QSC Q-Sys: Immersive Audio Channel Expansion (Atmos and Beyond) - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 76Likes
post #211 of 271 Old 08-17-2018, 02:03 PM
kingwiggi's Avatar
Quoted: 552 Post(s)
Liked: 354
Originally Posted by Jish9 View Post
I don't know if we are talking about the same thing.
Obviously not, I was responding to your comment
I think the most elegant solution is the trigger box if you want to solder and build something.
That's why I quoted it
Its always going to be simpler to buy something off the shelf, no disagreement there.
However simple is not always best so why not use the trigger out in the pre-pro to power on/off the amps so we loop back around to the diagram, now thats what I call an elegant solution
Trinnov Altitude 32, LCR JBL M2, JBL LSR 708i, 705i, Q-SYS Core 110f, Amps- QSC CXD4.2Q, 4.3Q, 4.5Q
Kaleidescape Strato, Zapitti 4K HDR Duo, Xbox One X, 8TB Tivo Roamio Pro,
JVC RS600 + ISCO IIIL, 158" 2.40:1 AT screen, Calman 5 Enthusiast, i1 Pro 2, i1 Display Pro, Spyder 5, 3D LUT Box
Oppo UDP-203, BDP-105, Onkyo DAC-1000s, Onkyo DP-X1 DAP, QNAP TVS-871
kingwiggi is offline
post #212 of 271 Old 08-18-2018, 04:08 PM
kingwiggi's Avatar
Quoted: 552 Post(s)
Liked: 354
Little bit of entertainment
Practice your Lua - Block programming skills
post #213 of 271 Old 08-19-2018, 03:58 AM - Thread Starter
BrolicBeast's Avatar
Quoted: 1802 Post(s)
Liked: 2122
Hey guys, I've been following the suggestions here, just couldn't give a detailed response until now....I'm VERY thankful for that diagram.....and also for the sharing of the recommendation to leave them on. I'm going to try that first, and see how that affects my electric bill. If theres no real hit, then I'll def do that! If there is, then I'm going to follow that digran, BUT I'll have some questions on it because I dont understand everything in it (I haven't built a circuit from a diagram since college). Now, the power strip wouldnt work for me unless I got a few of them. Each amp has it's own 20A circuit, so I'd need one switched MA strip per amp...which I dont mind and I'll def go that route if leaving the DCAs on impacts my electric bill too much.
Sent from my SM-G955U using Tapatalk
BrolicBeast is offline
post #214 of 271 Old 08-20-2018, 07:48 AM
Jish9's Avatar
Quoted: 276 Post(s)
Liked: 106
Out of curiosity Matt what do you have them plugged into now? 7 different outlets? It is no different than when running amps for pro tours. A friend of ours, who is a sound engineers and tours with Metallica, uses the same setup with the Middle Atlantic 20A switcher. That's who directed me to the product in the first place. Not trying to say what you should do, only that the above logic does not hold in practice.
Jish9 is offline
post #215 of 271 Old 08-20-2018, 11:14 AM - Thread Starter
Liked: 2122
Yup, 7 different outlets ...one per amp. You're saying one switched outlet per dedicated circuit? Any idea what pricing is?
post #216 of 271 Old 08-20-2018, 11:26 AM
Jish9's Avatar
Quoted: 276 Post(s)
Liked: 106
You can find them used for about $300 each on the 20A model. There is no way that you are drawing that much current from each amp to where 7 individual circuits would be needed. Regardless, given your current setup, you would probably need a couple of them and quite frankly making the circuit box would be cheaper.
You should post some pictures as you are making it and of the finished product. I think it would be an asset for others with a similar situation to emulate. Good luck with the GTG.
BrolicBeast likes this.
Jish9 is offline
post #217 of 271 Old 08-21-2018, 09:15 AM
kingwiggi's Avatar
Quoted: 552 Post(s)
Liked: 354
Just purchased two TSC-7W's to add to my QSC collection.
$250 for both - NIB, MSRP $1499 each
Black Friday came early
post #218 of 271 Old 08-21-2018, 09:32 AM - Thread Starter
Liked: 2122
Sounds like a plan!
Originally Posted by kingwiggi View Post
Just purchased two QSC-7W's to add to my QSC collection.
WHERE WHERE WHERE?
post #219 of 271 Old 08-21-2018, 09:42 AM
kingwiggi's Avatar
Quoted: 552 Post(s)
Liked: 354
Sounds like a plan! WHERE WHERE WHERE?
Unfortunately the seller only had 4, I would have grabbed all of them but by the time I blinked two had already gone. Perfect case of some eBay seller not realizing what they had.
Sent from my iPhone using Tapatalk Pro
post #220 of 271 Old 09-28-2018, 03:35 AM - Thread Starter
Liked: 2122
Uploading some pics of my UCI....my listening preferences change based on content. Thankfully, Qsys is here to help! Lol. Ive found it helpful to represent actual speaker positions with graphical approximations--it makes tweaking so easy.
Tapping a blue box above each speaker does two things: tapping and dragging up or down will increase or decrease the gain, but more importantly (and here’s why I went with this box as opposed to the knob), I can tap once and input a gain value directly. This is important because it allows for a level of accuracy not really possible (or not as quickly possible) as with the knobs and other options. PEQ is accessible on the “Wall” pages.
There are several listening modes, each one the product of painstaking testing and lengthy evaluation:
CALIBRATION: this mode disables all curves, shelves, and customizations to allow me to take neutral speaker/subwoofer measurements.
ATMOS: This mutes all non-ceiling speakers. Great for determining how much overhead content has been mixed into a track.
MUSIC: This mode was created purely for two-channel music. I’ve tailored this mode to really bring voices forward. The result is a very clear-sounding vocal presentation.
MOVIE NIGHT: This mode is basically for casual watching. Ticks all of the right boxes calibration-wise, and is basically “industry standard” before customization. If the other modes are the “after” then this is the “before.”
BEAST MODE: This is the mode that sounds great with everything. All material thrown at it excels. Has been customized to provide a high-impact experience with zero listening fatigue, even at very loud volumes.
THE BROLIC EXPERIENCE: This mode tightens the immersive audio bubble ( Dolby Atmos, DTS:X) around the seating area. This is certainly the recommended listening mode.
DANGER CLOSE: This mode is extreme. This mode is not for the faint of heart, as it uses a very special EQ shelf in conjunction with some other tweaks on the subwoofers that really put you into the action. This mode is, to me, the ULTIMATE listening mode. :-)
jjcook and DougUSMC like this.
post #221 of 271 Old 10-11-2018, 04:11 AM - Thread Starter
Liked: 2122
Posted this in my build thread, but wanted to re-post here since it directly involves QSys equalization comparisons against a well-measuring baseline.
______________________
Now that the G2G event has come and gone, I am posting bass measurements of the primary modes used, for both rows. I started with this baseline and then tuned each mode by ear.
I was very adamant about NOT measuring at any point during the customization process because I wanted my ears—not graphs—to tell me what I really liked to hear. I wanted the same thing for the G2G—I wanted everyone to judge the sound and video quality and impact based on subjective, not objective analyses.
What you’ll see below are the following: Rear Row 0-100Hz, Front Row 0-100Hz. The modes I measured are:
The Ultimate Experience (formerly Danger Close)
The Brolic Experience
The Movie Experience (Formerly Beast Mode)
The Music Experience (formerly Music)
Here are the graphs. Each mode has slight (or not so slight) variations in slope at select frequencies. Compare these modes to the baseline picture near the top of this post. Note that I enabled the REW feature that provides as much separation as possible between lines, so please the dB values are only relative within each line. dB values are not relative across lines:
Front Row Bass Response:
Rear Row Bass Response:
Having swapped back and forth between the “standard” and my various “custom” modes, I vastly prefer the custom modes.
Also re-posting the list that shows which mode was used with which content:
Sent from my iPad using Tapatalk Pro
Marc Alexander and audiofan1 like this.
post #222 of 271 Old 10-13-2018, 09:54 PM
Jish9's Avatar
Quoted: 276 Post(s)
Liked: 106
QSC I/O 8Flex
If anyone is interested, I am selling off one of my brand new QSC I/O 8Flex units that I am not using. All original accessories and packaging included along with appropriate AC adapter wired for immediate use versus POE. PM me if interested.
ID:	2468236   Click image for larger version
Jish9 is offline
post #223 of 271 Old 11-29-2018, 02:51 PM
dsl1's Avatar
Quoted: 201 Post(s)
Liked: 417
Joined the q-sys club, super impressed. This is head and shoulders above any other platform I've tried.
jjcook and BrolicBeast like this.
________________________________________
DIY Mid Hi Speakers Build - SKHorn Build - Gjallarhorn Build SOLD - Othorn Build SOLD - SEOS 12 Build - Other Gear: JVC NX5 - Seymour Matinee Black - QSC CX4.5Q amps x 5 - QSC Q-sys 110f - Speakerpower 6000 x2
dsl1 is offline
post #224 of 271 Old 11-29-2018, 10:54 PM
Jish9's Avatar
Quoted: 276 Post(s)
Liked: 106
This is one of the reasons why I never upgraded to the Trinnov. The flexibility of the Core and the robust nature of the design architecture is truly something else. They will also be coming out with their own cinema processor that can do immersive audio in the near future. Once you learn how to design, you can create some of the most immersive experiences all the while in a scalable fully customizable fashion. Welcome to the family!
dsl1 likes this.
Jish9 is offline
post #225 of 271 Old 11-30-2018, 12:13 AM
Apgood's Avatar
Quoted: 158 Post(s)
Liked: 78
You got any links about the cinema processor? Is it for home or commerical (or commercial ficussed but can decide home formats)?
DougUSMC likes this.
Apgood is offline
post #226 of 271 Old 11-30-2018, 05:59 AM
Jish9's Avatar
Quoted: 276 Post(s)
Liked: 106
That have yet to release it and hence no product link. This was info that I got while talking with them directly. As they are on the pro side, it will most likely compete directly with the Dolby commercial cinema processor but can probably be used for non commercial mixes as well. In our discussion they also spoke to being an alternative to Trinnov so I suspect pricing to be similar.
Jish9 is offline
post #227 of 271 Old 11-30-2018, 06:08 AM
Apgood's Avatar
Quoted: 158 Post(s)
Liked: 78
Sounds interesting. They give any indication on release timeframe?
Apgood is offline
post #228 of 271 Old 11-30-2018, 06:26 AM
Jish9's Avatar
Quoted: 276 Post(s)
Liked: 106
Apparently it will be one of two products released in 2019-2020. That is about as far as they knew. I am suspecting in the next 2-3 years as product development on the commercial side takes longer due to their specific application and clientele.
Jish9 is offline
post #229 of 271 Old 11-30-2018, 06:58 AM
Apgood's Avatar
Quoted: 158 Post(s)
Liked: 78
It'll be interesting to see what they develop.
Apgood is offline
post #230 of 271 Old 11-30-2018, 09:29 AM
sdurani's Avatar
Quoted: 6984 Post(s)
Liked: 5967
Probably was a matter of time before QSC came up with a cinema decoder. Their capability to natively decode/render the cinema version of DTS:X (DTS MDA) was mentioned back in 2014:
https://www.qsc.com/news/news/detail...mersive-audio/
Doubt that Dolby would let anyone else manufacture a cinema Atmos decoder to compete with their own. Better chance that Barco would license cinema Auro decoding.
Sanjay
sdurani is offline
post #231 of 271 Old 11-30-2018, 03:24 PM
Roger Dressler's Avatar
Quoted: 2930 Post(s)
Liked: 1686
I suspect that the QSC product would be aimed at playing the newly minted SMPTE ST 2098-2 "IAB" (Immersive Audio Bitstream) format. It is directly based on the Dolby Atmos format, so those files should also be playable -- theoretically. TBD.
What it probably will not play is any consumer bitstream format like DD, DD+, TrueHD, Atmos, or DTS:X. For that, some external decoder will be needed, same as today. Dolby's CP850 supports various Dolby codecs for alternative content (Dolby TrueHD, Dolby Digital Plus™, Dolby Digital, and Dolby E upmixing of non-digital cinema package content). Absent is consumer Dolby Atmos.
In case anyone is interested in the ST 2098-2 standard, here's an informative presentation. Link
jamin, sdurani and appelz like this.
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win7 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is offline
post #232 of 271 Old 11-30-2018, 06:56 PM
Apgood's Avatar
Quoted: 158 Post(s)
Liked: 78
What it probably will not play is any consumer bitstream format like DD, DD+, TrueHD, Atmos, or DTS:X. For that, some external decoder will be needed, same as today. Dolby's CP850 supports various Dolby codecs for alternative content (Dolby TrueHD, Dolby Digital Plus, Dolby Digital, and Dolby E upmixing of non-digital cinema package content). Absent is consumer Dolby Atmos.
The q-sys core already has a decoder built into it for DTS MDA and the "H" version of their new IO box already decided everything up to DTS HD MA and DD+ & Dolby Surround 7.1 via HDMI, but not TrueHD. Saw this on the q-sys Facebook group programming page supported with some photos.
Apgood is offline
post #233 of 271 Old 11-30-2018, 07:41 PM
sdurani's Avatar
Liked: 5967
Thanx for the link. Object coordinates look like they're based on the consumer version of Atmos (values = 0 to 1, location 0,0,0 is left bottom corner, etc) rather than cinema Atmos. Is IAB coming to a cinema (or mixing room) near you? Or is that what you meant by "theoretically"?
Sanjay
sdurani is offline
post #234 of 271 Old 11-30-2018, 07:48 PM
Liked: 1686
Oh yes, Q-Sys was the first to support DTS:X Cinema soundtracks (aka DTS MDA bitstreams). Just to clarify, this is not related with the DTS:X consumer bitstream format.
I stand corrected -- I see the DCIO box can ingest DD+ and DTS-HD (not HD MA). These are lossy codecs, probably for things like The Met on Fathom Events. Dolby Surround is their 7.1-channel upmixer for stereo sources. Be that as it may, it does not get us any closer to playing immersive bitstreams from UHD discs though Q-Sys.
post #235 of 271 Old 11-30-2018, 07:56 PM
Liked: 1686
The choice of origin for the Cartesian coordinates is quite arbitrary. As long as we stick with it for the whole movie!
Near me? Doubt it. I don't even have an Atmos cinema near me. More likely near you.
'Theoretically' refers to the ability of third-party (non-Dolby) IAB-compliant playback systems to also be able to play Atmos soundtracks as stated in the presentation.
post #236 of 271 Old 11-30-2018, 08:32 PM
sdurani's Avatar
Liked: 5967
'Twas a figure of speech (coming to a theatre near you), asking whether IAB is already in use or soon to be.
When I saw "Dolby Surround 7.1" in the previous post, I though it referred to the theatrical format that debuted with Toy Story 3. Is that what's in the QSC or Dolby's consumer upmixer?
Sanjay
sdurani is offline
post #237 of 271 Old 11-30-2018, 08:38 PM
Liked: 1686
Ahh -- of course. Well, I have no idea.
I'm certain it is their upmixer. So much of the "non-sync" programming comes with stereo soundtracks, it needs something to drive the center speaker, at minimum.
post #238 of 271 Old 11-30-2018, 08:56 PM
Apgood's Avatar
Quoted: 158 Post(s)
Liked: 78
For the DTS HD MA decide by the DCIO box I thought the same thing but there was the QSC distributor from Hong Kong showing it accepting a DTS HD MA input signal. He did confirm that he tried True HD and that didn't work.
Mind you for Home use I think the DCIO box is largely redundant as anything DTS-X or Atmos or Auro3D you can just decode into PCM a BD player or computer anyway and send straight to the core. It's really the DTS-X, Atmos or Auro3D tracks that some sort of special decoding box is needed for.
Pity there's no software solution available that can decide the bitstreams in to the different speaker layouts.... Assume the authoring tools can't do it or they are so expensive that it's cheaper to buy a Trinnov..
Apgood is offline
post #239 of 271 Old 12-01-2018, 04:46 AM
mmiles's Avatar
Quoted: 816 Post(s)
Liked: 432
Bob Lee from QSC use to post on AVS quite often a few years ago. Maybe Roger and Sanjay can poke him and get him back.
Mike Miles
[email protected]
mmiles is online now
post #240 of 271 Old 12-01-2018, 10:00 AM
Liked: 1686
I was just basing my comment on the QSC literature. It is usually correct. Also, a DTS HD MA bitstream carries a lossy DTS HD core inside so it may just been playing that. Whereas a TrueHD bitstream does not carry the lossy DD companion inside.
Yes, you can at least decode these in lossless quality up to the base 7.1 channels, but not the height channels.
Yes, you will still need an external decoder for the full immersive experience, same as today.
If you already have a Pro Tools rig, you can add the Dolby Atmos plugin for $300.
