AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Receivers, Amps, and Processors (https://www.avsforum.com/forum/90-receivers-amps-processors/)
-   -   The *OFFICIAL* Denon AVR-X8500H 13.2ch Flagship AVR Thread (https://www.avsforum.com/forum/90-receivers-amps-processors/2952552-official-denon-avr-x8500h-13-2ch-flagship-avr-thread.html)
batpig 01-25-2018 04:52 PM
Here we go!
Denon USA Product Page:
https://usa.denon.com/us/product/hom...vers/avrx8500h
Web Manual Direct Link (with PDF download available):
http://manuals.denon.com/avrx8500h/na/en/
Audioholics Preview Article (with bullet points provided/approved by batpig & JD):
http://www.audioholics.com/av-receiv...ch-av-receiver
Key features and major upgrades vs. prior 11ch models:
  • 51.4lbs of pure beef
  • 13 amplified channels and 13.1ch processing
  • 15.2ch RCA pre-outs and 15 pairs of speaker binding posts -- including 8 total height speaker outputs (with Height4 pair assignable to Front Wide).
  • The above facilitates the ability to run BOTH a 13ch Auro3D setup and a 13ch (9.1.4 / 7.1.6) Atmos setup without having to ruin positioning for one or the other. Because there are FOUR pairs of height speaker outputs (pre-out and speaker posts), with flexible assignment (including being able to assign Height4 to Front Wide output) you can do a complete Auro3D setup with five heights + VOG and still have another pair of height outputs for Top Middle or Front Wide use with Atmos.
OK, I'm not going to do more than 7.1.4 Atmos. What else does this offer vs. the cheaper X6400H?
  • Physically larger and heavier (51lbs vs. 39lbs) and higher power rating
  • Even if you don't go beyond 7.1.4 Atmos, the X8500H has significantly better Auro3D support (and also less compromise with a dual use Atmos/Auro layout). The X6400H like other previous 11ch D+M models is limited to 10.1ch Auro3D (5.1 + 4 heights + VOG). And the only way to practically mix Auro + Atmos is to use a Front Height + Rear Height layout. The X8500H can run a full 13.1ch Auro3D speaker layout and has FOUR pairs height speakers outputs, allowing you much more flexibility to configure your layout while maintaining optimal Atmos/DTS:X playback.
  • X8500H also has a "Custom" amp assign setting which allows you to map virtually any speaker binding post to any channel of output. For example, if you're using a 5ch amp to power LCR+Surrounds in the main zone, you can repurpose the unused FL/FR and SL/SR amps in the AVR to power Zone 2/3 speakers (the X6400H only has predefined templates for amp assign).
  • The X8500H also has a "pre-amp mode" which disconnects the amp section.
  • 7.1ch multi-ch analog audio inputs, extra (3 vs. 2) component video inputs.
  • Future HDMI 2.1 hardware upgrade to increase lifespan by supporting 8K resolution and more (the same way they offered the "A" upgrade to the 7200/8802 for HDMI 2.0 in the last generation).
  • The X8500H has different DAC's specified, it lists the AKM AK4490EQ for the X8500H and the AKM AK4458VN for the X6400H. A quick check shows 5dB increase in SNR for the DAC in the X8500H
  • The X8500H can do a vertical stretch for use with anamorphic lenses (note: does not appear to work with full bandwidth 4K signals like 4K/60 4:4:4)
  • X8500H has a rear USB input in addition to the front USB, the rear port is rated to power devices so more practical for a streaming stick or cooling fan etc.
  • The X8500H has a nicer remote with "learning" capabilities to copy IR commands, macro capabilities, and also a "Remote ID" setting so you can prevent conflicts with other Denon device remotes accidentally changing it.
http://www.bestofhighend.com/wp-cont...v-receiver.jpg
https://www.lowbeats.de/site/wp-cont...nenansicht.jpg
jdsmoothie 01-25-2018 04:54 PM
1 Attachment(s)
Features include:
- Bluetooth Version 3.0, Class 1 - increased from 33' up to 98ft/30m
- Audyssey MultEQ Editor iOS/Android phone app ($20) - (first introduced for use with the 2016 models) using the Audyssey mic included with the AVR, provides the ability to customize target curves, save them on the phone/tablet and send back to the AVR as needed generally only taking about 90 seconds).
- The HEOS module will allow streaming the (currently) 12 music services using the HEOS iOS/Android app to the AVR as well as allow streaming 2CH sources (PCM 2.0 from HDMI/optical/digital coax/analog) connected to the AVR to one or up to 32 HEOS wireless speakers placed around the home, up to 16 of which can be grouped together for whole house audio with up to 8 independent sources. Additionally 2 speakers of the same model (eg. HEOS 3 + HEOS 3) can be grouped together for stereo L/R.
- Auto Update - (default - OFF), allows for firmware updates while the unit is in Standby
- SAVE & LOAD (to USB taking only 1-2 minutes; no longer able to access the AVR via Web Control)
- Restart - (pressing/holding the power on button in lieu of having to pull power cable)
- DTS Virtual:X - simulates height/surround from DTS and PCM audio when no Height/Top/Dolby speakers are configured, ie. 7.1 or less setup (able to use w/Audyssey, unlike on X3400H and lower models)
- GUI/OSD overlay on 4K DV video - added with Auro 3D firmware update May 24, 2018
- 4K Signal Format (Standard (default)/Enhanced; Note: Enhanced setting must be used when passing 4K/60Hz video)
- HDMI Diagnostics (installer troubleshooting)
- Dolby Vision (to include the Sony Low Latency) + HLG
- eARC - via future firmware update (ETA summer 2018; able to receive HD audio (Dolby TrueHD/DTS HD-MA) from eARC capable TV) - Note an HDMI w/Ethernet cable must be used.
- DTS Headphone:X
- Dual USB - front USB for audio files only while rear USB is to provide 5v/1.5a power only
- Atmos: 7.2.6 or 9.2.4
- DTS:X: 5.2.6 or 7.2.4 or 9.2.2 (ie. currently only 11CH max although possibly 13CH via a future firmware at a later date); Note with 13 speakers connected (ie. 7.2.6), the TM speakers would be silent unless you disable the SB speakers in Manual Setup resulting in a 5.2.6 setup.
- Auro 3D: 13.2 (a newer version of the Auro 3D 10.1 featured on the X4400H/X6400H to be added via a free future firmware update (May 24, 2018))
- Dialog Enhancer: Also available on the X6400H, this feature focuses on improving the human voice frequencies 1kHz - 3kHz (Low/Medium/High)(unlike the lower level models which feature a <Dialog Level> setting which simply adjusts the volume of the center speaker)
- Remote ID: Able to change the Remote ID code (both for the remote and the AVR) when using another nearby Denon AVR (ie. so the X8500H remote doesn't try to operate the other Denon as well)
- Aux 3 - 7: To add these additional source names simply press/hold the DOWN arrow and BACK buttons on the front panel while powering on the AVR
- Macro A-D: Buttons located at the bottom of the remote each of which can store up to 18 programmable steps (eg. in lieu of using a Harmony remote); there are 5 pre-stored macro functions: (1) Watch movies, (2) Listen to music, (3) Watch TV, (4) Turn on all devices, and (5) Turn off all devices
- Although an issue on prior year models, the Subwoofer Level Adjust no longer has an ON/OFF setting, but rather simply mirrors the Subwoofer Manual Setup - Levels - Test Tones settings such that it can be adjusted on the fly now correctly as opposed to being in addition to the Manual Setup settings on previous year's models
-Web Control: Although this has been featured on non-HEOS networking models for many years, it was dropped on HEOS models beginning in 2016; however, will be reintroduced on 2018 and newer models, the X8500H via a firmware update sometime in 2019.
-IMAX Enhanced DTS:X; (via future firmware update late 2018)
- Spotify using a FREE Spotify account via the HEOS app - firmware update 8-21-2019
Tips and suggestions:
1. If the AVR is connected to a 4k TV then use only "Premium" certified 4k/18gbps HDMI cables (eg. Monoprice). https://www.hdmi.org/manufacturer/pr...n_Program.aspx
2. If the source will not pass 4k/60Hz HDR10: Set the "4k Signal Format" (p. 206 Owner's manual) setting to "Enhanced" from factory default of "Standard."
3. If TV will not accept HDR signal from the AVR: Enable the "enhanced" or "UHD" video mode for the TV input from the AVR (see below).
Samsung: Settings | Picture | Expert Settings/Picture Options | HDMI UHD Color
LG: Settings | All Settings | General | HDMI Ultra HD Deep Color
Vizio: Open SmartCast app | Settings | Inputs | HDMI Color Subsampling | Enable HDR
Sony Bravia: Home | Settings | External Inputs (under TV subsection) | HDMI signal format | Enhanced
Panasonic: Menu | Setup | HDMI HDR Setting: On
Philips: Menu | Setup | TV Settings | Installation | Preferences | HDMI mode : Normal
4. Dolby Atmos requires a minimum of a 5.1.2 setup while DTS:X/DTS Neural:X/Dolby Surround can use a 3.1.2 setup.
5. Regardless of where the height/overhead speakers are physically located, using a FH+RH (7.1.4) or FH+TM+RH (7.1.6) configuration will allow the FH+RH speakers to be used with all three 3D audio codecs: Atmos, DTS:X, Auro 3D.
6. Although up to 15 speakers can be connected (for convenience), a maximum of 13 speakers can operate at one time (regardless of whether using external amps or not).
7. Although DTS:X and Neural:X are currently limited to only 11 speakers, DTS plans on passing an update to D+M in 2019 to allow the processing of 13 speakers.
8. Although there exists a DTS <Dialog Control> setting (p. 182 Owner's manual), the audio mixer must include this control in the audio (which has been rare) in order for the setting to be active (ie. display) under SETUP - AUDIO - SURROUND PARAMETER - Dialog Control when a DTS:X audio track is playing.
9. ISF DAY/NIGHT Custom settings: After selecting either PICTURE ADJUST - ISF DAY/NIGHT, press <Enter> to select the setting. Then press/hold the INFO button for 5 seconds at which point the same Custom settings as are available with the "PICTURE ADJUST - Custom" setting should be displayed with the only difference being that the "Gamma Coefficient" (although not displayed nor editable) is different for each of the ISF DAY/NIGHT settings.
10. When using an HD DVD player, set the Deep Color setting on the TV input to OFF.
11. DTS Neural:X cannot be used to process audio above 48kHz.
General suggestions and setup tips provided in the 2017 Denon AVR Owner's thread --> https://www.avsforum.com/forum/90-re...l#post51748513
Remote Control Preset Codes: p. 271 Owner's manual - http://manuals.denon.com/AVRX8500H/p...resetCodes.pdf
Front Wide configuration
1. Dolby Surround will not simulate audio to FW speakers, rather only Atmos (13 speaker max) and DTS:X/DTS Neural:X (currently only 11 speaker max)
2. It is not possible to have 6 height speakers active when Front Wide are active with Atmos (TF+TM+TR) nor with the current DTS:X/Neural:X 11 speaker limitation.
Auro 3D Demo Disc Vol 2
If you would like to receive a copy of the Auro 3D Demo Disc from Auro Technologies, although the disc itself is free, Auro Technologies will send you the disc for FREE if you pay shipping and handling.
For Fedex shipment, handling and customs fees, pay 28 EUR (VAT included) onto bank account number BE07 3630 7852 4166 (BIC: BBRU BEBB). Please indicate a reference of the notification 'Dispatch Demo Disc/758'. Alternatively, payment via Paypal is also possible and upon your request via email to [email protected], Auro will send over a Paypal Payment Request.
Custom Amp Assign
https://www.avsforum.com/forum/attac...1&d=1548075856
How do I reset the microprocessor or do a network reset?
When the AVR is acting up or doing something strange, try the following steps before resorting to a microprocessor reset:
1. "Restart" - set the AVR to Standby and press/hold the power ON button until "Restart" is displayed on the front panel.
If no joy, then ...
2. Soft reset - set the AVR to Standby and unplug the power cord for about 10 minutes, then plug back in the power cord and turn ON.
If neither of the above resolves the issue, then you'll need to either do a network reset (if network related) or a microprocessor reset. You'll also want to reset the microprocessor before doing anything else if you purchased the AVR as an "open box" or demo/used/refurb unit to ensure all settings are returned to their original factory defaults. Prior to doing a reset, you can SAVE the config file to a USB thumb drive so it can be LOADed after doing the reset (SETUP - GENERAL - SAVE&LOAD).
Network Reset (“Amp Assign”, “Speaker Config.” and “Video” settings are not reset)
1 - Turn ON the power using ON/STANDBY.
2 - Select the HEOS Music source
3 - Simultaneously press/hold the "DIMMER" and ">" buttons for at least 3 seconds.
4 - Release your fingers when "Network Reset" is displayed on the front panel.
5 - "Complete" will display when the reset has completed.
Microprocessor Reset (aka "Reset to original factory settings")
1 - Turn off the power using ON/STANDBY.
2 - Press and release ON/STANDBY (as you normally would when powering on the AVR) while simultaneously pressing/holding the "INFO" and "BACK" buttons on the front panel
3 - Remove your fingers from the two buttons when "Initialized" appears on the front panel display.
Factory Restore
2 - Simultaneously press/hold the: "SETUP" and "DIMMER" buttons on the front panel and then press the ON/STANDBY button on the front panel. This procedure will take 15-20 minutes to restore to the original factory firmware.
** NOTES:
(1) Prior to resetting the microprocessor, you can SAVE the config/settings (to include Audyssey settings) to a USB thumb drive using the SETUP - GENERAL - SAVE & LOAD setting.
Firmware Change log Information
(1) Firmware updates should be available via Denon's website and can be downloaded and installed via USB thumb drive. You will need to enter the serial number of the AVR at the website page to obtain the update. It may take a month or more after the firmware update is released via the internet to the AVR for it to appear on the website for download.
(2) Firmware updates can also be installed by the owner via an internet connection to the Denon servers. Although it's not necessary to update your unit if you are not experiencing any problems, it's generally a good idea to keep it updated so that if there are any problems with the update the unit will still be covered under warranty. The update process generally doesn't take more than 30 minutes once the download begins and also generally does not erase any settings, although it's always a good idea to SAVE the config.avr file using the Setup - General - SAVE & LOAD - SAVE feature prior to doing the update just in case. Note that if the update process is stuck on "Authenticating", ensure a source other than NET/USB is selected and just let it continue for up to a few hours and it should eventually begin the update process (although note that Denon's servers have been known to crash the first day of release due to the overload, so you may want to wait a few days before trying again). Some have noted that rather than selecting the "Check for Update", instead simply selecting the "Start Update" will avoid the "Authenticating" issue. One prior model year owner found that disconnecting ALL sources to the AVR enabled the unit to connect to the Denon servers and update the firmware when the update process had previously been unsuccessful.
Other tips if having problems with the update include setting "Network Control" to OFF in Standby, cycling the DHCP setting on the AVR, or using a static IP address.
During the update, the AVR will go into Standby mode, but will continue to update status on the front panel display. If the update seems to be hung up (ie. goes beyond 1 hour) ... power the AVR to Standby, unplug it for a few minutes and power back on and attempt the update again. If the update fails to load, check the network environment (ie. reset the router, replace the router with a more current/robust model, or ideally wire directly to the router if connecting wirelessly) If still not having any luck with the update, perform a Network Reset as described in post 3 above. You may also want to consider purchasing a long (100'+) Cat5/6 cable for network updates only for a higher probability of a successful install.
You will be notified automatically when there is a firmware update when the AVR is turned ON as long as the Notification Update setting is set to ON (factory default). For more information refer to Setup - General - Firmware - Notifications -Update in the Owner's manual. To manually check for an update, refer to Setup - General - Firmware - Update - Check for Update.
(3) What is my unit's current firmware version? The current firmware version can be determined from the AVR's menu: Setup --> General --> Information --> Firmware Version.
Firmware change log date/info:
1. 2-15-2018
- Improves overall performance and stability
2. 5-23-2018
3. 5-24-2018
- Auro 3D/AuroMatic 13.1
- GUI/OSD able to overlay on DV video
4. 5-31-2018
- If the product is connected to ALLM compatible TV (HDMI 2.1), the transmission rate of 4K 50p / 60p format video does not become 6 Gbps.
6 Gbps of 4K signal is below.
4k 50p / 60p YCbCr 4: 2: 0 30/36 bit
4K 50p / 60p RGB 4: 4: 4 24bit
4K 50p / 60p YCbCr 4: 2: 2 36 bits
- Sometimes no grouping possible between some HEOS speakers.
- Specific Flac files from customer do not play; neither via USB or network (twonky server 8.2.1)
- After update, grouping of two HEOS products was no longer possible when Stereo grouped.
- When selecting the HEOS 1 under setup/help/system check/network status, and selecting the router it is connected to, a different value is shown.
- Two values for BSSID´s which are definitely wrong.
- Improved stability of audio playback and wireless connection when connecting HEOS speaker, HEOS AMP as wireless surround to HEOS Bar or HEOS AVR.
- Reduced time to detect HEOS equipment on the network and improved reliability.
5. 10-31-2018
- IMAX Enhanced DTS:X
- eARC (note that in order to pass "enhanced" HD audio from an eARC able TV (not expected until late 2018/early 2019), one of the following HDMI cables must be used to connect the AVR to the TV: Standard w/Ethernet, High Speed w/Ethernet (including "Premium" High Speed w/Ethernet), or Ultra High Speed w/Ethernet)
- Web Control (reintroduced after being dropped on all 2016-2017 "H" series models - currently only “Audio”, “Video”, ”Speakers” and “Inputs” can be accessed. “General” and “Network” will be supported early in 2019 via another firmware update)
6. 2-6-2019
- IMAX Enhanced "Manual" Audio Settings (High Pass Filter, Low Pass Filter, and Subwoofer Mode)
- While AVR displays Title/Artist/Album by status display, AVR will display "Spotify" after "Volume change, Mute, INFO, Sound Mode change, SLEEP, ZONE2 ON/OFF" operations.
- Audio is cutting out when using ARC via Low Quality Cable (Long Cable) after installing U18 firmware.
- Added "General" and "Network" to Web control. (New feature)
- Update the firmware version to 1.493.180 Music files in USB stick memory formatted with NTFS cannot be played on HEOS products.
7. 4-17-2019
- Improves performance and stability
8. 4-23-2019
- Corrects control system issue caused by 4-17-2019 update
9. 8-21-2019
10. 9-17-2019
- HEOS app update
** NOTES:
(1) The change log information above is provided as is, without any further explanation and only when I am able to obtain it. If the information listed above doesn't make sense, please don't ask for clarification, as I have none.
mtbdudex 01-25-2018 05:03 PM
[edit 2/2] My 8500H was delivered Friday Feb, 2, 2018.
I will have my own HT re-build thread, https://www.avsforum.com/forum/19-de...l#post55584676 , comments here will be specifically AVR X8500H related.
[edit 2/16] I'll add a few YouTube videos that give a great overview of the X8500H, as they are buried in this thread 1st page is easier
Via Chappie (Patrick)
Some screenshots here
https://uploads.tapatalk-cdn.com/201...484f0e6405.jpg
https://uploads.tapatalk-cdn.com/201...41a2605893.jpg
https://uploads.tapatalk-cdn.com/201...346d86e932.jpg
https://uploads.tapatalk-cdn.com/201...11027b9a72.jpg
https://uploads.tapatalk-cdn.com/201...be8c4fdf2c.jpg
https://uploads.tapatalk-cdn.com/201...c91c0a50bb.jpg
https://uploads.tapatalk-cdn.com/201...236c616796.jpg
https://uploads.tapatalk-cdn.com/201...c21257fc25.jpg
Yes they talked about future 13.1 but only showed this
https://uploads.tapatalk-cdn.com/201...1385f4219c.jpg
Peak 2.8kw ability vs 900w rating
https://uploads.tapatalk-cdn.com/201...4a537d1e3d.jpg
https://uploads.tapatalk-cdn.com/201...011a681892.jpg
https://uploads.tapatalk-cdn.com/201...1e85943508.jpg
https://uploads.tapatalk-cdn.com/201...1ac23be777.jpg
https://uploads.tapatalk-cdn.com/201...8e6845321c.jpg
So if dual core for 16 channels, 15.1 with 13.1 usable, I’m looking forward to triple core for 24 channels in 2021, 23.1 for 11.3.10, the added 8 solely via pre-outs [emoji848][emoji1303]
Learning from Stuart add side1 for 7 bed + FW + Side1, hence 11 floor channels, the subs 2 different managed for location grouping plus tactile transducer on its special managed channel, then 10 ceilings for max Atmos.
This post will be closure of the Wishlish thread, https://www.avsforum.com/forum/90-re...l#post29491946 , to this released / delivered thread.
I have compiled the first 3 pages of the wishlist thread viewed here into a tracker and summarized the status of 50 wishes.
It's a google doc web page, when updated it's live here, the pictures will get out-dated as updates to google doc are made.
Of 50 items, 23 are yes and 27 no.
let's not use this thread for a 2020/2021 X9500 flagship wishlist, that's too soon and worthy of another thread.
Google doc Denon 2018 Flagship AVR X8500H wishlist
https://lh3.googleusercontent.com/nO...=w800-h1200-no
https://lh3.googleusercontent.com/WQ...=w800-h1200-no
Alanlee 01-25-2018 05:05 PM
Originally Posted by batpig (Post 55570170)
Here we go!
[U]OK, I'm not going to do more than 7.1.4 Atmos. What else does this offer vs. the cheaper X6400H?
  • The X8500H can do a vertical stretch for use with anamorphic lenses.
I think a long video presentation is in order.
batpig 01-25-2018 05:09 PM
This diagram (pg 68 of the manual) shows the maximum layout to support 15 speaker connection with switching between two maxed out 13.1 layouts: 13.1ch Auro3D + 7.1.6 Atmos/DSU playback.
When in Atmos/DSU playback mode, the output will be 7.1.6 (using Front Height + Top Middle + Rear Height).
When in Auro3D playback mode, the output will be 13.1ch (using Front Height + Center Height + Rear Height + Top Surround).
Note that you can drop the Top Middle speakers and instead reassign Height4 to the Front Wide output, which would allow a mixed layout with 13.1ch Auro3D + 9.1.4 Atmos (Front Height + Rear Height).
https://www.avsforum.com/forum/attach...8&d=1515526140
https://www.avsforum.com/forum/attach...p;d=1515526300
batpig 01-25-2018 05:11 PM
My first step is to wire up a pair of extra Triad speakers I have sitting around in a Front Wide position. A couple of things I will be looking to test right away are:
1. Confirming that DSU will upmix to Front Wide speakers for full 9.1.4 output with legacy content
2. Confirming that DTS:X / Neural:X are indeed limited to 11ch output max, and which speakers are active in which situations
Nalleh 01-25-2018 05:54 PM
Ahh, feels good to be officially started :)
According to the manual, DTS:X/N:X in a 5.1 ear level setup should be able to utilize Top Surround(not in DTS:X)+ Center Height or Top Middle for a 5.1.6 setup.
Alanlee 01-25-2018 08:18 PM
Originally Posted by jdsmoothie (Post 55570184)
[B](1)
Question about the series two HEOS speakers. They are Bluetooth, so can one access the speaker directly with an iPhone and iTunes? That would be without the Denon app.
Q2 - If one had the app and a device ( iPhone, iPad ) could one use the speaker without the Denon AVR?
jdsmoothie 01-25-2018 08:25 PM
1. Yup, Bluetooth.
2. Yup, no AVR required. The iOS/Android HEOS App can stream to the HEOS speakers or to the AVR as the AVR is simply considered another HEOS speaker. I use my GS3 to stream Pandora to (2) HEOS 3 speakers (grouped as stereo L/R) in my office and to a HEOS 5 in my combined LR/DR/Kitchen for whole house audio when I walk between rooms. I also bring a HEOS 1 + Go Pack out to the patio for up to 6 hours of listening without having to plug it in when fully charged. Note however, the HEOS 1 is the only model that is both A/C powered and also can use a battery pack, while the other models 3/5/7 can only be plugged in to an A/C outlet.
The built-in HEOS module in the AVR also adds the convenience of streaming 2CH audio to the HEOS speakers with the same limitation as passing audio to the Zone 2 speakers (ie. source must be PCM 2.0 from either HDMI/optical/digital coax/analog/network/internet radio/USB/Tuner).
Also, although the app is initially required to stream audio to the AVR, once streamed, you can SAVE the station to the AVR's "HEOS Favorites" and then going forward you can select the station directly from the AVR rather than having to use the app again.
And for those of you with Alexa enabled devices (eg. Echo, Echo Dot), although currently only capable of simple control (ie. ON/OFF/network source) of the AVR, with a soon to be released update, the HEOS Home Entertainment skill will enable more advanced control of the AVR to include selection and control of external devices.
Ask Alexa to stream specific audio content to your HEOS-enabled devices. The HEOS Home Entertainment skill currently supports the following services:
· Amazon Prime Music
· Amazon Music Unlimited
· TuneIn
· Pandora
· iHeart Radio
· Spotify (coming soon)
· SiriusXM (coming soon)
Here are some examples of what you can say when streaming to HEOS speakers placed around the home:
· Alexa, play Shape of You by Ed Sheeran on kitchen
· Alexa, play The Beatles from iHeartRadio on kitchen
· Alexa, play “In the Air Tonight” from Pandora on bedroom
· Alexa, play Planet Money podcast on living room
· Alexa, play next on living room
· Alexa, volume 25 on kitchen
· Alexa, pause the dining room
· Alexa, resume the kitchen
· Alexa, volume down on the living room
jdsmoothie 01-25-2018 09:07 PM
Macro function
2 Attachment(s)
Here's another available feature (for those of you not using a Harmony remote) that is rarely (never?) discussed in the various "flagship" Owner's threads .... Macro function (p. 279 Owner's manual):
https://www.avsforum.com/forum/attach...1&d=1516943210
https://www.avsforum.com/forum/attach...1&d=1516943898
jdsmoothie 01-25-2018 09:13 PM
Remote ID
1 Attachment(s)
Yet another feature only readily accessible on the "flagship" models is the ability to change the Remote ID (p. 284 Owner's manual) when you are using another Denon AVR nearby the X8500H.
https://www.avsforum.com/forum/attach...1&d=1516943541
Alanlee 01-25-2018 09:31 PM
Originally Posted by jdsmoothie (Post 55571342)
1. Yup, Bluetooth.
· TuneIn
· Pandora
· iHeart Radio
Very Nice
krismate 01-25-2018 09:57 PM
Any idea if there's any benefit to upgrading to this from a x7200wa, in terms of hardware, dacs, amps etc? I might do it simply for the future HDMI 2.1 support but if I'm not going to gain anything now, I might as well wait until the 2.1 board comes standard.
fookoo_2010 01-25-2018 11:03 PM
A lot of info to digest. Thanks.
sveineb 01-26-2018 03:39 AM
[*]The X8500H also has a "pre-amp mode" which disconnects the amp section.
How does this works?
Can people hear a difference, and how will this be against a Marantz 7704 or 8805?
docderwood 01-26-2018 04:24 AM
?? Is this available in the US now
And if so, where?
Thx!
jdsmoothie 01-26-2018 07:53 AM
And if so, where?
Thx!
Yup. Released this week so shipping from Denon and and West Coast dealers this week and East Coast dealers next week. :)
batpig 01-26-2018 10:14 AM
I would only upgrade from the X7200WA if you were going to take advantage of the 13ch capability. The DAC's are the same and, while there may be some incremental improvements in other areas (e.g. power supply), I doubt you'll hear a major difference between the two models. If you're not going to go beyond 7.1.4 (or utilize the expanded Auro3D layout) then I don't think the incremental upgrades are worth it unless you REALLY want to integrate the built-in HEOS into a whole home audio system.
HDMI 2.1 isn't relevant yet as by all accounts it's over a year away from being ready on the hardware side (let alone there not being any 8k content to utilize it).
batpig 01-26-2018 10:18 AM
This isn't really a new feature, as it was available on previous models like the X7200W and 4520CI. To be honest, I consider it essentially a marketing gimmick with dubious real world benefits. The amps are disconnected from the signal input but they aren't "turned off", they just sit there idling with no signal. So maybe there's some tiny incremental benefit in from disconnecting them. But I wouldn't make my decision based on this feature.
Personally, if you're looking for a cheaper inroad into separates, I'd rather use the "free amps" in the unit to power the less important channels (e.g. overheads, back surrounds) and get better amps for the more important channels. This hybrid approach where you use some receiver amps + some separate amps is a lot better value.
Nalleh 01-26-2018 10:35 AM
Up and running yet?
Us internet buddies are dying for pics and info ;)
New24K 01-26-2018 10:39 AM
So does this give more power to the other amps...?
batpig 01-26-2018 10:40 AM
Geez, you guys are impatient! :p
Unfortunately, didn't have time/energy to set up last night after a long day of work and then getting the kiddos to bed. I'm going to hook up and play around this weekend though, so stay tuned!
jdsmoothie 01-26-2018 10:44 AM
Yes. The fewer internal amps that are used provides more available power to speakers connected to the speaker posts. :)
bluemoon737 01-26-2018 10:49 AM
OMG, and you call yourself an enthusiast! :D Kidding of course...looking forward to the updates this weekend.
New24K 01-26-2018 11:00 AM
Well, right - isn't that how all receivers work? :)
What does this Denon "feature" actually do that is different?
jdsmoothie 01-26-2018 11:03 AM
Simply shunts the signal from getting to the amps.
New24K 01-26-2018 11:11 AM
Does Denon have different front fascias for different markets?
Various pictures of the 8500 look different - one shows it with silver badging - others show it with gold badging and that INCommand badge.
https://images.cdn.whathifi.com/site...?itok=gnBbEdQO
http://www.tuexperto.com/wp-content/..._X8500H_01.jpg
jdsmoothie 01-26-2018 12:06 PM
Correct. Although all of the Denon USA "X" series models show the "InCommand" badge, in other regions (eg. UK, AU) they don't display it.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
