Owner's thread: Pioneer VSX-932 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #91 of 147 Old 10-12-2018, 07:46 AM
dfa973's Avatar
Quoted: 844 Post(s)
Liked: 788
Originally Posted by pault503 View Post
Sorry I am completely new to the whole AVR world....
What do you mean by not a true 7.2 ?
There are 2 pre-outs.. so shouldnt it be able to support 2 subwoofers?
Also i have 5 speakers rated (20W-200W) Wharfedale ATS 400 ... and a 150W sub Wharefedale SW150.....
would this receiver be able to support that load or should i be looking a more powerful one?
Thanks in advance for the replies...
As I have explained above, there are 2 pre-outs for 2 subs, but the receiver does not treat those 2 pre-outs as different subs, only as one sub - the calibration and the EQ does not take in consideration whatever difference is between those two subs (location, level, timing, FR, etc.).
The Wharfedale ATS 400's are fine, keep the receiver at 8ohm (default value).
dfa973 is offline
post #92 of 147 Old 10-12-2018, 08:56 AM
stumpper98's Avatar
re-install firmware by USB
No sound after firmware update VSX-932 1081-0020-0060-0010 (this ver. shows on the receiver)
My unit was working fine - no issues, before on the NET firmware update
Per Pioneer support:
re-install firmware by USB - make sure the files are not in a folder
with the power on - hold "Pure Direct and Power button"
move to USB update - enter - (you should see % complete on the screen)
Factory reset
with the power on - hold "Auto Direct and Power button"
stumpper98 is offline
post #93 of 147 Old 10-17-2018, 07:01 PM
Liked: 2
Firmware 1091 released:
https://www.pioneer-audiovisual.eu/u...e_update/14919
Adds support for Amazon Music. ※Amazon Music service requires that you have Amazon Prime
account or Amazon Music Unlimited account ※Pioneer Remote App is required for initial set-up of
Amazon Music.
For detail about updated function, please refer to the link below.
http://jp.pioneer-audiovisual.com/ma...amazon_pio.pdf
 Enhanced security.
Depending on the Firmware version, update will be needed 2 times.
 Minor bug fixes and improvements stability.
SirDishcloth is offline
post #94 of 147 Old 10-21-2018, 08:58 AM
pecoflyer's Avatar
Hi
I need some advice again, but I'm unsure if I'm in the right forum. If not just let me know which is the right one
I use the Pioneer remote app to play music from a USB stick on an MRX5 loudspeaker and a VSX932.
I can see what is on the stick on my android phone, , but can only create a playlist adding music one music piece at the time. I'd like to add them all at once to the playlist.
Is there any way I can accomplish that? Thanks
pecoflyer is offline
post #95 of 147 Old 10-23-2018, 03:59 PM
schwolowm's Avatar
Quoted: 16 Post(s)
Liked: 2
I feel like this is a dumb question. Sometimes I want to just listen to Bluetooth music on my nice speakers but I seem forced to have to look at the Bluetooth screen on my TV (P55-F1), instead of whatever I wanted to see in the background (Xbox, whatever). I have my cable box and Xbox running into this to the TV via hdmi. Noobie here.
schwolowm is offline
post #96 of 147 Old 11-08-2018, 11:10 PM
Liked: 0
A bit of info for those who have experienced unexplained relay clicks with this receiver.
After dicking around with the settings and different scenario's I eventually realised that the click occurs exactly 30 minutes after the unit is turned on. It doesn't matter if any sources or speakers are connected. The only setting that stops the click is setting the speakers from 6 ohm to 4 ohms in the config menu. My understanding is that this setting drops the voltage on the power supply, and in effect drops the power that can be supplied to the speakers. I have confirmed this behaviour with two different units.
I approached Pioneer's Australian distributor for support. After a week of trying this and that they went back to Pioneer Japan for an explanation. This is the response: "Pioneer have confirmed it is part of the design and you can’t disable it. The relay is controlling the main power transformer. When more or less power is required the relay activates and changes the transformer winding which raises or lowers the voltage to the output stage. This design is used across all the pioneer models so swapping to a different product is not going to solve your issue."
Mystery solved.
Belenus is offline
post #97 of 147 Old 11-09-2018, 04:34 PM
AJCxZ0's Avatar
Quoted: 61 Post(s)
Liked: 59
Thanks for sharing this with us.
While annoying, the clicks are tolerable for a receiver with these features for the prices I paid [I have two]. Nevertheless I just changed the setting from 6Ω to 4Ω and noticed no obvious change to the output from my various nominal 6Ω speakers.
AJCxZ0 is offline
post #98 of 147 Old 11-09-2018, 05:56 PM
Liked: 0
Mine was a dirt cheap display model. The distributor has given me a return authorisation if I want to take it back to the retailer but I think I'm going to stick it out.
Belenus is offline
post #99 of 147 Old 11-11-2018, 06:55 AM
AJCxZ0's Avatar
Quoted: 61 Post(s)
Liked: 59
I also noticed no change to the clicking, so changed the setting back to 6Ω.
AJCxZ0 is offline
post #100 of 147 Old 12-17-2018, 09:26 AM
HammerJoe's Avatar
Quoted: 149 Post(s)
I was eyeing this receiver but it seems that it doesnt support 8ohm speaker which is what I have.
Polk RM101 kit.
These are rated 8ohm so this would not be the right receiver to drive them?
HammerJoe is offline
post #101 of 147 Old 12-17-2018, 11:07 PM
AJCxZ0's Avatar
Quoted: 61 Post(s)
Liked: 59
It will drive your 8 Ω speakers just fine. The specs even give the power output per channel at 8 Ω with two channels driven (80 W).
AJCxZ0 is offline
post #102 of 147 Old 01-03-2019, 09:12 AM
HammerJoe's Avatar
Quoted: 149 Post(s)
Is there a way to increase the volume level without messing up with the mcacc calibration?
I'm finding that the volume is quite low with the cable dvr.
post #103 of 147 Old 01-04-2019, 10:33 AM
Liked: 3
Hello, Check for a new update for VSX-933 01/04/2019 1030-6000-1040-0010!
I have just applied the following equalizer settings manually on VSX-933, search on youtube the following Pioneer AV-R EQ Equalizer Einstellungen Heimkino / AV Receiver Series SC / LX / VSX
oliver44 is offline
post #104 of 147 Old 01-04-2019, 10:57 AM
Liked: 3
The VSX-932 also benefits from a new firmware 01/04/2019 1101-2020-0060-0010!
oliver44 is offline
post #105 of 147 Old 01-22-2019, 12:19 AM
Liked: 0
Anyone using this amp with a Universal Remote Control?
Trying to setup on a Harmony Elite, and can't figure out how to get it to turn to TuneIn Radio, at least (for example) or even to a particular station/preset.
S'pose similar for trying to get to any of the specific "NET" settings?
Not sure if it is possible...
hornetster is offline
post #106 of 147 Old 01-22-2019, 03:04 PM
AJCxZ0's Avatar
Quoted: 61 Post(s)
Liked: 59
Caveat: none of this is helpful.
My URC R40 was set up for my VSX-94TXH by learning the IR codes. Most of the comparable functions work with the VSX-932, but like with all URC R40s the screen has faded to black so I can't even see to try to program new codes.
With the Android app and HDMI CEC I almost never need a remote.
If you can't learn the IR code, then can you program it as a macro?
AJCxZ0 is offline
post #107 of 147 Old 01-22-2019, 11:40 PM
Liked: 0
Yeah, the problem being from what I can see, there is no 'revealed' IR code - no button on the original remote - to do this. Looks like it has to be a macro, but that's rather difficult too, as you need to go into NET, then choose TuneIn, but, going into NET just takes you to the last listened option ie may be Spotify, Tunein, Deezer etc. So difficult (impossible) to create an accurate macro, as it changes every time....
post #108 of 147 Old 01-25-2019, 12:39 PM
Liked: 0
Hi guys, hope someone can help.
I’ve noticed that there is a relay delay between the amp and the sub. The sub will sleep and when required by the amp, it’ll turn on again. It’s like a standby mode. I’ve played around with the settings but no change. Any help will be appreciated
Cheers
Hayssam Sleitini is offline
post #109 of 147 Old 01-31-2019, 07:51 AM
Liked: 2
Cheers
A lot of subs do this for "power saving" - it's nothing to do with the Amp.
post #110 of 147 Old 01-31-2019, 07:54 AM
Liked: 2
Firmware 1101 released 20190104:
Source:
post #111 of 147 Old 04-12-2019, 04:31 AM
Mr Man's Avatar
Can you set individual cross overs for each speaker with this AVR?
Mr Man is offline
post #112 of 147 Old 04-13-2019, 08:14 PM
AJCxZ0's Avatar
Quoted: 61 Post(s)
Liked: 59
Nope.
While the VSX-932 (and VSX-933) supports lots of inputs, outputs and encodings, it's still the basic seven channel receiver and features such as independent crossover are reserved for (some of?) the Elite range such as the SC-LX502 (if I interpret the manual correctly).
AJCxZ0 is offline
post #113 of 147 Old 04-27-2019, 01:18 PM
djdk80's Avatar
Vsx-932 Chromecast Group Play Delay after firmware update !
I noticed its way off sync after latest firmware update.
I have 7 speakers (Google Home Speaker Group) and they all sync well except vsx-932
anyone having same issue? hopefully there will be another firmware update soon?
Let me know .. Thanks
djdk80 is offline
post #114 of 147 Old 05-08-2019, 06:40 AM
Liked: 0
I’m having the same issue. Really out of sync!
Also, is there anyway to change the display info setting? It always reverts back to the HDMI input and Volume.
I’d like this to permanently display DOLBY DIGITAL+ or DTS-HD master, etc,
Joseph Naim is offline
post #115 of 147 Old 05-13-2019, 06:09 PM
schwolowm's Avatar
Quoted: 16 Post(s)
Liked: 2
Anyone with an Xbox 1 and this receiver? What's the best way to connect this thing? Do I send hdmi from the Xbox to the receiver, then to the P55-F1 I have? I just moved, was getting audio delay from the Xbox, been playing around with my setup. I think I had connected the Xbox via hdmi to input 5 of the TV which I think sent arc from input 1 of the TV to the receiver. Only input 5 of the TV is low latency, and that doesn't support arc. Now, when I have the unit muted, I see a permanent black bar of "muted" in the bottom of my screen. What's the deal. I just updated also. Version 1070-9020-0060-0010. Sorry I'm not super experienced with these.
Edit: I swear I didn't see edit button before the 2nd post. Took hdmi back direct to TV from Xbox, regained audio delay and got rid of muting bar.
post #116 of 147 Old 05-13-2019, 06:36 PM
schwolowm's Avatar
Quoted: 16 Post(s)
Liked: 2
Also, I swear since moving I've absolutely lost my low end. I have a Klipsch K100SW and man, I used to have to keep it way down on the receiver, - 10 or more for general viewing. It's absolutely gone now. Via Bluetooth, I find bass notes in Ext. Mono. It's strange and annoying as hell
post #117 of 147 Old 05-13-2019, 08:15 PM
djdk80's Avatar
Glad to hear Im not the only one !
I have contacted pioneer support multiple times but so far nothing they can help me
Please give them a call and inform about this matter
djdk80 is offline
post #118 of 147 Old 05-20-2019, 02:19 PM
djdk80's Avatar
Group google chrome cast sync issue is still there .. (speaker group play)
Omg this is driving me nuts .. anyone else having this issue too?
We really need to put our voice out there to pioneer so they can fix this issue
djdk80 is offline
post #119 of 147 Old 05-27-2019, 06:18 AM
noise36's Avatar
Originally Posted by SirDishcloth View Post
FYI, Chromecast Ultra (external 4K streaming device) still doesn't work on any of the HDMI input ports.
I just got this AVR as it was the cheapest I could find that had all the current features I need until HDMI 2.1 is mainstream in 2020 when I will upgrade the TV/AVR...and was disappointed to discover that CC Ultra doesn't work with it.
It's a strange one really as the CC Ultra is just a HDMI device like any other, nothing special about it, should work like any other device yet it doesn't.
Is there any official word from Pioneer as to why?
noise36 is offline
post #120 of 147 Old 06-12-2019, 04:36 AM
Liked: 0
Thumbs down Group google chromecast sync issue
Yes I have the same issue and I'm pretty sick of it!
Any view on when this will be solved?
Robert Elshout is offline
