Enter the Bubble: about format agnostic immersive lay-outs - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #1 of 76 Old 11-14-2017, 07:51 AM - Thread Starter
maikeldepotter's Avatar
Quoted: 1670 Post(s)
Liked: 637
With the recently introduced low entry 16 channel Trinnov Altitude, the upcoming (spring 2018) 13.x discrete channel D&M AVRs/processors (together with rumors of 15.x following soon after that), and a number of other companies promising and/or announcing 13.x or more discrete decoding (Stormaudio, Acurus, Emotiva, Lyngdorf, DataSat) the discussion on true format agnostic immersive speaker lay-outs will no longer be the predominant domain of ultra high-end (>20.000) gear or extreme multi-AVR hobbyists.
This thread is to discuss speaker lay-out options for rooms of various sizes and shapes, aiming at the best/ideal/optimal compromise between existing immersive formats (Atmos, DTS:X and Auro3D) and formats on the horizon (ATSC 3.0, link). Focus wil be on the said 13 and 15 main channel configurations, but can also include lower or higher channel counts.
The kick-off is a proposed 7.x.6 / 9.x.6 speaker configuration designed to fully comply to Atmos, DTS:X, Auro3D and ATSC3.0 recommendations. It took me quite some time to figure this one out, and I have posted about (parts of it) on several threads already. I believe it checks all the boxes, and wonder what you guys think of it:
<coming up>
Name:	Schermafbeelding 2017-11-14 om 15.45.10.png
PS Sorry for the cliffhanger, will come back soon ...
Krobar, mry110, mtbdudex and 2 others like this.
A good idea and understanding lies at the base of every successful project.
maikeldepotter is online now
post #2 of 76 Old 11-14-2017, 07:52 AM - Thread Starter
Liked: 637
BASE SPEAKER LOCATIONS
Center: 0d azimuth, (normal) elevation 0-10d
L/R Fronts: between 24-40d azimuth, (normal) elevation 0-10d
Wides: 50-70d azimuth, (normal) elevation 0-10d
L/R Side Surrounds: around 100-110d azimuth, (normal) elevation 5-10d
L/R Rear Surrunds: around 150d azimuth, (normal) elevation 5-10d
CEILING SPEAKER LOCATIONS
Top Fronts / Front Heights
40d azimuth (DTS:X, Auro3D)
42.5d longitudinal elevation (Atmos)
47.5d lateral elevation
35d normal elevation (DTS:X, Auro3D)
lateral separation: 85d
normal separation: 64d
Top Middles / Top Speakers
between 75-105d azimuth (Auro3D)
80-100d longitudinal elevation (Atmos)
57.5d lateral elevation (Auro3D)
56.5-57.5 normal elevation
lateral separation: 65d
normal separation: 64-65d
Top Rears / Surround Heights
135d azimuth (DTS:X, Auro3D)
130d longitudinal elevation (Atmos)
50d lateral elevation
40d normal elevation (DTS:X, Auro3D)
lateral separation: 80d
normal separation: 66d
EXAMPLE
Headspace = vertical distance from 'seated ears' to the ceiling speakers. .
W = distance between opposite side speakers.
L = distance between opposite front/back speakers.
All 'd' values are azimuth angles.
green lines are base speakers
blue lines are ceiling speakers
orange bar is (width of) the usable listening area
Name:	Schermafbeelding 2017-11-22 om 11.38.46.png
Name:	Schermafbeelding 2017-11-28 om 12.50.56.png
Name:	Schermafbeelding 2017-11-28 om 14.04.46.png
Last edited by maikeldepotter; 12-29-2017 at 05:58 AM. Reason: some nomenclature changes
post #3 of 76 Old 11-16-2017, 10:40 PM
Nalleh's Avatar
Quoted: 2931 Post(s)
Liked: 4077
Yes ?.......?.....
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 12xJBL 12" w/6xSLAPS M12 downfiring VNF - 3x2 stacked Crowson MA - 4xBK-LFE Dual TR Sleds- 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XB1X - ATV4K - Vertex2 - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
>>>>Nalleh’s HT<<<<
Nalleh is online now
post #4 of 76 Old 11-17-2017, 12:21 AM - Thread Starter
Liked: 637
Originally Posted by Nalleh View Post
Yes ?.......?.....
Yeah, I know.. Just as curious as you are
Checking the last bits and pieces, and waiting for confirmation from AuroTechnologies that their (near) equidistance requirement (height speakers becoming too noticeable if closer than 0.9x the distance to the speaker below) could be removed by tailoring the FR of each and every speaker to the same target curve. I wish to include that as an option, as it would greatly improve speaker placement flexibility.
post #5 of 76 Old 11-21-2017, 06:37 AM - Thread Starter
Liked: 637
As the response from Auro takes a bit longer than expected, I have started with a summary of the angular positions of 7 base and 6 overhead speakers (see post nr 2). Once I have their confirmation, I wil add examples with room dimensions.
Edit: example added in post no. 2
post #6 of 76 Old 11-22-2017, 05:04 PM
Nalleh's Avatar
Liked: 4077
Is there a reason you put top middle/top surround both in front of you, and closer to each other than the other heights?
Sitting in the right seat, it seems as right top middle and right front height is almost in-line with each other(as wieved from the right seat).
>>>>Nalleh’s HT<<<<
post #7 of 76 Old 11-22-2017, 05:30 PM
appelz's Avatar
Quoted: 735 Post(s)
Liked: 786
If he matrixes Ltm and Rtm as the Top speaker when decoding Auro3D, having them closer together will give a better phantom Top image across the seating area. I currently have a very similar setup in my Lab, but not quite as aggressive.
@jamin and I have some other ideas, but we aren't quite ready to share them yet.
Adam Pelz ,Acoustic Mafia - Hear No Evil
JBL Master ARCOS Calibrator, CEDIA Designer, Home Acoustics Alliance Instructor LIII, THX HT1+ HT2+ Video, Level III Trinnov Altitude Calibrator
Mercenary Calibrator for Manufacturers, Integrators and System Owners
appelz is offline
post #8 of 76 Old 11-22-2017, 10:55 PM
SoundChex's Avatar
Quoted: 393 Post(s)
Liked: 329
Listener Discrimination Between Common Speaker-Based 3D Audio Reproduction Formats
Authors:Howie, Will; King, Richard; Martin, Denis
Affiliation:The Graduate Program in Sound Recording, McGill University, Montreal, Quebec, Canada; The Centre for Interdisciplinary Research in Music Media and Technology, Montreal, Quebec, Canada
Over the last decade, numerous three-dimensional audio playback formats have been introduced and standardized for cinema, broadcast, and home theater environments. They differ in terms of number of speakers, speaker positions in the horizontal and vertical planes, and workflow strategies: channel-based, object-based, or some hybrid of the two. Each system possesses inherent pros and cons. This research attempts to determine whether listeners could discriminate among four currently standardized three-dimensional audio formats for reproduction of acoustic music. Double-blind listening tests showed that listeners could discriminate between NHK 22.2 Multichannel Sound (22.2) and several lower-channel-count 3D reproduction formats with a high degree of success, regardless of the musical stimulus. Listeners were also able to discriminate between three relatively similar 3D audio formats: ATSC 11.1, KBS 10.2, and Auro 9.1, although with significantly less success than with the 22.2. This suggests each of these formats deliver a perceptually different listening experience, with 22.2 being particularly different from the other formats under investigation.
...from JOURNAL OF THE AUDIO ENGINEERING SOCIETY, Current Issue: 2017 October - Volume 65 Number 10 ( http://www.aes.org/journal/ }
Looks like these are ITU-R BS.2051-0 layouts D, F, [subset of] G, and H. It will be interesting to see if|how this AES focus on streaming|broadcast speaker layouts in Korea and Japan is reflected in fothcoming premium priced processors...?!
_
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is offline
post #9 of 76 Old 11-23-2017, 02:16 AM - Thread Starter
Liked: 637
Good point. You can position those TMs anywhere within 75-105d azimuth, corresponding to 80-100d longitudinal (Atmos) elevation. I have corrected the angles and diagram accordingly. In this example, 85d azimuth could be the preferred position, as it puts them right in the middle of the aperture of both Wides to SideSurrounds as Top Fronts to Top Rears.
This has two reasons:
- Auro3D requirements do not allow Top Speakers to be positioned lower than 57.5 lateral elevation
- Moving them further apart (e.g. to align with the L/R fronts) will narrow the listening area (in this example from 4' to 3'). I have explained that here:
a 'too wide' separation angle between an overhead pair can make an in-between positioned mono-sound perceptually snap to one side for listeners sitting too far off-center.
post #10 of 76 Old 11-23-2017, 02:33 AM - Thread Starter
Liked: 637
Exactly. And this can also apply to Atmos, as an (mono) object intended to be heard right above is consequently pan-potted right in-between TM speakers.
Could that be related to your listening area being only two seats (3 feet) wide?
Good things come slowly.
post #11 of 76 Old 11-23-2017, 04:31 AM
Nalleh's Avatar
Liked: 4077
Good point. You can position those TMs anywhere within 75-105d azimuth, corresponding to 80-100d median (Atmos) elevation. I have corrected the angles and diagram accordingly. In this example, 85d azimuth could be the preferred position, as it puts them right in the middle of the aperture of both Wides to SideSurrounds as Top Fronts to Top Rears.
Yes, i realize you are trying to make top middle/top surround a «dual mode» set of speakers, And both those set are basically «right above you» speakers, so i just thought you might compromise the Atmos top middle to much by placing them that far ahead AND that much closer to each other. It kind of compounded the problem.
And since you have both front and rear heights(6 overhead speakers), i see no reason to NOT place them straight up @ 90°.
>>>>Nalleh’s HT<<<<
post #12 of 76 Old 11-23-2017, 04:53 AM - Thread Starter
Liked: 637
Originally Posted by soundchex View Post
...from journal of the audio engineering society, current issue: 2017 october - volume 65 number 10 ( http://www.aes.org/journal/ }
looks like these are itu-r bs.2051-0 layouts d, f, [subset of] g, and h. It will be interesting to see if|how this aes focus on streaming|broadcast speaker layouts in korea and japan is reflected in fothcoming premium priced processors...?!
Translating proposed 'Enter the Bubble' format agnostic 9.x.6 layout into ITU lay-out G and H:
Name:	Schermafbeelding 2017-11-23 om 11.33.33.png
Name:	Schermafbeelding 2017-11-23 om 11.24.10.png
post #13 of 76 Old 11-23-2017, 05:11 AM - Thread Starter
Liked: 637
Remember that following Atmos guidelines you can put Top Middles even further to the front (longitudinal elevation range is 65d - 100d), so anything between 80 and 100 degrees longitudinal elevation is not likely to compromise Atmos in any way. With regard to the lateral 'closeness, in this proposed layout the Top Middles are still 65 degrees separated, which I believe is sufficient for adequate stereo separation and left to right overhead panning.
post #14 of 76 Old 11-23-2017, 07:06 AM
Nalleh's Avatar
Liked: 4077
Remember that following Atmos guidelines you can put Top Middles even further to the front (median elevation range is 65d - 100d), so anything between 80 and 100 degrees median elevation is not likely to compromise Atmos in any way. With regard to the lateral 'closeness, in this proposed layout the Top Middles are still 65 degrees separated, which I believe is sufficient for adequate stereo separation and left to right overhead panning.
Sure, and with just one set of heights, putting them ahead of MLP (65-85°) is perfect.
But you already have front heights/top front. No need to push top middle in front of you. Closer to each other in it self: ok, but closer AND ahead of MLP: weeeell, i am not sure...
A general rule is to «spread them out», and this puts two out of three pairs in front of you, so....
But i haven’t tested it, so i don’t know, so go for it.
>>>>Nalleh’s HT<<<<
post #15 of 76 Old 11-23-2017, 07:18 AM - Thread Starter
Liked: 637
I will test it too, but I doubt that anyone will notice a significant difference between 80 and 100 degrees longitudinal elevation. We are just not very good at localizing sounds above us. Perceptual errors up to 30 degrees are not uncommon.
Name:	Schermafbeelding 2017-11-23 om 15.11.14.png
OKGeek likes this.
post #16 of 76 Old 11-23-2017, 07:48 AM
Nalleh's Avatar
Liked: 4077
I will test it too, but I doubt that anyone will notice a significant difference between 80 and 100 degrees median elevation. We are just not very good at localizing sounds above us. Perceptual errors up to 30 degrees are not uncommon.
Attachment 2319924
Sure, and hey: i have both top front AND top rear in front of MLP in my bastard setup, so i am not one to dish out what works and not, lool.
And i don’t understand what that pic means with the arrows, numbers and what not. .....
maikeldepotter likes this.
>>>>Nalleh’s HT<<<<
post #17 of 76 Old 11-23-2017, 08:12 AM - Thread Starter
Liked: 637
Explanation with picture: A sound source positioned right above someone's head (that's the arrow at 90d) can be perceived to originate either in front of that position (74+/-13 = 61d to 87d longitudinal elevation) or behind that position (68+/-22 = 46d to 90d longitudinal elevation, in Atmos terms: 90d-134d degrees elevation). That produces an average span of inaccuracy amounting to 112-74= 38d.
Edit: If your Top Rears are positioned at 127.5d longitudinal elevation (like in the proposed 'Enter he Bubble' example) they are according to this research within this perceptual range of inaccuracy. That means that a sound coming from Top Middle speakers at 90d longitudinal elevation may be perceived as coming from the Top Rear location. That could be a good reason to position the Top Middles not at 90d but at 80d longitudinal elevation, so that the separation between the two pairs is maximized and the risk of perceptual 'overlap' is minimized.
Nalleh likes this.
post #18 of 76 Old 11-23-2017, 01:15 PM
jamin's Avatar
Quoted: 61 Post(s)
Liked: 78
Would somebody please take a crack at defining these various terms for elevation listed below?
median elevation (Atmos)
radial (MLP ref) elevation
I thought I understood Azimuth and Elevation (either inclination, declination, or altitude) but I'm not so sure now!
plug in to play
jamin is online now
post #19 of 76 Old 11-23-2017, 01:20 PM
jamin's Avatar
Quoted: 61 Post(s)
Liked: 78
Ok, so I'm a little slow. Gotta love the name:
format agnostic immersive layout
F.A.I.L.
plug in to play
jamin is online now
post #20 of 76 Old 11-23-2017, 02:33 PM
appelz's Avatar
Quoted: 735 Post(s)
Liked: 786
Nah. Everything moves in the Lab. Although the seats aren't on rails or actuators like other stuff. Heh
appelz is offline
post #21 of 76 Old 11-23-2017, 05:43 PM
Nalleh's Avatar
Liked: 4077
From the master himself :
Azimuth is strictly in the horizontal pane, 'as seen from above'
Median is in the length of the room, 'as seen from the side' (used for Atmos elevation specs)
Radial is as seen from MLP (used for Auro3D height speakers elevation specs)
Lateral is in the width of the room, 'as seen from rear/front (used for the Auro3D top speakers elevation specs)
OKGeek likes this.
>>>>Nalleh’s HT<<<<
post #22 of 76 Old 11-23-2017, 08:29 PM
jamin's Avatar
Quoted: 61 Post(s)
Liked: 78
Thank you.
plug in to play
jamin is online now
post #23 of 76 Old 11-24-2017, 05:18 AM - Thread Starter
Liked: 637
I have slightly changed the position of the Top Rears / Surround Heights (see post no. 2) in order to decrease the difference in sound arrival time for listeners at the extreme end of the listening area: Azimuth from 130d to 135d, and lateral elevation from 47.5d to 50d.
And I have added separation angles for the ceiling speakers, showing that despite a much more narrow position of the Top Middles (lateral separation of 65d compared 80d-85d for the other two pairs), the normal separation angle (from MLP perspective) between the two overhead arrays remains almost the same (64-66 degrees).
post #24 of 76 Old 11-24-2017, 06:30 AM
Nalleh's Avatar
Liked: 4077
How about a median and lateral drawing, to easier vizualise what it looks like ?
>>>>Nalleh’s HT<<<<
post #25 of 76 Old 11-28-2017, 05:53 AM - Thread Starter
Liked: 637
Originally Posted by nalleh View Post
how about a median and lateral drawing, to easier vizualise what it looks like ?
Lateral (from side to center), showing longitudinal elevations:
Median, or better: Anterior (from rear to front), showing lateral elevations
Added to post no. 2
Nalleh likes this.
post #26 of 76 Old 11-29-2017, 05:25 AM - Thread Starter
Liked: 637
Five Steps to a F.A.I.L (format agnostic immersive lay-out)
Definitions:
  • Headspace (HS) is the vertical distance from ears to ceiling speakers.
  • Speaker-Layout Width is the side-to-side distance between opposite side wall speakers.
  • Speaker-Layout Length is the front-to-back distance between L/R front and Rear Surround speakers.
Acronym:
  • RLP is Reference Listening Position
STEP 1 DETERMINE SPEAKER-LAYOUT DIMENSIONS AND SEATING HEIGHT
  • Start with an existing room, and declare a front wall.
  • Check if the Headspace (HS) is between 1 and 2 times your seated ear height (ATMOS spec).
  • Check if Speaker-Layout Width can be arranged to be at least 2.6*HS (ATMOS spec related) and no more than 3.4*HS (Auro3D spec related)
  • Check if Speaker-Layout Length can be arranged to be at least 1.8*HS and no more than 3.4*HS, which is the sum of:
    at least 0.8*HS (allowing Top Rear speaker placement, see STEP 3) and no more than 1.6*HS (Auro3D spec related) rearward of the RFP, and
    at least 1.0*HS (ATMOS and Auro3D spec: L/R fronts azimuth <40d, see STEP 2) and no more than 1.8*HS (Auro3D spec related, resulting in min. 24d azimuth for L/R fronts) forward of the RFP
Name:	Schermafbeelding 2017-12-29 3.png
Nalleh and OKGeek like this.
post #27 of 76 Old 11-29-2017, 05:27 AM - Thread Starter
Liked: 637
Definitions:
  • The Center-Front reference denotes an imaginary line between the RLP and the middle of the screen or the placement of the center speaker
  • The Center-Side reference denotes an imaginary line between the RLP and the Speaker-Layout boundary to either side
Name:	Schermafbeelding 2017-12-21 om 11.00.06.png
STEP 2 DETERMINE REFERENCE LISTENING POSITION AND L/C/R FRONT SPEAKER LOCATIONS
  • Position the RLP right in the middle between Left and Right side boundary, and according to the positional ranges given in STEP 1.
  • Position the L/R Front speakers between 0.8*HS and 1.0*HS to either side of the Center-Front reference (ATMOS spec: lateral separation about the same as that of the overhead speakers, see STEP 3, and azimuth between 24d and 40d), and the C speaker right in the middle, all at an (normal) elevation of 0 - 10 degrees
Name:	Schermafbeelding 2017-12-24 om 13.15.57.png
Nalleh likes this.
post #28 of 76 Old 11-29-2017, 05:30 AM - Thread Starter
Liked: 637
Explanation spherical coordinate system: link
STEP 3 DETERMINE CEILING SPEAKER POSITIONS
  • Position the Top Fronts/ Front Heights AT THIS EXACT POSITION: 1.09*HS forward of, and 0.92*HS left and right from the Reference Listening Position (speaker distance=1.74*HS)
Name:	Schermafbeelding 2017-12-22 om 15.38.05.png
    Resulting spherical positions:
    42.5d longitudinal elevation (ATMOS spec: 30d-55d)
    35d normal elevation (Auro3D spec: 25-35d; DTS:X: 45d±10d; ATSC3.0 spec: 35d±10d)
    40d azimuth (Auro3D spec: 22d-40d; ATMOS spec: 30d-60d; DTS:X: 45d±5d; ATSC3.0 spec: 45d±5d)
  • Position the Top Middles (Top Speakers) WITHIN THIS RANGE (recommended position in italics): between 0.18*HS forward and 0.18*HS rearward of, and 0.64*HS left and right from the Reference Listening Position (speaker distance=1.20*HS)
Name:	Schermafbeelding 2017-12-22 om 15.43.50.png
    80d - 100d longitudinal elevation (ATMOS spec: 65d-100d)
    57.5d lateral elevation (Auro3D spec: 57.5d-72.5d)
    56.5d - 57.5d normal elevation
    75d - 105d azimuth (Auro3D spec: 75d-115d)
    normal separation: 64d - 65d
    Longitudinal separation Top Fronts - Top Middles: 37.5d - 57.5d (see also this post)
  • Position the Top Rears/ Surround Heights WITHIN THIS SMALL RANGE: 0.84*HS - 0.92*HS rearward of, and 0.84*HS l- 0,92*HS left and right from the Reference Listening Position (speaker distance=1.55*HS - )
Name:	Schermafbeelding 2017-12-22 om 15.49.16.png
    130d - 132.5d longitudinal elevation (ATMOS spec: 125d-150d)
    47.5d - 50d lateral elevation
    37.5d - 40d normal elevation (Auro3D spec: 30d-40d; DTS:X: 45d±10d; ATSC3.0 spec: 35±10d)
    135d azimuth (Auro3D spec: 90d-135d; ATMOS spec: 120d-150d; DTS:X and ATSC3.0 spec: 135d±5d)
    lateral separation: 80d - 85d
    normal separation: 66d -
    Longitudinal separation Top Middles - Top Rears: 30d - 50d - 52.5d (see also this post)
post #29 of 76 Old 11-29-2017, 05:31 AM - Thread Starter
Liked: 637
STEP 4 DETERMINE THE POSITIONS OF REMAINING BASE LAYER SPEAKERS
  • Position the L/R Side Surrounds at 100d-110d azimuth (ATMOS spec: 90d-110d; Auro3D spec: 90d-135d; F.A.I.L spec: 100d-110d to avoid speaker pointing right at listener's ear), and at 5d-10d (normal) elevation (Auro3D spec: 0d-10d; F.A.I.L spec: at least 2.5d-5d to not exceed 35d difference in normal elevation with Top Rears/ Surround Heights)
  • Position the Wides at 50d-70d azimuth (ATMOS spec: 50d-70d; Best Practice: preferrably at the median intersect between L/R Front and Side Surround), and at 0d-10d (normal) elevation (Auro3D spec: 0d-10d)
  • Position the L/R Rear Surrunds at 150d azimuth (ATMOS spec: 135d-150d; Auro3D spec: 135d-155d; F.A.I.L spec: at 150d to get maximum separation with Side Surrounds), and at 5d-10d (normal) elevation (ATMOS spec (deduced): 0d-10d; Auro3D: 0d-10d; F.A.I.L. spec: at least 2.5d-5d to not exceed 35d difference in normal elevation with Top Rears/ Surround Heights)
post #30 of 76 Old 11-29-2017, 05:32 AM - Thread Starter
Liked: 637
STEP 5 Enjoy!
