Marantz AV8805 15.2 XLR Pre/Pro Official Thread - Page 109 - AVS Forum | Home Theater Discussions And Reviews
 1845Likes
post #3241 of 3949 Old 02-08-2019, 09:04 AM
bambam's Avatar
Quoted: 203 Post(s)
Liked: 156
Originally Posted by george1906 View Post
The 2i does decode and stream MQA and DSD files.
I believe the Node 2 does also, correct?
bambam is offline
post #3242 of 3949 Old 02-08-2019, 09:08 AM
Quoted: 106 Post(s)
Liked: 82
I think when they released their firmware update for the Node 2, that enabled those to have the same functionality as the Node 2i.
george1906 is online now
post #3243 of 3949 Old 02-08-2019, 09:14 AM
T-smith's Avatar
Quoted: 355 Post(s)
Liked: 318
Originally Posted by uberanalyst View Post
My original "old" 35-foot HDMI cable (actually only a year old) to the TV now works perfectly with the new AV8805 firmware, so I'll find another use for my new cable. The AV8805 previous software was obviously the problem, likely a side-effect of Marantz's initial eARC implementation (my 2018 LG OLED TV supports ARC but not eARC).
That’s interesting as switching to an HDMI cable I knew was certified from one that wasn’t fixed the audio issue for me in November and my run is only 15 feet. This latest update had no negative or positive impact on my setup.
In the end I think you’d be better off using the certified cable but whatever works. I’m still surprised the old 35 foot cable ever worked but as long as it does.
Upgraditus is a real disease
T-smith is online now
post #3244 of 3949 Old 02-08-2019, 09:17 AM
jmschnur's Avatar
Quoted: 126 Post(s)
Liked: 61
Do any settings need to be updated after the update.
Sony A1E, Marantz 8805, Montis, Bryston,
jmschnur is offline
post #3245 of 3949 Old 02-08-2019, 12:28 PM
jdsmoothie's Avatar
Quoted: 22165 Post(s)
Liked: 12036
Originally Posted by Leeliemix View Post
Just to clarify, the analogue XLR input does AD/DA conversions no matter what even in DIRECT/PURE DIRECT modes?
Just want to know for sure because i was told when buying the unit that using DIRECT(PURE) would keep the signal analogue all the way through.
Correct.
jdsmoothie is offline
post #3246 of 3949 Old 02-08-2019, 12:36 PM
Quoted: 176 Post(s)
Liked: 81
Thank you jdsmoothie. Sort of defeats the purpose of the XLR inputs that if there is only RCA (on the 7.1 inputs) which can keep things purely analogue.
Leeliemix is offline
post #3247 of 3949 Old 02-08-2019, 01:09 PM
mlknez's Avatar
Quoted: 443 Post(s)
Liked: 135
Correct.
What is the purpose of the additional conversion from analog to digital if you are not doing room correction of any type?
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Pioneer SX-N30, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is online now
post #3248 of 3949 Old 02-08-2019, 06:37 PM
jdsmoothie's Avatar
Liked: 12036
Good question.
post #3249 of 3949 Old 02-08-2019, 06:49 PM
sdurani's Avatar
Quoted: 7054 Post(s)
Liked: 6064
Bass management, time alignment, etc.
Sanjay
sdurani is offline
post #3250 of 3949 Old 02-08-2019, 06:53 PM
jdsmoothie's Avatar
Liked: 12036
I believe he was specifically asking about DIRECT and PURE DIRECT in which case neither of the above is enabled.
post #3251 of 3949 Old 02-08-2019, 08:35 PM
audiofan1's Avatar
Quoted: 2296 Post(s)
Liked: 2834
The IMAX Enhanced DTS:X feature which was previously added in November 2018, was updated today to now include the "Manual" Audio Settings (High Pass filter, Lower Pass filter, Subwoofer mode). While the IMAX DTS:X disc is playing, select Audio Settings - Surround Parameter - IMAX Audio Settings - Manual to gain access to these settings.
Also included in this update was access to the last two remaining Web Control menus (GENERAL and NETWORK).
Thanks to this update and dialing in the same already crossover points, I popped in "Beautiful Planet" and found the audio so good I rewatched the whole thing
audiofan1 is offline
post #3252 of 3949 Old 02-09-2019, 10:08 AM
Dave-T's Avatar
Quoted: 1156 Post(s)
Liked: 551
To get Auro 3D 10.1 what would you do if you have your atmos speakers in the ceiling already at 45 degrees in front and 45 degrees behind the MLP? Would you still configure it as front height and rear height even though it is in the top front and top rear position to get Auro 3D to work? and where do you connect your RCA for top center if you currently have a 5.2.4 Atmos setup. Also has anybody tired Auro 3d with top front and rear not height channels listed as height channels to get Auro 3d to work and how does it sound? I have a extra channel on my amp for another channel so why not add another speaker is my thinking.
THANKS
Dave-T is online now
post #3253 of 3949 Old 02-09-2019, 12:34 PM
jdsmoothie's Avatar
Liked: 12036
THANKS
As noted on p. 305 in your Owner's manual, Auro 3D does not accept any of the Atmos "Top" speaker settings.
post #3254 of 3949 Old 02-10-2019, 10:41 AM
Quoted: 421 Post(s)
Liked: 179
I'd guess noise floor? Its still a fully balanced connection.
JBL Array 1400, 880, & 800s on custom sound anchors / Revel C763L x4
Marantz AV8805 / TEAC NT-505 / Oppo 205 / Emotiva XPA DR3 / Emotiva XPA-7 Gen3
PSA S1801 x2
Bob Carver Crimson 350 tube monoblocks
JBL Everest DD67000s (awaiting amplification)
love_that_sound is offline
post #3255 of 3949 Old 02-10-2019, 07:06 PM
ekohn00's Avatar
Quoted: 50 Post(s)
AppleTV or ???????
So here’s the scenario: I have a plex server and view 1080 and 4K rips via an appletv to my 8805.
The RIPS have trueHD 7.1 or AC3 5.1 for the most part. But because of the appletv, everything is passed to my 8805 as PCM.
The 8805 then select multi-Chan in for movie sound processing. The sound is great!
The question is, should I be replacing the appletv with some thing that would allow the 8805 to process the trueHD or AC3 and possibly get better results??
Sent from my iPhone using Tapatalk Pro
ekohn00 is offline
post #3256 of 3949 Old 02-10-2019, 10:26 PM
Nexgen76's Avatar
Quoted: 739 Post(s)
Liked: 218
Quick question because this tread moving so fast...If I'm watching Atmos movie are all six channels active top front, top middle, & top rear.
JVC NX5 Panasonic UB820 PC Madvr
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Pioneer Elite SC-LX801 Acurus A125x5
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is online now
post #3257 of 3949 Old 02-11-2019, 04:01 AM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 133
Correct, and as a result, no surround mode (eg. PURE DIRECT) can be selected.
You can use Pure Direct on an input that is using the 7.1 analog inputs.
Sam S is offline
post #3258 of 3949 Old 02-11-2019, 04:29 AM
jdsmoothie's Avatar
Liked: 12036
Indeed. Wasn't aware of that. Apparently to just cut out the analog video and front panel display.
post #3259 of 3949 Old 02-11-2019, 04:30 AM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 133
Yup. My preferred setting for listening to LPs!
Sam S is offline
post #3260 of 3949 Old 02-11-2019, 07:19 AM
DOC1963's Avatar
Quoted: 122 Post(s)
Liked: 151
Originally Posted by ekohn00 View Post
AppleTV or ???????
The odds are pretty high that you'd "hear" no difference at all. Decoding must be performed (and converted to PCM) before being passed to the DAC and your AppleTV 4K is more than capable of performing that task.
The only results that you could expect to be different is whether the display on your 8805 says "Multi-Channel" or "TrueHD" as the input format. With the display door closed, you wouldn't know the difference...
DOC1963 is online now
post #3261 of 3949 Old 02-11-2019, 07:23 AM
ekohn00's Avatar
Quoted: 50 Post(s)
I understand what your saying.
My thought was either my appleTV is doing the decide or the 8805.
I just find it “strange” that the appletv decoding would be the same quality.
ekohn00 is offline
post #3262 of 3949 Old 02-11-2019, 07:33 AM
DOC1963's Avatar
Quoted: 122 Post(s)
Liked: 151
The "decode" is a fairly straight forward process. The "quality" of the sound will still come from your 8805...
post #3263 of 3949 Old 02-11-2019, 07:38 AM
ekohn00's Avatar
Quoted: 50 Post(s)
So here's a trick question. AppleTV has the option to convert to Dolby 5.1 would this be better than PCM?
My thought is have it go to straight to PCM and not remix anything to a new 5.1 track?
ekohn00 is offline
post #3264 of 3949 Old 02-11-2019, 07:58 AM
DOC1963's Avatar
Quoted: 122 Post(s)
Liked: 151
No... "Best Quality" (which is presented as PCM) is always the best audio output option if you want a straight decode of the original native content.
Choosing "Dolby Digital 5.1" would decode the native content, then re-encode to 5.1 and pass along a DD stream. Any "hi-rez" formats like TrueHD or DTS-MA would be degraded...
batpig and ekohn00 like this.
post #3265 of 3949 Old 02-11-2019, 08:01 AM
Quoted: 106 Post(s)
Liked: 82
Question. If I run my Node 2i into one of the optical or coax digital inputs on the back of my 8805, the DAC in the 8805 will be used, correct? If so, which input or type should I use for no pure audio processing?
post #3266 of 3949 Old 02-11-2019, 08:01 AM
mitohobe's Avatar
Quoted: 25 Post(s)
Think of Dolby 5.1 as a compression format for “any” 5.1 PCM signal.
Pretty much all files look the same once uncompressed. Like a zip or arj file format.
However, they do allow for different efficiencies in reduction in file size.
Hence, Dolby ≠ DTS.
mitohobe is offline
post #3267 of 3949 Old 02-11-2019, 08:01 AM
jdsmoothie's Avatar
Liked: 12036
In this case, "decoding" is nothing more than "unzipping" the DD/DTS file to PCM. It doesn't matter whether the source or the AVP does the "unzipping", the end result is the same PCM file.
DOC1963 and ekohn00 like this.
post #3268 of 3949 Old 02-11-2019, 08:14 AM
ekohn00's Avatar
Quoted: 50 Post(s)
definitely the 8805's DAC, which makes me ask what's the value of the Node 2i?
ekohn00 is offline
post #3269 of 3949 Old 02-11-2019, 08:21 AM
Quoted: 106 Post(s)
Liked: 82
Just want to see how the 8805 DAC sounds in this way. The DAC in the Node 2i is definitely outstanding but I need to connect it to the 7.1 inputs when I get back from vacay.
post #3270 of 3949 Old 02-11-2019, 08:54 AM
jdsmoothie's Avatar
Liked: 12036
Additional change log information for the recent update:
- While AVR displays Title/Artist/Album by status display, AVR will display "Spotify" after "Volume change, Mute, INFO, Sound Mode change, SLEEP, ZONE2 ON/OFF" operations.
- Audio is cutting out when using ARC via Low Quality Cable (Long Cable) after installing U18 firmware.
- Update the firmware version to 1.493.180 Music files in USB stick memory formatted with NTFS cannot be played on HEOS products.
audiofan1 likes this.
