon and a reason to pursue the hobby. Sure, there are engineering reasons why, but there's an art to it too that separates some from others. Examples: the Epos ES14 speakers, White Audio A series and Trinity amps going back, some Audio Research stuff and others more in the present. The Storm is one of these; I can break it down w/adjectives as above -- we're trying to describe sound here and there's no other way -- but it just ups the engagement level versus a lot of competitors, and justifies its price for this and other reasons.
Background info, I've participated in a few hundred sound mixes in my real job and consider myself a highly critical person, self- and otherwise. I make a point to always A/B stuff I talk about. I really don't care what sounds better and would be f-ing thrilled if $500 receiver was as good. Or a $5000 one. If/when I find that, I'll post here on AVS when I'm in a masochistic moment!
G-Rex likes this.
rblnr is offline
post #642 of 874 Old 04-01-2019, 11:45 AM
noah katz's Avatar
Liked: 631
Yes, if that's actually what happened, which I doubt; all [email protected] said was that he heard them all.
Noah
post #643 of 874 Old 04-01-2019, 12:03 PM
Wookii's Avatar
Liked: 2048
Of course it didn’t happen, that’s the point I was making, since listening to the same content, on the same speaker system, in the same room, with a very short duration in between, would be the only physically possible way to make any kind of assessment as to which processor is:
. . . the best sounding processor . . .
sdrucker and RUR like this.
Wookii is offline
post #644 of 874 Old 04-01-2019, 12:44 PM
Quoted: 33 Post(s)
The A / B test I have only done with Datasat and Storm, Arcam and NAD have no chance against the two.
I have all heard in a room and with the same speakers.
post #645 of 874 Old 04-01-2019, 01:21 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 649 Post(s)
Liked: 577
I know some of you seem to want a 'this translates to that', so-called objective answer.....
Yes, we would. Absent objective data, or a proper blind test, such claims hold no value and are apt to be construed as marketing, not fact.
That would be nice, if you can arrange it.
Wookii likes this.
RUR is offline
post #646 of 874 Old 04-01-2019, 01:30 PM
noah katz's Avatar
Liked: 631
Ah, so I fell into the sarchasm.
Noah
post #647 of 874 Old 04-01-2019, 02:09 PM
Marc Alexander's Avatar
Quoted: 5269 Post(s)
Liked: 4794
This is a point you need much more clarification on. Storm is using a MDS/TI decoder board which I doubt is proprietary to Storm. When it switches codecs, I highly doubt it operates any differently than any other DSP based system.
At Starke Sound we have experienced some glitches switching between Dolby Atmos (True HD) and DTS-HD MA. A few seconds delay to lock on the new signal and produce sound is excusable. But we did experience no codec lock and no sound on at least one occassion. We had to switch to a different input then back to resolve. Source is an Oppo UDP-203.
Have any other users experienced this?
sdurani and Wookii like this.
Marc Alexander is offline
post #648 of 874 Old 04-02-2019, 07:54 AM
Quoted: 833 Post(s)
Liked: 667
IIRC, this is a very common way to do it. That's why there's a 1-2 second on some processors when you switch codecs. This delay is much longer than the look ahead delay which is measured in tens of milliseconds.
Acurus advertises no delay when switching codecs, so presumably they're all loaded into the memory and the default latency is long enough for all the codecs.
If Storm is gonna make the bold claim that only loading one codec is some sort of sound-enhancing feature, the burden of proof is on them to prove it.
I compared them blind with as small a delay as possible, but still pretty long. I preferred the Anthem due to the difference in RC, which was very audible in my room. There were no steering or other perceived differences.
sdurani likes this.
post #649 of 874 Old 04-02-2019, 08:38 AM
rblnr's Avatar
Quoted: 192 Post(s)
Liked: 171
I've done and do this w/a bunch of the processors in two channel and 5.1.
rblnr is offline
post #650 of 874 Old 04-02-2019, 08:40 AM
rblnr's Avatar
Quoted: 192 Post(s)
Liked: 171
[QUOTE=duckymomo;57842596}
I compared them blind with as small a delay as possible, but still pretty long. I preferred the Anthem due to the difference in RC, which was very audible in my room. There were no steering or other perceived differences.[/QUOTE]
Did the same for both two channel music and 5.1 and our findings were different.
rblnr is offline
post #651 of 874 Old 04-02-2019, 08:41 AM
rblnr's Avatar
Quoted: 192 Post(s)
Liked: 171
Cool. If you go with the Storm, I'm confident you'll be very happy with it.
rblnr is offline
post #652 of 874 Old 04-02-2019, 12:41 PM
sdurani's Avatar
Quoted: 6963 Post(s)
Liked: 5938
Last I checked (CEDIA 2016), Acurus was using separate DSP chips (on separate daughter cards) for Dolby and DTS codecs. With each codec suite having its own dedicated DSP, there was no loading/unloading of codecs, allowing them to advertise no delay when switching codecs. The downside with separate Dolby and DTS signal paths was that they couldn't do cross-codec upmixing (even when it was allowed).
duckymomo likes this.
Sanjay
sdurani is offline
post #653 of 874 Old 04-02-2019, 12:55 PM
Liked: 4794
Another Storm clone {from Focal}:
Originally Posted by Marc Alexander View Post
Storm ISP 3D.16.12 ELITE
Focal ASTRAL 16
post #654 of 874 Old 04-02-2019, 01:41 PM
Liked: 4794
That is very interesting. I'd love to understand the pros & cons. Does the Acurus or Storm support Dolby Pro-logic II? Yamaha CX-A5x00 uses a TI/MDS solution and supports PLII.
The Lyngdorf/McIntosh has 8 ADI SHARCs (4th gen) [which seems like a lot] so I wonder if they are doing the same. Both DTS Neural X and DTS Neo X are supported. We tried to get Pro-logic II added/activated but ADI indicated that they did not already have code with PLII and Dolby Surround both running (nor was it a trivial task). Storm is using 4th gen SHARCs for other DSP functions like Dirac.
post #655 of 874 Old 04-02-2019, 02:08 PM
sdurani's Avatar
Liked: 5938
Not that I know of (it's an additional licensing cost).
They already had PLII and Neo. When Yamaha did the DTS:X update, the new upmixers were added, but the ones that were already in there weren't removed. Later products from Yamaha never had the old upmixers, so they came to market with just the new ones (DSU and Neural).
Sanjay
sdurani is offline
post #656 of 874 Old 04-02-2019, 06:07 PM
noah katz's Avatar
Liked: 631
The Focal sure is prettier.
IMO the Storm looks like industrial lab equipment of decades gone by.
G-Rex likes this.
Noah
post #657 of 874 Old 04-03-2019, 11:47 AM
rblnr's Avatar
Quoted: 192 Post(s)
Liked: 171
The Storm does not do PLII. For myself anyway, I'm not sure what a use case would be. If I'm upmixing a movie I'd use Dolby Surround, and for music, hands down Auro.
rblnr is offline
post #658 of 874 Old 04-03-2019, 12:17 PM
madhuski's Avatar
Quoted: 1286 Post(s)
Liked: 823
Looks like JTR will be using a StormAudio Processor for their room at Axpona.
https://www.avnirvana.com/threads/jo...ona-2019.4354/
madhuski is offline
post #659 of 874 Old 04-03-2019, 12:43 PM
Quoted: 833 Post(s)
Liked: 667
What Auro settings do you use for music?
post #660 of 874 Old 04-03-2019, 02:07 PM
rblnr's Avatar
Quoted: 192 Post(s)
Liked: 171
[QUOTE=duckymomo;57849748]
Depends on the recording. Strength goes from 1-15; for electronica I might go up to 15, a blues club recording likely lower as examples. I’ll also mix a bit to taste, for example upping the surrounds for electronica.
rblnr is offline
auro-3d , dolby atmos , dts:x , i.isp , stormaudio
