Behringer KM750 vs A500? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By CrusherW9
  • 1 Post By StevenC56
  • 1 Post By jbjbjbjb
post #1 of 9 Old 12-30-2017, 06:12 PM - Thread Starter
CrusherW9's Avatar
Quoted: 213 Post(s)
Liked: 127
I've been looking at amps for my KEF Q100s and I stumbled upon the Behringer KM750. Spec wise it seems similar, actually, slightly better than the A500, but with more power (it has a fan though) and $50 cheaper. I've searched but haven't found anything about the KM750. Since they're both AB amps and have similar specs, is it possible this is some sort of remake/new version of the A500? Does anyone know anything about the KM750?
A500 Manual (Contains spec page):
https://media.music-group.com/media/...P0217_M_EN.pdf
A500 on Amazon:
https://smile.amazon.com/dp/B000CZ0R...8K0VMSWQ&psc=0
KM750 Manual:
https://media.music-group.com/media/...750_QSG_WW.pdf
KM750 on Amazon:
https://smile.amazon.com/Behringer-K...ct_top?ie=UTF8
CrusherW9 is offline
post #2 of 9 Old 12-30-2017, 06:14 PM - Thread Starter
CrusherW9's Avatar
Quoted: 213 Post(s)
Liked: 127
When I made the thread I only had 4 posts but you need 5 to post links. Since I now have 5 posts, here's what I was going to include .
Here's a video that shows the internals of the KM750, though I really don't know what I'm looking at.
Picture of the A500 internals
https://forums.audioholics.com/forum...ide1-jpg.3415/
Squirrel! likes this.
"Becoming educated is more than just acquiring knowledge. It involves the ability to see the world in ways never before conceived."
post #3 of 9 Old 09-04-2018, 02:58 PM
Squirrel!'s Avatar
Quoted: 823 Post(s)
Liked: 512
Old thread I know, but I just bought one of these amps. What you are looking at are 2 main differences, the 1st, no fan on the A500, instead, the cooling fins are external, and secondly, the torroidal transformer looks to be twice the size of the KM750 torroidal. Those are 2 highly desired features.
I opted for the KM750 is based on the desired use, to replace 2 Dayton Audio SPA500 plate amps. I am only looking for the same quality of audio, reasonably priced, not something to blow the doors off their hinges. Just something to replace what I already have/had. I think this amp should fill the need nicely.
Now, my only concern is where to place it so 1] I don't hear the fans and 2] it gets enough ventilation, which is likely what killed my SPA500, or lack thereof, anyway. Real estate in my living room is at a premium as well, making it that much more difficult to place than it needs to be.
Anyone here how loud the fan is? Can you compare it with something? Can't find any videos of the fan noise.
Main: Mitsubishi 73736|OTA|fireTV|Sony BDP-S1100|Denon AVR4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|1-1000watt & 1-500watt DIY 12" Subs|2 Bass Shaker|APC H15 Power Conditioner|Harmony Hub|Sennheiser RS 160|SMSL B1 BT Rx|Linksys SE2500
MBR: Vizio VF550M|OTA|fireTV3|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Dayton SAT-BK|MartinLogan Dynamo 300|Belkin PF30|Harmony 550
Squirrel! is offline
post #4 of 9 Old 09-04-2018, 10:27 PM
StevenC56's Avatar
Quoted: 586 Post(s)
Liked: 206
Which one are you saying has a larger transformer, the SPA500 or the KM750?
JVC X750R Projector,Yamaha CX-A5200 Pre-Pro, Yamaha RX-Z11 Receiver, (Amps Only) Yamaha MX-D1 Power Amps x 2, Yamaha RX-Z1 (L&R Surround Channel Amp), Oppo BDP-103D BR, Panasonic DP-UB820 UHD, Pioneer Elite CLD-99 LD, Definitive Tech BP7000SC Mains, CLR3000 Center, BPVX Surround Sides&Backs, BPX F&R Presence, Martin Logan Abyss Front L&R Subs/Dynamo L&R Rear Surround Channel Subs, Infinity SSW-210 Center Channel Sub.
StevenC56 is offline
post #5 of 9 Old 09-05-2018, 11:15 AM
Squirrel!'s Avatar
Quoted: 823 Post(s)
Liked: 512
The SPA, easily.
post #6 of 9 Old 09-05-2018, 12:02 PM
jbjbjbjb's Avatar
Quoted: 14 Post(s)
I use the KM750 for my rear surrounds. The fan is almost silent.
jbjbjbjb is offline
post #7 of 9 Old 09-05-2018, 06:02 PM
Squirrel!'s Avatar
Quoted: 823 Post(s)
Liked: 512
Thankyou for the insight!
post #8 of 9 Old 09-08-2018, 10:38 AM
Squirrel!'s Avatar
Quoted: 823 Post(s)
Liked: 512
LOL! Got mine. Fan sounds like a dang jet! I presume you have your mounted away somewhere so you can't hear the fan. I realize this piece was designed to be used in a music venue and not home theater duties so fan noise is really inconsequential in the right environment. I will be doing several tests as to what the appropriate 'fix' is and will report my findings here.
As for my venue, my living room, it won't be pushed hard except occasionally with some good action movies and music of course. The music is what gets cranked more than the movies, and is how I destroyed my SPA500 plate amp in one of my subs. So I am looking at 1 of 3 options:
1] No fan...just plain disconnect and be done with it.
2] Add a resistor to slow down the existing fan speed which in turn will be quieter
3] New Fan...go to a thinner fan blade - drawback is there will still be noise
Option 1 obviously is the 1st test. See how hot it gets.
post #9 of 9 Old 09-10-2018, 12:59 PM
Squirrel!'s Avatar
Quoted: 823 Post(s)
Liked: 512
Went with option #1 . Ran hard for an entire movie and warmest it got [no fan] was 141 degrees. Temp after extended 'normal' tv viewing [SNF] was 83 degrees. It'll be fine with no fan.
