"Official" 2017 Marantz SR8012 Owner's thread - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 1138Likes
post #1261 of 1922 Old 02-04-2019, 05:53 PM
Hydrazine's Avatar
Quoted: 108 Post(s)
Liked: 123
Originally Posted by spawntech15 View Post
My best suggestion is testing by elimination, go to BestBuy or someone's home who has a QLED, OLED TV or any model with HDR10/or Dolby Vision capabilities, take your FireTV along with your SR8012 and test. If the problem continues then next is the FireTV. In my opinion the issue is your TV, either buy the box that @bluemoon737 is suggesting or get a new TV if you want to use full potential of your SR8012. To save you some money return that HDMI 4K expensive cable that BestBuy told you to buy....smh. As long as the HDMI cable is high speed and goes up to 18Gbps of bandwidth it will work or it won't, there is no middle ground for HDMI. You can get the Amazon Basics High Speed HDMI cable for a better value and it will do the same job.
Yeah, the cable was returned. Cables weren't the problem and Best Buy doesn't have a HU9000 available for testing.
Unfortunately the 3500 unit is out of production. It was produced for only a short time.
I may have to try the Key Digital HDFIX22 or Atlona ETU Sync and see what happens.
Tony
Hydrazine is offline
post #1262 of 1922 Old 02-05-2019, 06:14 PM
dagwod's Avatar
Marantz sr8012 overhanging the depth of tv stand
The marantz sr8012 receiver is over 18.5 inches deep but most tv stands are less than that depth.
Is there a problem with having the sr8012 partly sticking out the back of a less deep tv stand or would this be a huge mistake? This is assuming I can modify and cut out the back of a 15.5 or 16 inch deep stand so that the receiver can protrude out of the stand shelf area and overhang the back. What about an 18 inch deep stand?
The problem is all the stands we prefer come in less than 18.5 in depths. Is it better to just by a larger deeper stand in this case that we like less?
What have others done with such large avrs?
dagwod is offline
post #1263 of 1922 Old 02-05-2019, 06:19 PM
afrogt's Avatar
Quoted: 2428 Post(s)
Liked: 1593
can the 4 feet sit securely on the stand? If so, I wouldn't worry about it hanging out the back a little.
Afro GT
afrogt is offline
post #1264 of 1922 Old 02-05-2019, 08:44 PM
muscles's Avatar
Quoted: 936 Post(s)
Liked: 1511
Anyway to find out what todays firmware update did? I can't find any literature or mention of it online anywhere. Went through the menus but everything looked the same. Any ideas?
Greg
Subwoofers: Dual JTR RS1's - SB13 Ultra (bedroom)
Speakers: 2xJTR Noesis 212RT 1 210RM - KEF LS50W
Audio:McIntosh C2600 Pre - Marantz SR-8012 -Dual McIntosh 601's - PS Audio M700 - McIntosh MT5 - GoldNotePH10 - Oppo UDP-205 - BlueSound Node 2
TV: Samsung 75" Q9FN - Sony 75" 940D
muscles is online now
post #1265 of 1922 Old 02-05-2019, 09:10 PM
bluemoon737's Avatar
Quoted: 2210 Post(s)
Liked: 2710
Greg
Maybe the Imax Enhanced update??
-Jeff-
Man cave: Sony XBR75Z9D, Marantz SR8012, and OPPO UDP-203
Living room: Sony XBR75X950G, Denon x4500, and Sony UBP-X800M2
bluemoon737 is offline
post #1266 of 1922 Old 02-06-2019, 04:38 AM
rwestley's Avatar
Quoted: 680 Post(s)
Liked: 425
You are probably correct. Could someone who has done the update please post firmware number and
DTS number it is listed under General, About, Firmware information.
rwestley is offline
post #1267 of 1922 Old 02-06-2019, 05:18 AM
mbernstein's Avatar
Quoted: 95 Post(s)
Liked: 27
Mine said Imax Enhanced.
bluemoon737 likes this.
Samsung UN78HU9000GXZD / Marantz SR8012 / B&W 705 S2 + HTM71 S2 Front + B&W DB4S sub + Polk Audio Monitor 30 Back
LG OLED 65C8PSA / Marantz SR6013 / B&W CM1 S2 + CM Center S2 Front + Jamo J10 sub + NHT SuperZeros 2.1 Back
LG OLED 55EA9850 / Yamaha Soundbar YSP 2700
mbernstein is offline
post #1268 of 1922 Old 02-06-2019, 05:44 AM
ratbuddy's Avatar
Quoted: 930 Post(s)
Liked: 1380
Mine says that as well, and no way is it getting installed until we learn more about whether it can be turned off or not. It supposedly overrides your crossover settings and that doesn't sound like something I want.
ratbuddy is offline
post #1269 of 1922 Old 02-06-2019, 07:48 AM
mbernstein's Avatar
Quoted: 95 Post(s)
Liked: 27
I guess that's another situation when the Audyssey app comes handy.
post #1270 of 1922 Old 02-06-2019, 08:00 AM
rwestley's Avatar
Quoted: 680 Post(s)
Liked: 425
The crossover will only change with Imax Enhanced disks.
What is the new firmware number?
rwestley is offline
post #1271 of 1922 Old 02-06-2019, 08:24 AM
ratbuddy's Avatar
Quoted: 930 Post(s)
Liked: 1380
Sure, but is the 'enhancement' optional? If not, I don't want it.
ratbuddy is offline
post #1272 of 1922 Old 02-06-2019, 08:25 AM
rwestley's Avatar
Quoted: 680 Post(s)
Liked: 425
Yes, It will only go on when you play an Imax Enhanced disk. similar to Dolby Atmos or any other flag.
rwestley is offline
post #1273 of 1922 Old 02-06-2019, 08:38 AM
Quoted: 61 Post(s)
Liked: 25
Just did update
Imax Enhanched. Firmware ver. 6461-5243-6181-3094. -DTS ver. 3.90.50.51.
72.greyscale is offline
post #1274 of 1922 Old 02-06-2019, 08:53 AM
ratbuddy's Avatar
Quoted: 930 Post(s)
Liked: 1380
No, what I mean is, if I don't like it, will I have the option to disable the 'enhancement' in the receiver or disc menus, or will it be automatically turned on when a disc containing that metadata is present?
ratbuddy is offline
post #1275 of 1922 Old 02-06-2019, 08:55 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 24144 Post(s)
Liked: 13347
The "flagship" Denon X8500H received a second IMAX Enhanced update today which adds a "Manual" setting change for (High Pass filter, Low Pass filter, Subwoofer mode) so that was also likely included in this update to the SR8012 and upper level 2018 Denon/Marantz models as well. Simply purchase an IMAX Enhanced DTS:X disc and you can confirm for yourself.
ratbuddy likes this.
jdsmoothie is offline
post #1276 of 1922 Old 02-06-2019, 09:09 AM
ratbuddy's Avatar
Quoted: 930 Post(s)
Liked: 1380
Guess I could order a disc and give it a try, then. Does this new mode offer anything beyond the crossover settings? The marketing materials were really spotty on actual details of what it is, besides Imax branding on top of HDR10+ and DTS:X with different crossover settings.
ratbuddy is offline
post #1277 of 1922 Old 02-06-2019, 09:20 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13347
It allows the AVR to decode the IMAX Enhanced DTS:X file, otherwise, if the IMAX setting is set to OFF, then just the regular DTS:X decoder is used.
post #1278 of 1922 Old 02-06-2019, 09:45 AM
rwestley's Avatar
Quoted: 680 Post(s)
Liked: 425
I have two Imax Enhanced disks I will check when I get home
rwestley is offline
post #1279 of 1922 Old 02-06-2019, 10:03 AM
gene4ht's Avatar
Quoted: 2099 Post(s)
Liked: 2945
JD...Up-to-date change log entries and associated information or lack thereof is historically a reoccurring question/concern/complaint and not just isolated to D+M. It would seem to be a "no brainer" to update change logs prior to pushing the FW updates. Any insight as to why manufacturers are not diligent in this regard? If not, can/would you pass this on to the various reps on the consumer's behalf? Thanks!
rwestley likes this.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is offline
post #1280 of 1922 Old 02-06-2019, 10:06 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13347
I've been doing this each year for the past 10 years.
gene4ht likes this.
post #1281 of 1922 Old 02-06-2019, 10:09 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13347
Just learned from an SR8012 owner that the update also now includes access to the rest of the Web Control menus (ie. GENERAL and NETWORKING).
post #1282 of 1922 Old 02-06-2019, 10:10 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7502 Post(s)
Liked: 7537
True.......
Wayfair had a HUGE selection of stands, but if you really like a stand, buy a 1/2" or 3/4" piece of plywood, paint it black, and cut it so its longer then the shelf? The stand will not be touching the wall anyway I suppose so you will have a gap anyway from the wall to the stand.
Cleveland Plasma is offline
post #1283 of 1922 Old 02-06-2019, 10:39 AM
gene4ht's Avatar
Liked: 2945
A+ for your effort...E- for manufacturers!
gene4ht is offline
post #1284 of 1922 Old 02-07-2019, 04:03 AM
rwestley's Avatar
Quoted: 680 Post(s)
Liked: 425
A little more information is now available about the I-Max update which just went live.
https://www.highdefdigest.com/news/s...eceivers/43551
rwestley is offline
post #1285 of 1922 Old 02-08-2019, 05:30 PM
maf113's Avatar
Quoted: 55 Post(s)
Liked: 47
Did you try the Imax discs. I tried one and the receiver only goes to multi channel 7.1
maf113 is offline
post #1286 of 1922 Old 02-08-2019, 05:48 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13347
As is the case when playing DTS:X audio as well, your Blu Ray player must be set to "bitstream." If the AVR panel is reading "Multi Ch In", that means the Blu Ray player is decoding the audio to PCM.
post #1287 of 1922 Old 02-08-2019, 05:54 PM
maf113's Avatar
Quoted: 55 Post(s)
Liked: 47
Darn. I knew that but completely forgot. Reset the player and bam it works.
maf113 is offline
post #1288 of 1922 Old 02-08-2019, 06:06 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13347
Easy fix.
post #1289 of 1922 Old 02-15-2019, 07:32 AM
tswon's Avatar
Quoted: 60 Post(s)
Liked: 35
I just received my SR8012 a couple of days ago. I build up static electricity as I walked towards the unit. As soon as I touched it, the receiver shut down for a couple of seconds and started back up. Does anyone know if this is some sort of protection capability?
Sony XBR-75Z9F | Marantz SR8012 | Parasound Halo A 52+ | Panasonic DP-UB820K
7.2.4 | Fronts: Bowers & Wilkins S702 S2s | Center: Bowers & Wilkins HTM71 S2 | Surrounds: Bowers & Wilkins S706 S2s | Back Surrounds: Mission 761is | Atmos: Bowers & Wilkins CCM664 x 4 | Subwoofers: Rythmik FV25HP x 2
tswon is offline
post #1290 of 1922 Old 02-15-2019, 10:40 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13347
If you must continue to manually touch the unit, consider looking into an ESD solution.
marantz 8012 , repairs , sr8012
