Marantz AV8805 15.2 XLR Pre/Pro Official Thread - Page 52 - AVS Forum | Home Theater Discussions And Reviews
 2018Likes
post #1531 of 4398 Old 05-11-2018, 12:09 PM
T-smith's Avatar
Quoted: 371 Post(s)
Liked: 336
Originally Posted by DreamWarrior View Post
It is limited to 44.1khz CD-quality, but unless his source files are better than that, it's no different than DLNA so far as SQ. Of course, I'm not going to delve further down the hi-res rabbit hole, so....if you want that and believe you can hear the difference, then, true, Airplay will not allow it. If you're listening to your iTunes music library, which is likely going to be 44.1khz or less (how much HD music is available on iTunes? any?) and probably lossy, then it's more than adequate.
Not trying to get into a big debate here but the ability to do X and actually doing X are two different things and where you are Airplaying from will have a lot to do with that.
There is a reason why most ppl choose DLNA or SMB over AirPlay but at the end of the day it all comes down to personal preference and I was offering another option to the OP who is having a problem with AirPlay.
Upgraditus is a real disease
T-smith is online now
post #1532 of 4398 Old 05-11-2018, 12:40 PM
Quoted: 28 Post(s)
Liked: 6
Originally Posted by exm View Post
Are you using the same M-Dax settings?
the m-dax was set to low on the 8805 and off on the 7012.
changing it to off seems to have brought it much closer, but I still feel like there is some difference.
i will play with the dialog enhancer too, see if that helps.
NJ_Audio is offline
post #1533 of 4398 Old 05-11-2018, 01:59 PM
Quoted: 28 Post(s)
Liked: 6
Thanks for the suggestion. I will give it a shot as well.
NJ_Audio is offline
post #1534 of 4398 Old 05-11-2018, 03:36 PM
DreamWarrior's Avatar
Quoted: 1062 Post(s)
Liked: 634
How so? All sources need to transcode to 44.1k ALAC to put their Airplay packets over the network. Do you think some things can do that better than others?
The reasons people choose DLNA or SMB are unlikely based in any solid technical knowledge of how the protocols work. Outside audio above 44.1k (or non PCM-audio, like DSD), there's no SQ advantage to any of them. There are certainly usability differences, though. If one wants to pick for that, I'd certainly agree!
DreamWarrior is offline
post #1535 of 4398 Old 05-12-2018, 07:32 AM
Quoted: 423 Post(s)
Liked: 179
I finally had the time to mess with audyssey some.. the Emotiva Differential Reference 3 channel was reverse phased (according to audyssey).
love_that_sound is offline
post #1536 of 4398 Old 05-12-2018, 08:30 AM
jnelson2000's Avatar
Quoted: 562 Post(s)
Liked: 549
All Emotiva amps are like that. Reverse the speaker bindings at amp end. Problem solved.
love_that_sound likes this.
Sony XBR-65A1E, XBR-55A1E, Marantz AV8805, AV7704
Naim SN3, Hi-Cap DR, NDX2, Naim Unity Core, Emotiva XPA-9, A-5175
Dynaudio Contour 30, Focus 210C, IC17, S4-W80, Evoke 10, 2X REL S/812, SVS SB-2000
Panasonic UBD-820, Bluesound Node 2i, Ansuz Mainz D2 Power Distribution,A2 and X Power and speaker cables
jnelson2000 is offline
post #1537 of 4398 Old 05-12-2018, 09:16 AM
jmschnur's Avatar
Quoted: 127 Post(s)
Liked: 62
How do I ensure that Heo will play Tidal at HiFi quality through my 8805?
Sony A1E, Marantz 8805, Montis, Bryston,
jmschnur is offline
post #1538 of 4398 Old 05-12-2018, 10:33 AM
jdsmoothie's Avatar
Quoted: 22914 Post(s)
Liked: 12536
If you have a paid TIDAL subscription, that should do it ...
There is no visual icon or settings to control what you stream. As long as you have a valid TIDAL HiFi subscription it will automatically stream HiFi. TIDAL HiFi streams in Lossless FLAC 16bit/44.1kHz and TIDAL Premium streams in AAC 320kbps
https://support.tidal.com/hc/en-us/a...-HEOS-by-Denon
jdsmoothie is offline
post #1539 of 4398 Old 05-12-2018, 11:27 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6858 Post(s)
Liked: 6860
Hate to somewhat derail but there has to be a better way to play the music you are trying to play as Airplay will never give you the best quality or anywhere close to it.
I’m assuming this is your iTunes music, is it stored on a computer that you can stream from using DLNA?
I have been using you tube, watch the video while you jam and its free Fun fact, Despasito is the number 1 watched video on you tube, over 5 billion views....
Cleveland Plasma is online now
post #1540 of 4398 Old 05-12-2018, 11:36 AM
jmschnur's Avatar
Quoted: 127 Post(s)
Liked: 62
jmschnur is offline
post #1541 of 4398 Old 05-13-2018, 09:01 AM
fish5225's Avatar
Quoted: 170 Post(s)
Liked: 79
Just hooked it up last night! It works like a charm. An incredible amount of music at your finger tips. IMHO the HEOS app alone is worth the upgrade to the 8805. After running the app, tweaking the system to my likes and streaming some of my favorites I had a smile a mile wide.
audiofan1 likes this.
fish5225 is offline
post #1542 of 4398 Old 05-13-2018, 03:15 PM
jmschnur's Avatar
Quoted: 127 Post(s)
Liked: 62
Any word on the auro3d firmware?
jmschnur is offline
post #1543 of 4398 Old 05-13-2018, 03:20 PM
jdsmoothie's Avatar
Liked: 12536
May 2018
post #1544 of 4398 Old 05-15-2018, 10:27 PM
pennynike1's Avatar
Quoted: 660 Post(s)
Liked: 32
Greatest showman
Originally Posted by bearcat2002 View Post
He say's "that's a good girl." I can hear it nice and clear on my 8805.
Thanks for checking on it. Not certain if people liking your comment means that they also hear the same thing.
Fairly certain that this specific scene was dubbed over when he thanks the elephant. They dont even have subtitles on the film for what he says.
If I were to bet money on it, I would say that PT says "Thatta girl"
This is what I heard on the Tag Mclaren initially, and what I now hear by adjusting the center channel up 1 db on the marantz
For sale: Oppo 203 UHD player; 2 Mackie c300z speakers, Tag Mclaren av32r preamplifier
pennynike1 is offline
post #1545 of 4398 Old 05-17-2018, 12:52 AM
mikey mo's Avatar
Sorry I'm late to the debate on whether to "upgrade" to the 8805. Is it true that the 8805 does not feature an HD FM Tuner as does the 8802A. If this is the case then it is a serious omission for a classical music buff in rural Central Florida. Both Tampa and Orlando public radio stations within range transmit classical only on their HD2 channels.
Mikey Mo
"Survived Charley, Frances & Ivan. But Jeanne got me."
Anxiously Awaiting 2014 Hurricane Season.
"OAR OR DIE"
They killed the SACD. Bring it back.
mikey mo is offline
post #1546 of 4398 Old 05-17-2018, 02:45 AM
jdsmoothie's Avatar
Liked: 12536
Correct. Replaced with internet radio. Note however, that numerous HD2/HD3 channels are available via internet radio as well.
post #1547 of 4398 Old 05-17-2018, 08:23 AM
drh3b's Avatar
Quoted: 2110 Post(s)
Liked: 4263
These are available, and can be hooked up to a digital input:
https://www.amazon.com/Sangean-HDT-2...ngean+hd+radio
https://www.amazon.com/Sangean-HDT-1...HD+radio+tuner
drh3b is offline
post #1548 of 4398 Old 05-17-2018, 03:51 PM
Will Binegar's Avatar
Quoted: 25 Post(s)
Liked: 34
Is there a significant improvement in sound quality by making the move from the 8802A to the 8805?
I craved Dolby Atmos and DTS-X, so when the 8802A came out, I got one to replace a Meridian G68. It's done a fine job, but it can't match the Meridian for music reproduction. I'm wondering if the 8805 closes the gap, or if I should be looking at something like the Lyngdorf MP-50.
Any thoughts?
Thanks All!
Will Binegar is offline
post #1549 of 4398 Old 05-17-2018, 05:32 PM
jmschnur's Avatar
Quoted: 127 Post(s)
Liked: 62
We are still waiting for serious reviews and comparisons.
In my system the sound is quite good .
joerod likes this.
jmschnur is offline
post #1550 of 4398 Old 05-18-2018, 01:58 AM
audiofan1's Avatar
Quoted: 2365 Post(s)
Liked: 2988
Any thoughts?
Thanks All!
For music comparisons,yes there is improvement but how significant will be ones priorities. From what I hear in my setup the improvement warrants a move.
Couldn't agree more.
fish5225 and hgosmelbfl like this.
audiofan1 is online now
post #1551 of 4398 Old 05-18-2018, 06:26 AM
Quoted: 13 Post(s)
Liked: 5
Any thoughts?
Thanks All!
No, brands like Meridian and Classé are musically unattainable for any Marantz or Denon. AV8805 is an excellent audio-video processor, but that's the target.
I have no idea how Lyngdorf sounds or other hi-end processors, but Meridian is almost unreachable at all.
Australopitecus Erectus is offline
post #1552 of 4398 Old 05-18-2018, 07:56 AM
Industry Insider
Liked: 6860
Sometimes these high end units like this never get a pro review, even though they are the best, it is a "niche" unit.
post #1553 of 4398 Old 05-18-2018, 08:14 AM
BillJulyan's Avatar
Quoted: 47 Post(s)
Liked: 85
Just got delivery of my AV8805 Tuesday (thanks to Chris at Cleveland Plasma). After some strange issues with my Sony A1E not recognizing the AV8805 through HDMI ARC, I did a factory reset of the Sony and all is now fine. This morning I'm listening to Tidal using the HEOS app. In addition to displaying the album art and other normal information on the Sony, I was pleasantly surprised to to see "FLAC - 44.1 kHz/16 bit" displayed, dispelling any doubt about whether the app actually uses the lossless format that I pay for with Tidal. Oh, and it sounds good, too.
Home theater: Sony XBR75Z9D, McIntosh MX122 & MC8207, B&W 804D3, HTM1D3, 805D2, SVS SB-13, Oppo UDP-203, Atmos 7.1.4;
Living room: Sony XBR65A1E, Marantz AV8805, MC8207, B&W 802D2, 804D2, HTM2D2, 805D2, SVS SB-13, Oppo UDP-203;
Bedroom: Sony XBR65X950B, Marantz AV8802a, MC8207, B&W 805D2, HTM2D3, Oppo UDP-203
BillJulyan is offline
post #1554 of 4398 Old 05-18-2018, 10:54 AM
jmschnur's Avatar
Quoted: 127 Post(s)
Liked: 62
I am hoping that Kal gets his unit and provides us with his insights.
GerryWaz and audiofan1 like this.
jmschnur is offline
post #1555 of 4398 Old 05-18-2018, 11:19 AM
audiofan1's Avatar
Liked: 2988
I'll take that bet
TL5 likes this.
post #1556 of 4398 Old 05-18-2018, 12:19 PM
Quoted: 25 Post(s)
Liked: 34
Well, no doubt Meridian is a high bar. I've had the top processors from Anthem, Denon, and a couple of more boutique brands over the years, and none have quite scaled the mountain. Who knows when or if Meridian will ever incorporate the object oriented formats, but it seems certain that I won't be able to afford one if they do.
I really like how stable the Marantz platform is; I've never had a HDMI handshake issue or any other glitchy behavior. I could probably tolerate a bit of that, but the rest of the household couldn't. That's one of the great advantages that bigger producers like Marantz, Denon, etc. have. If you sell enough across your various lines, everyone is going to work hard to make sure their stuff plays nice with yours.
Thanks for sharing your take Audiofan1. If anyone else would like to share their upgrade impressions, I'm all ears (or is it eyes?)
audiofan1 and hgosmelbfl like this.
post #1557 of 4398 Old 05-18-2018, 01:44 PM
Quoted: 423 Post(s)
Liked: 179
and why exactly is this? Is it because Classe sells 50 processors a year ..or maybe in 2 years? What do you think one of these Marantz processors would cost if they only sold 50?
TL5, nerdkiller and audiofan1 like this.
post #1558 of 4398 Old 05-19-2018, 04:38 AM
Quoted: 13 Post(s)
Liked: 5
Who cares how much he sells one or the other, the answer concerned the sound quality of one processor over another. AV8805 filled the sound gap with Meridian? No
skypop likes this.
post #1559 of 4398 Old 05-19-2018, 05:12 AM
Quoted: 423 Post(s)
Liked: 179
And what exactly is this sound gap?
post #1560 of 4398 Old 05-19-2018, 05:58 AM
alebonau's Avatar
Quoted: 1981 Post(s)
Liked: 1373
whats the bet.... a true high end flagship classe processor is re born with the help of the denon & marantz side of things given all three brands now part of sound united....
all that said ... I wouldnt turn up nose so much at denon or marantz things... I remember a comparison i was part off with the classe ssp800 vs the denon avp-a1hd flagship...I was happy i had the denon and person demoing ended up getting the denon. we also compared at the time the 2ch pre in the very beautiful cp700 and classe cd player. that slaughtered both the denon and the classe ssp for 2ch and musicality
"Technology is a drug. We can't get enough of it."
Welcome to my lounge room :)
alebonau is offline
