"Official" Onkyo TX-RZ 620/720/820 Owners Thread - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 225Likes
post #241 of 688 Old 07-07-2018, 06:21 AM
geronimoxx's Avatar
Quoted: 14 Post(s)
Liked: 2
That's not possible on an 820
Verzonden vanaf mijn iPhone met Tapatalk
geronimoxx is offline
post #242 of 688 Old 07-07-2018, 08:16 AM
egnlsn's Avatar
Quoted: 172 Post(s)
Liked: 66
Originally Posted by Brian_Barros View Post
They should be set at 8
Sent from my Pixel 2 XL using Tapatalk
The options are 4 and 6. Interesting that with 6 ohm speakers the rated output power is about twice that with 8 ohm speakers.
CIAO!
Ed N.
egnlsn is offline
post #243 of 688 Old 07-07-2018, 08:18 AM
Quoted: 1114 Post(s)
Liked: 291
A little harder to drive 6ohm so the extra power is needed
Brian_Barros is offline
post #244 of 688 Old 07-07-2018, 08:20 AM
___MIKE___'s Avatar
Quoted: 22 Post(s)
Liked: 39
___MIKE___ is offline
post #245 of 688 Old 07-07-2018, 09:07 AM
word302's Avatar
Originally Posted by ___MIKE___ View Post
Hi all, with the upcoming release of the new models, is there still value to be had in buying the 820?
I’ll be starting with 5.1.2.
Check out the price at amazon. I would say there’s plenty of value.
word302 is offline
post #246 of 688 Old 07-07-2018, 02:17 PM
Quoted: 145 Post(s)
Liked: 133
There isn't an 8 setting. Its hidden in the manual to use 6 for 6 and 8 ohm speakers. Its odd, but correct.
gene4ht and TechSilver13 like this.
"Home Theater" setup:
Living Room is 4300 cubic feet Towers: Klipsch KF-28 Center: Klipsch KC-25 Rears: Klipsch KS-14 Sub: HSU VTF-3 MK5 HP Receiver: Onkyo TX-RZ820
Jeremy67J is offline
post #247 of 688 Old 07-07-2018, 08:07 PM
gene4ht's Avatar
Quoted: 1988 Post(s)
Liked: 2689
+1
Jeremy67J likes this.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is offline
post #248 of 688 Old 07-07-2018, 09:05 PM
tmservo's Avatar
Just ordered the 820 on Amazon on a quick sale with Prime "points" or whatever that is; made my price $469. seemed like a hell of a deal. I'm upgrading from an Onkyo 626. At that price point, seemed like a good deal. I need to upgrade the receiver for 4K, the rest of the features are all bonus. But at that price I figure I can't do better. My setup has always been in the old school DTS-ES style from way back because I loved it; Front R/C/L, Rear R/C/L for a 6.1 (SVS sub) that I loved. I may fool around with Atmos, but not sure if it is a priority. Small room relatively 15x17.
tmservo is offline
post #249 of 688 Old 07-07-2018, 09:40 PM
gene4ht's Avatar
Liked: 2689
Congrats on your purchase! That's a great price and it's definitely an upgrade from the 626 (a fine AVR) as you will be gaining the newer Atmos and DTS:X codecs. For sure, add two speakers and upgrade to 5.1.2 Atmos when you get the opportunity. Atmos will add a new and more immersive dimension to your setup and enjoyment. BTW: Your room is not considered small but more likely medium sized.
gene4ht is offline
post #250 of 688 Old 07-07-2018, 11:30 PM
nodoubt's Avatar
Quoted: 442 Post(s)
Liked: 262
just did a quick reset
chrome cast and spotify work fine now
good deal, i was dreading sending this thing back
nodoubt is offline
post #251 of 688 Old 07-10-2018, 04:56 PM
Stryker412's Avatar
Quoted: 90 Post(s)
Liked: 37
Hi all, I'm looking to make the jump to 4K and currently have an Onkyo TX-SR608. I only have a 5.1 setup (SVS sub) and am really just looking to support 4K with a TV purchase also coming soon. I do have an AppleTV 4K but my XBOX/PS4 are not the 4K versions. Just wondering what the overall impressions of the 820 are and if it's a good choice for my setup.
Stryker412 is offline
post #252 of 688 Old 07-10-2018, 05:29 PM
Quoted: 145 Post(s)
Liked: 133
The 820 is a great receiver, but it might be a little overkill for what you're describing. Don't get me wrong if you get an 820 you'll like it, but it sounds like you're happy with with your current recevier except for 4k. I think TX-NR676 is closer to what you have price and spec wise, but now includes 4k. Accessories4less has the 676 for $279. Best I've seen recently on the 820 is $599. Keep in mind the original MSRP for the 820 was $1399 and the MSRP for your current receiver was $599 making the 676 more comparable. Just my thoughts on getting you 4k while saving you money. If you go the 820 route you'll enjoy it as well.
gene4ht likes this.
post #253 of 688 Old 07-10-2018, 05:34 PM
gene4ht's Avatar
Liked: 2689
If you do not anticipate migrating beyond 5.1.2, then the 820 would be perfect and more than capable for your 4K needs...especially now that it can be found discounted everywhere for $599. Since the 820 has 7 channel (max) capability, you will also have the option of moving to Atmos with 2 overhead channels later on if you choose...but not beyond 7 channels. If there is a possibility you would ever want/need 9, 11, or 13 channels and beyond, you'll need to look upstream at higher end models. BTW...the 830 was announced recently and will have 9 channel capability...but at a higher price point...and the reason the 820 is now being offered at close out pricing.
gene4ht is offline
post #254 of 688 Old 07-10-2018, 05:37 PM
Stryker412's Avatar
Quoted: 90 Post(s)
Liked: 37
I don't see myself going beyond 5.1 in the current room but if I'm able to redo the garage I could see going 7.1 (or even .2). I personally don't see the need to go beyond 7 channels.
gene4ht likes this.
post #255 of 688 Old 07-10-2018, 06:10 PM
gene4ht's Avatar
Liked: 2689
Jeremy67J makes a good point as well if your current needs are satisfied with 5.1 and you only need 4k capability. A model like the 676 would serve that purpose. Should you want a bit more capability, then the 820 is currently a bargain. Good luck with your decision!
gene4ht is offline
post #256 of 688 Old 07-10-2018, 06:13 PM
TechSilver13's Avatar
Quoted: 60 Post(s)
The 820 is 499 refurbished from accessories4less which is a certified reseller. I bought mine from there. Comes with a one year warranty as well.
gene4ht likes this.
TechSilver13 is offline
post #257 of 688 Old 07-10-2018, 06:19 PM
jimbob200521's Avatar
Quoted: 18 Post(s)
Just a general thought/throwing it out there post. I see quite a few people recommending the 820 which I have no doubt is a great receiver. However, why does no one recommend the 720 or 620? Am I missing some big upgrade feature in going to the 820? It has a bit more power per channel and direct mode but doesn't really offer much more beyond that (of significance that I have noticed, at least). Thoughts from anyone on why you went with an 820 vs a 720 or 620?
Onkyo TX-RZ620 | Polk LSI-15 | Polk LSIC | Polk FXIA4 | SVS PB1000
jimbob200521 is offline
post #258 of 688 Old 07-10-2018, 06:52 PM
Quoted: 60 Post(s)
I just wanted to spend 500 so that’s why I jumped on the 820 with the extra power. The 777 and the 720 are great deal right now as well. If you wanna spend a little extra, marantz 5013 is 589 on accessories4less. I just dislike the small screen on the marantz (I had the 5009).
post #259 of 688 Old 07-10-2018, 07:13 PM
Liked: 291
I currently have a Sony str dn1080. Anyone come from this receiver to the 820? I'm looking to upgrade my receiver and I think this is where I'm going to end up. Was it a big step up in sound? Not to much different? I like the sound of the Sony but think I want more power. I'd also like to have the option to add a separate amp
post #260 of 688 Old 07-10-2018, 07:24 PM
Quoted: 60 Post(s)
The power really only makes the volume louder. I can from a Marantz 5009 and it wasn’t much different to be honest. I have never had a Sony receiver but I would assume you would gain some improvement. I know my sub sounds better with the 820 (HSU VTF-15)
I just looked your receiver up, it seems to be pretty equal in terms of featured. Any particular reason you want an 820?
post #261 of 688 Old 07-10-2018, 07:27 PM
Liked: 291
How is that sub? I'm looking at the vt 2 mk5. I'm also looking at the svs pb2000. I've looked at some comparisons and HSU seems to be favored over the SVS. There's a substantial price difference too
post #262 of 688 Old 07-10-2018, 07:30 PM
Quoted: 60 Post(s)
I love the HSU but yeah it's stupid expensive. I don't ever plan on getting a new sub because this thing is so powerful. I usually leave it at about 25% volume.
post #263 of 688 Old 07-10-2018, 07:50 PM
Liked: 291
The one I'm looking at is only 350 continuous but jumps to 1400 watts I believe
post #264 of 688 Old 07-10-2018, 07:51 PM
Liked: 291
And it's only $500
post #265 of 688 Old 07-10-2018, 07:53 PM
Quoted: 60 Post(s)
And it's only $500
It's the same mode I have, the newer model has more power but the one you are looking at is a great price. I paid 1300 for it 7 Yeats ago.
post #266 of 688 Old 07-10-2018, 07:56 PM
Liked: 291
Wow! That's crazy.
post #267 of 688 Old 07-10-2018, 07:57 PM
Quoted: 60 Post(s)
The new version is about 1300 shipped to but has a lot more power.
post #268 of 688 Old 07-10-2018, 08:23 PM
Liked: 291
And the one I'm looking at is the old model?
post #269 of 688 Old 07-10-2018, 08:41 PM
Liked: 291
So what I'm really after is maybe bigger speakers? I have Polk signature s50s....5.25 speakers. I've been thinking about upgrading to the s55s which have 6.5 speakers. The clarity is amazing but I just feel like the sound is a little thin. So more power isn't what I want?
post #270 of 688 Old 07-10-2018, 08:47 PM
Quoted: 60 Post(s)
I think the Sony is powerful enough but yeah new speakers might be a better option. I don't think the 820 adds anything you don't already have minus a little more power. What's your wattage at 8 ohm? Or are your speakers 6ohm?
