Marantz AV8805 15.2 XLR Pre/Pro Official Thread - Page 119 - AVS Forum | Home Theater Discussions And Reviews
 1812Likes
post #3541 of 3884 Old 04-15-2019, 03:50 AM
Quoted: 101 Post(s)
Liked: 67
Originally Posted by audiofan1 View Post
Yup the 8805 went to work on GOT and delivered
The Dragons flying was absolutely amazing!!
audiofan1 and ekohn00 like this.
george1906 is online now
post #3542 of 3884 Old 04-15-2019, 09:33 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6391 Post(s)
Liked: 6389
Originally Posted by Desert Pilot View Post
Just joining the group!
I am upgrading my home theater. I ordered an AV8805 and is due for delivery on Wednesday. My current pre/pro is an AV7702 purchased in 2014. My reason for the upgrade is a recent 4K projector purchase which requires HDCP 2.2.
Marcus
Congrats, which projector did you get?
Cleveland Plasma is online now
post #3543 of 3884 Old 04-15-2019, 10:04 AM
Desert Pilot's Avatar
Quoted: 103 Post(s)
Liked: 92
Thanks for asking. The BenQ LK990. Should be shipped tomorrow. My screen is a 160 inch diagonal. I'm looking forward to improved multichannel music and, of course, 4K UHD movies.
Marcus
Ediddy likes this.
Desert Pilot is offline
post #3544 of 3884 Old 04-15-2019, 04:41 PM
batpig's Avatar
Quoted: 4661 Post(s)
Liked: 4846
Originally Posted by fish5225 View Post
Based upon your suggestion I switched to auro3d for some critical listening. It’s certainly an interesting listen. I found the bass to be much more up front. I’m going to continue to play with it. Thanks for the suggestion.
FYI, Auro3D has a few adjustable parameters (Audio > Surround Parameter) that impact the upmix....
First there's the "room size" setting which I think controls the flavor of processing (and perhaps the amount of delay/reverb) in the expanded signal. I prefer the "Small" setting myself, from what I can tell with 2ch upmix the "Medium" and "Movie" and "Speech" settings are more center channel focused (so 2ch music will have more sound collapsed to the center channel) whereas "Small" and "Large" settings tend to spread the sound more evenly across the LCR. If you put on 2ch music and switch between the modes you can hear how some are more "center focused" than others.
Also there's an "Auro-Matic 3D Strength" control which defaults to 10 but can be adjusted from 1-16, which I believe controls the level of the "fake reflections" that Auromatic is creating in the other speakers If it sounds too reverby and synthetic you can use this setting to tame it down so it's more of a gentle expansion of the plain stereo signal.
fish5225 and Sal1950 like this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #3545 of 3884 Old 04-16-2019, 01:54 PM
sdurani's Avatar
Quoted: 6960 Post(s)
Liked: 5938
Room Size parameter determines the length of the decay tails (large rooms have longer decay times than small rooms). You can use a click track on YouTube to hear the difference. Amount of reverb added is controlled by the Strength parameter.
fish5225 and batpig like this.
Sanjay
sdurani is offline
post #3546 of 3884 Old 04-16-2019, 02:17 PM
batpig's Avatar
Liked: 4846
Ah yes that's it.
Room Size also seems to impact the "center spread" as well. From what I can tell the Small/Large settings act more like DSU with "Center Spread" whereas the Medium size behaves like the "Movie" setting with more collapsing to the center channel.
Setup Guide and FAQ
post #3547 of 3884 Old 04-16-2019, 02:31 PM
sdurani's Avatar
Liked: 5938
From the little I've played with Auro-Matic, I don't remember the centre speaker getting much content. Like the second to widest Center Spread setting on PLII.
BTW, Auro-Matic2D has no adjustable parameters, so its Strength and Room Size are the default settings of Auro-Matic3D.
Sanjay
sdurani is offline
post #3548 of 3884 Old 04-16-2019, 03:23 PM
batpig's Avatar
Liked: 4846
Out of curiosity have you checked the new "Movie" mode? Originally there was just the small/medium/large room size options.... in theory an upmix mode focused on video/movie content specifically should have more going to the center channel.
Setup Guide and FAQ
post #3549 of 3884 Old 04-16-2019, 03:59 PM
sdurani's Avatar
Liked: 5938
Haven't tried it (didn't even know there was a Movie mode).
Sanjay
sdurani is offline
post #3550 of 3884 Old 04-16-2019, 04:17 PM
batpig's Avatar
Liked: 4846
It was something new D+M (not sure of other brands) added this current model year. There used be just the Small/Medium/Large and the "Speech" setting, but now there's a "Movie" setting. They also added in an option for "Channel Expansion" which I'm assuming would (for example) take a native Auro3D track recording in 9.1 or 10.1 and expand it to 13.1 output if you have that many speakers enabled.
fish5225 likes this.
Setup Guide and FAQ
post #3551 of 3884 Old 04-16-2019, 04:32 PM
sdurani's Avatar
Liked: 5938
The description for Movie mode makes it sound like another room simulation setting. Since Auro-Matic doesn't do matrix extraction, I wonder if the centre output is simply L+R. In which case, how does that change when switched to Movie mode?
Didn't you try this in the past, only to discover that "expansion" from 5 to 7 in the base layer simply mean copying the 2 surround channels to the Sides and Rears?
Sanjay
sdurani is offline
post #3552 of 3884 Old 04-16-2019, 04:47 PM
batpig's Avatar
Liked: 4846
Subjectively, it sounds more "center focused". If I listen to 2ch music and toggle between "Small" and "Movie" mode it feels analogous to using Dolby Surround and switching the "Center Spread" parameter on/off. So given the lack of matrix extraction, I'm assuming it's just a level difference in the LCR channels' respective balance.
Yes, I'm assuming it's simply copying the signals. However, previously there wasn't an option to enable/disable it, and also this appears to be intended for *native* Auro3D content -- when I was testing before it was Auromatic.
sdurani likes this.
Setup Guide and FAQ
post #3553 of 3884 Old 04-17-2019, 07:42 AM
retate's Avatar
Quoted: 58 Post(s)
Liked: 62
There is an AV8805 firmware update today for improved stability.
giomania and audiofan1 like this.
Bob
retate is offline
post #3554 of 3884 Old 04-17-2019, 01:12 PM
Dave-T's Avatar
Quoted: 1129 Post(s)
Liked: 528
I just downloaded the new firmware, anybody know what it was supposed to do?
Dave-T is offline
post #3555 of 3884 Old 04-17-2019, 02:21 PM
batpig's Avatar
Liked: 4846
Improve stability
gsr, sdurani, giomania and 1 others like this.
Setup Guide and FAQ
post #3556 of 3884 Old 04-17-2019, 02:32 PM
sdurani's Avatar
Liked: 5938
Can't say I didn't see that coming.
giomania and Dave-T like this.
Sanjay
sdurani is offline
post #3557 of 3884 Old 04-17-2019, 02:59 PM
Gary Bechtold's Avatar
Quoted: 141 Post(s)
Liked: 194
Improve stability
audiofan1 and audiofan1 like this.
Home Theater 5.1 Setup: Marantz AV8805, Sunfire TGA-7401, Monitor Audio Gold GX300 Front/Rear, Monitor Audio Gold GXC 350 Center, Rythmik Audio G25HP, Oppo UDP-203, Samsung PN64F8500
PC Audio 5.1 Setup: Denon AVR-X3300W, Monitor Audio Gold GX100 Front/Rear, Monitor Audio Gold GXC 150 Center, Rythmik Audio F12SE
Gary Bechtold is offline
post #3558 of 3884 Old 04-17-2019, 03:03 PM
Quoted: 141 Post(s)
Liked: 194
These version numbers make no sense.
Previous version was...
Firmware Version: 7300-5254-9181-3094
DTS Version: 3.90.50.54
Current version is...
Firmware Version: 7300-0153-9131-5005
post #3559 of 3884 Old 04-17-2019, 04:05 PM
Dave-T's Avatar
Liked: 528
Maybe it is the update we were waiting for that allows custom crossovers for imax enhanced instead of the set 70Hz. Crossovers.
Dave-T is offline
post #3560 of 3884 Old 04-17-2019, 05:34 PM
retate's Avatar
Quoted: 58 Post(s)
Liked: 62
In terms of version numbers making sense the last six digits of the firmware version are the same for the Marantz AV8805 and Denon AVR-X4500H for today's firmware updates. The previous three versions of firmware for the these two units also match in the last six digits. In contrast the DTS versions for these two units are not an exact match with the AV8805 at 3.90.50.54 and the X4500H at 3.90.50.51.
giomania likes this.
Bob
retate is offline
post #3561 of 3884 Old 04-17-2019, 07:54 PM
Quoted: 103 Post(s)
Liked: 92
Received my AV8805 today. Everything is working and completed a firmware update. It is driving an SVS 5.2 home theater speaker system. Tomorrow morning while everyone is asleep, I will complete an Audyssey calibration. At the moment, I am music only as my new projector has not shipped and my old projector died several weeks ago. Right now, I am using an old 1080p monitor hooked up so I can read the 8805. Multichannel surround from my HTPC working. Streaming from my Nvidia Shield working. CAB/SAT from my Dish receiver working.
Looking forward to critical music listening after Audyssey correction. I may replace my amplifier. Old one (Outlaw 755) still working.
Marcus
audiofan1 likes this.
post #3562 of 3884 Old 04-17-2019, 09:14 PM
audiofan1's Avatar
Quoted: 2285 Post(s)
Liked: 2793
That happened with the last update and as I reported sounds fantastic
audiofan1 is online now
post #3563 of 3884 Old 04-18-2019, 11:47 AM
audiomanz's Avatar
Quoted: 198 Post(s)
Liked: 49
Hi all,
I'm happy to report that I just ordered the AV8805 today off my dealer. I'm super pumped and have no regrets about making the jump from the AV7705 for sure. I should be getting it next week and reading the posts here, reviews, and youtube videos all helped me to make my decision that buying this flagship processor was the way to go and I should be good to go for years to come and its upgradeable to HDMI 2.1 when the time comes as well. So thanks again and now I will be posting my questions here come next Saturday..haha..thanks again all. :-)
Quick question. I read a review where it said that the AV8805 dropped the AM/FM tuner on this model. Is there any truth to this statement? Thanks again all.
audiomanz
audiomanz is offline
post #3564 of 3884 Old 04-18-2019, 08:02 PM
SJHT's Avatar
Quoted: 1021 Post(s)
Liked: 681
Never used it, but it is listed in the specs....
SJHT is offline
post #3565 of 3884 Old 04-18-2019, 08:35 PM
audiomanz's Avatar
Quoted: 198 Post(s)
Liked: 49
Ok..you're right SJHT. I noticed it too in the specs. Even a video showed the AM and FM antennas in the box so I'm sure that reviewer is incorrect. Thanks for your comment.
audiomanz
post #3566 of 3884 Old 04-18-2019, 09:30 PM
drh3b's Avatar
Quoted: 1859 Post(s)
Liked: 3375
Originally Posted by audiomanz View Post
Hi all,
audiomanz
I think some European models have dropped the AM/FM tuner. This is probably one of them. The American version, at least, seems to still have the tuner.
drh3b is offline
post #3567 of 3884 Old 04-18-2019, 11:15 PM
DOC1963's Avatar
Quoted: 115 Post(s)
Liked: 148
audiomanz
In comparison to the 8802A, the reviewer may have been referring to the “HD Radio” feature which has been dropped.
drh3b likes this.
DOC1963 is online now
post #3568 of 3884 Old 04-19-2019, 05:24 AM
zimmo's Avatar
Quoted: 309 Post(s)
Liked: 114
for europe the 8805 not have radio am fm,just north américa have radio.
marantz av 8805, 13 chanels, emotiva 2 xpa 5 gen1,1 emotiva xpa3 gen3, 7.4.6,4 speakers monitor 11 ,2 paradigm studio 100 v2,4 ceillings speakers ss82w sweet spot earthquake ,2 earthquake ecs-8.0,1 center Paradigm cc390,4 subs klipsch r-sw112 sw.antimod 8033 perfect bass kit paradigm, Buttkicker amplificateur lfe 1000 watts, , tv oled 65e6p,, room 12x25x7,bluray player oppo bdp 203,4coolers ac infinity s9 fan.
zimmo is offline
post #3569 of 3884 Old 04-19-2019, 06:53 AM
audiomanz's Avatar
Quoted: 198 Post(s)
Liked: 49
Hi all,
Thanks for your comments. I was looking for the review to see where it was written but no such luck. I do agree with zimmo, DOC1943 and drh3b that it most likely a site in either in Europe or the UK where it this was mentioned cause as I stated earlier the video review was from the Audioholics site and it did reveal during the unboxing there was am/fm antennas in the box. Thanks for your comments and I am really looking forward to receiving my AV8805 a week from tomorrow.
audiomanz
audiofan1 and drh3b like this.
post #3570 of 3884 Old 04-19-2019, 04:12 PM
jdsmoothie's Avatar
Quoted: 21986 Post(s)
Liked: 11925
Hi all,
audiomanz
The images listed in post 1 are of the European AV8805, one of which clearly shows no AM/FM antenna posts rather only a TUNER RCA input.
jdsmoothie is online now
