"Official" 2017 Marantz SR8012 Owner's thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 1100Likes
post #991 of 1644 Old 09-16-2018, 07:36 AM
zimmo's Avatar
Quoted: 309 Post(s)
Liked: 114
BIGGUYCA
I try 6400 and 8012 before I buy 8012 .the model 8012 beat and eat 6400 ,is not same class the 6400 same to 7012 ,the componants Inside the 8012 is more better and the sound for me only the avr -x8500h and 8805 is ressembler to marantz sr8012.
marantz av 8805, 13 chanels, emotiva 2 xpa 5 gen1,1 emotiva xpa3 gen3, 7.4.6,4 speakers monitor 11 ,2 paradigm studio 100 v2,4 ceillings speakers ss82w sweet spot earthquake ,2 earthquake ecs-8.0,1 center Paradigm cc390,4 subs klipsch r-sw112 sw.antimod 8033 perfect bass kit paradigm, Buttkicker amplificateur lfe 1000 watts, , tv oled 65e6p,, room 12x25x7,bluray player oppo bdp 203,4coolers ac infinity s9 fan.
zimmo is offline
post #992 of 1644 Old 09-16-2018, 04:52 PM
RC1991's Avatar
Quoted: 65 Post(s)
Liked: 31
I just set-up an 8012 coming from a NAD T777 v2. I didn't want to deal with updating the MDC on the T777 and even with the update the 8012 promised some nice additional features (Auro 3D, etc). In any event I am quite pleased and after running Audessey I think the sound is actually better than where I was the T777, especially with movies. I set up a 7.1.2 Atmos configuration just using some Def Tech bookshelf speakers at the moment for makeshift Atmos speakers. I did order a pair of the Elac Atmos modules for now given that the KEF Q50a are impossible to find at the moment.
The one issue I've had is that I have an Oppo BDP-95 and when I went to play an SACD via HDMI I noticed I had no sound. Same deal with other discs...the analog 7.1 did produce sound. I swapped out the Oppo for another player in the same input on the 8012 so that was fine and the Oppo worked on another receiver. It read on this forum that there was a non-public firmware update for the Oppo that solves the issue as others also had the same issue with the Marantz 8802 and Oppo BDP-95. Has anyone here experienced anything like this and if so, does anyone have the Oppo firmware that solves it? I emailed Oppo support as well and perhaps they still have it. Also, does anyone know if the Marantz remote can change the channels on an Xfinity cable box? Thanks!
UPDATE: Oppo emailed me the link to the firmware (on a Sunday afternoon no less) and that fixed the issue!
CrazyEddie likes this.
KEF R900, R600C, Q500, Q100; Oppo BDP-95; Marantz SR8012; Sony UDP-X800; Technics SL-5; NAD Phono Preamp; Apple TV 4th Gen (Also....Parasound Halo A23; NAD T777v2)
RC1991 is offline
post #993 of 1644 Old 09-17-2018, 02:16 AM
srinibrick's Avatar
Liked: 1
Can anyone guide me to interconnect marantz sr8012 and marantz sr7007 so that i can drive the height channels from sr7007 and in doing so can the unused height channels of sr8012 be bridged to the front channels.
srinibrick is offline
post #994 of 1644 Old 09-17-2018, 03:48 AM
bluemoon737's Avatar
Quoted: 2204 Post(s)
Liked: 2705
I could very well be wrong and I'm sure one of our experts will weigh in, but I don't think you can do that.
-Jeff-
Man cave: Sony XBR75Z9D, Marantz SR8012, and OPPO UDP-203
Living room: Sony XBR75X950G, Denon x4500, and Sony UBP-X800M2
bluemoon737 is offline
post #995 of 1644 Old 09-17-2018, 08:20 AM
Quoted: 2453 Post(s)
Liked: 1174
The using the 7007's amps to run the heights; or the bridging of the fronts; or both...
Shopping List:
TV: LG C9/C10, or Samsung Q90R, or Sony ...
Blu-ray: Panasonic UB820, or Pioneer Elite LX500, or Sony X800M
AVR/Pre-pro: Marantz 8805/7705 or 8012, or Yamaha 5200 or 3080
Speakers: GE Triton One.R, or ML ElectroMotion ESL X
New24K is offline
post #996 of 1644 Old 09-17-2018, 09:05 AM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2848
Originally Posted by New24K View Post
The using the 7007's amps to fun the heights; or the bridging of the fronts; or both...
Bridging.
Receiver speaker outputs usually ground one of the binding posts. Connecting two amps together will ground one of the active outputs and "let the magic smoke out". You need a specially designed amplifier which is designed for bridging.
Using an old receiver as a multichannel amplifier works fine: set its volume control to 80 and connect its multichannel analog inputs to appropriate outputs on the primary receiver. Then run Audyssey in the primary receiver.
bluemoon737 likes this.
Selden
Selden Ball is offline
post #997 of 1644 Old 09-17-2018, 01:28 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6677 Post(s)
Liked: 6672
Originally Posted by Robert Crawford View Post
How much of an improvement is the 8012 over my Yamaha 3060? Also, I'm thinking of getting an audio calibration so any calibrator recommendations?
Chad B : [email protected]
Not disagreeing, but we do have the report saying it would be offered. I really have no dog in this fight because I have no forseeable need for the full 2.1 feature set, but just want to "officially" put this to bed if we could.
We will know soon enough for sure Marantz / Denon have done updates before like this, so I am sure they can do it again.....
I will note The 84" LG TV was supposed to get a free board upgrade so it could except a 4K signal in, they did release the update at just under $500, not free ...... Sure a company would get bad press for promising something but.......
Cleveland Plasma is offline
post #998 of 1644 Old 09-18-2018, 04:45 AM
Liked: 0
Add more amp to 8012
@zimmo
I see that ju are using "1 emotiva xpa 5 gen1,2 emotiva xpa3 gen3" for your Sr8012. I own the SR8012 and wonder if there is going to be a big diffrent to add emotivas amps for preout ?
Running XTZ Cinema 7.2.4 system
Are you using XPA 5 for surround and XPA 3 for RCL and the internal amp for atmos ?
/thx in adv.
Denny C is offline
post #999 of 1644 Old 09-18-2018, 05:04 AM
rwestley's Avatar
Quoted: 460 Post(s)
Liked: 300
Looking on the Marantz website it seems that I-Max enhanced will be a firmware upgrade sometime in October for the 8012. It is now listed as part of the features.
rwestley is online now
post #1000 of 1644 Old 09-18-2018, 05:23 AM
zimmo's Avatar
Quoted: 309 Post(s)
Liked: 114
DENNISC
I running alone first they sr 8012 but I change my room for more bigger ,that why I put power amplifier and when I see the film I likre to lesson strong sound .
this receiver (sr8012) is very good ,for now to me is the better sound for other receiver in this catégory.
my first xpa-3 gen3 is collect front speakers (3).
second xpa3-gen3 collect whit 3 surround (side left and right side and and back left side).
xpa-5 gen 1 collect whit 4 atmos top back and front and stay one out ,I put to the back surround right side .
all collect in preout whit cable rca .
the sub (4 subs collect preout)in 2 cables Y .
my cinema home have 7.4.4 and éventually I like to have 15 speakers and for shur I need xpa-5 gen 2 or 3 .
zimmo is offline
post #1001 of 1644 Old 09-18-2018, 05:39 AM
Liked: 0
Originally Posted by zimmo View Post
DENNISC
Hi
Thanks for your quick feedback.
I will test a emotiva 3ch for LRC or perhaps a 7ch for base-layout and see if thats improve. Or just a 3ch for RLC and 4ch for the other or 6 ch(furture proof for 9.x setup) when RMC-1 hit´s the market
Denny C is offline
post #1002 of 1644 Old 09-18-2018, 08:06 AM
zimmo's Avatar
Quoted: 309 Post(s)
Liked: 114
DENNIC
dont forget they xpa-gen 3 have more power ex; xpa3gen1or 2 have 200 watts each chanels ,xpa3gen3 have 275 watts each chanels. all gen3 have more power except
xpa7 gen3 have 200watts each chanels.
now we have new model xpa-dr1-2-3-whit very more power see in site émotiva but more expensif.
zimmo is offline
post #1003 of 1644 Old 09-18-2018, 10:31 AM
bigguyca's Avatar
Quoted: 1100 Post(s)
Liked: 929
Bridging amplifiers requires access to an inverted signal to drive one of the amplifiers. How do propose to obtain this inverted signal?
The amplifiers in AVR's, including the SR8012, are quite limited in their ability to provide current to a load (loudspeaker). The voltage on the power rails drops as the output and thus current increases. Bridging coulds provide double the voltage output (in a perfect world) if more current were available. Since the amplifiers are already current limited there is no additional current available. No added output is the best case. The SR8012 is not designed for its amplifier channels to be bridged so the results are unpredictable.
bigguyca is offline
post #1004 of 1644 Old 09-18-2018, 10:51 AM
CrazyEddie's Avatar
Quoted: 295 Post(s)
Liked: 255
LOL. IOWs, the magic smoke could escape.
CrazyEddie is offline
post #1005 of 1644 Old 09-20-2018, 12:29 AM
srinibrick's Avatar
Liked: 1
using the height channel on marantz sr7007 is the first option and bridging marantz sr8012 if possible
is the second option
post #1006 of 1644 Old 09-20-2018, 12:37 AM
srinibrick's Avatar
Liked: 1
I tried connecting the height channels on the marantz sr7007 after taking the pre out from marantz sr8012, could not get any sound off the speakers. do i have to change any settings in the sr8012 and sr7007.
post #1007 of 1644 Old 09-20-2018, 12:49 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22594 Post(s)
Liked: 12295
The SR8012 pre-outs are always hot. Connect the SR8012 Height 1 and Height 2 pre-outs to the SR7007 [7.1 CH IN] FL/FR and SL/SR inputs with the speakers connected to the SR7007 FL/FR and SL/SR speaker posts. On the SR7007 set the volume to 80/0dB and the <INPUT MODE> to "7.1 CH IN". Run Audyssey on the SR8012.
jdsmoothie is offline
post #1008 of 1644 Old 09-20-2018, 06:56 AM
uberjase's Avatar
Liked: 0
Does Audessy downsample to 48khz on the SR8012? I have my PC connected to mine for gaming and was wondering if I should set windows output to 96khz or will it just be dowmsampled by audessy.
Marantz SR8012, Samsung q9fn 55"
Monitor Audio RX6 + silver center + 4xsilver 1 + 4x Kef R50
Panasonic UB900
uberjase is offline
post #1009 of 1644 Old 09-20-2018, 09:58 AM
Liked: 2848
Unfortunately Audyssey still downsamples in D&M equipment. You'll have to disable it (e.g. use Direct) to get higher bitrates. Enabling Audyssey also might result in a perceptible lag when playing some "twitch" games. See pages 184 and 199 of the SR8012's owner's manual for other audio and video settings that can be optimized for gameplay. If you don't have a copy, the manual can be downloaded from http://manuals.marantz.com/sr8012/na/en/
Selden
post #1010 of 1644 Old 09-20-2018, 02:17 PM
uberjase's Avatar
Liked: 0
[quote=Selden Ball;56838276]Unfortunately Audyssey still downsamples in D&M equipment. You'll have to disable it (e.g. use Direct) to get higher bitrates. Enabling Audyssey also might result in a perceptible lag when playing some "twitch" games. See pages 184 and 199 of the SR8012's owner's manual for other audio and video settings that can be optimized for gameplay.
Thanks mate, I've set to direct mode for the PC and output to 24bit/96khz.
uberjase is offline
post #1011 of 1644 Old 09-20-2018, 04:35 PM
Liked: 2848
Be sure to listen carefully to the results. Many people find the improvements provided by Audyssey to be greater than those provided by higher bitrates.
Selden
post #1012 of 1644 Old 09-21-2018, 08:47 AM
uberjase's Avatar
Liked: 0
I've done a bit of googling and what little I can find on the subject, audyssey lag is as much as using bass management. Using dynamic EQ increases lag quite a bit. Not sure if this is correct or not though
Panasonic UB900
uberjase is offline
post #1013 of 1644 Old 09-21-2018, 09:02 AM
bigguyca's Avatar
Liked: 929
Are there any documented benefits for sample rates over 48 kHz for audio?
bigguyca is offline
post #1014 of 1644 Old 09-21-2018, 10:31 AM
Liked: 2848
I'm not sure what you mean by "documented". Many people have posted here on AVS how high sampling-rate soundtracks sound better to them than 44.1k (CD) and 48k (DVD) sampling rates do. There are even some tests where you can find out if you can hear the differences. Some people report being able to reliably hear a difference and others report that they can't. Also, it seems that some high sampling rate soundtracks contain only silence or noise above 20KHz, not anything related to the actual musical content.
However, some related problems are that if a speaker's tweeter which was designed for audible frequencies is actually driven with soundtracks containing high amplitudes of high frequencies, it's likely to introduce its own distortions (including aliasing down to frequencies that are audible) and/or be damaged by the overheating caused by the ultrasonic content.
Some of the audibility threads are
https://www.avsforum.com/forum/91-au...-take-2-a.html (7/10/2014)
https://www.avsforum.com/forum/91-au...ts-so-far.html (7/28/2014)
https://www.avsforum.com/forum/91-au...res-audio.html (3/18/2016)
Selden
post #1015 of 1644 Old 09-22-2018, 11:01 AM
Dave Moritz's Avatar
Quoted: 100 Post(s)
Liked: 82
I was finally able to pull the trigger on a new Marantz SR-8012 and should have it around 10/1/18. This will be replacing my Pioneer Elite SC-05 and it will be nice to have all the features the 8012 will give me over what I had before. I do have some SACD's and some DVD-A's that I look forward to listening through the new receiver. Anyone have any set up tips for when I get my receiver? This will also be my first receiver with Audyssey room correction so it is going to be fun.
HT System: Marantz SR-8012 11.2 (7.2.4) Receiver, Sony XBR55A9F 55"OLED 4K HDR/Dolby Vision/IMAX Enhanced TV, Panasonic DP-UB9000 4K UHD Blu-ray Player, Toshiba HD-XA2 HD-DVD player,4K Apple TV 64GB, Speakers: Altec Lancing A-7's (L&R), Bowers & Wilkins HTM61 S2 center channel, Klipsch RP-600M Surround Speakers, Advent Marbles (Height Speakers), HSU VTF-3 MK5HP Subwoofer. AudioQuest Cables, Pangea Audio speaker stands.
Dave Moritz is offline
post #1016 of 1644 Old 09-22-2018, 11:47 AM
CrazyEddie's Avatar
Quoted: 295 Post(s)
Liked: 255
Originally Posted by Dave Moritz View Post
...Anyone have any set up tips for when I get my receiver? This will also be my first receiver with Audyssey room correction so it is going to be fun.
Get a microphone boom/stand to hold the Audyssey mic. Far better results and much faster to reposition the mic for the eight measurement locations than fiddling with the rocket ship.
"rocket ship" <- the supplied cardboard stand for the mic.
== edit
Thinned the quote some.
Years ago I built an adapter to help with using a mic boom for Audyssey calibrations. The white surface is a rubberized / non-slip type of paint on stuff. The bubble level is glued on and really helps with quickly ensuring the microphone is pointed straight up.
post #1017 of 1644 Old 09-22-2018, 05:16 PM
ratbuddy's Avatar
Quoted: 844 Post(s)
Liked: 1162
For new owners, I'd suggest buying the $20 Audyssey app off the bat, and running your measurements through that instead of the receiver. If you run it through the receiver first, you'll have to redo the whoop whoop whoop setup again if you later decide you want to take advantage of the adjustment flexibility offered through the app.
ratbuddy is offline
post #1018 of 1644 Old 09-23-2018, 09:08 PM
Quoted: 100 Post(s)
Liked: 82
I have a camera tripod will that work?
post #1019 of 1644 Old 09-23-2018, 09:49 PM
CrazyEddie's Avatar
Quoted: 295 Post(s)
Liked: 255
Never did well enough for me.
Problem with a camera tripod is it is designed to be a stable foundation straight up through the center of balance of the tripod. Straight up / down.
Whereas mic booms are designed to stick the mic 'over there' off to the side of the stand.
Whatever works for you by definition works. Me, I wish I had spent the thirty dollars or so for a mic stand at least a decade earlier than I did rather than fiddling with the camera tripod year after year.
post #1020 of 1644 Old 09-23-2018, 10:14 PM
Quoted: 100 Post(s)
Liked: 82
I will price one and see how much I can get one but right now I am waiting for my employment agency to find me another job. I already had this receiver bought and paid for before my job ended.
repairs , sr8012
