Marantz AV8805 15.2 XLR Pre/Pro Official Thread - Page 98 - AVS Forum | Home Theater Discussions And Reviews
 1814Likes
post #2911 of 3887 Old 12-15-2018, 12:29 AM
Geronimo.USMC's Avatar
Quoted: 302 Post(s)
Liked: 178
Originally Posted by James Bielfelt View Post
New to the forum and have a question for current owners of the 8805.
I just received my unit tonight, and swapped out the 7703 I've been enjoying the past 2 years in my main setup. The issue I noticed is that my TV will randomly go black, like it's lost video signal, and the return within a second or 2. No impact at all to audio. It does this on all the sources I have hooked up and tested.
I've never once had this issue with my 7703. I even took my Denon 3300 from my bedroom and swapped out and there is no issue.
So, I'm just wondering if I have a defective unit or if there is something else I might be missing?
You might need to upgrade the HDMI cables to the certified ones if you haven't done so already.
- AUDIO: (7.2.4 Atmos) EMOTIVA RMC-1 | McIntosh MC-8207 + CROWN XLS 2502, 1502 | KEF LS50, SVS Prime Elevations, RYTHMIK G25HP + L22
- VIDEO: SONY OLED 65A1E | Panasonic UB820 | 44TB Synology DS1815+ | Dune Solo 4K | XBOX ONE X SCORPIO | PS4 PRO | Apple TV 4K | HTPC/Gaming Rig (Ryzen 3700X, GIGABYTE X570 I AORUS PRO WIFI, 16GB, STRIX OC 1080TI, Auzen HDMI XFi)
Geronimo.USMC is offline
post #2912 of 3887 Old 12-15-2018, 01:19 AM
audiofan1's Avatar
Quoted: 2287 Post(s)
Liked: 2798
I read/heard something awhile back, don't recall where, that the players do not need to be updated. Which is nice. Although Oppo is giving us HDR10+. Not that it matters. But I digress, as for Sony, not sure what they're thinking. The X1E processor has the power as evidenced by another set with the X1E getting the update. Maybe an email campaign to Sony saying, hey, how about a little something for the effort?
Yup! lets bug them till they let us have it
Originally Posted by T-smith View Post
I tried the A Beautiful Planet disk today from my Pioneer LX-500 player without any issues and IMAX DTS:X lit up on the 8805.
Only difference I see is on the App when I check Input I see the speaker channels lit up which is not something I normally see for an Atmos or DTS:X track on that Input screen. It does however show them for non object based formats.
I didn’t watch much but the shots of the earth are amazing.
I picked it up as well and will give it a go tomorrow, glad to hear it looks good.
audiofan1 is offline
post #2913 of 3887 Old 12-15-2018, 08:39 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6404 Post(s)
Liked: 6398
Cleveland Plasma is online now
post #2914 of 3887 Old 12-15-2018, 11:10 AM
Rise & Grind
dinamigym's Avatar
Quoted: 297 Post(s)
Liked: 279
Did you check your settings. Make sure it’s on enhanced if devices support?
Trinnov Altitude 16, Magico A3, Magico ACC, Magico A1s, Dual Rythmik FV25HP
Amps- ATI AT523NC, AT524NC, AT528NC
Kaleidescape Terra Server/Strato, Oppo UDP-203, Apple TV4k, XFinity X1
Sony VPL-VW5000, 136" 2.35:1 Stewart Studiotek 100 screen, Lumagen Pro 4242
dinamigym is online now
post #2915 of 3887 Old 12-15-2018, 04:18 PM
lovingdvd's Avatar
Quoted: 3639 Post(s)
Liked: 810
Very likely to be your HDMI cable from the AVR to your display. What length and what cable are you using now? If you decide to go with Celerity HDMI 2.1 fiber cable let me know.
lovingdvd is online now
post #2916 of 3887 Old 12-15-2018, 11:42 PM
Quoted: 60 Post(s)
Liked: 29
Hey guys,
I have a question in regards to amp assignment & speaker layout on the 8805.
Im planning to have Front heights & rear heights with top middle in ceilings. So for Dolby, I would be doing a 7.2.6, pretty straight forward.
Is the marantz smart enough to let me assign the two top middle in-ceiling speakers as Voice of God channel (phantom VOG) to run a 12.1 Auro 3D setup ?
So in essence, 12.1 channels but 13 speakers, the voice of God channel will be done by the two in-ceiling TML & TMR speakers. Is this possible ?
Thanks in advance !
Sent from my ONEPLUS A5010 using Tapatalk
lampsy is offline
post #2917 of 3887 Old 12-16-2018, 12:44 AM
jdsmoothie's Avatar
Quoted: 22015 Post(s)
Liked: 11939
Originally Posted by lampsy View Post
Hey guys,
Thanks in advance !
No, the TS (VOG) audio would pass to the TML speaker only or you could install a dedicated TS speaker in between the two TM speakers. Additionally, you will need to use either a USB thumb drive or the MultEQ Editor app ($20 iOS/Android) to SAVE a copy of each Audyssey EQ for each of the two configurations (ie. FH+TM+RH and FH+TS+RH).
jdsmoothie is offline
post #2918 of 3887 Old 12-16-2018, 12:52 AM
Quoted: 60 Post(s)
Liked: 29
Ah bummer !!
Tks.
lampsy is offline
post #2919 of 3887 Old 12-16-2018, 04:47 AM
locutus2k's Avatar
Quoted: 242 Post(s)
Liked: 80
Just received my new 8805. Setup was a breeze, first impression on AQ is very positive. Now i would like to enter service menu to test my HDMI cables for 4k 12 bit etc. Can someone please recall the procedure to enter the hidden service menu? Thanks
locutus2k is offline
post #2920 of 3887 Old 12-16-2018, 02:38 PM
batpig's Avatar
Quoted: 4667 Post(s)
Liked: 4852
Why would he need to save the configs separately? He can select the "7ch" height layout with FH+TM+RH+TS.
Or are you specifically referring to the scenario of trying to repurpose the TM speaker as VOG vs. installing a dedicated TS speaker?
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #2921 of 3887 Old 12-16-2018, 05:39 PM
liltalkm's Avatar
Quoted: 278 Post(s)
Liked: 312
Does the 8805 already pass HDR10+ or will there be a firmware update for it?
Edit, NM I figured out that it doesn't yet. I hope it does get an update as I would rather one HDMI cable and not split the audio.
(Theater)Speakers: Martin Logan Expression 13A, Stage X, Dual Depth I Subs, Vanquish in ceiling (surrounds) | Processor: Marantz 8805 | Amp: Three Moon Simaudio 400m monoblocks,One Moon Simaudio 330a, PS Audio Directstream | Sources: DirecTV HR17, Mac Mini, PS4 Pro, Xbox One X, Panny UB820| Television: Samsung 75Q9FN | Remote: Logitech Harmony Elite
(Loft) Anthem MRX 520, LG 77G6P, Oppo UDP-203, Martin Logan Montis, Harmony Elite.
liltalkm is offline
post #2922 of 3887 Old 12-17-2018, 04:34 AM
jdsmoothie's Avatar
Liked: 11939
The former.
post #2923 of 3887 Old 12-17-2018, 04:35 AM
jdsmoothie's Avatar
Liked: 11939
As a "flagship" model which will be around for 3 years, it will most likely receive the update, although no confirmation at this point in time.
post #2924 of 3887 Old 12-18-2018, 11:55 PM
locutus2k's Avatar
Quoted: 242 Post(s)
Liked: 80
Possible HDMI I/O issue
I have a brand new 8805 and i'm experimeting what could be an issue with the HDMI video I/O. The source is a Cambridge CXUHD player (an Oppo clone but -imho- better pq). The vpr is an "old" Jvc RS-57E, the new 4k native Jvc is on my list as soon as it will be available. The 8805 is connected to the vpr with a 66ft HDMI fiber cable Ruipro. The CXUHD is connected to the 8805 with a very short hdmi premium certified cable. The RS-57 even if not native 4k can accept 4k signals (no hdr 10/12bit etc.). This is the issue i'm experimenting:
- Cambridge CXUHD directly connected to vpr with 66ft fiber cable= 4K OK
- 8805 connected to vpr with 66ft fiber cable= 4K upscaling of 1080p input signals OK
- Cambridge CXUHD connected to 8805= not possible to select a 4k output on the player, it keeps saying that the connected gear is not 4K capable, only on start screen it works, on video reproduction it reverts to 108024p and there's no way to force it
Before you ask i have epxerimented with a variety of "premium 4K" hdmi cables from player to receiver (max 5ft lenght).
Any suggestion? I'm posting this on the CXUHD thread too
post #2925 of 3887 Old 12-19-2018, 12:13 AM
jdsmoothie's Avatar
Liked: 11939
Try connecting to one of the HDMI inputs closer to the Zone 2 HDMI monitor output (ie. Media Player, Aux 2, or CD). Note when using the "CD" input, the INPUT ASSIGN setting must be changed from the factory default "Analog" to "HDMI."
post #2926 of 3887 Old 12-19-2018, 10:39 AM
batpig's Avatar
Liked: 4852
While the JVC RS57 accepts 4K signals, it does NOT have HDMI 2.0a / HDCP 2.2 inputs.
The 4K upscaled signals from 1080p are NOT copy protected 4K content, so there isn't any issue with the AVR scaling to 4K output and sending to the PJ.
However, when you actually try to select 4K from the player, it "knows" that the projector is not HDCP 2.2 certified so it steps down to the 1080p output.
As to why it worked with the CXUHD connected directly to the PJ, I'm assuming it's doing some kind of handshake and automatically stepping down the output to a "legal" signal, but with the AVR in the middle as a switch it isn't able to do so. When you connect the CXUHD directly to the PJ, and try to play a 4K BD, what does the projector report as the input signal?
Setup Guide and FAQ
batpig is offline
post #2927 of 3887 Old 12-20-2018, 12:35 AM
locutus2k's Avatar
Quoted: 242 Post(s)
Liked: 80
The vpr report the direct CXUHD signal as 4K 2K 24 YUV 8bit and i can tell that the input signal is a real 4K in resolution because the eshift circuit is greyed out; If i ipass through the 8805 it reports 1080p24 YUV 12bit and the eshift is working to "upscale" to 4K.
I think that the HDCP 2.2 is the culprit. Well, i must wait for the true 4K to come out ...
post #2928 of 3887 Old 12-21-2018, 07:57 AM
locutus2k's Avatar
Quoted: 242 Post(s)
Liked: 80
I'm planning to expand my home theater in the next moths, adding speakeers to complete a Dolby Atmos/DTS:X configuration. In the meantime i have the "classic" 5.1 setup that i'm using with my new Marantz 8805. In the owner's opinion what is the most effective way to listening to "virtual X" surround modes? DTS Virtual or Neural X, Auro Surround simulation Or just plain DTS-HD/Dolby TrueHD decoding? I've noticed that with DTS: Neural X The Cinema EQ is greyed out, is this normal?
post #2929 of 3887 Old 12-21-2018, 08:37 AM
jdsmoothie's Avatar
Liked: 11939
The only "virtual height" mode would be "DTS Virtual:X" (only works on DTS and PCM audio). The other modes are simulation modes that would simulate 2.0 up to 5.1.
post #2930 of 3887 Old 12-21-2018, 12:15 PM
Chokurei's Avatar
Quoted: 27 Post(s)
Liked: 34
Does it matter if I connect a Roku ultra directly to my 8805 or go through the Oppo? Is there a benefit from doing one over the other? Thanks.
Chokurei is offline
post #2931 of 3887 Old 12-22-2018, 08:38 AM
ShotFire's Avatar
Quoted: 23 Post(s)
I'm very confused, haha, some times it dosn't take much. I ordered a AV8805. I'm running a 7.2.4 system right now with the atmos in the front and rear positions. My question is with the AV8805 I can add two more sets of speakers, where should I put them? I read through the 8805 manual on speaker placements and became even more confused with all the different placement options and different decoders using different sets of speakers. HELP? any suggestions would be greatly appreciated.
9.2.6 - Using - Marantz AV8805, Titan 630lx's-LCR "Dual 15's", HTM-12's-Surrounds, Volt10's-Atmos
4x-UM-18-22 in Full Marty's
ShotFire is offline
post #2932 of 3887 Old 12-22-2018, 11:11 AM
jdsmoothie's Avatar
Liked: 11939
The Oppo may provide better upscaling. Try it both ways and decide which you prefer.
post #2933 of 3887 Old 12-22-2018, 11:14 AM
jdsmoothie's Avatar
Liked: 11939
You could add Front Wide and Top Middle speakers noting the current 11 speaker limitation with DTS audio and 13 speaker limitation with Atmos and Auro 3D. For additional options, refer to p. 310 of the Owner's manual.
post #2934 of 3887 Old 12-23-2018, 01:55 AM
locutus2k's Avatar
Quoted: 242 Post(s)
Liked: 80
Is it normal that on "DTS Virtual:X" the dynamic EQ is greyed out? Anyway the online manual is very poor on info.
post #2935 of 3887 Old 12-23-2018, 05:59 PM
jdsmoothie's Avatar
Liked: 11939
Yup, normal.
DTS Virtual:X - simulates height/surround from DTS/PCM audio when no Height/Top/Dolby speakers are configured; able to use Audyssey MultEQ XT32 (lower level models cannot even use Audyssey at all), but unable to use any other Audyssey feature (ie. Dynamic EQ, Dynamic Volume, LFC))
post #2936 of 3887 Old 12-24-2018, 06:04 AM
acidjazz1's Avatar
Quoted: 27 Post(s)
Hi together, does anybody know, what the max sampling rate on the Toslink input is? I onky get 24Bit/96khz through (MacMini build in output), is this correct? Thanks a lot!
Gesendet von meinem SM-G960F mit Tapatalk
acidjazz1 is offline
post #2937 of 3887 Old 12-24-2018, 12:29 PM
ShotFire's Avatar
Quoted: 23 Post(s)
Well I received my AV8805 today or what I thought was a AV8805. The package was unopened and the packing material was factory original, but what was in there was a AV8801. The remote and all the accessories are for the AV8805. Even the sticker on the lower right side says AV8805. Someone at Marantz screwed up. I'm bummed. Bought from Amazon, now I have to return it and wait for another one. !!!!!!!!!!!
ID:	2500502   Click image for larger version
ShotFire is offline
post #2938 of 3887 Old 12-24-2018, 01:01 PM
Dave Vaughn's Avatar
Quoted: 1430 Post(s)
Liked: 2187
I wouldn't buy from that seller ever again. That is outright fraud. There is ZERO chance this happened directly from Marantz--none at all.
audiofan1, audiofan1 and drh3b like this.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
For Sale: JVC X750R Projector (RS500 Equivalent) https://www.avsforum.com/forum/252-f...l#post58241092
Dave Vaughn is offline
post #2939 of 3887 Old 12-24-2018, 01:51 PM
jdsmoothie's Avatar
Liked: 11939
Amazon may have shipped it, but who was the seller? Amazon? Amazon Warehouse? 3rd party dealer?
As Dave noted, highly unlikely that Marantz would somehow place a 7 year old model in with the 2018 model line.
audiofan1 likes this.
post #2940 of 3887 Old 12-24-2018, 02:05 PM
farsider3000's Avatar
Quoted: 1409 Post(s)
Liked: 795
My guess is that someone bought an 8805 from Amazon and returned it with the 8801 inside. Maybe they opened the box from the bottom and resealed it? That is terrible that someone would do that and I am sure amazon will make it right.
Sent from my iPhone using Tapatalk Pro
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5 for surround & ceiling
Subs: JTR Captivator S2, JTR Captivator S1, 2 Seaton Submersive (dual 15")
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is offline
