The *OFFICIAL* Denon AVR-X8500H 13.2ch Flagship AVR Thread - Page 99 - AVS Forum | Home Theater Discussions And Reviews
 4206Likes
post #2941 of 4568 Old 11-11-2018, 05:23 PM
mtbdudex's Avatar
Quoted: 83 Post(s)
Liked: 1494
Originally Posted by ANSEK View Post
After two months and a half I finally installed my top rear speakers to go along with my top middle. I was shocked to discover that the 8500 doesn’t support a 5.1.4 configuration with Top middle and top rear. I have to tell it that it is too front and top rear. Given the price of the 8500 I’m shocked it doesn’t support this official Dolby speaker layout. Please tell me the 8500 treats Top Front as as Top Middle in a 5.1.4 config.
I don’t see TM + TR in the July-2017 install guide , where is it??
These are the 4 in 5.1.4 configurations I see:
TF + TR
DEF + DER
TF + DER
DEF + TR
mtbdudex is offline
post #2942 of 4568 Old 11-11-2018, 06:06 PM
gene4ht's Avatar
Quoted: 1981 Post(s)
Liked: 2673
FH - TF - TM - TR - RH
IIRC, it was either Dolby or D+M that stated the following...but...selecting any two adjacent speakers is an invalid configuration
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is online now
post #2943 of 4568 Old 11-11-2018, 08:38 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6495 Post(s)
Liked: 6475
Originally Posted by Stro3579 View Post
guess I have to eventually get a amp then. It drives me bonkers having to turn volume up to 65-70ish.
Why, mine does the same, 50 is almost a whisper, 75 is more then enough over here.
Matt2026 likes this.
Cleveland Plasma is online now
post #2944 of 4568 Old 11-11-2018, 11:55 PM
CBdicX's Avatar
Quoted: 1621 Post(s)
Liked: 384
Indeed a stupid way of not letting the user decid what to speaker setup to use.
I had a discusion with Auro in the past of using a mix of DE speakers and Direct fire for Height, they told me that was not preferd in a Auro setup so it was not possible
I do not care if it's preferd in what ever setup, i think if the user wants it, it must be possible if you have the amps.
I use my Surround Back speakers near the ceiling as i do not have space on ear level, works for me and would be very strange if the receiver would say during setup that SB speakers in that spot are not supported.
I have just 2 Height speakers in the Top Middle spot, and also i can not say i have only 2 TM speakers.
So i run them as FH, i my case absolute no problem but still a strange way of pushing users into specific setups.
I do not care what Dolby, DTS or Auro wants as a speaker setup, i want to decid myself please !
CBdicX is offline
post #2945 of 4568 Old 11-12-2018, 03:28 AM
jdsmoothie's Avatar
Quoted: 22163 Post(s)
Liked: 12033
Originally Posted by gene4ht View Post
I have to admit to using a slide rule for more than a few years!
Curious...what branch? If army...what was your MOS?
Navy. Supply Corps officer (submarines).
longbow, Alanlee and vn800art like this.
jdsmoothie is offline
post #2946 of 4568 Old 11-12-2018, 03:33 AM
jdsmoothie's Avatar
Liked: 12033
Suggest you use the dB volume option.
I have mine set at the dB volume option and default on is -35db, then I turn it up from there. I’ve also got max volume limited to 0db, there’s no need to go over that at all in a properly setup system for normal usage, heck even demos .
Setting the MAX VOLUME is a smart thing to do especially when there can be other fingers on the AVR's remote when you're not around. I start mine at -40dB which is sufficient for any early morning viewing when the wife is still asleep.
mtbdudex and Nalleh like this.
post #2947 of 4568 Old 11-12-2018, 04:39 AM
ANSEK's Avatar
Quoted: 52 Post(s)
Liked: 46
TF + TR
DEF + DER
TF + DER
DEF + TR
It must be a labeling thing because if you go to the Dolby 5.1.4 overhead setup guide you will see the position is clearly the same as top middle but the I know see the labeling is top front. A little confusing.
https://www.dolby.com/us/en/guide/do...etup-guide.pdf
anseK®
Denon AVR-8500H | Optoma UHD60 | Xbox One X | AppleTV 4K
SVS Ultra Towers | SVS Ultra Center | SVS Ultra Surrounds | SVS Prime Elevation | SVS PB16 Ultra
ANSEK is offline
post #2948 of 4568 Old 11-12-2018, 05:22 AM
mtbdudex's Avatar
Quoted: 83 Post(s)
Liked: 1494
Honestly it’s not in middle, rather front and rear, from pdf link you provided
They are showing a typical example of single row and small room usage for Atmos, no need 7 bed channels ...
And side view also
Q; if you using 5.1.4 why the 8500H?
It’s overkill for that.
A 4400H would totally suffice, I’ve got a 4300H in my family room at 5.1.2 soon 5.1.4
mtbdudex is offline
post #2949 of 4568 Old 11-12-2018, 06:45 AM
bigguyca's Avatar
Quoted: 983 Post(s)
Liked: 813
Both volume scale alternatives are calibrated in dB's.
dB is correct, the "B" is for Alexander Graham Bell: another example; the unit for current is A, ampere, for Andre-Marie Ampere
db has no meaning in this context
mtbdudex likes this.
bigguyca is offline
post #2950 of 4568 Old 11-12-2018, 07:17 AM
bigguyca's Avatar
Quoted: 983 Post(s)
Liked: 813
Evidently you're serious with the post, but I've rarely (actually never that I remember) heard them without an implied reference, and multiple levels of meaning. Those words trigger me to other Claude Rains lines, such as "Round up the usual suspects."
Next is a quick search of lines from Casablanca, and then perhaps yet another viewing of Casablanca.
The power of words is amazing.
Craig Peer and brazensol like this.
bigguyca is offline
post #2951 of 4568 Old 11-12-2018, 07:46 AM
petetherock's Avatar
Quoted: 1694 Post(s)
Liked: 890
I'm moving to a new place, and it's rather small: 4m wide, 2.93m long
If I go by the Atmos ceiling speaker guides, I can place the front height and the rear height speakers on the front and rear wall respectively, but will that be effected?
The front will be about 40 degrees and the rear about 30-32 degrees.
Logistically it's easier to mount on the walls than the false ceiling..
petetherock is offline
post #2952 of 4568 Old 11-12-2018, 07:59 AM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2846
Yes, those Front and Rear Height positions will be fine.
The front-to-back soundstage will be somewhat expanded when compared to what you'd hear if you mounted the speakers on the ceiling, but it'll still produce an enjoyable experience.
petetherock likes this.
Selden
Selden Ball is offline
post #2953 of 4568 Old 11-12-2018, 08:38 AM
ANSEK's Avatar
Quoted: 52 Post(s)
Liked: 46
And side view also
I went with the 8500 for a few reasons, amongst them are more power (it is actually underpowered for my SVS Ultra Towers), the option to go 5.1.6 (since my dedicated theater is pre-wired for 5.1.6+ Voice of God), and I wanted to see how this compares to my Anthem D2 and A5 downstairs.
anseK®
ANSEK is offline
post #2954 of 4568 Old 11-12-2018, 09:53 AM
mtbdudex's Avatar
Quoted: 83 Post(s)
Liked: 1494
I, Michael Rosinski, being a HT hobbyist with overall good intentions, do herby define the abbreviation db = dB when I’m using it in acoustical contexts on AVS forum
Acoustics
https://en.m.wikipedia.org/wiki/Acoustics
db = dB = decibel
https://en.m.wikipedia.org/wiki/Decibel
Fat fingering be Dammed!
batpig, GIEGAR, drh3b and 1 others like this.
mtbdudex is offline
post #2955 of 4568 Old 11-13-2018, 08:33 PM
Craig Peer's Avatar
Quoted: 6703 Post(s)
Liked: 7828
I've had a few movies where I've turned it up to 80 - much to the absolute delight of my " we love it loud " movie watching friends. When the wife's watching - 70ish max.
Parts of Sicario 2 just sounded awesome !!
Craig Peer is online now
post #2956 of 4568 Old 11-14-2018, 01:14 AM
CBdicX's Avatar
Liked: 384
There are a lot of Font Wide users here, but isn't FW in the upmixed content just a copy of the front speaker signal ?
Is FW in Atmos/DTSX a signal complete separated from the Fronts ?
CBdicX is offline
post #2957 of 4568 Old 11-14-2018, 05:21 AM
Liked: 2846
That'd depend on the algorithm used by the upmixer.
The Dolby Surround upmixer doesn't use Front Wides at all. They stay silent.
[/quote]
The Front Wide speakers are used when Atmos sound objects have xyz coordinates which are in the vicinity of the nominal FW speaker locations. (E.g. sounds closer to the front would be "phantom imaged" between the FW and Fronts, while sounds closer to the sides would be phantom imaged between FW and Surrounds.) FW is not implemented as a separate channel as are the Fronts, Center, Surrounds and Rear Surrounds.
In contrast, the consumer DTS:X soundtracks contain 7.1.4 discrete channels which do not include Font Wides. As a result, the DTS:X decoding algorithm, in combination with DTS Neural:X, uses matrix decoding to make use of Front Wide speakers if you have them.
Selden
post #2958 of 4568 Old 11-14-2018, 07:41 AM
Craig Peer's Avatar
Liked: 7828
I like using front wide speakers. They do add to the 3 dimensional sound field in my room when they are active. But, I have a wide theater.
post #2959 of 4568 Old 11-14-2018, 07:44 AM
Josh Z's Avatar
Quoted: 4000 Post(s)
Liked: 3017
At the cost of forcing you to give up two other channels so as not to exceed the 11-channel limit for DTS:X.
Josh Z
Home Theater Writer/Editor, High-Def Digest
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is online now
post #2960 of 4568 Old 11-14-2018, 08:00 AM
Quoted: 91 Post(s)
How does the multiroom work on this avr? My main room has 7.1.4 and I would like to add some ceiling speakers in another room. Do I just connect the speaker to a open channel? (I think the only open source is wide speakers) if so how would I play just that room without effecting the main room?
Stro3579 is offline
post #2961 of 4568 Old 11-14-2018, 08:06 AM
Manni01's Avatar
Quoted: 5382 Post(s)
Liked: 5465
Yes, that's why I only enable the wides (by disabling the SBs) with Neural:X on 5.1 tracks. I'd rather have FWs than SBs in that case as my room is wide and my SRs are at 110 degrees.
If there is 7.1 in the track, I certainly want to keep the native channels rather than losing real SBs for fake FWs, and I wouldn't want to lose a pair of heights for FWs, so I just stick to 7.1.4.
But with 5.1 tracks, it's great to have FWs, at least in my room.
JVC Autocal Software V11 Calibration for 2019 Models (Google)
Batch Utility V4.02 May 16 2019 to automate measurements files for madVR with support for BD Folders
Manni01 is offline
post #2962 of 4568 Old 11-14-2018, 09:44 AM
CBdicX's Avatar
Liked: 384
Would just connecting the FW to the Front speakers give the same result and "saves" me 2 channels for other use ?
My FW are close the the Fronts and I set them at the same volume level as the fronts, Audyssey sets them around 2 dB lower.
CBdicX is offline
post #2963 of 4568 Old 11-14-2018, 09:51 AM
Dan Hitchman's Avatar
Quoted: 4503 Post(s)
Liked: 2566
Would just connecting the FW to the Front speakers give the same result and "saves" me 2 channels for other use ?[/QUOTE]
Nope. FW positions are sporadic in an Atmos track. You would lose most of the front bed channel information.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #2964 of 4568 Old 11-14-2018, 09:54 AM
CBdicX's Avatar
Liked: 384
Nope. FW positions are sporadic in an Atmos track. You would lose most of the front bed channel information.[/QUOTE]
Sorry, what means "sporadic in a Atmos track" ?
CBdicX is offline
post #2965 of 4568 Old 11-14-2018, 09:59 AM
Liked: 2566
Sorry, what means "sporadic in a Atmos track" ?[/QUOTE]
Not used very frequently or not all the time.
post #2966 of 4568 Old 11-14-2018, 10:05 AM
CBdicX's Avatar
Liked: 384
Ok clear :-)
But why when I connect the FW to the F will I lose most of the front bed channel
information ?
CBdicX is offline
post #2967 of 4568 Old 11-14-2018, 10:12 AM
Liked: 2566
Ok clear 🙂
information ?
Because you are only hearing the FW signal when an object is locked to that position or pans through it. With DTS: X it's only the matrixed signal part way between the fronts and side surround channel audio.
post #2968 of 4568 Old 11-14-2018, 11:05 AM
brazensol's Avatar
Quoted: 715 Post(s)
Liked: 532
And videos too! I don't know how many hours I lose when I sit down to watch a YouTube video for a legitimate learning reason and the next thing I know 4-5 hours have gone by...
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP's; (3) HTM-12's; (14) RSL C34e surrounds; (2) 18" Dayton Audio RSS460HO-4 Subwoofers; (1) Dayton Audio UM18-22 18" Ultimax Subwoofer; (4) Dayton Audio RSS390HO-4 15" Reference HO Subwoofers
brazensol is offline
post #2969 of 4568 Old 11-14-2018, 11:38 AM
CBdicX's Avatar
Liked: 384
But I connect the FW L/R to the Front L/R (parallel), then there is no FW any more.
The FW will receive the same signal as the Front speakers, as there is no FW...…
My FW speakers are just 20-30 cm aside to the Fronts on the same front wall (Kef T101 and Kef T301), making the "stage" just a bit wider, see pic.
CBdicX is offline
post #2970 of 4568 Old 11-14-2018, 01:09 PM
MagnumX's Avatar
Quoted: 1091 Post(s)
Liked: 600
I don't get it. Why would you even want to connect FW to your front speakers in parallel? If you don't use Front Wide at all then that information is routed for your front speakers anyway (especially snap to) or with DTS divided between front and side surrounds. I see little point in using front wides that close to the mains either way, personally.
Click THEATER (Updated: May-22-2019) for pics: Epson 3100 3D Projector, DaLite 92" screen, 11.1.6 (Marantz SR7012 + Yamaha HTR-5960 + Onkyo ESPro) - Dialog Lift - PSB T45/B15/S50/X1T/CS500 Speakers & Def Tech PF-1500 15" sub; 2nd Room (Updated Apr-22-2019): 48" Plasma TV, Carver AL-III, Carver C-5 Pre-Amp, Technics SH-AC500D, Dual Carver TFM-35x Amps (Active Bi-Amp), Klipsch Surrounds ; Sources: PS4, LG UP875 UHD, Nvidia Shield (KODI), ATV4K, Zidoo X9S, LD, GameCube : Props (Updated 8-17-19)
MagnumX is online now
