"Budget" 7.1 AVR & Speaker Recommendations - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Blorton
post #1 of 6 Old 11-11-2017, 03:46 PM - Thread Starter
SabresfortheCup's Avatar
Quoted: 148 Post(s)
Liked: 66
Can anyone recommend a good 5.1.2 AVR around $400? Perhaps an Onkyo TX-NR676 or Denon AVR-X2300W?
I'm looking at building a "budget" home theater system, and I'm trying to narrow down the AVR & Speakers. All-in-all, I'm looking at a $1,500 - $2,000 budget, built over time. I've been looking at the Onkyo TX-NR676, which on paper seems like a great receiver at a great price, but I've heard they have had some major quality issues recently, and that the AccuEQ is so-so. I'm also considering a Denon AVR-X2300W, or maybe a comparable Yamaha unit. I have past experience with Onkyo, so the 676 would be familiar, but I don't want to buy a receiver that will have lesser sound quality or build quality.
Spec-wise, I'm looking for full 4k HDR passthrough (R10, Dolby Vision and HLG), 4 ohm speaker compatibility, and at least 80W 2ch driven 8 ohm 20Hz-20kHz 0.08% THD, with AirPlay, GoogleCast, Bluetooth & Wifi - I think that's more or less bare minimum for a modern Atmos/DTS:X enabled AVR.
Speaker-wise, I'm looking at ELAC Uni-fi UB5's for a 2.0 system to start right now, and a BIC Acoustech PL200 ii later. The speakers are a little large (especially the center channel) and will require some space with the rear ports, but I've heard outstanding reviews and expect that they are well worth the space & cost. I have a lot of faith in Andrew Jones speakers. I also considered ELAC B5/6, KEF 300's and Pioneer SP-EBS73LR's (reviews only, no sound demos).
I'm thinking $400 AVR, $500 Front L/R, $350 Center, $250 Sub, maybe $100 surrounds and $100 height/rear (haven't decided on the make/model/configuration of surrounds/heights).
I have past experience with an Onkyo HTIB (HT-S6800 7.1 system) that I upgraded with Infinity Primus P363 towers, PC-351 Center and a BIC America V1220 sub. I was happy with that system overall, but the Infinity Primus series has been discontinued, and I would like to get something comparable or even a moderate step up in sound quality.
I'm looking for overall recommendations & opinions on a good AVR around $400. Also interested in recommendations & experience with the ELAC UB5's and/or other speakers under $500/pair.
Denon AVR-X4300H, 5.1 KEF Q100's w/Q200C center, SVS PB1000 on the way. 50" Panasonic Plasma (3D), Xbox One
Previous build - Onkyo HT-S6800 7.1 w/ Infinity Primus P262 towers & PC351 Center, BIC America V1220 sub & 52" Sony XBR LCD
SabresfortheCup is offline
post #2 of 6 Old 11-12-2017, 03:30 AM
Quoted: 96 Post(s)
Liked: 123
At $400, Denon and Yamaha are your best bets IMO. If you can spend a little more, the Sony 1080 is worth a look.
Projector: LG PF1500W; Receiver: Sony STR-DN1080; Speakers: Monitor Audio Controlled Performance Inwalls and Inceilings; Subwoofer(s): SVS PC-2000; Bluray Player: Sony BDP-S6500; Remote: Roomie Remote; Cables: Monoprice
rnatalli is offline
post #3 of 6 Old 11-12-2017, 04:38 AM
Blorton's Avatar
Quoted: 35 Post(s)
Liked: 33
Suggest you have a look into the diy speakers area. For the money you can get far better results with very easy to assemble kits.
Sent from my iPad using Tapatalk Pro
- Born half deaf in the 60's and cranking it to 11 ever since.
Living Room: Audio: Pioneer Elite VSX-26tx in 2.1 with Behringer B215XL and Dayton SUB-1500, Video: Roku Ultra and PS4 to an XBR65X930E
Home Gym: Denon DRA-395 in 2.0 with Klipsch KLF-10
wishlist - new LR AVR and Rythmik sub
Blorton is online now
post #4 of 6 Old 11-12-2017, 07:05 AM - Thread Starter
Quoted: 148 Post(s)
Liked: 66
I considered the Sony, but I was concerned about its ability to drive 4 ohm speakers. Aside from that, all the reviews I?ve read have said it?s a fantastic sounding detailed receiver, so I?m still tempted. Whatever I get, I?m hoping to get a good deal (new or used) in the coming weeks.
post #5 of 6 Old 11-12-2017, 07:11 AM - Thread Starter
Quoted: 148 Post(s)
Liked: 66
Interesting idea, I never really considered DIY speaker kits. I haven?t heard too much about them, to be honest, I wouldn?t know where to look for reviews or to buy a good kit.
As good as the Andrew Jones offerings and the ELAC UB5?s are, you?re saying that the kits are well designed enough and with high enough quality components to deliver even better sound at a similar price point?
post #6 of 6 Old 11-12-2017, 07:28 AM
Blorton's Avatar
Quoted: 35 Post(s)
Liked: 33
Hehe. There is a very active sub forum on this very site. Have a gander. Diysoundgroup.com has a lot of great choices. And yes, a well-engineered kit assembled correctly will smoke commercial offerings.
unretarded likes this.
avr , budget , elac uni-fi ub5 , onkyo tx-nr676
