Receiver, Amp and Processors Deals Thread - Page 39 - AVS Forum | Home Theater Discussions And Reviews
 1341Likes
post #1141 of 1552 Old 07-27-2019, 07:03 AM
lemonslush's Avatar
Quoted: 987 Post(s)
Liked: 476
Originally Posted by Rich428 View Post
What’s this 20% deal Lemon?
Its on amazon and it should be a box when you view the item or at check out. Just like selecting a coupon normally. You wont see the 20% off if you had purchased something from that department before. I had my wife use her amazon login and she saw the 20% off coupon. Its dirt cheap price for a decent receiver.
Blorton likes this.
"we need more power" - My Wife.
Theater Build Thread - Wartooth
lemonslush is offline
post #1142 of 1552 Old 07-29-2019, 09:43 AM
Blorton's Avatar
Quoted: 35 Post(s)
Liked: 33
Thanks Lemonslush! My old receiver just died so this is excellent timing. Mine should be here tomorrow.
lemonslush likes this.
- Born half deaf in the 60's and cranking it to 11 ever since.
Living Room: Audio: Pioneer Elite VSX-26tx in 2.1 with Behringer B215XL and Dayton SUB-1500, Video: Roku Ultra and PS4 to an XBR65X930E
Home Gym: Denon DRA-395 in 2.0 with Klipsch KLF-10
wishlist - new LR AVR and Rythmik sub
Blorton is offline
post #1143 of 1552 Old 07-31-2019, 08:08 AM
Blorton's Avatar
Quoted: 35 Post(s)
Liked: 33
The receiver arrived yesterday and have just done basic connections and the quick ypao setup. Sounds great!
Thanks again for the pointer.
cocrh likes this.
Blorton is offline
post #1144 of 1552 Old 08-05-2019, 06:23 PM
Quoted: 14 Post(s)
Liked: 2
Originally Posted by shinksma View Post
Yes, exactly. I live in FL too, and we are the lightning "capital" of the US. And it doesn't need to be a "power" surge - I've had stuff that was "off" via a power strip but still connected to ground fry from a ground surge - nearby lightning causes a surge backwards up the ground lines and can fry stuff from the back side, as it were. HDMI is especially sensitive to this - although I hope current design have improved hardiness.
Any solution to this lightening , like ground-ing etc?
mapleoak is offline
post #1145 of 1552 Old 08-06-2019, 05:30 AM
Blorton's Avatar
Quoted: 35 Post(s)
Liked: 33
I’m sure a good electrician can fit a suppressor on the breaker panel to address those issues.
Edit: What you are looking for is called a whole house surge suppressor.
mapleoak likes this.
Blorton is offline
post #1146 of 1552 Old 08-07-2019, 08:22 AM
eaayoung's Avatar
Quoted: 357 Post(s)
Liked: 216
Just had a whole house surge protector installed in my home yesterday. Cost of the unit was $168 on Amazon and $225 to install. The one I used (Leviton 51120-1 Panel Protector, 120/240-Volt) is a commercial grade unit and very good per my electrician. It needs to be installed on one of the first two spots in your main electrical panel to be effective. Additionally, make sure you put all sensitive electronics on a surge device at the plug as well. And don't forget to have a surge device for your phone and cable. I have that covered with a device installed where my cable line comes into the home with the cable going through the surge device before going to the cable modem. Phone line is also routed through the surge device as well.
eaayoung is online now
post #1147 of 1552 Old 08-07-2019, 12:23 PM
rakstr's Avatar
Quoted: 502 Post(s)
Liked: 232
I applaud the use of surge devices but they will do nothing for lightning, especially if you've got low voltage connections between devices like a phone line or network or coax or HDMI distribution. I know this from 1st hand experience.
Gator99 and Peja like this.
rakstr is online now
post #1148 of 1552 Old 08-07-2019, 02:38 PM
Gator99's Avatar
Quoted: 90 Post(s)
I agree, as lightning hit a tree 30+ feet from my house (Florida) and fried all network connections devices, $5,000 of damage.
Sent from my Pixel 2 XL using Tapatalk
Jeff
Gator99 is offline
post #1149 of 1552 Old 08-07-2019, 02:48 PM
rakstr's Avatar
Quoted: 502 Post(s)
Liked: 232
My ground strike across the street about 100 or more yards away was around $50K.
post #1150 of 1552 Old 08-07-2019, 02:54 PM
Gator99's Avatar
Quoted: 90 Post(s)
That does suck, the funny part of my strike is everything worked but only on Wifi.
Jeff
Gator99 is offline
post #1151 of 1552 Old 08-07-2019, 07:51 PM
eaayoung's Avatar
Quoted: 357 Post(s)
Liked: 216
I made a decision to install a whole house device for the first time after lightning hit my home when I was living in Florida. It caused extensive damage to wiring, appliances, alarm, phones and electrical devices in my home. The second time I got hit, the damage was minimal. I've also been around of lightning events in my work where a whole house surge device was fried plus ever electrical device in the home. It can be a roll of the dice.
The only way to ensure 100% protection against surges caused by lightning is to unplug your electrical devices before a storm hits. But who does that? And who does that every time? There's a reason The National Electric Code recommends surge protectors. They recommend surge devices because they work. Not all the time of course. But you increase your odds to have less damage with their use. They also recommend a three layered approached: 1) Surge device at the meter, 2) a whole house surge device in the electrical panel and 3) surge protection devices at the electrical plugs. Whether you follow their advice is your choice. But they are an organization knows more about this subject than some of the keyboard warriors on this forum.
Blorton, checker9 and mapleoak like this.
post #1152 of 1552 Old 08-27-2019, 12:48 PM
Liked: 3
Is anyone seeing any Labor Day deals on receivers, specifically Denon? I've looked around but haven't seen anything.
TooHappy is offline
post #1153 of 1552 Old 08-28-2019, 12:37 PM
Quoted: 622 Post(s)
Liked: 558
Crutchfield and Safe and Sound has them on sale but not at stellar discounts.
https://www.safeandsoundhq.com/colle...rice-ascending
Probably the best deal Safe and Sound has is on the X2500 and X4500.
cocrh is online now
post #1154 of 1552 Old 08-28-2019, 02:09 PM
pjp
pjp's Avatar
Quoted: 971 Post(s)
Liked: 534
This GFCI adapter device is pretty cool -> https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The outlet shuts off both on surges and on loss of power. Often the power goes out briefly before surges happen, so the outlet will shut itself off on the first power loss and be isolated from everything that follows until you manually hit the switch to turn it back on. I use this to protect my tube amp.
Pete7874 likes this.
pjp is offline
post #1155 of 1552 Old 08-28-2019, 03:07 PM
MrKyle's Avatar
Quoted: 187 Post(s)
Liked: 98
Am I looking at the wrong spot? Only X4500 I see discounted are Open Box / Factory Refurbed ones
I'm tempted by the open box one but it doesn't say much about what damage there might be... the open box still maintains full Denon warranty right?
Living Room - XBR77A9G / X800M2 / X4500H / ATV4K
Klipsch RF-7 iii - RC-64 iii - 4x CDT 5650 II - 2x R-5800 W II
2x HSU VTF-15H Mk2 / miniDSP 2x4HD
Bedroom - 65VT30
MrKyle is online now
post #1156 of 1552 Old 08-28-2019, 07:00 PM
Quoted: 622 Post(s)
Liked: 558
Yes, open box has full warr. Call them and see what they can do. Sometimes they might be able to get you a brand new one for a bit more as some have done here on AVS.
MrKyle likes this.
cocrh is online now
post #1157 of 1552 Old 08-29-2019, 05:40 AM
Pete7874's Avatar
Quoted: 472 Post(s)
Liked: 504
Amazon has the X3600H for $899.
MrKyle likes this.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Samsung UN55B7100  Denon AVR-S740H  Chane A2.4  Dayton MK402X  Premier Acoustic PA120  Roku Premiere Plus  Squeezebox Classic  CCA
Pete7874 is offline
post #1158 of 1552 Old 08-29-2019, 08:23 AM
MrKyle's Avatar
Quoted: 187 Post(s)
Liked: 98
Looks like the X4500h price dropped to $1,399 on Denon Site / BB etc
Bedroom - 65VT30
post #1159 of 1552 Old 08-29-2019, 10:13 AM
MrKyle's Avatar
Quoted: 187 Post(s)
Liked: 98
I just called in to Safe and Sound HQ - Got a new X4500H for $999 out the door shipped to me in CA
355F1 and TooHappy like this.
Bedroom - 65VT30
post #1160 of 1552 Old 08-29-2019, 10:18 AM
Pete7874's Avatar
Quoted: 472 Post(s)
Liked: 504
Wow! Crazy deal.
How can they expect to sell the refurbs at $999, if they're giving away new ones at the same price?
MrKyle and MRAYB like this.
Pete7874 is offline
post #1161 of 1552 Old 08-29-2019, 10:27 AM
MrKyle's Avatar
Quoted: 187 Post(s)
Liked: 98
Originally Posted by Pete7874 View Post
Wow! Crazy deal.
I know, right? I actually called asking about the Open box one @ $950 to see if it was a scratch/dent etc or what was missing and the guy asked if he could put me on a hold to see if they could work a deal on a new one instead.
Bedroom - 65VT30
post #1162 of 1552 Old 08-29-2019, 10:37 AM
MRAYB's Avatar
Quoted: 547 Post(s)
Liked: 2244
And I thought I was doing good with a new X4400H for $799 in June from an authorized dealer on Amazon. The 4400 is going for a little more than your 4500 deal currently. Love the Denon. I think you will also, enjoy.
MrKyle likes this.
MRAYB is online now
post #1163 of 1552 Old 08-29-2019, 12:30 PM
MrKyle's Avatar
Quoted: 187 Post(s)
Liked: 98
Thanks! Looking forward to it - I just got some Pioneer Elite SP-EBS73-LR speakers for my surrounds + rear elevation/Atmos speakers so needed to bump up the AVR for 5.1.4!
MRAYB likes this.
Bedroom - 65VT30
post #1164 of 1552 Old 09-09-2019, 05:46 AM
bslep's Avatar
Quoted: 297 Post(s)
Liked: 192
Worldwidestereo.com has the Yamaha MX-A5200 Aventage 11 channel amplifier on sale for $1,949.95 plus another 10% off with coupon code WWSALE for an out the door price of $1,754.95.
eriksells916 likes this.
bslep is offline
post #1165 of 1552 Old 09-13-2019, 08:01 PM
flyinrazrback's Avatar
Quoted: 302 Post(s)
Liked: 209
Any sales out there on the Anthem MRX 720?
flyinrazrback is offline
post #1166 of 1552 Old 09-16-2019, 03:53 PM
wdskuk's Avatar
I like to know as well.
wdskuk is offline
post #1167 of 1552 Old 09-19-2019, 07:52 AM
Quoted: 30 Post(s)
Question pIONEER eLITE sc-lx801 SALE
Is $999 a good price for the Pioneer Elite SC-LX801 receiver? The seller is not an authorized dealer but is a major retail operation in business since 2002
Purdue Boiler is offline
post #1168 of 1552 Old 09-19-2019, 07:54 AM
VisionxOrb's Avatar
Quoted: 381 Post(s)
Liked: 270
id rather buy the onkyo tx-rz840 thats going for 849 at amazon, atleast it was two days ago. The lx801 is a 3yr old product.
asabrag likes this.
2000 watts of power and climbing
-Fred
VisionxOrb is offline
post #1169 of 1552 Old 09-19-2019, 08:03 AM
skylarlove1999's Avatar
Quoted: 2276 Post(s)
Liked: 2432
I would never buy from a non authorized dealer. You don't receive any warranty whatsoever from the manufacturer at that point. I'm sure the major retail operation claims that they have their own warranty that's just as good as the manufacturers until it isn't. Just my two cents.
Sent from my SM-G965U using Tapatalk
asabrag likes this.
skylarlove1999 is offline
post #1170 of 1552 Old 09-19-2019, 12:15 PM
checker9's Avatar
Quoted: 1659 Post(s)
Liked: 380
Anyone seen any good deals on Denon X3500 or X3400 refurbished or new?
checker9 is offline
denon s740h , yamaha tsr-7850
